8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
1452
INITIAL RELEASE
07/31/07
RAH
B
1660
ADD TOLERANCE TO TABLE
04/15/08
ASK
C
1871
UPDATE POSITION, TEXT & TOLERANCE
2/2/2009
JH
F
B
A
E
E
PIN 1
.134 3.40
.050 1.27
.050 1.27
D
D
.118 3.00
.039 1.00
.016 0.40
.201 5.10
01-20, 0.20mm MAX.
21-50, 0.30mm MAX.
C
B
C
A
PIN 1
A
.079 2.00
B
.240 6.10
NOTES:
1. INSULATOR MATERIAL: NYLON 9T.
*PROCESSING TEMPERATURE = 260° C FOR 10 SEC.
2. CONTACT MATERIAL: BRASS.
3. PLATING: GOLD FLASH OVERALL.
4. OPERATING TEMPERATURE: -40°C TO +105° C.
5. INSULATION RESISTANCE: 5000 MEGA OHM MIN.
6. CONTACT RESISTANCE: 20 MILLI OHM MAX.
7. DIELECTRIC WITHSTANDING: AC 500V.
8. UL FLAMMABILITY RATING: 94V-0.
9. CURRENT RATING: 1 AMP.
.073 1.85
.029 0.74
.050 1.27
RECOMMENDED PCB SMD LAYOUT
Pb
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT
INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED,
PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR
DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
8
7
6
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES[MM]
TOLERANCES:
ANGULAR:
.XX= .012 [.30]
.XXX= .008 [.20]
.XXXX= .004 [.10]
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
5
4
DRAWN
NAME
12/08/08
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
.050" DUAL ROW MALE HEADER, SMT
GRPB_ _2VWQS-RC
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
DATE
REV
10958
SCALE: 8:1
2
C
SHEET 1 OF 1
1
FILE NAME: Z:\COMPONENTS\Taiwan\10958, GRPB_ _2VWQS-RC PRINT: 2/2/2009
A
很抱歉,暂时无法提供与“GRPB052VWQS-RC”相匹配的价格&库存,您可以联系我们找货
