1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 8U/12U/22U Expandable Flat-Pack
Low-Profile Switch-Depth Wall-Mount 2-Post
Open Frame Rack
MODEL NUMBER: SRWO8U22
Highlights
Maximum load capacity of 150
lbs (68 kgs)
Configures to 8U, 12U or 22U of
rack space
Allows easy access to
equipment and cabling
Stores 19 in. rack equipment up
to 18 in. deep
Simple to assemble and mount
Package Includes
Expandable open-frame rack stores 8U, 12U or 22U of 19-inch rack equipment up to 18 inches deep in
locations with limited floor space where a locked enclosure is not required. Allows easy access to
equipment and cabling.
Description
The SRWO8U22 SmartRack 8U/12U/22U Expandable Flat-Pack Low-Profile Switch-Depth Wall-Mount 2Post Open-Frame Rack stores and organizes EIA-standard 19-inch rack equipment compatible with 2post mounting in network wiring closets, back offices and other secure IT areas with limited floor space
where a locked enclosure is not required. Mounted to the wall or resting on the floor, this rack offers fast,
easy access to network components and cabling.
Constructed from heavy-duty steel with a durable black powder-coated finish, the rack has a maximum
load capacity of 150 lbs (68 kgs). The expandable design allows you to assemble the rack in an 8U, 12U
or 22U configuration to meet your current needs, while leaving rack space in reserve for future expansion.
The rack is simple to assemble and mount to the wall. Threaded 12-24 mounting holes and numbered
rack spaces make equipment installation easy. The vertical mounting rails accommodate equipment up to
18 inches deep, such as network switches and patch panels. Assembly and equipment-mounting
hardware is included.
Features
Saves Valuable Workspace
● Perfect for network wiring closets, back offices and other secure areas with limited floor space where a
Stores and organizes EIA-standard 19 in. rack equipment compatible with 2-post mounting
Maximum load capacity of 150 lbs (68 kgs)
Expandable 2-Post Open Frame Design
● Assembles in 8U, 12U or 22U configuration to meet current needs
Expands to add equipment later without having to buy a bigger rack
Allows easy access for installing, configuring and servicing equipment and cabling
Easy Assembly and Installation
1/3
(24) 12-24 equipment mounting
screws
(8) M6 x 12 Phillips-head screws
(16) M5 x 10 Phillips-head
screws
(2) Short vertical mounting rails
(2) Long vertical mounting rails
(2) Mounting rail tie plates
(2) Top/bottom panel frames
(2) Support straps
(8) Zip ties
3 mm hex key
Owner’s manual
Cleveland, OH 44122
United States
Wall-mounting holes spaced 16 in. apart for standard wall stud placement
Vertical mounting rails accommodate equipment up to 18 in. deep, such as network switches and patch
panels
Rails support threaded-hole equipment mounting
Rack spaces numbered for easy reference
Includes assembly and equipment-mounting hardware
Specifications
OVERVIEW
UPC Code
037332156778
Device Compatibility
Patch Panel; Network Switch
Rack Type
Open-Frame
PHYSICAL
Color
Black
Rack Height
22U
Rack Depth
Shallow
Maximum Device Depth (cm)
46.33
Maximum Device Depth (in.)
18.24
Maximum Device Depth (mm)
463
Maximum Weight Capacity (lbs.)
150
Maximum Weight Capacity (kg)
68
Shipping Dimensions (hwd / in.)
3.70 x 22.80 x 21.80
Shipping Dimensions (hwd / cm)
9.40 x 57.91 x 55.37
Shipping Weight (lbs.)
19.00
Shipping Weight (kg)
8.62
Unit Dimensions (hwd / in.)
42.300 x 20.110 x 18.240
Unit Dimensions (hwd / cm)
45.22 (8U), 63 (12U), 107.45 (22U) x 51.08 x 46.33
Unit Weight Details
Weight varies depending on configuration 8U = 11.21lbs, 12U = 12.23lbs, 22U = 15.03lbs
Number of Vertical Mounting Rails
2
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SRWO8U22”相匹配的价格&库存,您可以联系我们找货
