EKZH250ETD102MJ201
EKZH250ETD102MJ201
    NCC(贵弥功)
    插件,D10xL20mm
    直插铝电解电容 插件,D10xL20mm 1mF ±20% Ф10.00 x 20.00mm 25V 6000Hrs@105℃
EKZH250ETD102MJ201 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS KZH Low impedance, 105℃ KZM P5-24 Series Longer life KZH ・Newly innovative electrolyte is employed to minimize impedance ・Endurance with ripple current: 5,000 to 6,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant Lower Z KZE P5-29 ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ 6.3 to 35Vdc ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V tanδ(Max.) 0.22 0.19 0.16 0.14 0.12 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. Z (-25℃) / Z (+20℃) 2max. Z (-40℃) / Z (+20℃) 3max. Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage)for the specified period of time at 105℃. Time φ5 &φ6.3 : 5,000hoursφ8 to φ16 : 6,000hours Capacitance change ≦±25% of the initial value (6.3, 10Vdc :≦±30%) D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±25% of the initial value (6.3, 10Vdc :≦±30%) D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life φd Sleeve (PET : Brown) F±0.5 Code : E φD' ●Terminal F±0.5 ◆DIMENSIONS [mm] L' Vent (Exceptφ5 &φ6.3) 15min 4min (φ5 to φ10) (φ12.5 to φ16) φD φd F φD' L' 5 0.5 2.0 6.3 0.5 2.5 10 12.5 8 0.6 0.6 0.6 3.5 5.0 5.0 φD+0.5max. L+1.5max. 16 0.8 7.5 Gas escape end seal ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KZH AAA E AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470, 100µF:101, 1,000µF:102) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3, 35V:350) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 5-27 CAT. No. E1001R MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KZHSeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 6.3 10 16 220 470 820 1,200 1,200 1,500 1,800 2,200 2,700 3,900 4,700 5,600 6,800 6,800 8,200 150 330 680 1,000 1,000 1,500 1,500 1,800 2,200 3,300 3,900 4,700 4,700 5,600 6,800 100 220 470 680 680 1,000 1,000 1,500 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 12.5×35 16×20 16×25 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 0.24 0.11 0.062 0.048 0.045 0.033 0.032 0.020 0.018 0.017 0.015 0.013 0.012 0.015 0.013 0.24 0.11 0.062 0.048 0.045 0.033 0.032 0.020 0.018 0.017 0.015 0.013 0.015 0.012 0.013 0.24 0.11 0.062 0.048 0.045 0.033 0.032 0.020 0.80 0.35 0.19 0.15 0.14 0.11 0.10 0.060 0.054 0.043 0.038 0.033 0.031 0.038 0.035 0.80 0.35 0.19 0.15 0.14 0.11 0.10 0.060 0.054 0.043 0.038 0.033 0.038 0.031 0.035 0.80 0.35 0.19 0.15 0.14 0.11 0.10 0.060 330 500 900 1,210 1,240 1,410 1,650 1,960 2,250 2,480 2,900 3,450 3,570 3,250 3,630 330 500 900 1,210 1,240 1,410 1,650 1,960 2,250 2,480 2,900 3,450 3,250 3,570 3,630 330 500 900 1,210 1,240 1,410 1,650 1,960 WV (Vdc) Part No. Cap (µF) Case size φD×L(mm) 20℃ EKZH6R3E□□221ME11D EKZH6R3E□□471MF11D EKZH6R3E□□821MHB5D EKZH6R3E□□122MH15D EKZH6R3E□□122MJC5S EKZH6R3E□□152MH20D EKZH6R3E□□182MJ16S EKZH6R3E□□222MJ20S EKZH6R3E□□272MJ25S EKZH6R3E□□392MK20S EKZH6R3E□□472MK25S EKZH6R3E□□562MK30S EKZH6R3E□□682MK35S EKZH6R3E□□682ML20S EKZH6R3E□□822ML25S EKZH100E□□151ME11D EKZH100E□□331MF11D EKZH100E□□681MHB5D EKZH100E□□102MH15D EKZH100E□□102MJC5S EKZH100E□□152MH20D EKZH100E□□152MJ16S EKZH100E□□182MJ20S EKZH100E□□222MJ25S EKZH100E□□332MK20S EKZH100E□□392MK25S EKZH100E□□472MK30S EKZH100E□□472ML20S EKZH100E□□562MK35S EKZH100E□□682ML25S EKZH160E□□101ME11D EKZH160E□□221MF11D EKZH160E□□471MHB5D EKZH160E□□681MH15D EKZH160E□□681MJC5S EKZH160E□□102MH20D EKZH160E□□102MJ16S EKZH160E□□152MJ20S 16 25 35 1,800 2,200 2,700 3,300 3,300 3,900 4,700 68 150 330 390 470 560 680 820 1,000 1,500 1,800 2,200 2,200 2,700 3,300 47 100 220 270 330 390 470 560 680 1,000 1,200 1,500 1,500 1,800 2,200 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.018 0.017 0.015 0.013 0.015 0.012 0.013 0.24 0.11 0.062 0.048 0.045 0.033 0.032 0.020 0.018 0.017 0.015 0.013 0.015 0.012 0.013 0.24 0.11 0.062 0.048 0.045 0.033 0.032 0.020 0.018 0.017 0.015 0.013 0.015 0.012 0.013 0.054 0.043 0.038 0.033 0.038 0.031 0.035 0.80 0.35 0.19 0.15 0.14 0.11 0.10 0.060 0.054 0.043 0.038 0.033 0.038 0.031 0.035 0.80 0.35 0.19 0.15 0.14 0.11 0.10 0.060 0.054 0.043 0.038 0.033 0.038 0.031 0.035 2,250 2,480 2,900 3,450 3,250 3,570 3,630 330 500 900 1,210 1,240 1,410 1,650 1,960 2,250 2,480 2,900 3,450 3,250 3,570 3,630 330 500 900 1,210 1,240 1,410 1,650 1,960 2,250 2,480 2,900 3,450 3,250 3,570 3,630 Part No. EKZH160E□□182MJ25S EKZH160E□□222MK20S EKZH160E□□272MK25S EKZH160E□□332MK30S EKZH160E□□332ML20S EKZH160E□□392MK35S EKZH160E□□472ML25S EKZH250E□□680ME11D EKZH250E□□151MF11D EKZH250E□□331MHB5D EKZH250E□□391MH15D EKZH250E□□471MJC5S EKZH250E□□561MH20D EKZH250E□□681MJ16S EKZH250E□□821MJ20S EKZH250E□□102MJ25S EKZH250E□□152MK20S EKZH250E□□182MK25S EKZH250E□□222MK30S EKZH250E□□222ML20S EKZH250E□□272MK35S EKZH250E□□332ML25S EKZH350E□□470ME11D EKZH350E□□101MF11D EKZH350E□□221MHB5D EKZH350E□□271MH15D EKZH350E□□331MJC5S EKZH350E□□391MH20D EKZH350E□□471MJ16S EKZH350E□□561MJ20S EKZH350E□□681MJ25S EKZH350E□□102MK20S EKZH350E□□122MK25S EKZH350E□□152MK30S EKZH350E□□152ML20S EKZH350E□□182MK35S EKZH350E□□222ML25S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Capacitance(µF) 0.47 220 680 2,200 4,700 to to to to to 150 560 1,800 3,900 8,200 120 0.40 0.50 0.60 0.75 0.85 1k 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 5-28 CAT. No. E1001R
EKZH250ETD102MJ201 价格&库存
很抱歉,暂时无法提供与“EKZH250ETD102MJ201”相匹配的价格&库存,您可以联系我们找货
EKZH250ETD102MJ201
  • 5+1.52880
  • 20+1.39230
  • 100+1.25580
  • 500+1.11930
  • 1000+1.05560
  • 2000+1.01010
库存:110
