engineered to light up your design
www.vcclite.com
1.800.522.5546
CMDA7 Series HIGH BRIGHTNESS Right Angle Surface Mount LED
Description and Features
Features
• High brightness
• Small size
• Industry standard
Footprint
• Non-diffused optics
• Right angle emitting
• Compatible with IR
solder profiles
• Ideal for use with
Light Pipes
• Available in 8 mm tape
on 7" diameter reel
• Packaged 3,000 pieces
per reel
• RoHS Compliant
NOTES:
1. All dimensions are in inches (mm)
2. 1 micro second @ 10% duty cycle
Applications
• LCD backlighting
• Push button
backlighting
• Front panel indicator
• Symbol indicator
• Microdisplays
• Small message panel
signage
CAUTION: CMDA6AG
is Class 1 ESD
sensitive per MILSTD-1686. Please
observe appropriate
precautions during
handling and
processing.
Electro-Optical Characteristics and Ratings
Part
Number
Diffusion
Output
Color
Package
Color
Test
Current
(mA)
Forward
Voltage
Typ. (V)
Forward
Voltage
Max. Typ. (V)
Luminous
Intensity
Min. (mcd)
Luminous
Intensity
Typ. (mcd)
Peak
Wavelength
(nm)
Viewing
Angle
(Degrees)
CMDA7AG7A1S
Green
Non-Diffused
Clear
3.9
40
150
520
130
CMDA7DY7A1S
Amber
Non-Diffused
Clear
2.4
25
95
595
130
CMDA7AR7A1S
Red
Non-Diffused
Clear
2.4
25
95
637
130
Absolute Maximum Ratings to = 25°C
Part
Number
Power
Dissipation
(mW)
Operating
Temperature
(°C)
Storage
Temperature
(°C)
Peak Forward
Current Max.
(See note 2) (mA)
Reverse Voltage
(IR = 100 mA)
(V)
Lead Solder Time
at 230°C
(Seconds)
AG
98
-30 to +85
-40 to +85
100
5
10
DY
75
-30 to +85
-40 to +85
100
5
10
AR
75
-30 to +85
-40 to +85
100
5
10
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“CMDA7BA7A1S”相匹配的价格&库存,您可以联系我们找货
