1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 10U Low-Profile Switch-Depth WallMount Small Rack Enclosure, Hinged Back
MODEL NUMBER: SRW10US
Highlights
Maximum load capacity of 200
lbs (90.7 kgs)
Swings away from wall on hinge
for easy back-door access
Locking steel cabinet vented at
sides, front, top and bottom
Flow-through ventilation keeps
equipment cool
Secures 10U of 19 in. rack
equipment up to 20.5 in. deep
Package Includes
Wall-mount cabinet secures and organizes 10U of 19-inch rack equipment in network closets, classrooms
and other locations with limited floor space. Houses network switches and patch panels up to 20.5 inches
deep.
Description
The SRW10US SmartRack 10U Low-Profile Switch-Depth Wall-Mount Rack Enclosure Cabinet is
designed to house EIA-standard 19-inch rack equipment in network wiring closets, retail locations,
classrooms, back offices and other areas with limited floor space where you need equipment to be secure,
organized and out of the way. Constructed from heavy-duty steel with a durable black powder-coated
finish, the cabinet has a maximum load capacity of 200 lbs (90.7 kgs).
The cabinet swings away from the wall on a sturdy hinge, allowing easy back-door access to equipment
and cabling during installation and maintenance. The doors and side panels lock securely to help prevent
damage, tampering or theft. The front, top, bottom and removable side panels are vented, which allows air
to flow freely and keep equipment cool. The reversible doors can open left or right by rotating the cabinet
180° before mounting. Convenient top and bottom ports allow easy cable routing.
The SRW10US comes fully assembled and ready to mount to the wall, or use Tripp Lite's optional
SRCASTER rolling caster kit to make it a mobile rack. Square and 12-24 threaded mounting holes and
numbered rack spaces make equipment installation easy. The vertical mounting rails adjust in 7/8-inch
increments to accommodate equipment up to 20.5 inches deep, such as network switches and patch
panels.
Features
Saves Valuable Workspace
● Perfect for network wiring closets, retail locations, classrooms, back offices and other areas with limited
floor space where you need equipment to be secure, organized and out of the way
Houses EIA-standard 19 in. rack equipment in 10U of space
Maximum load capacity of 200 lbs (90.7 kgs)
Hinged Cabinet for Convenient Access
● Swings away from the wall to allow easy back-door access to equipment and cabling during installation
and maintenance
Rotate cabinet 180° before mounting to open reversible doors left or right
1/3
Low-Profile Switch-Depth WallMount Rack Enclosure Cabinet
(24) M6 screws
(24) M6 cage nuts
(24) M6 washers
(24) 12-24 screws
(2) Keys
Owner’s manual
Cleveland, OH 44122
United States
Keeps Important Equipment Secure
● Side panels and doors lock securely to help prevent damage, tampering or theft
Vented panels allow generous airflow that keeps equipment cool
Convenient ports with removable covers allow cable routing through top and bottom
Easy Enclosure and Equipment Installation
● Ships fully assembled for quick installation
Mounts to wall or rolls on floor with Tripp Lite's optional SRCASTER caster kit
Wall-mounting holes spaced 16 in. apart for standard wall stud placement
Vertical mounting rails adjust in 7/8 in. increments to accommodate equipment up to 20.5 in. deep, such
as network switches and patch panels
Rails support square-hole or 12-24 threaded-hole mounting
Rack spaces numbered for easy reference
Meets Payment Card Industry Standards
● Provides physical equipment and media security required for PCI DSS (Payment Card Industry Data
Security Standard) compliance
Specifications
OVERVIEW
UPC Code
037332154828
Device Compatibility
Patch Panel; Network Switch; UPS
Rack Type
Small Enclosure
PHYSICAL
Color
Black
Rack Height
10U
Rack Depth
Shallow
Factory Preset Rack Depth (in.)
10.42
Factory Preset Rack Depth (cm)
26.5
Factory Preset Rack Depth (mm)
265
Maximum Device Depth (cm)
52.07
Maximum Device Depth (in.)
20.5
Maximum Device Depth (mm)
521
Minimum Device Depth (cm)
7.62
Minimum Device Depth (in.)
3
Minimum Device Depth (mm)
76
Cable Access Hole Measurement
(inches)
9.812 x 2.35 (l x w)
2/3
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / in.)
24.25 x 26.38 x 24.13
Shipping Dimensions (hwd / cm)
61.60 x 67.01 x 61.29
Shipping Weight (lbs.)
59.00
Shipping Weight (kg)
26.76
Unit Dimensions (hwd / in.)
21.560 x 23.630 x 21.630
Unit Dimensions (hwd / cm)
54.79 x 59.99 x 54.86
Unit Weight (lbs.)
55
Unit Weight (kg)
24.95
Weight Capacity - Stationary (kg)
91
Weight Capacity - Stationary (lbs.)
200
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SRW10US”相匹配的价格&库存,您可以联系我们找货
