1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 12U Heavy-Duty Low-Profile ServerDepth Side-Mount Wall-Mount Small Rack
Enclosure
MODEL NUMBER: SRW12UHD
Highlights
Maximum load capacity of 500
lbs (226.8 kgs)
Locking steel cabinet vented at
sides, top and bottom
Flow-through ventilation keeps
equipment cool
Secures 12U of 19 in. rack
equipment up to 32.5 in. deep
Package Includes
Wall-mount cabinet secures and organizes 12U of 19-inch rack equipment in network wiring closets and
other locations with limited floor space. Houses servers up to 32.5 inches deep, but extends less than 25
inches from wall.
Description
The SRW12UHD SmartRack 12U Heavy-Duty Low-Profile Server-Depth Side-Mount Wall-Mount Rack
Enclosure Cabinet is designed to house EIA-standard 19-inch rack equipment in network wiring closets,
retail locations, classrooms, back offices and other areas with limited floor space where you need
equipment to be secure, organized and out of the way. Constructed from heavy-duty steel with a durable
black powder-coated finish, the cabinet has a maximum load capacity of 500 lbs (226.8 kgs).
Because the low-profile cabinet mounts sideways, it extends less than 25 inches from the wall while
housing equipment up to 32.5 inches deep, including 1U servers, UPS systems, battery packs, network
switches and patch panels.
The removable front panel and side doors lock securely to help prevent damage, tampering or theft. The
top, bottom and sides are vented, which allows air to flow freely and keep equipment cool. Convenient top
and bottom ports allow easy cable routing.
The SRW12UHD comes fully assembled and ready to mount to the wall. Square and 12-24 threaded
mounting holes and numbered rack spaces make equipment installation easy. The vertical mounting rails
adjust in 7/8-inch increments.
Features
Saves Valuable Workspace
● Perfect for network wiring closets, retail locations, classrooms, back offices and other areas with limited
floor space where you need equipment to be secure, organized and out of the way
Houses EIA-standard 19 in. rack equipment in 12U of space
Extends less than 25 in. from the wall while housing 1U servers, UPS systems, battery packs, network
switches and patch panels up to 32.5 in. deep
Maximum load capacity of 500 lbs (226.8 kgs)
Keeps Important Equipment Secure
● Sides and front lock securely to help prevent damage, tampering or theft
Vented panels allow generous airflow that keeps equipment cool
1/3
Rack Enclosure Cabinet
(20) M6 screws
(20) M6 cage nuts
(20) M6 washers
(20) 12-24 screws
(2) Keys
Owner’s manual
Cleveland, OH 44122
United States
Convenient ports with removable covers allow cable routing through top and bottom
Easy Enclosure and Equipment Installation
● Ships fully assembled for quick installation
Wall-mounting holes spaced 16 in. apart for standard wall stud placement
Vertical mounting rails adjust in 7/8 in. increments
Rails support square-hole or 12-24 threaded-hole mounting
Rack spaces numbered for easy reference
Meets Payment Card Industry Standards
● Provides physical equipment and media security required for PCI DSS (Payment Card Industry Data
Security Standard) compliance
Specifications
OVERVIEW
UPC Code
037332183323
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Small Enclosure
PHYSICAL
Color
Black
Rack Height
12U
Rack Depth
Mid
EIA Mounting Rails
Square holes / 12-24 threaded holes
Maximum Device Depth (cm)
82.55
Maximum Device Depth (in.)
32.5
Maximum Device Depth (mm)
826
Minimum Device Depth (cm)
7.62
Minimum Device Depth (in.)
3
Minimum Device Depth (mm)
76
Shipping Dimensions (hwd / in.)
32.09 x 25.79 x 37.20
Shipping Dimensions (hwd / cm)
81.51 x 65.51 x 94.49
Shipping Weight (lbs.)
130.00
Shipping Weight (kg)
58.97
Unit Dimensions (hwd / in.)
26.460 x 24.770 x 36.220
Unit Dimensions (hwd / cm)
67.21 x 91.95 x 62.92
Unit Weight (lbs.)
101.4
2/3
Cleveland, OH 44122
United States
Unit Weight (kg)
45.99
Weight Capacity - Stationary (kg)
227
Weight Capacity - Stationary (lbs.)
500
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Built-in Cable Management
No
Extra Wide
No
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SRW12UHD”相匹配的价格&库存,您可以联系我们找货
