1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 230V 1.5kVA 900W Line-Interactive
UPS, Tower, LCD, USB, 8 Outlets
MODEL NUMBER: SMX1500LCDT
Highlights
Corrects under- and
overvoltages from 170V to 280V
8 C13 outlets—2 surge-only
Interactive LCD monitoring
screen
Monitoring of power conditions
via PowerAlert software
10 min. runtime at half load
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, surges and line noise. Ideal for home/office workstations, media centers and home
entertainment systems.
Description
The SMX1500LCDT SmartPro 230V 1.5kVA 900W Line-Interactive UPS provides battery backup and AC
power protection against blackouts, brownouts, power surges and line noise that can damage electronics
or destroy data. Ideal for backing up home/office workstations, media centers and home entertainment
systems, the SMX1500LCDT switches to battery mode in milliseconds to keep your connected equipment
running long enough to save files and shut down safely with no data loss.
Featuring eight IEC-320-C13 outlets and a C14 inlet that accepts a user-supplied AC power cord, the
SMX1500LCDT has an internal battery that provides 10 minutes of support at half load. It can also power
an entry-level PC up to 90 minutes. Two of the eight outlets provide surge protection only for printers and
other non-essential devices A front-panel LCD screen lets you configure settings and monitor operating
data, such as voltage, battery and load statuses.
Automatic voltage regulation (AVR) maintains 230V nominal output over an input range of 170V to 280V
without using battery power. EMI/RFI noise filtering improves your equipment’s performance and prevents
damage. A 455-joule surge suppression rating protects your equipment from harmful power surges. With
Tripp Lite’s free downloadable PowerAlert software, SMX1500LCDT enables safe unattended system
shutdown and file saves in case of a prolonged power failure.
Features
Protects Mission-Critical EquipmentProvides fully regulated AC output for home/office workstations,
media centers and home entertainment systemsAudible alarm signals loss of utility power or low battery8
C13 outlets—2 surge-onlyC14 inlet accepts user-supplied AC power cord with country-specific plug455joule surge suppression rating
Reliable Battery BackupSupports half load up to 10 min.Powers entry-level PC up to 90 min.Internal
batteries designed for hot-swap field replacement95% line-power efficiency rating saves money in energy
costsCold-start capability enables turn-on in battery mode during blackouts
Automatic Voltage Regulation (AVR)Maintains 230V nominal output over input range of 170V–280V
EMI/RFI Line Noise FilteringRemoves electromagnetic and radio frequency interference that can disrupt
or damage equipment’s performance
1/5
UPS
USB cable
C13-to-C14 power cable
Owner’s manual
Cleveland, OH 44122
United States
Interactive LCD ScreenFront-panel LCD signals voltage, battery and load statusesSupports multiple
advanced user setup and operating preferences
Communications PortUSB port enables data-saving unattended shutdown when used with Tripp Lite's
PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert
RJ45 Telephone/Ethernet Protection JacksProtect phone/DSL/fax/modem/Ethernet network against
power surges
Specifications
OVERVIEW
UPC Code
037332177445
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
9A
Nominal Input Voltage(s) Supported
230V AC
UPS Input Connection Type
C14 inlet
Input Circuit Breakers
10A fuse
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Input Frequency
±3Hz
OUTPUT
Output Capacity (VA)
1500
Output Capacity (kVA)
1.5
Output Capacity (Watts)
900
Output Capacity (kW)
0.9
Output Capacity Details
6.5 A @ 230 V~
Power Factor
0.6
Nominal Voltage Details
230V nominal output in battery mode
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection
Output Voltage Regulation (Line
Mode)
230V~ (+7% / - 12.8%)
Output Voltage Regulation (Battery
Mode)
+/- 5%
2/5
Cleveland, OH 44122
United States
UPS Output Receptacles (Surge
Suppression Only)
6 UPS outlets, 2 surge-only outlets
Hot-Swap PDU options
PDUBHV10 (2U / 8 C13 outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(8) C13
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
1.96 min. (900W)
Runtime Half Load (min.)
9.96 min. (450W)
Expandable Runtime
No
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
10.1 hours from 10% to 90%
Internal UPS Replacement Battery
Cartridge
RBC51 (requires 2)
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with a correction range from 170V to 280V
Overvoltage Correction
Input voltages between 247 and 280 are reduced by 15%
Undervoltage Correction
Input voltages between 170 and 207 are boosted by 18%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
LCD screen with scroll buttons indicates Input voltage, Output voltage, Frequency (Hz), AVR boost / cut status,
Output load in watts, Output load percentage, Output load in watts, Battery voltage and Estimated runtime in minutes
Switches
Power switch offers whole UPS power control; Scroll/mute button enables LCD selection options and silences
audible alarm; Test button initiates self test
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
455
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
3/5
Cleveland, OH 44122
United States
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
394
Primary UPS Height (mm)
203
Primary UPS Width (mm)
146
Shipping Dimensions (hwd / in.)
11.30 x 9.10 x 19.30
Shipping Dimensions (hwd / cm)
28.70 x 23.11 x 49.02
Shipping Weight (lbs.)
27.20
Shipping Weight (kg)
12.34
UPS Power Module Dimensions
(hwd, cm)
20.32 x 14.60 x 39.37
(hwd, in.)
8 x 5.75 x 15.5
UPS Power Module Weight (kg)
11.20
UPS Power Module Weight (lbs.)
24.7
Unit Weight (lbs.)
24.7000
Unit Weight (kg)
11.20
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
79
Battery Mode BTU / Hr. (Full Load)
918
AC Mode Efficiency Rating (100%
Load)
95%
COMMUNICATIONS
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network Management Card
Description
Network management not supported
4/5
Cleveland, OH 44122
United States
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
6 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
170V (factory setting), 175V (medium setting), 180V (narrow setting)
High Voltage Transfer to Battery
Power (Setpoint)
280V (factory setting), 275V (medium setting), 270V (narrow setting)
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
STANDARDS & COMPLIANCE
Product Certifications
GOST (Russia); EN 62040-1; EN 62040-2
Product Compliance
RoHS; SASO (Saudi Arabia); CE (Europe)
WARRANTY & SUPPORT
Product Warranty Period
(International)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“SMX1500LCDT”相匹配的价格&库存,您可以联系我们找货
