GWKAJRB2.EM-STTQ-27H4 数据手册
2013-05-16
SOLERIQ® E 30
Datasheet
Version 1.0
GW KAJRB2.EM
The SOLERIQ® E products were specifically designed
for applications requiring large flux packages out of a
compact area.
For the replacement of traditional CFL light sources in
downlights the following typical LED efficacies can be
achieved at 4000 K:
2x18 W 111 lm/W
2x26 W 101 lm/W
Die SOLERIQ® E Produkte wurden speziell für
Anwendungen entwickelt, die große Lumenpakete
aus einer kompakten Fläche benötigen.
Für den Ersatz von traditionellen CFL-Lichtquellen in
Downlights lassen sich bei 4000 K folgende typische
LED Effizienzen erzielen:
2x18 W 111 lm/W
2x26 W 101 lm/W
Features:
Besondere Merkmale:
Package: Chip-on-Board
Viewing angle at 50 % IV: 120°
Color: 2700 K - 6500 K ( white )
CRI: min. 80 ( typ. 85 )
Luminous Flux: typ. 3000 lm @ 4000 K
Luminous efficacy: typ. 114 lm/W @ 4000 K
Applications
Anwendungen
• Downlights
• Indoor General Lighting
2013-05-16
Gehäusetyp: Chip-on-Board
Abstrahlwinkel bei 50 % IV: 120°
Farbe: 2700 K - 6500 K ( weiß )
Lichtstrom: typ. 3000 lm @ 4000 K
Lichtausbeute: typ. 114 lm/W @ 4000 K
• Downlights
• Innen-Allgemeinbeleuchtung
1
Version 1.0
GW KAJRB2.EM
Ordering Information
Bestellinformation
Type:
Color
Temperature
Luminous Flux
Ordering Code
Typ:
Farbtemperatur
Lichtstrom
Bestellnummer
1) page 18
1) Seite 18
IF = 600 mA
[K]
ΦV [lm]
GW KAJRB2.EM-STTQ-27H4
2700
2400 ... 3300
Q65111A2515
GW KAJRB2.EM-SUTQ-30H4
3000
2590 ... 3300
Q65111A2516
GW KAJRB2.EM-TPTR-40H4
4000
2800 ... 3590
Q65111A2517
GW KAJRB2.EM-TPTR-50H4
5000
2800 ... 3590
Q65111A2518
GW KAJRB2.EM-TPTR-57H4
5700
2800 ... 3590
Q65111A2519
GW KAJRB2.EM-TPTR-65H4
6500
2800 ... 3590
Q65111A2520
Note:
The above Type Numbers represent the order groups which include only a few brightness groups (see page ). Only one group will be shipped on each
packing unit (there will be no mixing of two groups on each packing unit). E. g. GW KAJRB2.EM-TPTR-40H4 means that only one group TP, TPTR,
TQ, TR will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable.
In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing
unit. GW KAJRB2.EM-TPTR-40H4 means that the device will be shipped within the specified limits. In order to ensure availability, single color
chromaticity groups groups will not be orderable (see page ).
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite ). Es
wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW KAJRB2.EM-TPTR-40H4 bedeutet, dass in einer
Verpackungseinheit nur eine der Helligkeitsgruppen TP, TPTR, TQ, TR enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne
Helligkeitsgruppen nicht bestellt werden.
Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert.
Z.B. GW KAJRB2.EM-TPTR-40H4 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist (siehe Seite ). GW
KAJRB2.EM-TPTR-40H4 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten,
können einzelne Farbortgruppen nicht bestellt werden.
2013-05-16
2
Version 1.0
GW KAJRB2.EM
Maximum Ratings
Grenzwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Operating temperature range
Betriebstemperatur
Top
-30 ... 85
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 100
°C
Junction temperature
Sperrschichttemperatur
Tj
125
°C
Forward current
Durchlassstrom
(TS = 25 °C)
IF
1080
mA
Surge current
Stoßstrom
(t
GWKAJRB2.EM-STTQ-27H4 价格&库存
很抱歉,暂时无法提供与“GWKAJRB2.EM-STTQ-27H4”相匹配的价格&库存,您可以联系我们找货
