1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208 & 120V 8kVA 7.2kW DoubleConversion UPS, 8U Rack/Tower, Extended Run,
Network Card Options, USB, DB9 Serial, Bypass
Switch, NEMA outlets
Highlights
8kVA / 8000VA / 7200W on-line
double-conversion 8U
rack/tower UPS; Sine Wave
Includes 3U UPS power module
with maintenance bypass, 3U
battery pack and 2U transformer
module
Extended runtime options,
Interactive LCD interface,
Economy-mode option, 0.9
power factor
USB, RS232 & EPO ports;
Network management card
options
208V Hardwire 60Hz (3 wire)
input; NEMA L6-30R, L6-20R
(208V) and 5-15/20R (120V)
outlets
MODEL NUMBER: SU8000RT3U1TF
Package Includes
Description
Tripp Lite SU8000RT3U1TF 8000VA / 8kVA / 7200 watt online, double-conversion UPS system offers
complete power protection for critical network applications. This system delivers online, double-conversion
UPS protection with zero transfer time, suitable for advanced networking applications. Fault-tolerant autobypass prevents unexpected service interruptions during UPS overload or internal fault conditions.
Included detachable PDU with manual bypass switch enables hot-swappable replacement of entire UPS
power module with no interruption to connected equipment. Enhanced availability, fault tolerance and
simple hot-swap replacement options make this UPS ideal for advanced networking applications in data
centers, computer rooms, network closets and rugged industrial locations.
Features
Tripp Lite SU8000RT3U1TF 8kVA / 8000VA / 7200 watt on-line, double-conversion UPS system in 8U
total rack/tower configuration (3U UPS power module, 3U external battery pack and 2U step-down
transformer)
Detachable PDU with manual bypass switch enables hot-swappable UPS power module replacement
with no interruption in output power to connected networking equipment
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Hardwire input; 2 L6-30R, 4 L6-20R and 12 5-15/20R outlets
Maximum installed rack depth of only 32.5 in. / 82.6cm inches
Full-time active power conditioning provides clean, continuous dual-conversion AC output free of
voltage fluctuations, power interruptions and line noise
Double-conversion operation converts raw input from AC to DC, then re-synthesizes output power back
to perfect sine wave AC with enhanced protection from harmonic distortion, fast electrical impulses and
other hard-to-solve power problems not addressed by other UPS types
Maintains full-time sine wave output within 2% of 208/120V nominal at 60Hz during brownouts as low as
100V and overvoltages as high as 300V
Expandable runtime is supported with optional BP240V10RT3U; BP240V787C-1PH external battery
packs
Intelligent battery management system with temperature-compensated charging extends battery life
1/7
SU8000RT3UPM 3U UPS
power module
BP240V10RT3U external
battery pack
SU5000XFMRT2U step down
transformer
SUPDMB710 Detachable PDU
Four post compatible rack rail kit
(3 sets)
Tower stands for upright tower
configuration
USB, DB9 and EPO cabling
Cleveland, OH 44122
United States
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Highly efficient operation in optional economy mode significantly reduces BTU heat output and
operating energy costs
Battery independent restart ensures automatic UPS power-up without user interaction after lengthy
power outages, even when batteries are expired and require replacement
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
HID-compliant USB interface enables integration with built-in power management and auto shutdown
features of Windows and Mac OS X
Includes slot for network management card options
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Optional RELAYIOMINI interface module offers three configurable hard contact closure outputs for
custom event notification (requires removal of USB interface module)
Supports Emergency Power Off (EPO) via built-in interface
Included rail kit supports 8U 19 inch rackmount installation in 4 post racks
Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks
Optional 2-9USTAND supports upright tower placement
Front panel LEDs and LCD readout with scroll controls and password option supports visual monitoring
of all major UPS functions and advanced UPS settings for charge level, nominal voltage selection,
frequency conversion and other operational parameters
LED / LCD display panel rotates for viewing in rackmount or tower configurations
Network-grade AC surge and noise suppression
Industrial mode option (factory preset) enables supports high current startup loads by momentarily
switching to bypass mode in response to short duration overload conditions
External battery packs are field replaceable and hot swappable
Specifications
OVERVIEW
UPC Code
037332138026
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
44.2A (208V)
Nominal Input Voltage(s) Supported
208V AC
UPS Input Connection Type
Hardwire
UPS Input Connection Description
3 wire single phase input (L1, L2, G)
Recommended Electrical Service
50A
OUTPUT
Output Capacity (VA)
8000
2/7
Cleveland, OH 44122
United States
Output Capacity (kVA)
8
Output Capacity (Watts)
7200
Output Capacity (kW)
7.2
Output Capacity Details
Supports up to 105% load continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30
seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power;
Double conversion mode is automatically restored as load levels are reduced to 95% or less
Power Factor
0.9
Crest Factor
3:1
Nominal Voltage Details
7200 watts total output supported; 5000 watts maximum 120V output; Add 1 additional SU5000XFMRT2U
transformer for full load 120V operation; Voltage selection via front panel LCD interface; This configuration requires
the Power Module be set to 208V output voltage; Included step-down transformer supports 120V output
Frequency Compatibility
60 Hz
Frequency Compatibility Details
Output frequency regulation +/- 0.05Hz (free running)
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Output Circuit Breakers
20A double-pole (x2) protects 2 L6-20R outlets each, 30A double-pole (x2) protects 1 L6-30R outlets each, 20A
single-pole (x4) protect 3 5-15/20R outlets each
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
120V; 208V
Output Receptacles
(12) 5-15/20R; (4) L6-20R; (2) L6-30R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
5.5 min. (7200W)
Runtime Half Load (min.)
13.5 min. (3600W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP240V10RT3U ; BP240V787C-1PH
DC System Voltage (VDC)
240
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 90% (typical, full load discharge)
Battery Replacement Description
Hot-swappable, user replaceable external battery packs
3/7
Cleveland, OH 44122
United States
VOLTAGE REGULATION
Voltage Regulation Description
2% output voltage regulation in standard online, double-conversion mode
Overvoltage Correction
Corrects overvoltages up to 300V
Undervoltage Correction
Corrects undervoltages as low as 100V
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options;
LED/LCD panel rotates for viewing in rack/tower formats; LCD Display supports ENGLISH, FRENCH, GERMAN,
ITALIAN, SPANISH and PORTUGUESE (see manual)
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and
execute scrolling LCD functions; bundled PDU includes bypass switch to enable hot-swap UPS power module
replacement
Alarm Cancel Operation
Alarm cancel switch
Audible Alarm
Unique audible alarms for all major UPS, environmental and power conditions (see manual)
LED Indicators
6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD
screen offers additional information and control options
ISOLATION
Output Isolation Transformer
120V output is isolation transformer protected
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
2565
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
8U
Cooling Method
Fan
Included Battery Pack Dimensions
(hwd / in.)
5.25 x 17.5 x 25
Included Battery Pack Weight (lbs.)
158.7
Included Battery Pack Weight (kg)
71.99
Included Mounting Accessory
Description
3 sets of adjustable 4 post rack rails included; 2-9USTAND tower kit included
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD )
Maximum Device Depth (cm)
82.55
Maximum Device Depth (in.)
32.5
4/7
Cleveland, OH 44122
United States
Maximum Device Depth (mm)
826
Minimum Required Rack Depth (cm)
96.52
(inches)
38
Optional Mounting Accessory Notes
3 sets of 2POSTRMKITHD required for 2 post
rackmount installation of separate power module, battery pack and transformer
Primary UPS Depth (mm)
656
Primary UPS Height (mm)
131
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
31.50 x 26.00 x 41.00
Shipping Dimensions (hwd / cm)
80.01 x 66.04 x 104.14
Shipping Weight (lbs.)
402.16
Shipping Weight (kg)
182.42
Stepdown Transformer Dimensions
(hwd / cm)
8.89 x 44.45 x 52.83
(hwd / in.)
3.5 x 17.5 x 20.8
Stepdown Transformer Height (mm)
89
Stepdown Transformer Width (mm)
445
Stepdown Transformer Depth (mm)
528
Stepdown Transformer Weight (kg)
25.85
Stepdown Transformer Weight (lbs.)
57
Unit Dimension Details
Includes 3U UPS/power module, 3U battery pack, 2U SU5000XFMRT2U step down transformer plus SUPDMB710
PDU with bypass; MAXIMUM DEVICE DEPTH specification refers to the whole UPS installed depth with bypass
PDU installed
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.06 x 44.45 x 65.58
(hwd, in.)
5.14 x 17.5 x 25.82
UPS Power Module Weight (kg)
19.50
UPS Power Module Weight (lbs.)
43
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
2732
AC Economy Mode BTU / Hr. (Full
Load)
1024
5/7
Cleveland, OH 44122
United States
Battery Mode BTU / Hr. (Full Load)
2432
AC Mode Efficiency Rating (100%
Load)
91%
AC Economy Mode Efficiency Rating
(100% Load)
96%
Operating Elevation (ft.)
0-3000m (0 to 10,000 ft.)
Audible Noise
60 dBA at front side 1 meter
Operating Elevation (m)
0-3000 m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
Additional contact closure support with optional RELAYIOCARD and RELAYIOMINI interface cards. RELAYIOMINI
installation requires removal of panel containing USB ports
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports , download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB, DB9 serial and EPO cables included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Transfer Time (Economy Mode)
8 ms. typical power failure response in optional economy mode
Low Voltage Transfer to Battery
Power (Setpoint)
100V
High Voltage Transfer to Battery
Power (Setpoint)
300V
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
Economy Mode Operation
Optional economy mode enables high-efficiency bypass operation with a maximum output voltage variation of +/10%. Double conversion mode is automatically restored as mains voltage varies beyond +/-10% with less than 1
millisecond transfer time between modes.
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Hot swappable batteries; Hot
swappable UPS power module; Manual bypass switch; Remote management; Surge/noise protection; Zero transfer
time
Green Energy-Saving Features
High efficiency economy mode operation; Schedulable daily hours of economy mode operation
STANDARDS & COMPLIANCE
6/7
Cleveland, OH 44122
United States
Product Certifications
IEC 61000; CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
7/7
