R
UMW
SMD Type
UMW AO3401A
M SFET
P-Channel Enhancement MOSFET
SOT–23
■ Features
● VDS (V) =-30V
● ID =-4.2 A (VGS =-10V)
● RDS(ON) < 55mΩ (VGS =-10V)
● RDS(ON) < 70mΩ (VGS =-4.5V)
● RDS(ON) < 120mΩ (VGS =-2.5V)
1. GATE
2. SOURCE
3. DRAIN
D
G
S
■ Absolute Maximum Ratings Ta = 25℃
Symbol
Rating
Drain-Source Voltage
Parameter
VDS
-30
Gate-Source Voltage
VGS
±12
Continuous Drain Current
Ta = 25℃
ID
Ta = 70℃
Pulsed Drain Current
Power Dissipation
IDM
Ta = 25℃
PD
Ta = 70℃
Thermal Resistance.Junction- to-Ambient t ≤ 10s
RthJA
-3.5
1.4
1
W
90
125
60
TJ
150
Junction and Storage Temperature Range
Tstg
-55 to 150
1
A
-30
RthJC
www.umw-ic.com
V
-4.2
Junction Temperature
Thermal Resistance.Junction- to-Case
Unit
℃/W
友台半导体有限公司
UMW
R
UMW AO3401A
■ Electrical Characteristics Ta = 25℃
Parameter
Symbol
Drain-Source Breakdown Voltage
VDSS
Zero Gate Voltage Drain Current
IDSS
Gate-Body leakage current
Gate Threshold Voltage
Test Conditions
Min
Typ
-30
ID=-250μA, VGS=0V
VDS=-24V, VGS=0V
-1
VDS=-24V, VGS=0V, TJ=55℃
-5
IGSS
VDS=0V, VGS=±12V
VGS(th)
VDS=VGS ID=-250μA
On state drain current
Forward Transconductance
RDS(On)
ID(ON)
gFS
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Gate resistance
Rg
Total Gate Charge
Qg
Gate Source Charge
Qgs
VGS=-10V, ID=-4.2A
-0.4
65
VGS=-2.5V, ID=-1A
120
VGS=-4.5V, VDS=-5V
VDS=-5V, ID=-5A
-25
7
77
VGS=0V, VDS=0V, f=1MHz
6
Ω
9.4
VGS=-4.5V, VDS=-15V, ID=-4A
VGS=-10V, VDS=-15V, RL=3.6Ω,RGEN=6Ω
nC
2
3.2
ns
38.3
12
Turn-Off Fall Time
tf
Body Diode Reverse Recovery Time
trr
IF=-4A, dI/dt=100A/μs
20.2
Body Diode Reverse Recovery Charge
Qrr
IF=5A, dI/dt=100A/μs
11.2
Maximum Body-Diode Continuous Current
IS
www.umw-ic.com
pF
115
3
VSD
S
954
VGS=0V, VDS=-15V, f=1MHz
6.3
Diode Forward Voltage
mΩ
A
11
Qgd
tr
V
VGS=-4.5V, ID=-4A
td(on)
td(off)
nA
-1.3
50
Turn-On DelayTime
Turn-Off DelayTime
μA
±100
75
TJ=125℃
Gate Drain Charge
Turn-On Rise Time
Unit
V
VGS=-10V, ID=-4.2A
Static Drain-Source On-Resistance
Max
IS=-1A,VGS=0V
2
-0.75
nC
-2.2
A
-1
V
友台半导体有限公司
UMW
R
UMW AO3401A
■ Typical Characterisitics
10
25.00
-10V
V DS =-5V
-4.5V
20.00
8
6
-ID(A)
-ID (A)
-3V
15.00
-2.5V
10.00
V GS =-2V
5.00
0.00
0.00
125°C
4
25°C
2
2.00
3.00
4.00
5.00
120
Normalized On-Resistance
RDS(ON) (mΩ)
1.5
2
2.5
3
1.8
100
80
V GS =-2.5V
V GS =-4.5V
60
40
V GS =-10V
ID=-3.5A, VGS=-4.5V
1.6
ID=-3.5A, VGS=-10V
1.4
V GS =-2.5V
1.2
ID=-1A
1
0.8
2.00
4.00
6.00
8.00
10.00
-ID (A)
Figure 3: On-Resistance vs. Drain Current and
Gate Voltage
25
50
75
100
125
150
175
Temperature (°C)
Figure 4: On-Resistance vs. Junction
Temperature
1.0E+01
190
170
1.0E+00
150
I D=-2A
1.0E-01
130
125°C
-IS (A)
RDS(ON) (mΩ)
1
-VGS(Volts)
Figure 2: Transfer Characteristics
-VDS (Volts)
Fig 1: On-Region Characteristics
110
90
125°C
70
1.0E-02
1.0E-03
25°C
1.0E-04
50
25°C
1.0E-05
30
1.0E-06
10
4
6
8
0.0
10
www.umw-ic.com
0.2
0.4
0.6
0.8
1.0
1.2
-VSD (Volts)
Figure 6: Body-Diode Characteristics
-VGS (Volts)
Figure 5: On-Resistance vs. Gate-Source Voltage
3
友台半导体有限公司
UMW
R
UMW AO3401A
1400
5
V DS =-15V
ID =-4A
1200
Capacitance (pF)
-VGS (Volts)
4
3
2
1000
C iss
800
600
400
C oss
1
C rss
200
4
6
8
10
12
-Qg (nC)
Figure 7: Gate-Charge Characteristics
T J(Max) =150°C
T A =25°C
10
15
30
-VDS (Volts)
Figure 8: Capacitance Characteristics
40
T J(Max) =150°C
T A =25°C
10 µs
R DS(ON)
10.0 limited
30
100 µs
Power (W)
-ID (Amps)
100.0
5
1ms
0.1s
10ms
1.0
1s
10s
DC
0.1
0.1
1
10
100
Figure 9: Maximum Forward Biased Safe
Operating Area (Note E)
ZθJA Normalized Transient
Thermal Resistance
10
D=T on /T
T J,PK =T A +P DM .ZθJA .RθJA
R θJA =90°C/W
0.01
0.1
1
10
100
1000
Pulse Width (s)
Figure 10: Single Pulse Power Rating Junction-toAmbient (Note E)
-VDS (Volts)
In descending order
D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, single pulse
1
PD
0.1
T on
T
Single Pulse
0.01
0.00001
0.0001
0.001
0.01
0.1
1
10
100
1000
Pulse Width (s)
Figure 11: Normalized Maximum Transient Thermal Impedance
www.umw-ic.com
4
友台半导体有限公司
很抱歉,暂时无法提供与“UMW AO3401A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12225
- 200+0.11365
- 600+0.10504
- 3000+0.09643
