74HC14; 74HCT14
Hex inverting Schmitt trigger
Rev. 7 — 19 November 2015
Product data sheet
1. General description
The 74HC14; 74HCT14 is a hex inverter with Schmitt-trigger inputs. This device features
reduced input threshold levels to allow interfacing to TTL logic levels. Inputs also include
clamp diodes, this enables the use of current limiting resistors to interface inputs to
voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals
into sharply defined jitter-free output signals.
2. Features and benefits
Complies with JEDEC standard no. 7A
Low-power dissipation
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
3. Applications
Wave and pulse shapers
Astable multivibrators
Monostable multivibrators
74HC14; 74HCT14
Nexperia
4. Ordering information
Table 1.
Type number
Package
74HC14D
Temperature range
Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads; body
width 5.3 mm
SOT337-1
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
40 C to +125 C
DHVQFN14
plastic dual in-line compatible thermal enhanced very SOT762-1
thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
74HCT14D
74HC14DB
74HCT14DB
74HC14PW
74HCT14PW
74HC14BQ
74HCT14BQ
5. Functional diagram
Logic symbol
74HC_HCT14
Product data sheet
PQD
Fig 1.
PQD
DDF
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3.
Logic diagram
(one Schmitt trigger)
Nexperia B.V. 2017. All rights reserved
2 of 20
74HC14; 74HCT14
Nexperia
6. Pinning information
WHUPLQDO
LQGH[DUHD
9&&
6.1 Pinning
9&&
*1'
*1'
*1'
DDF
7UDQVSDUHQWWRSYLHZ
DDF
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 4.
Pin configuration SO14 and (T)SSOP14
Fig 5.
Pin configuration DHVQFN14
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A to 6A
1, 3, 5, 9, 11, 13
data input 1
1Y to 6Y
2, 4, 6, 8, 10, 12
data output 1
GND
7
ground (0 V)
VCC
14
supply voltage
7. Functional description
Table 3.
Function table[1]
Input
Output
nA
nY
L
H
H
L
[1]
H = HIGH voltage level;
L = LOW voltage level.
74HC_HCT14
Product data sheet
3 of 20
74HC14; 74HCT14
Nexperia
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7
V
mA
mA
25
mA
50
mA
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
0.5 V < VO < VCC + 0.5 V
ICC
supply current
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
500
mW
total power dissipation
Ptot
SO14, (T)SSOP14 and DHVQFN14
packages
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 C.
For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C.
9. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74HC14
Min
Typ
74HCT14
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
74HC_HCT14
Product data sheet
4 of 20
74HC14; 74HCT14
Nexperia
10. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Tamb = 25 C
Conditions
Tamb = 40 C
to +85 C
Tamb = 40 C
to +125 C
Unit
Min
Typ
Max
Min
Max
Min
Max
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.16
0.26
0.33
0.4
V
74HC14
VOH
VOL
HIGH-level
output voltage
LOW-level
output voltage
VI = VT+ or VT
VI = VT+ or VT
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1.0
±1.0
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
2.0
A
CI
input
capacitance
3.5
pF
IO = 20 A
4.4
4.5
4.4
4.4
V
IO = 4.0 mA
3.98
4.32
3.84
3.7
V
IO = 20 A;
0.1
0.1
V
IO = 4.0 mA;
0.15
0.26
0.33
0.4
V
74HCT14
VOH
VOL
HIGH-level
output voltage
LOW-level
output voltage
VI = VT+ or VT; VCC = 4.5 V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1.0
±1.0
A
ICC
supply current
VCC = 5.5 V
2.0
A
ICC
additional
supply current
per input pin;
VI = VCC 2.1 V; other pins
at VCC or GND; IO = 0 A;
VCC = 4.5 V to 5.5 V
30
108
135
147
A
CI
input
capacitance
3.5
pF
74HC_HCT14
Product data sheet
5 of 20
74HC14; 74HCT14
Nexperia
11. Dynamic characteristics
Table 7.
GND = 0 V; CL = 50 pF; for test circuit see Figure 7.
Symbol Parameter
Tamb = 25 C
Conditions
Tamb = 40 C to
+125 C
Unit
Min
Typ
Max
Max
(85 C)
Max
(125 C)
VCC = 2.0 V
41
125
155
190
ns
VCC = 4.5 V
15
25
31
38
ns
VCC = 5.0 V; CL = 15 pF
12
ns
12
21
26
32
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
6
13
15
19
ns
7
pF
74HC14
propagation delay nA to nY; see Figure 6
tpd
[1]
VCC = 6.0 V
transition time
tt
[2]
see Figure 6
VCC = 6.0 V
power dissipation
capacitance
CPD
per package; VI = GND to VCC
[3]
74HCT14
tpd
transition time
tt
power dissipation
capacitance
CPD
[1]
VCC = 4.5 V
43
51
ns
17
ns
VCC = 4.5 V; see Figure 6
[2]
7
15
19
22
ns
per package;
VI = GND to VCC 1.5 V
[3]
8
pF
[1]
tpd is the same as tPHL and tPLH.
[2]
tt is the same as tTHL and tTLH.
[3]
CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74HC_HCT14
Product data sheet
6 of 20
74HC14; 74HCT14
Nexperia
12. Waveforms
9,
90
Q$LQSXW
90
*1'
W 3+/
W 3/+
92+
90
90
Q
很抱歉,暂时无法提供与“74HC14PW,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.440201+0.41510
- 10+2.2157010+0.26740
- 100+1.36440100+0.16470
- 1000+0.981901000+0.11850
- 2500+0.688002500+0.08310
- 10000+0.6461010000+0.07800
- 25000+0.6216025000+0.07500
- 50000+0.6041050000+0.07290
- 国内价格
- 5+0.58553
- 20+0.53387
- 100+0.48220
- 500+0.43054
- 1000+0.40643
- 2000+0.38921
