1000 Eaton Boulevard
Cleveland, OH 44122
United States
500W PowerVerter Ultra-Compact Inverter Portable Power for All Applications
MODEL NUMBER: PV500
Description
Highlights
12V DC input; 120V AC output;
3 outlets
500 watts continuous output
(800 watts peak output)
Convenient battery clip
connectors
Harness your vehicle's battery to efficiently power office equipment on the road. Continuously supplies up
to 500 watts of 120V AC power to 3 AC outlets from any 12V battery or automotive DC source. Includes 4
Package Includes
ft. of DC cabling with battery clips for simple installation. Super-compact, lightweight metal case design is
PV 500 Inverter
among the smallest, most rugged inverters available at this power level.
(2) 4-ft. cords with battery
clamps
Warranty information
Instruction manual
NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at
100a should be positioned no more than 18" from the PV500's battery in the positive line.
Features
Allows users to run AC appliances from any 12V battery or automotive DC system
Converts 12V DC battery power to 120V AC power
500 watts continuous output power; 800 watts peak output power
3 outlets
(2) 4-ft. cords with battery clamps
Ultra compact, lightweight design with all-metal housing
Diagnostic LED indicates low battery-voltage
Low battery alarm with auto-shutoff prevents deep battery discharge
High-efficiency operation conserves batteries to prolong run time
(2) 30-amp fuses protects inverter from overload
Lighted power switch
Specifications
OVERVIEW
UPC Code
037332050298
INPUT
Voltage Compatibility (VDC)
12
OUTPUT
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
5-15/20R
Continuous Output Capacity (Watts)
500
1/2
Cleveland, OH 44122
United States
PHYSICAL
Shipping Dimensions (hwd / in.)
12.50 x 11.50 x 3.00
Shipping Dimensions (hwd / cm)
31.75 x 29.21 x 7.62
Shipping Weight (lbs.)
3.50
Shipping Weight (kg)
1.59
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“PV500”相匹配的价格&库存,您可以联系我们找货
