1000 Eaton Boulevard
Cleveland, OH 44122
United States
PowerVerter Plus Inverter - Industrial Strength
Power for Heavy-Duty Applications
MODEL NUMBER: PV500FC
Description
Harness your vehicle's battery to efficiently power office equipment on the road or power tools at a work
site. Continuously supplies up to 500 watts of 120V AC power to 2 AC outlets from any 12V battery or
automotive DC source. Frequency control locks AC output at 60Hz for operating stability of motor loads.
Includes a set of high current DC input terminals for simple, permanent installation. Highly reliable large
transformer design specializes in powering motors and other inductive loads with high-current startup
needs.
Features
Allows users to run large, motorized AC appliances from any 12V battery or automotive DC system
Converts 12V DC battery power to 120V AC power
500 watts continuous output power
1,000 watts peak output power to startup heavy motorized/inductive loads
2 outlets; DC input terminals for 12V battery connection (User supplies cable)
Frequency control for operating stability
Diagnostic LEDs indicate load level (high, medium, and low) and battery charge (high, medium, and
low)
DC fusing protects inverter against overload
3.5mm port for connecting remote switch (User supplies cable and switch)
Highlights
12V DC input; 120V AC output;
2 outlets
1000 watts peak surge output
High efficiency power
conversion
Automatic overload protection
Package Includes
PV500FC inverter
Instruction manual
Specifications
OVERVIEW
UPC Code
037332042170
INPUT
Maximum Input Amps / Watts
Full continuous load - 50A at 12VDC, No load - 2.2A at 12VDC
Recommended Electrical Service
Requires 12VDC input source capable of delivering 50A for the required duration (when used at full continuous
capacity). For automotive applications, professional hardwire installation with 100A battery system fusing is
recommended.
Input Connection Type
Set of 2 DC input terminals
Input Cord Length Details
User supplies cabling. 4 gauge or larger recommended.
Voltage Compatibility (VDC)
12
OUTPUT
Frequency Compatibility
60 Hz
Output Nominal Voltage
120V nominal
Output Voltage Regulation
Maintains PWM sine wave output voltage of 120 VAC (+/-5%)
Output Frequency Regulation
60 Hz (+/- 0.3 Hz)
1/2
Cleveland, OH 44122
United States
Overload Protection
Circuit breaker
BATTERY
DC System Voltage (VDC)
15
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7
levels reported). See manual for sequences.
Switches
Lighted on/off power switch, plus 2 conductor 3.5 mm port for connecting remote switch - user supplies switch,
3.5mm plug and cable.
PHYSICAL
Material of Construction
Polycarbonate
Cooling Method
Convection
Form Factors Supported
Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional
mounting information)
Shipping Dimensions (hwd / in.)
11.62 x 9.50 x 9.50
Shipping Dimensions (hwd / cm)
29.53 x 24.13 x 24.13
Shipping Weight (lbs.)
17.00
Shipping Weight (kg)
7.71
Unit Dimensions (hwd / in.)
10.000 x 7.000 x 7.000
Unit Dimensions (hwd / cm)
17.8 x 17.8 x 25.4
Unit Weight (lbs.)
15
Unit Weight (kg)
6.80
ENVIRONMENTAL
Relative Humidity
0-95% non-condensing
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“PV500FC”相匹配的价格&库存,您可以联系我们找货
