UMW
R
UMW TLP785
Photocoupler
GaAs IRED & Photo −Transistor
Unit: mm
TLP785
Office Equipment
Household Appliances
Solid State Relays
Switching Power Supplies
Various Controllers
Signal Transmission Between Different Voltage
Circuits
The UMW TLP785 consists of a silicone phototransistor optically
coupled to a gallium arsenide (GaAs) infrared emitting diode in a four
lead plastic DIP (DIP4) with having high isolation voltage
(AC: 5kVRMS (min)).
Weight: 0.32 g (typ.)
Collector-emitter voltage: 80V (min.)
Current transfer ratio: 50% (min.)
TLP785
Unit: mm
Rank GB: 100% (min.)
Isolation voltage: 5000Vrms (min.)
UL approved: UL1577, file No. E492440
Pin Configurations
(top view)
1
4
2
3
1 : Anode
2 : Cathode
3 : Emitter
4 : Collector
Weight:
www.umw-ic.com
1
0.31g (typ.)
友台半导体有限公司
UMW
R
UMW TLP785
Current Transfer Ratio
Type
TLP785
Classification
(Note 1)
Current Transfer Ratio (%)
(IC / IF)
IF = 5mA, VCE = 5V, Ta = 25°C
Min
Max
Marking of Classification
None
50
600
Blank
Rank Y
50
150
YE
Rank GR
100
300
GR
Rank BL
200
600
BL
Rank GB
100
600
GB
Rank YH
75
150
Y+
Rank GRL
100
200
G
Rank GRH
150
300
G+
Rank BLL
200
400
B
(Note 1): Ex. rank GB: TLP785 (GB)
(Note 2): Application type name for certification test, please use standard product type name, i. e.
TLP785 (GB): TLP785
Absolute Maximum Ratings (Ta = 25°C)
Characteristic
Symbol
Rating
Unit
IF
60
mA
ΔIF / °C
−0.7
mA / °C
IFP
1
A
PD
100
mW
ΔPD / °C
−0.9
mW / °C
Reverse voltage
VR
5
V
Junction temperature
Tj
125
°C
Collector−emitter voltage
VCEO
80
V
Emitter−collector voltage
VECO
7
V
Collector current
IC
80
mA
Power dissipation (single circuit)
PC
150
mW
ΔPC / °C
−1.5
mW / °C
Tj
125
°C
Operating temperature range
Topr
−55 to 110
°C
Storage temperature range
Tstg
−55 to 125
°C
Lead soldering temperature (10s)
Tsol
260
°C
Total package power dissipation
PT
200
mW
ΔPT / °C
−2.4
mW / °C
BVS
5000
Vrms
Forward current
Forward current derating (Ta ≥ 39°C)
LED
Pulse forward current
(Note 3)
Power dissipation
Detector
Power dissipation derating
(Ta ≥ 25°C)
Total package power dissipation derating
(Ta ≥ 25°C)
Isolation voltage
(Note 4)
(Note 3): 100 μs pulse, 100 Hz frequency
(Note 4): AC, 1 min., R.H.≤ 60%. Apply voltage to LED pin and detector pin together.
www.umw-ic.com
2
友台半导体有限公司
UMW
R
UMW TLP785
Recommended Operating Conditions (Note)
Characteristic
Symbol
Min
Typ.
Max
Unit
Supply voltage
VCC
5
24
V
Forward current
IF
16
25
mA
Collector current
IC
1
10
mA
Topr
−25
85
°C
(Note): Recommended operating conditions are given as a design guideline
to obtain expected performance of the device.
Additionally, each item is an independent guideline respectively.
In developing designs using this product, please confirm
specified characteristics shown in this document.
Individual Electrical Characteristics (Ta = 25°C)
Detector
LED
Characteristic
Test Condition
Symbol
Min
Typ.
Max
Unit
Forward voltage
VF
IF = 10 mA
1.0
1.15
1.3
V
Reverse current
IR
VR = 5 V
10
μA
Capacitance
CT
V = 0V, f = 1 MHz
30
pF
Collector−emitter
breakdown voltage
V(BR) CEO
IC = 0.5 mA
80
V
Emitter−collector
breakdown voltage
V(BR) ECO
IE = 0.1 mA
7
V
VCE = 24 V
0.01
0.1
μA
VCE = 24 V ,Ta = 85°C
0.6
50
μA
V = 0V, f = 1 MHz
6
pF
Min
Typ.
Max
Unit
50
600
100
600
60
30
0.4
0.2
0.4
Min
Typ.
Max
Unit
0.8
pF
Ω
Collector dark current
Capacitance
(collector to emitter)
ID(ICEO)
CCE
Coupled Electrical Characteristics (Ta = 25°C)
Characteristic
Saturated CTR
Test Condition
Symbol
IC / IF
IC / IF (sat)
IF = 5 mA, VCE = 5 V
IF = 1 mA, VCE = 0.4 V
Rank GB
Rank GB
IC = 2.4 mA, IF = 8 mA
Collector−emitter saturation
voltage
VCE (sat)
IC = 0.2 mA, IF = 1 mA
Rank GB
V
Isolation Characteristics (Ta = 25°C)
Characteristic
Symbol
Test Condition
Capacitance
(input to output)
CS
VS = 0V, f = 1 MHz
Isolation resistance
RS
VS = 500 V
AC, 1 minute
Isolation voltage
www.umw-ic.com
BVS
12
1×10
10
14
5000
AC, 1 second, in oil
10000
DC, 1 minute, in oil
10000
3
Vrms
Vdc
友台半导体有限公司
UMW
R
UMW TLP785
Switching Characteristics (Ta = 25°C)
Characteristics
Symbol
Rise time
tr
Fall time
tf
Turn−on time
ton
Turn−off time
toff
Turn−on time
ton
Storage time
ts
Turn−off time
toff
Test Condition
VCC = 10 V, IC = 2 mA
RL = 100Ω
RL = 1.9 kΩ
VCC = 5 V, IF = 16 mA
(fig. 1)
Min
Typ.
Max
2
3
3
3
1.5
25
50
Unit
μs
μs
IF
IF
RL
VCC
ts
VCE
VCC
4.5V
VCE
0.5V
ton
toff
(fig. 1): Switching time test circuit
www.umw-ic.com
4
友台半导体有限公司
UMW
R
UMW TLP785
1. Product Naming System
Type of package used for shipment is denoted by a symbol suffix after a product number. The method of
classification is as below.
(Example)
TLP785 (BL− S
SMD
CTR Rank
Device name
2. Tape Dimensions
2.1 Orientation of Device in Relation to Direction of Tape Movement
Device orientation in the recesses is as shown in Figure 2.
Tape feed
1pin indication
Figure2 Device Orientation
2.2 Tape Packing Quantity:2000 devices per reel
www.umw-ic.com
5
友台半导体有限公司
UMW
R
UMW TLP785
I F - Ta
100
P C - Ta
200
PC (mW)
This curve shows the maximum
limit to the forward current.
60
Collector power dissipation
Forward current
I F (mA)
80
40
60
Ambient temperature
80
Ta
100
120
160
120
80
40
maximum limit to the
collector power dissipation.
80
Ambient temperature
(˚C)
Ta
100
120
(˚C)
IF-VF
∆ V F / ∆ Ta - I F
100
-3
Ta=25˚C
(mA)
-2.6
10
IF
-2.2
-1.8
Forward current
Forward voltage temperature coefficient
ΔVF/ΔTa (mV/°C)
40
-1.4
-1
1
0.1
-0.6
0.1
1
Forward current
10
IF
0.4
100
(mA)
0.9
1.4
Forward voltage
VF
1.9
(V)
IFP – VFP
1000
Pulse width≤10μs
(mA)
Repetitive frequency=100Hz
IFP
100
Ta=25°C
10
1
0.8
1.2
Pulse forward voltage
www.umw-ic.com
6
1.6
VFP
2
2.4
(V)
友台半导体有限公司
UMW
R
UMW TLP785
IC-VCE
I C E O - Ta
10
80
Ta=25˚C
(mA)
1
60
50
30
IC
0.1
Collector current
ID (mA)
VCE =24V
0.01
0.001
40
10
I F= 2 m A
0.0001
60
Ambient temperature
80
100
4
6
8
Ta (°C)
VCE
10
(V)
IC-IF
IC-VCE
100
40
Ta=25˚C
Ta=25˚C
30
Collector current IC
Collector current
(mA)
30
IC
(mA)
50
15
5
10
10
1
I F= 2 m A
0.4
0.6
0.8
1
VCE
0.1
1.2
(V)
VCE=5V
VCE=0.4V
0.01
0.1
1
10
IC/IF -IF
VCE
100
(V)
1000
IC / IF (%)
Ta=25˚C
100
10
VCE=5V
VCE=0.4V
1
0.1
1
Forward current
www.umw-ic.com
10
IF
100
(mA)
7
友台半导体有限公司
UMW
R
UMW TLP785
I C - Ta
V C E ( s a t ) - Ta
100
0.2
IF=5mA,
Collector-Emitter saturation Voltage
VCE(sat) (V)
(mA)
10
5
10
1
1
IF=0.5mA
VCE=5V
IC=1mA
0.16
0.12
0.08
0.04
-40
-20
Ambient temperature
60
Ta
80
-40
100
-20
Ambient temperature
(°C)
60
Ta
80
100
(°C)
Switching time - RL
1000
Ta=25˚C
IF=16mA
VCC=5V
toff
Switching time
(μs)
100
ts
10
ton
1
1
10
Load resistance
www.umw-ic.com
100
RL (kΩ)
8
友台半导体有限公司
很抱歉,暂时无法提供与“UMW TLP785GB-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.38870
- 20+0.35420
- 100+0.31970
- 500+0.28520
- 1000+0.26910
- 2000+0.25760
