74LV393
Dual 4-bit binary ripple counter
Rev. 6 — 19 March 2021
Product data sheet
1. General description
The 74LV393 is a dual 4-stage binary ripple counter. Each counter features a clock input (nCP), an
overriding asynchronous master reset input (nMR) and 4 buffered parallel outputs (nQ0 to nQ3).
The counter advances on the HIGH-to-LOW transition of nCP. A HIGH on nMR clears the counter
stages and forces the outputs LOW, independent of the state of nCP. Inputs include clamp diodes.
This enables the use of current limiting resistors to interface inputs to voltages in excess VCC.
2. Features and benefits
Optimized for low voltage applications: 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Typical VOLP (output ground bounce) 0.8 V at VCC = 3.3 V, Tamb = 25 °C
Typical VOHV (output VOH undershoot) 2 V at VCC = 3.3 V, Tamb = 25 °C
Two 4-bit binary counters with individual clocks
Divide-by any binary module up to 28 in one package
Two master resets to clear each 4-bit counter individually
Complies with JEDEC standard no. 7A
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
3. Ordering information
Table 1. Ordering information
Type number Package
Temperature range
Name
Description
Version
74LV393D
-40 °C to +125 °C
SO14
plastic small outline package; 14 leads; body width 3.9 mm SOT108-1
74LV393PW
-40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74LV393
Nexperia
4. Functional diagram
1
1Q0
1CP
1
2
1MR
13
2CP
2
12
2MR
CTR4
3
2
1Q1
4
1Q2
5
1Q3
6
2Q0
11
1
2
13
12
1CP
2Q1
10
2Q2
9
2Q3
8
CTR4
1MR
2CP
2MR
3
6
CT = 0
13
10
9
3
8
001aad533
1Q0
IEC logic symbol
3
1Q1
4
1Q2
5
1Q3
2Q0
4-BIT
BINARY
RIPPLE
COUNTER
5
CT
Fig. 2.
4-BIT
BINARY
RIPPLE
COUNTER
4
12
Logic symbol
1
3
CT
001aad532
Fig. 1.
CT = 0
11
2Q1
10
2Q2
9
2Q3
8
1
2
3
15
5
14
6
13
7
12
11
10
9
Functional diagram
CP
Fig. 4.
T
FF
1
8
001aad535
001aad534
Fig. 3.
4
Q
T
RD
FF
2
State diagram
Q
T
RD
FF
3
Q
T
RD
FF
4
Q
RD
MR
Q0
Q1
Q2
Q3
001aad536
Fig. 5.
Logic diagram (one counter)
74LV393
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 13
74LV393
Nexperia
5. Pinning information
5.1. Pinning
74LV393
1CP
1
14 VCC
1MR
2
13 2CP
1Q0
3
12 2MR
1Q1
4
11 2Q0
1Q2
5
10 2Q1
1Q3
6
9
2Q2
GND
7
8
2Q3
74LV393
1CP
1
14 VCC
1MR
2
13 2CP
1Q0
3
12 2MR
1Q1
4
11 2Q0
1Q2
5
10 2Q1
1Q3
6
9
2Q2
GND
7
8
2Q3
aaa-011662
Fig. 6.
aaa-011663
Pin configuration SOT108-1 (SO14)
Fig. 7.
Pin configuration SOT402-1 (TSSOP14)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1CP, 2CP
1, 13
clock input (HIGH-to-LOW, edge-triggered)
1MR, 2MR
2, 12
asynchronous master reset input (active HIGH)
1Q0, 1Q1, 1Q2, 1Q3
3, 4, 5, 6
flip-flop output
GND
7
ground (0 V)
2Q0, 2Q1, 2Q2, 2Q3
11, 10, 9, 8
flip-flop output
VCC
14
supply voltage
74LV393
Product data sheet
3 / 13
74LV393
Nexperia
6. Functional description
Table 3. Count sequence for one counter
H = HIGH voltage level; L = LOW voltage level.
Count
Output
nQ0
nQ1
nQ2
nQ3
L
L
L
L
1
H
L
L
L
2
L
H
L
L
3
H
H
L
L
4
L
L
H
L
5
H
L
H
L
6
L
H
H
L
7
H
H
H
L
8
L
L
L
H
9
H
L
L
H
10
L
H
L
H
11
H
H
L
H
12
L
L
H
H
13
H
L
H
H
14
L
H
H
H
15
H
H
H
H
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
IOK
IO
ICC
Min
Max
Unit
-0.5
+4.6
V
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±50
mA
output current
VO = -0.5 V to VCC + 0.5 V
±25
mA
supply current
+50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
Conditions
Tamb = -40 °C to +125 °C
[1]
For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C.
For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C.
74LV393
Product data sheet
4 / 13
74LV393
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
Min
Typ
Max
Unit
1.0
3.3
3.6
V
VCC
V
VCC
V
-40
+125
°C
VCC = 1.0 V to 2.0 V
500
ns/V
VCC = 2.0 V to 2.7 V
200
ns/V
VCC = 2.7 V to 3.6 V
100
ns/V
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VIH
HIGH-level input
voltage
VIL
LOW-level input
voltage
VOH
VOL
Conditions
-40 °C to +85 °C
Min
Typ[1]
Max
Min
Max
VCC = 1.2 V
0.9
0.9
V
VCC = 2.0 V
1.4
1.4
V
2.0
2.0
V
VCC = 1.2 V
0.3
0.3
V
VCC = 2.0 V
0.6
0.6
V
0.8
0.8
V
1.2
V
IO = -100 μA; VCC = 2.0 V
1.8
2.0
1.8
V
IO = -100 μA; VCC = 2.7 V
2.5
2.7
2.5
V
IO = -100 μA; VCC = 3.0 V
2.80
3.0
2.8
V
IO = -6 mA; VCC = 3.0 V
2.40
2.82
2.20
V
IO = 100 μA; VCC = 1.2 V
V
IO = 100 μA; VCC = 2.0 V
0.2
V
IO = 100 μA; VCC = 2.7 V
0.2
V
IO = 100 μA; VCC = 3.0 V
0.2
V
IO = 6 mA; VCC = 3.0 V
0.25
0.40
0.50
V
HIGH-level output VI = VIH or VIL
voltage
IO = -100 μA; VCC = 1.2 V
LOW-level output
voltage
-40 °C to +125 °C Unit
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND; VCC = 3.6 V
1.0
1.0
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 3.6 V
20.0
160
μA
ΔICC
additional supply
current
per input;
VI = VCC - 0.6 V; VCC = 2.7 V to 3.6 V
500
850
μA
CI
input capacitance
3.5
pF
[1]
All typical values are measured at Tamb = 25 °C.
74LV393
Product data sheet
5 / 13
74LV393
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 10.
Symbol Parameter
tpd
propagation
delay
Conditions
-40 °C to +85 °C
Min
Typ[1]
VCC = 1.2 V
VCC = 2.0 V
VCC = 2.7 V
VCC = 3.3 V, CL = 15 pF
Max
Min
75
ns
26
49
60
ns
19
36
44
ns
12
ns
14
29
35
ns
VCC = 1.2 V
25
ns
VCC = 2.0 V
9
17
ns
VCC = 2.7 V
6
13
15
ns
4
ns
5
10
12
ns
VCC = 1.2 V
70
ns
VCC = 2.0 V
24
44
54
ns
VCC = 2.7 V
18
33
40
ns
11
ns
13
26
32
ns
VCC = 2.0 V
34
10
41
ns
VCC = 2.7 V
25
8
30
ns
24
ns
VCC = 2.0 V
34
12
41
ns
VCC = 2.7 V
25
9
30
ns
24
ns
VCC = 1.2 V
5
ns
VCC = 2.0 V
5
2
5
ns
VCC = 2.7 V
5
2
5
ns
5
1
5
ns
VCC = 2.0 V
14
53
12
MHz
VCC = 2.7 V
19
72
16
MHz
99
MHz
24
90
MHz
nCP to nQ0; see Fig. 8
HIGH to LOW
propagation
delay
[3]
nQ to nQn+1; see Fig. 8
[2]
[3]
nMR to nQx; see Fig. 9
VCC = 3.0 V to 3.6 V
tW
pulse width
Max
[2]
tPHL
[3]
nCP HIGH or LOW; see Fig. 8
[3]
nMR HIGH; see Fig. 9
trec
recovery time
nMR to nCP; see Fig. 9
fmax
maximum
frequency
[3]
[3]
see Fig. 8
74LV393
Product data sheet
[3]
6 / 13
74LV393
Nexperia
Symbol Parameter
CPD
[1]
[2]
[3]
[4]
power
dissipation
capacitance
Conditions
-40 °C to +85 °C
VI = GND to VCC
Min
Typ[1]
Max
Min
Max
23
[3] [4]
pF
tpd is the same as tPLH and tPHL.
Typical values are measured at VCC = 3.3 V.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of outputs.
10.1. Waveforms and test circuit
1/f max
VI
input nCP
VM
GND
t PHL
t PLH
VOH
output nQx
VM
VOL
t THL
t TLH
001aad537
tTLH = 10 % and tTHL = 90 %,
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 8.
Propagation delays clock (nCP) to output (nQx), output transition times and maximum clock frequency
Table 8. Measurement points
Input
Supply voltage VCC
Output
VM
VM
VX
VY
< 2.7 V
0.5VCC
0.5VCC
VOL + 0.1VCC
VOH - 0.1VCC
2.7 V to 3.6 V
1.5VCC
1.5VCC
VOL + 0.3VCC
VOH - 0.3VCC
74LV393
Product data sheet
7 / 13
74LV393
Nexperia
VI
input nMR
VM
GND
tW
t rec
VI
input nCP
VM
GND
t PHL
VOH
output nQx
VM
VOL
001aad538
Fig. 9.
Propagation delays clock (nCP) to output (nQx), pulse width master reset (nMR), and recovery time
master reset (nMR) to clock (nCP)
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig. 10. Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPHL, tPLH
< 2.7 V
VCC
≤ 2.5 ns
50 pF
1 kΩ
open
2.7 V to 3.6 V
2.7 V
≤ 2.5 ns
15 pF, 50 pF
1 kΩ
open
74LV393
Product data sheet
VEXT
Load
8 / 13
74LV393
Nexperia
11. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
A2
Q
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 11. Package outline SOT108-1 (SO14)
74LV393
Product data sheet
9 / 13
74LV393
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
D
SOT402-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
7
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 12. Package outline SOT402-1 (TSSOP14)
74LV393
Product data sheet
10 / 13
74LV393
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LV393 v.6
20210319
Product data sheet
74LV393 v.5
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Section 1 updated.
Section 7: Derating values for Ptot total power dissipation updated.
Type number 74LV393DB (SOT337-1 / SSOP14) removed.
74LV393 v.5
20151208
Modifications:
74LV393 v.4
20140918
Modifications:
74LV393 v.3
20140428
Modifications:
Product data sheet
74LV393 v.4
Type number 74LV393N (SOT27-1) removed.
Product data sheet
74LV393 v.3
Table 4 minus sign added to the minimum ground current.
Fig. 10 and Table 9 updated because of a missing load resistance in the test circuit.
Product data sheet
74LV393 v.2
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
74LV393 v.2
19970610
Product specification
74LV393 v.1
74LV393 v.1
19970304
74LV393
Product data sheet
11 / 13
74LV393
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LV393
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
12 / 13
74LV393
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................5
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms and test circuit........................................ 7
11. Package outline.......................................................... 9
12. Abbreviations............................................................ 11
13. Revision history........................................................11
14. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 19 March 2021
74LV393
Product data sheet
13 / 13
