1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208/240 & 120V 16kVA 14.4kW
Double-Conversion UPS, N+1, 14U, Network Card
Slot, USB, DB9, Bypass Switch
Highlights
16kVA / 16,000VA / 14,400W
on-line double-conversion UPS;
0.9 power factor
208/120V or 240/120V 60Hz
compatibility
Hot-swap power and battery
modules, N+1 fault tolerance at
loads up to 8kVA
USB, RS232 & EPO ports; slot
for network management card
options
Front panel LEDs with detailed
LCD monitoring and control
screen
Expandable runtime with
optional external battery packs
Hardwire input (3 wire); L6-30R,
C19, 5-15/20R & 5-15R outlets
MODEL NUMBER: SU16KRT-1TF
Package Includes
Two SU8000RT3UPM UPS
power modules
Two BP240V10RT3U battery
packs
One SU6000XFMR2U 208/240V
to 120V transformer
SUPDMB20K parallel PDU with
Bypass switch
4 post rackmount installation
rails
USB, DB9 & EPO cabline
Description
Tripp Lite SU16KRT-1TF 16,000VA / 16kVA / 14,400 watt online, double-conversion UPS system offers
complete power protection for critical server, network and telecommunications equipment in a 14U
rack/tower configuration. This system delivers complete N+1 redundancy when used at loads up to 8kVA,
and non-redundant operation at loads between 8 and 16kVA. Fault-tolerant auto-bypass prevents
unexpected service interruptions during UPS overload or internal fault conditions. Included parallel PDU
with manual bypass switching enables hot-swappable replacement of all major UPS system components
in both N+1 and combined operating modes. Enhanced availability, fault tolerance and simple hot-swap
replacement options make this UPS ideal for advanced networking applications in data centers, computer
rooms, network closets and rugged industrial locations.
Features
Tripp Lite SU16KRT 16kVA, 16,000VA / 14,400 watt on-line, double-conversion UPS system in 14U
total rack/tower configuration
Unique configuration offers 16kVA non-redundant operation and automatic N+1 redundancy at load
levels of 8kVA and under
Included Parallel PDU with manual bypass switch enables hot-swap replacement of power modules at
any supported load level
Hardwire input; 2 L6-30R (208/240v), 8 C19 (208/240v), 8 5-15/20R (120v) and 4 5-15R (120v) outlets
Maintains full-time sine wave output within 2% of selectable 200/208/220/230/240V & 120V nominal
Expandable runtime with optional external battery packs
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD (NOTE: Applications utilizing any supported
network management card option, require the installation of two of the same model network card –
install one card per included UPS power module)
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Battery independent restart ensures automatic UPS power-up after lengthy power outages, even with
expired batteries
Intelligent battery management system with temperature-compensated charging extends battery life
HID-compliant USB interface
1/6
Cleveland, OH 44122
United States
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks (6 required)
Optional 2-9USTAND supports upright tower placement (2 required)
Supports Emergency Power Off (EPO) via built-in interface
Front panel LEDs and LCD readout with scroll controls
LED / LCD display panel rotates for viewing in rackmount or tower configurations
External battery packs are field replaceable and hot swappable
Specifications
OVERVIEW
UPC Code
037332158253
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
88.4A (208V), 76.6A (240V)
Nominal Input Voltage(s) Supported
208V AC; 240V AC
UPS Input Connection Type
Hardwire
UPS Input Connection Description
3 wire single phase input (L1, L2, G)
Recommended Electrical Service
100A @ 208V, or 240V (L1, L2, G)
OUTPUT
Output Capacity (VA)
16000
Output Capacity (kVA)
16
Output Capacity (Watts)
14400
Output Capacity (kW)
14.4
Output Capacity Details
Supports up to 105% load continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30
seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power;
Double conversion mode is automatically restored as load levels are reduced to 95% or less
Power Factor
0.9
Crest Factor
3:1
Nominal Voltage Details
This configuration requires the Power Module be set to 208 or 240V output voltage; included step-down transformer
supports 120V output (when the voltage-selection switch on the transformer module is set to match the 208 or 240V
power module setting)
Frequency Compatibility
60 Hz
Frequency Compatibility Details
Output frequency regulation +/- 0.05Hz (free running)
Output Voltage Regulation (Line
Mode)
+/- 2%
2/6
Cleveland, OH 44122
United States
Output Voltage Regulation (Battery
Mode)
+/- 2%
Output Receptacle Details
Total 120V output is limited to 4992 watts for 208V input and 5760 watts for 240V input. Additional 120V capacity is
available by adding a second SU6000XFMR2U step-down transformer.
Output Circuit Breakers
POWER MODULE: Two built-in 30A breakers protect one L6-30R outlet each, Eight built-in 20A breakers protect
one C19 outlet each; TRANSFORMER MODULE: Two 15A breakers protect 2 5-15R outlets each, Two 20A
breakers protect 4 5-15/20R outlets each
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
120V; 208V; 240V
Output Receptacles
(4) 5-15R; (8) 5-15/20R; (2) L6-30R; (8) C19
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
5.5 min. (14.4kW)
Runtime Half Load (min.)
13.5 min. (7200W)
Expandable Runtime
Yes
Expandable Runtime Description
For best results, add external batteries in multiples of two so that both included 8kVA power modules have an equal
number and type of connected battery packs
External Battery Pack Compatibility
BP240V10RT3U ; BP240V787C-1PH
DC System Voltage (VDC)
240
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 90% (typical, full load discharge)
Battery Replacement Description
Hot-swappable, user replaceable external battery packs
VOLTAGE REGULATION
Voltage Regulation Description
2% output voltage regulation in standard online, double-conversion mode
Overvoltage Correction
Corrects overvoltages up to 300V
Undervoltage Correction
Corrects undervoltages as low as 100V
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options;
LED/LCD panel rotates for viewing in rack/tower formats; LCD Display supports ENGLISH, FRENCH, GERMAN,
ITALIAN, SPANISH and PORTUGUESE (see manual)
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and
execute scrolling LCD functions; bundled PDU includes bypass switch to enable hot-swap UPS power module
replacement
Alarm Cancel Operation
Alarm cancel switch
3/6
Cleveland, OH 44122
United States
Audible Alarm
Unique audible alarms for all major UPS, environmental and power conditions (see manual)
LED Indicators
6 LEDs indicate line power, online mode, bypass mode, on-battery, charger and AC output status; LCD screen offers
additional information and control options
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
2565
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
14U
Cooling Method
Fans
Included Battery Pack Dimensions
(hwd / in.)
5.25 x 17.50 x 25.00
Included Battery Pack Weight (lbs.)
158.7
Included Battery Pack Weight (kg)
71.99
Included Mounting Accessory
Description
5 sets of adjustable 4 post rack rails included (one for each included 2U/3U module)
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Maximum Device Depth (cm)
82.55
Maximum Device Depth (in.)
32.5
Maximum Device Depth (mm)
826
Minimum Required Rack Depth (cm)
96.52
(inches)
38
Optional Mounting Accessory Notes
Qty 5 2POSTRMKITHD required for 2 post
rackmount installation; Qty 2 2-9USTAND required for tower installation
Primary UPS Depth (mm)
656
Primary UPS Height (mm)
131
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
31.50 x 40.00 x 51.00
Shipping Dimensions (hwd / cm)
80.01 x 101.60 x 129.54
Shipping Weight (lbs.)
678.00
4/6
Cleveland, OH 44122
United States
Shipping Weight (kg)
307.54
Stepdown Transformer Dimensions
(hwd / cm)
8.89 x 44.45 x 55.37
(hwd / in.)
3.50 x 17.50 x 21.80
Stepdown Transformer Height (mm)
89
Stepdown Transformer Width (mm)
445
Stepdown Transformer Depth (mm)
554
Stepdown Transformer Weight (kg)
32.93
Stepdown Transformer Weight (lbs.)
72.6
Unit Dimension Details
Includes 2 SU8000RT3UPM UPS/Power modules, 2 BP240V10RT3U Battery packs, 1 SU6000XFMR2U
transformer and SUPDMB20K parallel bypass PDU; Listed weights and dimensions for UPS/Power module, battery
pack and transformer each refer to a single unit; MAXIMUM DEVICE DEPTH specification refers to the whole UPS
installed depth with parallel bypass PDU installed
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.06 x 44.45 x 65.58
(hwd, in.)
5.14 x 17.50 x 25.82
UPS Power Module Weight (kg)
19.50
UPS Power Module Weight (lbs.)
43
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius.
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius.
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
5464
Battery Mode BTU / Hr. (Full Load)
4864
AC Mode Efficiency Rating (100%
Load)
90%
Operating Elevation (ft.)
0-3000m (0 to 10,000 ft.)
Audible Noise
60 dBA at front side 1 meter
Operating Elevation (m)
0-3000 m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
Applications utilizing any supported network management card option, require the installation of two of the same
model network card – install one card per included UPS power module; RELAYIOMINI installation requires removal
of panel containing USB ports on each included UPS power module
5/6
Cleveland, OH 44122
United States
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB, DB9 serial and EPO cables included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
100V
High Voltage Transfer to Battery
Power (Setpoint)
300V
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic inverter bypass; Expandable battery backup; Hot
swappable UPS power module; Hot swappable batteries; Manual bypass switch; N+1 Redundant up to 50%
capacity; On-Line/Double-Conversion; Remote management; Sine wave output; Surge/noise protection; Zero
transfer time
Green Energy-Saving Features
Support for daily startup and shutoff
STANDARDS & COMPLIANCE
Product Certifications
IEC 61000; CSA (Canada); UL 1778
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
