DATA SHEET
CURRENT SENSOR - LOW TCR
PT series
5%, 2%, 1%
sizes 0402/0603/0805/1206/2010/2512
Product specification – December 30, 2015 V.1
RoHS compliant & Halogen free
Chip Resistor Surface Mount
PT
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes PT
series current sensor - low TCR and
high power with lead-free
terminations made by thick film
process.
Part numbers is identified by the series, size, tolerance, packing type,
temperature coefficient, taping reel and resistance value.
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED )
APPLICATIONS
Converters
2
9
SERIES
PT XXXX X X X XX XXXX L
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0402 / 0603 / 0805 / 1206 / 2010 / 2512
Printer equipment
Server board
Telecom
F = ± 1%
Consumer electronics
G = ± 2%
Car electronics
J = ± 5%
(2) TOLERANCE
“-“ = jumper ordering
FEATURES
AEC-Q200 qualified
(3) PACKAGING TYPE
R = Paper taping reel
Halogen Free Epoxy
RoHS compliant
Reduce environmentally
High component and equipment
reliability
Non-forbidden material used in
products/production
07 = 7 inch dia. Reel and standard power
Low resistances applied to
current sensing
7W = 7 inch dia. reel and 2 x standard power
Moisture sensitivity level: MSL 1
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
– = Based on spec.
(5) TAPING REEL
13 = 13 inch dia. Reel and standard power
3W = 13 inch dia. reel and 2 x standard power
(6) RESISTANCE VALUE
There are 3~5 digits indicated the resistor value. Letter R is decimal point.
Detailed coding rules of resistance are shown in the table of “Resistance rule of global
part number”.
(7) DEFAULT CODE
Letter L is system default code for order only (Note)
Resistance rule of global part
number
Resistance code rule
Example
0RXXX
(25 to 910 mΩ)
0R025 = 25 mΩ
0R1 = 100 mΩ
0R91 = 910 mΩ
O RDERING EXAMPLE
The ordering code of a PT0603 chip
resistor, 1/5W, value 0.56 with ±1%
tolerance, supplied in 7-inch tape reel is:
PT0603FR-7W0R56L.
N OTE
1. All our Rchip products meet RoHS
compliant. "LFP" of the internal 2D
reel label mentions "Lead Free
Process"
2. On customized label, "LFP" or specific
symbol printed and the optional "L" at
the end of GLOBAL PART NUMBER
/ 12NC can be added (both are on
customer request)
www.yageo.com
Dec. 30, 2015 V.1
PT
SERIES
3
9
MARKING
PT0402
No marking
Fig. 4
PT0603
E-24 series / Non-E series (R= 250/400/500 mΩ): 3 digits
Fig. 2 Value = 220 mΩ
The “R” is used as a decimal point; the other 2 digits are significant.
PT0805 / PT1206 / PT2010 / PT2512
E-24 series / Non-E series (R= 250/400/500 mΩ): 4 digits
Fig. 3
Value = 220 mΩ
The “R” is used as a decimal point; the other 3 digits are significant.
For further marking information, please refer to data sheet “Chip resistors marking”.
CONSTRUCTION
The resistors are constructed out of a high-grade
ceramic body. Internal metal electrodes are added at
each end and connected by a resistive paste. The
composition of the paste is adjusted to give the
approximately required resistance and laser cutting
of this resistive layer that achieves tolerance trims
the value. The resistive layer is covered with a
protective coat and printed with the resistance value.
Finally, the three external terminations (Cu/Ni/matte tin)
are added, as shown in Fig.5.
OUTLINES
Fig. 5 Chip resistor outlines
www.yageo.com
Dec. 30, 2015 V.1
PT
SERIES
4
9
DIMENSIONS
Table 1
TYPE
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
PT0402
1.00 ± 0.10
0.50 ± 0.05
0.35 ± 0.05
0.20 ± 0.10
0.25 ± 0.10
PT0603
1.60 ± 0.10
0.80 ± 0.10
0.45 ± 0.10
0.25 ± 0.15
0.25 ± 0.15
PT0805
2.00 ± 0.10
1.25 ± 0.10
0.55 ± 0.10
0.35 ± 0.20
0.35 ± 0.20
PT1206
3.10 ± 0.10
1.60 ± 0.10
0.55 ± 0.10
0.45 ± 0.20
0.45 ± 0.20
PT1206(Note)
3.10 ± 0.10
1.60 ± 0.10
0.55 ± 0.10
0.75 ± 0.20
0.45 ± 0.20
PT2010
5.00 ± 0.10
2.50 ± 0.15
0.55 ± 0.10
0.60 ± 0.20
0.50 ± 0.20
PT2512
6.35 ± 0.10
3.20 ± 0.15
0.55 ± 0.10
0.60 ± 0.20
0.50 ± 0.20
Note: For resistance range: 75mΩ ≦ R < 91mΩ
For dimensions, please refer to Table 1
Fig. 6 Chip resistor dimensions
www.yageo.com
Dec. 30, 2015 V.1
PT
SERIES
5
9
ELECTRICAL CHARACTERISTICS
Table 2
Type
PT0402
Power
Operating
Temp. range
Max working
voltage
Tolerance
1/16W
1/8 W
1/10W
PT0603
1/5 W
1/3 W
1/8 W
PT0805
1/4 W
1/4 W
PT1206
1/2 W
PT2010
PT2512
-55°C to +155°C
(PxR)^1/2
Temperature Coefficient of
Resistance
50mΩ ≦ R<68mΩ
68mΩ ≦ R<100mΩ
100mΩ ≦ R<1Ω
±600ppm/°C
±300ppm/°C
±200ppm/°C
50mΩ
50mΩ <R<68mΩ
68mΩ ≦ R<100mΩ
100mΩ ≦ R<1Ω
0/+400ppm/°C
0/+350ppm/°C
0/+300ppm/°C
±200ppm/°C
50mΩ
50mΩ <R<68mΩ
68mΩ
0/+400ppm/°C
0/+350ppm/°C
0/+300ppm/°C
50mΩ
50mΩ <R<68mΩ
68mΩ ≦ R<100mΩ
100mΩ ≦ R<1Ω
0/+350ppm/°C
0/+300ppm/°C
0/+250ppm/°C
±100ppm/°C
50mΩ ≦ R < 75mΩ
75mΩ ≦ R≦ 100mΩ
100mΩ <R<1Ω
±350ppm/°C
±100ppm/°C
±75ppm/°C
E24 ±2%, ±5%
E24/E96 ±1%
3/4 W
1W
1W
2W
Jumper criteria
Max. resistance 10mΩ
Rated current
3A
-Max. resistance
Rated current
8mΩ
5A
Max. resistance
Rated current
5mΩ
6A
Max. resistance
Rated current
5mΩ
10A
100 mΩ
100 mΩ < R < 1 Ω
±100 ppm/°C
±75 ppm/°C
www.yageo.com
Dec. 30, 2015 V.1
PT
6
9
SERIES
FOOTPRINT AND SOLDERING PROFILES
Recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
Paper taping reel (R)
Embossed taping reel (K)
REEL
DIMENSION
PT0402
PT0603
PT0805
PT1206
PT2010
PT2512
7" (178 mm)
10,000
5,000
5,000
5,000
13" (330 mm)
50,000
20,000
20,000
20,000
7" (178 mm)
4,000
4,000
NOTE
1. For paper/embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”.
FUNCTIONAL DESCRIPTION
OPERATING TEMPERATURE RANGE
Range: –55 °C to +155 °C
POWER RATING
Each type rated power at 70 °C:
PT0402=1/16W, 1/8W
PT0603=1/10W, 1/5W, 1/3W
PT0805=1/8W, 1/4W
PT1206=1/4W, 1/2W
PT2010=3/4W, 1W
PT2512=1W, 2W
R ATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
Fig. 7 Maximum dissipation (P max ) in percentage of rated power
as a function of the operating ambient temperature (T amb)
V = √(P X R)
Where
V = Continuous rated DC or AC (rms) working
voltage (V)
P = Rated power (W)
R = Resistance value (Ω)
www.yageo.com
Dec. 30, 2015 V.1
PT
SERIES
7
9
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
Temperature
Coefficient of
Resistance (T.C.R.)
MIL-STD-202 Method 304
At +25/+125 °C
REQUIREMENTS
Refer to table 2
Formula:
R2–R1
T.C.R= ------------------------- × 106 (ppm/°C)
R1(t2–t1)
Where
t1=+25 °C or specified room temperature
t2=+125 °C test temperature
R1=resistance at reference temperature in ohms
R2=resistance at test temperature in ohms
Life/
Endurance
MIL-STD-202 Method 108A
High Temperature
Exposure
IEC 60115-1 4.25.1
IEC 60068-2-2
1,000 hours at 70± 2 °C applied RCWV
1.5 hours on, 0.5 hour off, still air required
± (1.0%+0.0005 Ω)
1,000 hours at maximum operating temperature
depending on specification, unpowered
± (1.0%+0.0005 Ω)
No direct impingement of forced air to the parts
Tolerances: 155± 3 °C
Moisture Resistance
MIL-STD-202 Method 106
Each temperature / humidity cycle is defined at 8
hours (method 106F), 3 cycles / 24 hours for
10d with 25 °C / 65 °C 95% R.H, without steps
7a & 7b, unpowered
± (0.5%+0.0005 Ω)
Parts mounted on test-boards, without
condensation on parts
Measurement at 24± 2 hours after
test conclusion
Thermal Shock
MIL-STD-202 Method 107
-55/+125 °C
± (1.0%+0.0005 Ω)
Number of cycles required is 300. Maximum
Devices mounted:
transfer time is 20 seconds. Dwell time is 15
minutes. Air – Air
www.yageo.com
Dec. 30, 2015 V.1
TEST
Short Time
Overload
TEST METHOD
IEC60115-1 4.13
PT
SERIES
PROCEDURE
PT standard power: 2.5 times rated voltage for
5 sec at room temperature
8
9
REQUIREMENTS
± (1.0%+0.0005 Ω)
No visible damage
PT high power: 5 times rated power for 5 sec
at room temperature
PT jumper: 2.5 times rated current for 5 sec at
room temperature
Board Flex/
Bending
IEC 60115-1 4.33
Device mounted on PCB test board as
described, only 1 board bending required
± (1.0%+0.0005 Ω)
No visible damage
Bending for 0402: 5 mm
0603/0805: 3 mm
1206 and above: 2 mm
Holding time: minimum 60± 1 seconds
Ohmic value checked during bending
Solderability
- Wetting
J-STD-002 test B
Electrical Test not required
Magnification 50X
Well tinned (≥95% covered)
No visible damage
SMD conditions:
1st step: method B, aging 4 hours at 155 °C
dry heat
2nd step: leadfree solder bath at 245± 3 °C
Dipping time: 3± 0.5 seconds
- Leaching
J-STD-002 test D
Leadfree solder, 260 °C, 30 seconds
immersion time
No visible damage
- Resistance to
Soldering Heat
IEC 60115-1 4.18
Condition B, no pre-heat of samples.
± (0.5%+0.0005 Ω)
Leadfree solder, 260± 5 °C, 10± 1 seconds
immersion time
No visible damage
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
www.yageo.com
Dec. 30, 2015 V.1
PT
SERIES
9
9
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 1
Jul. 02, 2015
- Extend resistor value
Version 0
Aug. 21, 2014
- New datasheet for current sensor - low TCR PT series sizes of
0402/0603/0805/1206/2010/2512, 1%, 2%, 5% with lead-free
termination
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any
product change will be announced by PCN.”
www.yageo.com
Dec. 30, 2015 V.1
