1000 Eaton Boulevard
Cleveland, OH 44122
United States
Position a 125A fuse link less than 18 in. from the battery in the positive line to protect against highcurrent draw that may occur during inverter failure.
700W PowerVerter APS 12VDC 120V
Inverter/Charger with Auto-Transfer Switching, 1
Outlet
MODEL NUMBER: APS700HF
Highlights
Delivers clean 120V AC power
from AC or DC power source
700W continuous output power;
1400W peak power
Auto-transfer switching option
for UPS operation
Protects against blackouts,
surges and EMI/RFI line noise
Compact, lightweight aluminum
housing weighs just 4 lb.
Package Includes
Portable single-outlet power source for small power applications, such as power tools and computers, as
a vehicle inverter, standalone AC power source or extended-run UPS. Ideal for RVs, fleet vehicles and
conversion vans.
Description
The APS700HF 700W PowerVerter APS 12V DC 120V AC Inverter/Charger is a reliable power source for
a variety of small power applications ranging from power tools to computers and sensitive monitoring
equipment. With no fumes, fuel or excess noise, it’s an excellent alternative to generator power.
The DC-to-AC inverter features an automatic line-to-battery transfer switch and integrated charging
system that allow it to work as a vehicle inverter, standalone AC power source or extended-run UPS. It
delivers 700W of continuous power, 1050W up to 1.5 seconds, or 1400W of peak power up to 1.1
seconds during equipment startup or cycling. An automatic overload detector, cooling fan and resettable
AC circuit breaker protect the unit from damage.
Designed for easy installation in RVs, over-the-road trucks, fleet vehicles and conversion vans, the
APS700HF converts stored power from any 12V battery or automotive DC source to safe, stable,
computer-grade AC power and sends it to a NEMA 5-15R outlet for unlimited runtime. When powered by
an external 120V AC source, the unit keeps the user-supplied battery charged via a three-stage 6A
charging system while simultaneously delivering AC power to connected equipment.
When used as a UPS, the APS700HF responds to blackouts and brownouts with an automatic,
instantaneous transfer to battery-derived AC output. LEDs on the unit indicate AC/DC operational modes,
overload status, DC voltage level, shutdown status and system fault status.
Features
Reliable Power for Mobile and Remote Sites
● Generates safe, stable, computer-grade 120V AC power from 12V battery bank
Ideal for powering small applications ranging from power tools to computers and sensitive monitoring
equipment
Functions as vehicle inverter, standalone AC power source or extended-run UPS
Features NEMA 5-15R outlet
1/4
APS 12V DC 120V AC
Inverter/Charger
Owner’s manual
Cleveland, OH 44122
United States
Unlimited runtime with variety of user-supplied batteries
Meets Normal and Peak Power Demands
● 700W of continuous power
1050W of reserve power up to 1.5 sec.
1400W of peak power up to 1.1 sec. to accommodate surge power demands during equipment startup
and cycling
Automatic overload detector, built-in multi-speed cooling fan and resettable AC circuit breakers protect
unit from damage
High-current DC input terminals for simple hardwired installation
Automatic Transfer Switching
● Transfer relay switches to inverter power during blackout in 16.6 ms
3-position switch enables Auto, Charge Only or System Off mode
3-Stage 6A Battery Charger
● Serves as battery charger when external 120V AC power is supplied and powering connected
equipment
Protects battery from overcharging and overdischarging
Low-battery protection prevents excessive battery depletion
Front-Panel LEDs
● Indicate AC/DC operational modes, overload status, DC voltage level, shutdown status and system fault
status
Compact Aluminum Housing
● Weighs just 4 lb.
Resists moisture in high-humidity environments
Built-in mounting feet for installation on any rigid horizontal surface
Grounding lug connects unit to earth ground or vehicle grounding system
Built-in AC power cord and NEMA 5-15P plug connects to AC power source
Specifications
OVERVIEW
UPC Code
037332126948
INPUT
Nominal Input Voltage(s) Supported
120V AC
2/4
Cleveland, OH 44122
United States
Maximum Input Amps / Watts
DC INPUT: Full continuous load - 72A at 12V DC. AC INPUT: 8.4 amps at 120VAC with full inverter and charger
load (1.4A max charger-only)
Recommended Electrical Service
DC INPUT: Requires 12V DC input source capable of delivering 72A for the required duration (when used at full
continuous capacity - DC requirements increase during Over-Power and Double-Boost operation). AC INPUT: 15A
120V AC recommended
Input Connection Type
DC INPUT: Set of 2 DC bolt-down terminals. AC INPUT: NEMA 5-15P input plug
Voltage Compatibility (VAC)
120
Voltage Compatibility (VDC)
12
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(1) 5-15R
Continuous Output Capacity (Watts)
700
Peak Output Capacity (Watts)
1400
Output Voltage Regulation
LINE POWER (AC): Maintains 120V nominal sine wave output from line power source. INVERTER POWER (AC):
Maintains PWM sine wave output voltage of 120 V AC (+/-5%).
Output Frequency Regulation
60 Hz (+/- 0.3 Hz)
Overload Protection
Includes 7A output breaker for AC output loads
BATTERY
Expandable Runtime
Yes
Expandable Battery Runtime
Runtime is expandable with any number of user supplied wet, gel or SLA type batteries
Expandable Runtime Description
DC System Voltage (VDC)
12
Battery Charge
6A max, steps down to float level to maintain
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
6 diagnostic LEDs indicate battery voltage level (high, medium & low) and operation (line, inverter, load)
Switches
3 position DC off, auto (inverter or AC) and charge-only switch enables simple operation
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
300
PHYSICAL
Material of Construction
Aluminum
Cooling Method
Multi-speed fan
Form Factors Supported
Integrated mounting feet for easy installation
3/4
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / in.)
8.50 x 14.50 x 8.50
Shipping Dimensions (hwd / cm)
21.59 x 36.83 x 21.59
Shipping Weight (lbs.)
5.50
Shipping Weight (kg)
2.49
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Weight (lbs.)
4
Unit Weight (kg)
1.81
ENVIRONMENTAL
Relative Humidity
0%-95% Non-Condensing
LINE / BATTERY TRANSFER
Transfer Time (Line Power to
Battery Mode)
16.6 milliseconds (typical - compatible with many computers, servers and networking equipment - verify transfer time
compatibility of loads for UPS applications)
Low Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 85V (user adjustable to 85,
95V - see manual)
High Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 139V
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
1-year limited warranty
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
