PT2512FK-7W0R1L
PT2512FK-7W0R1L
    YAGEO(国巨)
    贴片电阻 2512 100mΩ ±1% 2W ±100ppm/℃
PT2512FK-7W0R1L 数据手册
www.yageo.com Current Sensing Chip Resistors About Yageo Founded in 1977, the Yageo Corporation has become a world-class provider of passive component services with capabilities on a global scale, including production and sales facilities in Asia, Europe and the Americas. Yageo currently ranks as the world No.1 in chip-resistors, No. 3 in MLCCs and No. 4 in ferrite products, with a strong global presence: 21 sales offices in 15 countries, 9 production sites, 8 JIT logistic hubs, and 2 R&D centers worldwide. Ferroxcube and Vitrohm, who produce ferrites and leaded resistors, are also a part of the Yageo group. We support our customers with extensive literature including datasheets, brochures and application notes, which are also available electronically on our website at: www.yageo.com Table of Contents Introduction..............................................................3 Current-Sensing Circuit Applications..........4 Market Applications..............................................6 Product Portfolio....................................................7 Product Selection Tables................................. 10 2 Introduction Low Resistance, High Power for Current Sensing Applications Current Sensing Chip Resistors Current measurement is very important in power and instrumentation systems for circuit control, protection, monitoring, and performance enhancement. Engineers in power supply and battery circuit designs need to consider a give-and-take strategy between low resistance values to minimize power losses and sufficient voltage supplies to avoid noises generated from the environments or particularly in switch mode power supplies. Yageo’s current-sensing chip resistors are also fully compatible with today’s high volume pick-and-place assembly systems. As such, they offer attractive, cost-effective solutions to designers of low voltage power supplies and battery management systems. Featuring a comprehensive resistance range of 0.5 milli-ohms to 1 ohm (low-ohmic), and available from 0.05 to 5 watts, they are not only applicable to battery packs, power supplies and converters, but also suitable for use in diverse power control circuits of tablets, notebook computers and hard disks. Introduction Yageo now offers three types of surface-mount (SMT) current-sensing chip resistors based on thick film, metal foil, and metal plate technologies, with scalable product portfolios to meet the various demands of customers and their applications. Main Features of Yageo’s Current-Sensing Chip Resistors • • • • Low resistance value from 1mΩ to 20 mΩ for minimizing power losses. High power-rating from 0.05 to 5 watts. Tight tolerance within 2% to exhibit actual current via voltage reading. Low TCR to avoid measurement distortions. TCR ranges from 50 to 100ppm/ºC for metal and 100 to 1500ppm/ºC for thick film current sensors. • Scalable off-the-shelf products in standard case sizes. • Compatibility with surface-mount assembly process. • RoHS/REACH-compliant & Halogen-free. The low temperature coefficient of resistance (TCR) of Yageo's current-sensing chip resistors minimizes the resistance change caused by self-heating and high temperature environments. Thermal electromotive force (EMF) is also an important consideration. Thermal EMF is an important parameter of the metal foil series of battery management circuits, and of current-sensor resistors. Thermal electromotive force (EMF) of an Mn-Cu alloy is especially optimal with low EMF below µ0.03 uV/oC. 3 Current-Sensing Circuit Applications Low-Ohmic Resistors in Power-Sensing Current-sensor resistors are used in power sensing applications such as sensing output current in power supplies and automotive engine management systems. As shown in Figure 1, a typical function for a current-sensor chip resistor is as a currentsensor (Rsense). This generates the sensing voltage (Vs) for a feedback control network through which an output current (Io) passes. The sensing voltage triggers MOSFET switches, switching them ON and OFF to regulate the duty factor of the current passing through a choke (L). The sensing voltage (Vs) is given by the simple relation: Figure 1 Current sensor chip resistor in current sensing application Vs = Io x Rsense This sensing voltage is generally set at around 100 mV both to save power and maintain satisfactory noise immunity. To sense a 5 A average output current, Rsense must be 100 mV/5 A = 20 mΩ. The power dissipation will then be: P = Io2Rsense = 5 A x 5 A x 20 mΩ = 0.5 W A current-sensor chip resistor with a power rating 1.0 W would then be recommended for this application to provide an adequate safety margin. Over-Current Detection As a means to detect the current passing through the transistor (see Figure 2), a resistor in series is added between an emitter and a ground. This resistor shouldn't emit smoke or catch fire even when the switching transistor, subjected to a larger current, breaks down. In addition, reduced parasitic inductance is required, particularly for high frequency switching control. Recommended resistors with low resistance are metal-plate types, like the PE-series. DC/DC converter Figure 3 on the right shows the current-detecting circuit of a DC/DC converter. The voltage across the currentdetecting resistor is fed back to control the output power. The resistance should be low to reduce power dissipation, and the resistor should withstand a repeated rush current. Furthermore, the self-inductance should be low for highfrequency applications. Recommended types are PE-series chip resistors. As for high frequency DC/DC converters, metal-plate chip resistor, PE-series are the best fit. 4 Figure 2 Over-current protection circuit Figure 3 DC/DC converter circuit Tight Tolerance in Sensing Resistance 2 Current Sensing Chip Resistors The magnitude of the output ripple depends on the inductance of the choke - the higher the inductance, the lower the ripple. A high inductance choke, however, reduces the ability of the circuit to respond to high frequency transients. Such a choke will also be physically large, limiting the possibilities for miniaturization so essential to modern mobile equipment. 0.04 = 4 Figure 4 Relationship between average output current and Introduction A trade-off is therefore necessary between choke peak current with a ripple of 0.04 volume and output current ripple. Experience indicates that a ripple of 0.04 provides a good compromise in this area. With this ripple value, the peak output current (Ipeak) is 2% greater than the average current (Iavg): Ipeak = 1.02 x Iavg (Figure 4). The voltage generated across the sensing resistor is used in a feedback network to trigger the power-switching IC.To allow for variation in the characteristics of the power-switching IC, a safety margin for the sensing-voltage is necessary. A -2% margin on sensing-voltage is usually taken for general applications. As mentioned earlier, the relation between current sensor resistance, feedback sensing voltage and output current is given given by the formula: Rsense = Vs/Io. With an output ripple of of 0.04, a 4% (± 2%) deviation on output current and a safety margin on the sensing voltage of -2%, the allowable deviation on (Rsense) is: 0.98 x Vs 0.98 x 1o Vs 0.85 x 1o If Vs= 100 mV and Io= 5 A, the allowable current sensor sensing resistance must lie in the range 19.2mΩ to 20.4mΩ. Excellent Low TCR Values for Precision Applications The above discussion does not, of course, take into account the effects of the temperature coefficient of resistance (TCR) on current sensing applications. With a maximum deviation of 4% on output current and a safety margin of 2% on sensing voltage, the maximum allowable deviation on sensing resistance is 6%. The limit on TCR is then given by: T.C.R. So TCR 1.06 Rsense 0.06 Figure 3 plots the allowable T.C.R. values required to maintain tolerance on sensing resistance within the specified limit. TCR values of Yageo’s current-sensor chip resistors fall well within these allowed limits over the temperature range 25°C to 155°C. 5 Market Applications Yageo’s current sensor chip resistors are optimized for current sensing control. The current sensor current sensors, available from 0.05 to 5 watts, are applicable to battery pack, power supply and converter, and are suitable for use in diverse power control circuit of notebook computer or the hard disk of other compact portable devices that have current sensing and over current protection requirements. Featuring a comprehensive resistance range of 0.5 milliohms to 1 ohm and superior temperature coefficient (T.C.R.) performance is able to meet various customer demands and applications. Application Segment Consumer Automotive Industrial Telecom Medical Device & Computing Home Appliances v Air Conditioners v v Diagnostic Equipment Infotainment System v v v Smart Meters v Smartphones & Tablets v v Notebooks v v Wearable Devices v v Networking v v v Batteries Battery Chargers v v v v v Battery Life Indicators v v v v v Battery Packs v v v v v Motor Controls v v v Motor Drives v v v v v v v v Motors Power Supplies DC/DC Converters v Switch Mode Power Supplies v v v LED Drivers v v v v Ballasts v v v v LED Lighting Storage & Cloud Computing 6 Disk Drives (HDD &SSD) v Servers v Product Portfolio Thick Film Current-Sensing Chip Resistors (RL & PT Series) marking layer overcoat protective coat Based on thick film technology, these products exhibit far low parasitic inductance than wirewound and leaded counter parts. Yageo’s thick film RL/PT low-ohmic current sensing chip resistors is low cost, capable of providing low TCR down to ±75ppm/°C, resistance value down to 50mΩ with power up to 2 watts of power dissipation. resistive layer termination (Ni / matte tin) inner electrode ceramic substrate Cross section of RL / PT series Metal Foil Current-Sensing Chip Resistors (PE & PF Series) Metal Plate Current-Sensing Chip Resistors (PA & PR Series) A related simple construction without multiple cuts, metal plate current-sensing resistors provide low TCR down to ±25ppm/°C, high power rating up to 3W, high frequency performance and low resistance down to 0.5mΩ. marking layer protective coat end termination H inner electrode I2 protective coat ceramic substrate resistive layer (metal foil) Cross section of PE / PF series metal substrate H end termination I2 protective coat Cross section of PA / PR series marking layer protective coat Wide Terminal Current-Sensing Chip Resistors Using the wider side as connection in the mounting plate, wide terminal current-sensing chip resistors strengthen solder joints, holding reliably to achieve higher power rating needs. With an ideal structure to suppress heat generation, wide terminal type currentsensors save space, and reduce resistor numbers in high-density circuit board designs. Market Applications / Product Portfolio Metal foil current-sensing resistors made of Mn-Cu alloy are developed with substrates to provide a better thermal dissipation and with a wider resistance range up to 300mΩ. Metal foil PE series feature low EMF below conditions of temperature changes. µ0.03 uV/ºC is more likely to endure harsh conditions. In the metal foil type, TCR ranges from 50 to 100ppm/ºC, power rates up to 3W, and resistance value is available as low as 0.5mΩ. Current Sensing Chip Resistors inner electrode resistive layer inner electrode H termination (Ni/matte tin) I2 ceramic substrate Cross section of wide terminal series Four-Terminal, Current-Sensing Chip Resistors Design of accurate measurement circuitry, lower power consumption, higher accuracy, and smaller space requirements are important features for electronic control units. To minimize power losses, a large current across the (Rsense) resistor needs to be measured, and high-side, current-sense amplifier ICs have to monitor the current accurately. Four-terminal, current-sensing resistors separating current-carry from voltage-sensing terminals are able to improve voltage and current measurement accuracy from the ideal Kelvin configuration. They also improve interference and thermoelectric effects at higher applied power. 7 Dimensions Wide terminal I1 I1 I1 I1 H H W I2 I2 L Type I2 I2 W L unit: mm unit: mm Resistance range L W H I1 I2 50mΩ ≤ R < 1Ω RL0402 (1) 1.00 ±0.10 0.50 ±0.05 0.35 ±0.05 0.20 ±0.10 0.25 ±0.10 RL0603 (1) 1.60 ±0.10 0.80 ±0.10 0.45 ±0.10 0.25 ±0.15 0.25 ±0.15 RL0805 (1) 2.00 ±0.10 1.25 ±0.10 0.50 ±0.10 0.35 ±0.20 0.35 ±0.20 RL1206 (1) 3.10 ±0.10 1.60 ±0.10 0.55 ±0.10 0.45 ±0.20 0.45 ±0.20 3.10 ±0.10 2.60 ±0.15 0.55 ±0.10 0.50 ±0.20 0.50 ±0.20 RL1218 (1) 3.05 ±0.15 4.60 ±0.20 0.55 ±0.10 0.45 ±0.25 0.50 ±0.25 RL2010 (1) 5.00 ±0.10 2.50 ±0.15 0.55 ±0.10 0.60 ±0.20 0.50 ±0.20 RL2512 (1) 6.35 ±0.10 3.20 ±0.15 0.55 ±0.10 0.60 ±0.20 0.50 ±0.20 PT0402 (1) 1.00 ±0.10 0.50 ±0.05 0.35 ±0.05 0.20 ±0.10 0.25 ±0.10 PT0603 (1) 1.60 ±0.10 0.80 ±0.10 0.45 ±0.10 0.25 ±0.15 0.25 ±0.15 PT0805 (1) RL1210 (1) PT1206 (1) 10mΩ ≤ R < 1Ω 50mΩ ≤R < 1Ω 2.00 ±0.10 1.25 ±0.10 0.55 ±0.10 0.35 ±0.20 0.35 ±0.20 50mΩ ≤ R < 75mΩ & 91mΩ ≤ R < 1Ω 3.10 ±0.10 1.60 ±0.10 0.55 ±0.10 0.45 ±0.20 0.45 ±0.20 75mΩ ≤ R < 91mΩ 3.10±0.10 1.60±0.10 0.55±0.10 0.75±0.20 0.45±0.20 5.00 ±0.10 2.50 ±0.15 0.55 ±0.10 0.60 ±0.20 0.50 ±0.20 6.35 ±0.10 3.20 ±0.15 0.55 ±0.10 0.60 ±0.20 0.50 ±0.20 0.25 ± 0.10 PT2010 (1) PT2512 (1) PE0402 (2) 10mΩ ≤ R ≤ 50mΩ 1.00 ± 0.30 0.50 ± 0.20 0.45 ± 0.20 --- PE0603 (2) 5mΩ ≤ R < 100mΩ 1.60 ± 0.25 0.80 ± 0.25 0.60 ± 0.25 --- 100mΩ ≤ R < 1Ω 4mΩ PE0805 (2) PE1206 (2) 5mΩ 6mΩ 2.00 ± 0.25 1.25 ± 0.25 0.60 ± 0.25 --- PE2512 4mΩ 1.20 ± 0.25 5mΩ ≤ R ≤ 8mΩ 5mΩ ≤ R ≤ 9mΩ 10mΩ ≤ R < 100mΩ 9mΩ ≤ R < 99mΩ 100mΩ 3.20 ± 0.25 1.60 ± 0.25 0.60 ± 0.25 1.15 ± 0.25 0.58 ± 0.25 5.00 ± 0.25 2.50 ± 0.25 0.60 ± 0.25 --- 6.30 ± 0.25 3.10 ± 0.25 0.60 ± 0.25 --- 6.45 ± 0.25 3.25 ± 0.25 0.70 ± 0.25 --- Note: 1. Apply to ordering codes ending in “L” 2. Apply to ordering codes ending in “Z” Please contact sales offices, distributors and representatives in your region before ordering 8 0.55 ± 0.25 0.40 ± 0.25 6mΩ ≤ R ≤ 8mΩ (2) 0.63 ± 0.25 7mΩ ≤ R < 100mΩ 9mΩ ≤ R < 100mΩ PE2010 (2) 0.30 ± 0.25 0.70 ± 0.25 1.50 ± 0.25 0.60 ± 0.25 1.90 ± 0.25 0.95 ± 0.25 0.60 ± 0.25 Type Resistance range 5mΩ PE4527 (2) PR1206 6mΩ ≤ R < 910mΩ (2) 1mΩ ≤ R ≤ 4mΩ PR2010 (2) W H I1 I2 11.50 ± 0.25 7.00 ± 0.25 0.60 ± 0.25 --- 3.20 ± 0.25 1.60 ± 0.25 0.64 ± 0.25 0.50 ± 0.25 0.50 ± 0.25 2.90 ± 0.25 2.60 ± 0.25 1mΩ ≤ R ≤ 3mΩ 5.10 ± 0.25 2.54 ± 0.25 0.80 ± 0.25 1.30 ± 0.25 1.30 ± 0.25 4mΩ 5.10 ± 0.25 2.54 ± 0.25 0.64 ± 0.25 0.80 ± 0.25 0.80 ±0.25 1mΩ ≤ R ≤ 5mΩ 6.50 ± 0.20 3.20 ± 0.20 0.65 ± 0.15 0.90 ± 0.20 0.90 ± 0.20 Current Sensing Chip Resistors PA2512 (1) L Wide terminal Resistance range L W H I1 I2 PE0306 (2) 5mΩ ≤ R ≤ 100mΩ 0.90 ± 0.20 1.70 ± 0.20 0.65 ± 0.20 0.25 ± 0.15 0.25 ± 0.15 PE0508 (2) 3mΩ ≤ R ≤ 100mΩ 1.35 ± 0.20 2.10 ± 0.20 0.65 ± 0.20 0.43 ± 0.15 0.43 ± 0.15 1mΩ 1.60 ± 0.20 3.20 ± 0.20 0.60 ± 0.15 0.55 ± 0.20 0.55 ± 0.20 PE0612 (2) 2mΩ ≤ R ≤ 4mΩ 1.60 ± 0.20 3.20 ± 0.20 0.60 ± 0.15 0.40 ± 0.20 0.40 ± 0.20 5mΩ ≤ R ≤ 300mΩ 1.60 ± 0.20 3.20 ± 0.20 0.60 ± 0.15 0.30 ± 0.20 0.30 ± 0.20 1mΩ 2.50 ± 0.20 3.70 ± 0.20 0.60 ± 0.15 0.95 ± 0.20 0.95 ± 0.20 2mΩ 2.50 ± 0.20 3.70 ± 0.20 0.60 ± 0.15 0.75 ± 0.20 0.75 ± 0.20 3mΩ ≤ R ≤ 100mΩ 2.50 ± 0.20 3.70 ± 0.20 0.60 ± 0.15 0.60 ± 0.20 0.60 ± 0.20 6 / 8 / 10mΩ 2.00 ± 0.20 7.50 ± 0.30 0.60 ± 0.15 0.60 ± 0.15 0.60 ± 0.15 1mΩ ≤ R ≤ 100mΩ (except 6/8/10mΩ) 2.50 ± 0.20 7.50 ± 0.30 0.60 ± 0.15 0.58 ± 0.15 0.58 ± 0.15 PE0815 (2) PE0830 (2) PE1225 (2) 1mΩ 3.10 ± 0.20 6.30 ± 0.20 0.60 ± 0.15 1.15 ± 0.20 1.15 ± 0.20 2mΩ ≤ R ≤ 100mΩ 3.10 ± 0.20 6.30 ± 0.20 0.60 ± 0.15 0.50 ± 0.20 0.50 ± 0.20 Product Portfolio Type 4 terminal D W C PS0306 / PS0508 / PS0612 A L A C C PS1225 A H A unit: mm Type Resistance range L W A D C H PS0306 10mΩ ≤ R ≤ 50mΩ 0.80 ± 0.20 1.60 ± 0.20 0.25 ± 0.20 0.30 ± 0.15 0.30 ± 0.15 0.55 ± 0.20 PS0508 10mΩ ≤ R ≤ 50mΩ 1.25 ± 0.20 2.00 ± 0.20 0.25 ± 0.20 0.20 ± 0.15 0.30 ± 0.20 0.55 ± 0.20 PS0612 (2) 0.5mΩ ≤ R ≤ 100mΩ 1.60 ± 0.20 3.20 ± 0.20 0.45 ± 0.20 0.50 ± 0.20 0.65 ± 0.20 0.60 ± 0.20 PS1225 (2) 3mΩ ≤ R ≤ 100mΩ 3.10 ± 0.20 6.30 ± 0.20 0.80 ± 0.20 --- 2.20 ± 0.20 0.60 ± 0.15 Note: 1. Apply to ordering codes ending in “L” 2. Apply to ordering codes ending in “Z” Please contact sales offices, distributors and representatives in your region before ordering 9 Product Selection Tables T. C. R. - RL series Type T.C.R RL0402 RL0603 RL0805 / RL1206 / RL2010 50mΩ≤R
PT2512FK-7W0R1L 价格&库存
很抱歉,暂时无法提供与“PT2512FK-7W0R1L”相匹配的价格&库存,您可以联系我们找货
PT2512FK-7W0R1L
    • 1+6.08630
    • 100+4.51680
    • 1000+3.22590
    • 2000+2.39450
    • 4000+1.70570
    库存:283
    PT2512FK-7W0R1L
    • 1+1.46300
    • 100+1.17700
    • 1000+1.04610
    • 2000+0.98780
    • 4000+0.93610
    库存:3907
    PT2512FK-7W0R1L
    • 4000+1.708304000+0.22039
    • 8000+1.592818000+0.20549
    • 12000+1.5335112000+0.19784
    • 20000+1.4664220000+0.18918
    • 28000+1.4267628000+0.18407
    库存:1870
    PT2512FK-7W0R1L
    • 1+1.27131
    • 30+1.22591
    • 100+1.18050
    • 500+1.08969
    • 1000+1.04429
    • 2000+1.01705
    PT2512FK-7W0R1L
      库存:4000
      PT2512FK-7W0R1L
      • 10+3.26995
      • 1000+3.19809
      • 2000+3.12832
      库存:3140
      PT2512FK-7W0R1L
      • 1+6.278021+0.80992
      • 10+4.0769710+0.52597
      • 25+3.4703425+0.44771
      • 50+3.0902450+0.39867
      • 100+2.76832100+0.35714
      • 250+2.41418250+0.31145
      • 500+2.19254500+0.28286
      • 1000+2.004331000+0.25858
      库存:1870
