1000 Eaton Boulevard
Cleveland, OH 44122
United States
1250W PowerVerter Plus Industrial-Strength
Inverter with 2 Outlets
MODEL NUMBER: PV1250FC
Highlights
12V DC input; 120V AC output;
2 outlet
1250 watts continuous output
Peak surge output: OverPower
(up to 1 hour) - 1875 watts,
Double-Boost (up to 10
seconds) - 2500 watts
High efficiency power
conversion
Automatic overload protection
Package Includes
Description
Utilize you vehicle's battery to efficiently power work site power tools, pumps, as well as your laptop
computer. Continuously supplies 1250 watts of 120VAC power to (2) AC outlets from any 12VDC battery
source. Frequency control locks AC output at 60Hz for operating stability of motor loads and other
inductive loads with high current startup requirements.
NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at
200a should be positioned no more than 18" from the PV1250FC's battery in the positive line.
Features
Allows users to run large, motorized AC appliances from any 12V battery or automotive DC system
Converts 12V DC battery power to 120V AC power
1,250 watts continuous output power
Peak output power: OverPower (up to 1 hour) - 1875 watts, Double-Boost (up to 10 seconds) - 2500
watts
2 outlets; DC input terminals for 12V battery connection
Frequency control for operating stability
High-efficiency operation conserves batteries to prolong run time
Diagnostic LEDs indicate load level (high, medium, and low) and battery charge (high, medium, and
low)
DC fusing protects inverter against overload
RJ45 port allows connection of APS/PowerVerter Remote Switch (APSRM4)
Automatic overload shutdown
Ignition interlock jack
Specifications
OVERVIEW
1/3
PV1250FC inverter
Instruction manual
Cleveland, OH 44122
United States
UPC Code
037332124241
INPUT
Maximum Input Amps / Watts
Full continuous load - 127A at 12V DC, No load - 2.2A at 12V DC
Recommended Electrical Service
Requires 12V DC input source capable of delivering 127A for the required duration (when used at full capacity). For
automotive applications, professional hardwire installation with 200A battery system fusing is recommended.
Input Connection Type
Set of 2 DC input terminals
Input Cord Length Details
User supplies cabling. 4 gauge or larger recommended.
Voltage Compatibility (VDC)
12
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(2) 5-15R
Continuous Output Capacity (Watts)
1250
Peak Output Capacity (Watts)
2500
Output Voltage Regulation
Maintains PWM sine wave output voltage of 120 VAC (+/-5%)
Output Frequency Regulation
60 Hz (+/- 0.3 Hz)
Overload Protection
Circuit breaker
BATTERY
DC System Voltage (VDC)
12
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7
levels reported). See manual for sequences.
Switches
3 position on/off/remote switch enables simple on/off power control plus "remote" setting that enables distant on/off
control of the inverter system when used in conjunction with optional APRM4 remote
PHYSICAL
Material of Construction
Polycarbonate
Cooling Method
Fan
Form Factors Supported
Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional
mounting information)
Shipping Dimensions (hwd / in.)
12.50 x 10.40 x 10.40
Shipping Dimensions (hwd / cm)
31.75 x 26.42 x 26.42
Shipping Weight (lbs.)
22.50
Shipping Weight (kg)
10.21
2/3
Cleveland, OH 44122
United States
Unit Dimensions (hwd / in.)
7.000 x 8.750 x 9.000
Unit Dimensions (hwd / cm)
17.78 x 22.23 x 22.86
Unit Weight (lbs.)
23.2
Unit Weight (kg)
10.52
ENVIRONMENTAL
Relative Humidity
0%-95% Non-Condensing
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PV1250FC”相匹配的价格&库存,您可以联系我们找货
