1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 18U Low-Profile Patch-Depth WallMount Half-Height Rack Enclosure, Hinged Back
MODEL NUMBER: SRW18US13
Highlights
Maximum load capacity of 200
lbs (90.7 kgs)
Swings away from wall on hinge
for easy back-door access
Locking steel cabinet vented at
sides, front, top and bottom
Flow-through ventilation keeps
equipment cool
Secures 18U of 19 in. rack
equipment up to 12.75 in. deep
Package Includes
Wall-mount cabinet secures and organizes 18U of 19-inch rack equipment in network closets, classrooms
and other locations with limited floor space. Houses patch panels and shallow network switches up to
12.75 inches deep.
Description
The SRW18US13 SmartRack 18U Low-Profile Patch-Depth Wall-Mount Rack Enclosure Cabinet is
designed to house EIA-standard 19-inch rack equipment in network wiring closets, retail locations, back
offices, classrooms and other areas with limited floor space where you need equipment to be secure,
organized and out of the way. Constructed from heavy-duty steel with a durable black powder-coated
finish, the cabinet has a maximum load capacity of 200 lbs (90.7 kgs)
The cabinet swings away from the wall on a sturdy hinge, allowing easy back-door access to equipment
and cabling during installation and maintenance. The doors and side panels lock securely to help prevent
damage, tampering or theft. The front, top, bottom and removable side panels are vented, which allows air
to flow freely and keep equipment cool. The reversible doors can open left or right by rotating the cabinet
180° before mounting. Convenient top and bottom ports allow easy cable routing.
The SRW18US13 comes fully assembled and ready to mount to the wall, or use Tripp Lite's optional
SRCASTER rolling caster kit to make it a mobile rack. Square and 12-24 threaded mounting holes and
numbered rack spaces make equipment installation easy. The vertical mounting rails adjust in 7/8-inch
increments to accommodate equipment up to 12.75 inches deep, such as patch panels and shallow
network switches.
Features
Saves Valuable Workspace
● Perfect for network closets, retail locations, back offices, classrooms and other areas with limited floor
space where you need equipment to be secure, organized and out of the way
Houses EIA-standard 19 in. rack equipment in 18U of space
Maximum load capacity of 200 lbs (90.7 kgs)
Hinged Cabinet for Convenient Access
● Swings away from the wall to allow easy back-door access to equipment and cabling during installation
and maintenance
Rotate cabinet 180° before mounting to open reversible doors left or right
1/3
Low-Profile Patch-Depth WallMount Rack Enclosure Cabinet
(42) M6 screws
(42) M6 cage nuts
(42) M6 washers
(42) 12-24 screws
(2) Keys
Owner’s manual
Cleveland, OH 44122
United States
Keeps Important Equipment Secure
● Side panels and doors lock securely to help prevent damage, tampering or theft
Vented panels allow generous airflow that keeps equipment cool
Convenient ports with removable covers allow cable routing through top and bottom
Easy Enclosure and Equipment Installation
● Ships fully assembled for quick installation
Mounts to wall or rolls on floor with Tripp Lite's optional SRCASTER caster kit
Wall-mounting holes spaced 16 in. apart for standard wall stud placement
Vertical mounting rails adjust in 7/8 in. increments to accommodate equipment up to 12.75 in. deep,
such as patch panels and shallow network switches
Rails support square-hole or 12-24 threaded-hole mounting
Rack spaces numbered for easy reference
Meets Payment Card Industry Standards
● Provides physical equipment and media security required for PCI DSS (Payment Card Industry Data
Security Standard) compliance
Specifications
OVERVIEW
UPC Code
037332177964
Device Compatibility
Patch Panel
Rack Type
Half-Height Enclosure
PHYSICAL
Color
Black
Rack Height
18U
Rack Depth
Shallow
Maximum Device Depth (cm)
32.38
Maximum Device Depth (in.)
12.75
Maximum Device Depth (mm)
324
Cable Access Hole Measurement
(inches)
9.812 x 2.35 (l x w)
Shipping Dimensions (hwd / in.)
15.55 x 26.10 x 40.71
Shipping Dimensions (hwd / cm)
39.50 x 66.29 x 103.40
Shipping Weight (lbs.)
79.00
Shipping Weight (kg)
35.83
Unit Dimensions (hwd / in.)
35.600 x 23.620 x 13.000
Unit Dimensions (hwd / cm)
90.42 x 59.9 x 33.02
2/3
Cleveland, OH 44122
United States
Unit Weight (lbs.)
83.77
Unit Weight (kg)
38.00
Weight Capacity - Stationary (kg)
113
Weight Capacity - Stationary (lbs.)
250
Number of Vertical Mounting Rails
2
FEATURES & SPECIFICATIONS
Grounding Lug
Front door frame
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; EIA/ECA-310-E; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SRW18US13”相匹配的价格&库存,您可以联系我们找货
