1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 12U Heavy-Duty Flat-Pack LowProfile Switch-Depth Wall-Mount 2-Post Open
Frame Rack
MODEL NUMBER: SRWO12UHD
Highlights
Maximum load capacity of 200
lbs (90.7 kgs)
Allows easy access to
equipment and cabling
Stores 12U of 19 in. rack
equipment up to 18 in. deep
Simple to assemble and mount
Assembly and equipmentmounting hardware included
Package Includes
Open frame rack stores 12U of 19-inch rack equipment up to 18 inches deep in network closets and other
locations with limited floor space where a locked enclosure is not required. Allows easy access to
equipment and cabling.
Description
The SRWO12UHD SmartRack 12U Heavy-Duty Flat-Pack Low-Profile Switch-Depth Wall-Mount 2-Post
Open Frame Rack stores and organizes EIA-standard 19-inch rack equipment compatible with 2-post
mounting in network wiring closets, back offices and other secure areas with limited floor space where a
locked enclosure is not required. Constructed from heavy-duty steel with a durable black powder-coated
finish, the rack has a maximum load capacity of 200 lbs (90.7 kgs).
The open frame design allows unrestricted access for installing, configuring and servicing equipment and
cabling. The rack is simple to assemble and mount to the wall. Threaded 12-24 mounting holes and
numbered rack spaces make equipment installation easy. The vertical mounting rails accommodate
equipment up to 18 inches deep, such as network switches and patch panels. Assembly and equipmentmounting hardware is included.
Features
Saves Valuable Workspace
● Perfect for network wiring closets, back offices and other secure areas with limited floor space where a
Stores and organizes EIA-standard 19 in. rack equipment compatible with 2-post mounting in 12U of
space
Maximum load capacity of 200 lbs (90.7 kgs)
2-Post Open Frame Design
● Allows easy access for installing, configuring and servicing equipment and cabling
Easy Assembly and Installation
● Wall-mounting holes spaced 16 in. apart for standard wall stud placement
Vertical mounting rails accommodate equipment up to 18 in. deep, such as network switches and patch
panels
1/3
(24) 12-24 equipment mounting
screws
(8) M5 button-head cap screws
(8) M6 x 12 Phillips-head screws
(2) Support straps
(2) Vertical mounting rails
(2) Top/bottom panel frames
3 mm hex key
Owner’s manual
Cleveland, OH 44122
United States
Rails support threaded-hole equipment mounting
Rack spaces numbered for easy reference
Includes assembly and equipment-mounting hardware
Specifications
OVERVIEW
UPC Code
037332182654
Device Compatibility
Patch Panel; Network Switch
Rack Type
Open-Frame
PHYSICAL
Color
Black
Rack Height
12U
Rack Depth
Shallow
Maximum Device Depth (cm)
45.72
Maximum Device Depth (in.)
18
Maximum Device Depth (mm)
457
Shipping Dimensions (hwd / in.)
4.10 x 22.80 x 21.30
Shipping Dimensions (hwd / cm)
10.41 x 57.91 x 54.10
Shipping Weight (lbs.)
15.10
Shipping Weight (kg)
6.85
Unit Dimensions (hwd / in.)
24.800 x 20.110 x 18.240
Unit Dimensions (hwd / cm)
62,992 x 51,05 x 46,33
Unit Weight (lbs.)
14.3
Unit Weight (kg)
6.49
Weight Capacity - Stationary (kg)
91
Weight Capacity - Stationary (lbs.)
200
Number of Vertical Mounting Rails
2
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SRWO12UHD”相匹配的价格&库存,您可以联系我们找货
