74AVC4T774PW
4-bit dual supply translating transceiver; 3-state
Rev. 1 — 25 September 2017
1
Product data sheet
General description
The 74AVC4T774PW is a 4-bit, dual supply transceiver that enables bidirectional level
translation. It features eight 1-bit input-output ports (An and Bn), four direction control
inputs (DIR1, DIR2, DIR3 and DIR4), an output enable input (OE) and dual supply pins
(VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any voltage between
0.8 V and 1.95 V for translating between the 0.8 V, 1.2 V, 1.5 V and 1.8 V supply voltage
nodes or 1.1 V to 3.6 V for translating between the 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V
supply voltage nodes. Pins An, OE and DIRn are referenced to VCC(A) and pins Bn are
referenced to VCC(B). A HIGH on DIRn allows transmission from An to Bn and a LOW on
DIRn allows transmission from Bn to An. The output enable input (OE) can be used to
disable the outputs so the buses are effectively isolated.
The device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing any damaging backflow current through the
device when it is powered down. In suspend mode when either VCC(A) or VCC(B) are at
GND level, both An and Bn are in the high-impedance OFF-state.
2
Features and benefits
• Wide supply voltage range:
– VCC(A) and VCC(B): 0.8 V to 1.95 V or 1.1 V to 3.6 V
• Complies with JEDEC standards:
– JESD8-12 (0.8 V to 1.3 V)
– JESD8-11 (0.9 V to 1.65 V)
– JESD8-7 (1.2 V to 1.95 V)
– JESD8-5 (1.8 V to 2.7 V)
– JESD8-B (2.7 V to 3.6 V)
• ESD protection:
– HBM JESD22-A114E Class 3B exceeds 8000 V
– CDM JESD22-C101C exceeds 1500 V
• Maximum data rates:
– 380 Mbit/s (≥ 1.8 V to 3.3 V translation)
– 200 Mbit/s (≥ 1.1 V to 3.3 V translation)
– 200 Mbit/s (≥ 1.1 V to 2.5 V translation)
– 200 Mbit/s (≥ 1.1 V to 1.8 V translation)
– 150 Mbit/s (≥ 1.1 V to 1.5 V translation)
– 100 Mbit/s (≥ 1.1 V to 1.2 V translation)
• Suspend mode
• Latch-up performance exceeds 100 mA per JESD 78 Class II
• Inputs accept voltages up to 3.6 V
• IOFF circuitry provides partial Power-down mode operation
74AVC4T774PW
Nexperia
• Specified from -40 °C to +85 °C and -40 °C to +125 °C
3
Ordering information
Table 1. Ordering information
Type number
74AVC4T774PW
4
Package
Temperature range Name
Description
Version
-40 °C to +125 °C
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
TSSOP16
Marking
Table 2. Marking codes
Type number
Marking code
74AVC4T774PW
VC4T774
5
Functional diagram
B1
B2
B3
B4
VCC(B)
VCC(A)
OE
A1 DIR1
A2 DIR2
A3 DIR3
A4 DIR4
001aao069
Figure 1. Logic symbol
OE
An
DIRn
Bn
VCC(A)
VCC(B)
to next transceiver
001aao070
Figure 2. Logic diagram (one 1-bit transceiver)
74AVC4T774PW
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 24
74AVC4T774PW
Nexperia
6
Pinning information
6.1 Pinning
74AVC4T774
DIR1
1
DIR2
2
16 VCC(A)
15 VCC(B)
A1
3
14 B1
A2
4
13 B2
A3
5
12 B3
A4
6
11 B4
DIR3
7
10 GND
DIR4
8
9
OE
aaa-027528
Figure 3. Pin configuration SOT403-1 (TSSOP16)
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
VCC(A)
16
supply voltage A (An, OE and DIRn inputs are referenced to VCC(A))
DIR1, DIR2, DIR3, DIR4 1, 2, 7, 8
direction control input
A1, A2, A3, A4
3, 4, 5, 6
data input or output
GND
10
ground (0 V)
B1, B2, B3, B4
14, 13, 12, 11
OE
9
output enable input (active LOW)
VCC(B)
15
supply voltage B (Bn pins are referenced to VCC(B))
74AVC4T774PW
Product data sheet
3 / 24
74AVC4T774PW
Nexperia
7
Functional description
Table 4. Function table
[1] [2]
Supply voltage
Input
VCC(A), VCC(B)
OE
DIR1
DIR2
DIR3
DIR4
An
Bn
0.8 V to 3.6 V
L
L
X
X
X
A1 = B1
input B1
0.8 V to 3.6 V
L
H
X
X
X
input A1
B1 = A1
0.8 V to 3.6 V
L
X
L
X
X
A2 = B2
input B2
0.8 V to 3.6 V
L
X
H
X
X
input A2
B2 = A2
0.8 V to 3.6 V
L
X
X
L
X
A3 = B3
input B3
0.8 V to 3.6 V
L
X
X
H
X
input A3
B3 = A3
0.8 V to 3.6 V
L
X
X
X
L
A4 = B4
input B4
0.8 V to 3.6 V
L
X
X
X
H
input A4
B4 = A4
0.8 V to 3.6 V
H
X
X
X
X
Z
Z
[3]
X
X
X
X
X
Z
Z
GND
Input/output
[1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
[2] The An, DIRn and OE input circuit is referenced to VCC(A); The Bn input circuit is referenced to VCC(B).
[3] If at least one of VCC(A) or VCC(B) is at GND level, the device goes into suspend mode.
8
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC(A)
Conditions
Min
Max
Unit
supply voltage A
-0.5
+4.6
V
VCC(B)
supply voltage B
-0.5
+4.6
V
IIK
input clamping current
-50
-0.5
+4.6
-50
[1] [2] [3]
-0.5
VCCO + 0.5
V
Suspend or 3-state mode
[1]
-0.5
+4.6
V
[2]
±50
mA
100
mA
-100
mA
-65
+150
°C
500
mW
VI < 0 V
[1]
VI
input voltage
IOK
output clamping current
VO < 0 V
VO
output voltage
Active mode
IO
output current
VO = 0 V to VCCO
ICC
supply current
ICC(A) or ICC(B)
IGND
ground current
Tstg
storage temperature
Ptot
[1]
[2]
[3]
[4]
total power dissipation
Tamb = -40 °C to +125 °C
[4]
mA
V
mA
The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed.
VCCO is the supply voltage associated with the output port.
VCCO + 0.5 V should not exceed 4.6 V.
For TSSOP16 package: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
74AVC4T774PW
Product data sheet
4 / 24
74AVC4T774PW
Nexperia
9
Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
VCC(A)
Min
Max
Unit
supply voltage A
0.8
3.6
V
VCC(B)
supply voltage B
0.8
3.6
V
VI
input voltage
V
VCCO
V
V
-40
+125
°C
10
VO
Conditions
output voltage
Active mode
[1]
Tamb
Δt/ΔV
ambient temperature
input transition rise and fall rate
VCCI =0.8 V to 3.6 V
[2]
ns/V
[1] VCCO is the supply voltage associated with the output port.
[2] VCCI is the supply voltage associated with the input port.
10 Static characteristics
Table 7. Typical static characteristics at Tamb = 25 °C
[1] [2]
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VOH
VOL
Conditions
Min
Typ
Max
VI = VIH or VIL
HIGH-level
output voltage
IO = -1.5 mA; VCC(A) = VCC(B) = 0.8 V
0.69
V
VI = VIH or VIL
LOW-level
output voltage
IO = 1.5 mA; VCC(A) = VCC(B) = 0.8 V
0.07
V
±0.025
±0.25
μA
[3]
±0.5
±2.5
μA
[3]
±0.5
±2.5
μA
[3]
±0.5
±2.5
μA
II
input leakage DIRn, OE input; VI = 0 V or 3.6 V;
current
VCC(A) = VCC(B) = 0.8 V to 3.6 V
IOZ
A or B port; VO = 0 V or VCCO; VCC(A) = VCC(B) = 3.6 V
OFF-state
output current
suspend mode A port; VO = 0 V or VCCO;
Unit
VCC(A) = 3.6 V; VCC(B) = 0 V
suspend mode B port; VO = 0 V or VCCO;
VCC(A) = 0 V; VCC(B) = 3.6 V
power-off
leakage
current
A port; VI or VO = 0 V to 3.6 V; VCC(A) = 0 V;
±0.1
±1
μA
B port; VI or VO = 0 V to 3.6 V; VCC(B) = 0 V;
VCC(A) = 0.8 V to 3.6 V
±0.1
±1
μA
CI
input
capacitance
DIRn, OE input; VI = 0 V or 3.3 V; VCC(A) = VCC(B) = 3.3 V
2.0
pF
CI/O
input/output
capacitance
A and B port; VO = 3.3 V or 0 V; VCC(A) = VCC(B) = 3.3 V
4.0
pF
IOFF
[2] VCCI is the supply voltage associated with the data input port.
[3] For I/O ports, the parameter IOZ includes the input leakage current.
74AVC4T774PW
Product data sheet
5 / 24
74AVC4T774PW
Nexperia
Table 8. Static characteristics
[1] [2]
Symbol
VIH
Parameter
HIGH-level
input voltage
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Max
Min
Max
VCCI = 0.8 V
0.70VCCI
0.70VCCI
V
VCCI = 1.1 V to 1.95 V
0.65VCCI
0.65VCCI
V
VCCI = 2.3 V to 2.7 V
1.6
1.6
V
VCCI = 3.0 V to 3.6 V
2
2
V
VCC(A) = 0.8 V
0.70VCC(A)
0.70VCC(A)
V
VCC(A) = 1.1 V to 1.95 V
0.65VCC(A)
0.65VCC(A)
V
VCC(A) = 2.3 V to 2.7 V
1.6
1.6
V
VCC(A) = 3.0 V to 3.6 V
2
2
V
VCCI = 0.8 V
0.30VCCI
0.30VCCI
V
0.35VCCI
0.35VCCI
V
0.7
0.7
V
0.8
0.8
V
VCC(A) = 0.8 V
0.30VCC(A)
0.30VCC(A) V
0.35VCC(A)
0.35VCC(A) V
0.7
0.7
V
0.8
0.8
V
VCCO - 0.1
VCCO - 0.1
V
IO = -3 mA;
VCC(A) = VCC(B) = 1.1 V
0.85
0.85
V
IO = -6 mA;
VCC(A) = VCC(B) = 1.4 V
1.05
1.05
V
IO = -8 mA;
VCC(A) = VCC(B) = 1.65 V
1.2
1.2
V
IO = -9 mA;
VCC(A) = VCC(B) = 2.3 V
1.75
1.75
V
IO = -12 mA;
VCC(A) = VCC(B) = 3.0 V
2.3
2.3
V
data input
DIRn, OE input
VIL
LOW-level
input voltage
data input
DIRn, OE input
VOH
HIGH-level
output voltage
74AVC4T774PW
Product data sheet
VI = VIH or VIL
IO = -100 μA;
6 / 24
74AVC4T774PW
Nexperia
Symbol
VOL
Parameter
LOW-level
output voltage
II
IOZ
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Max
Min
Max
IO = 100 μA;
0.1
0.1
V
IO = 3 mA;
0.25
0.25
V
IO = 6 mA;
0.35
0.35
V
IO = 8 mA;
0.45
0.45
V
IO = 9 mA;
0.55
0.55
V
IO = 12 mA;
0.7
0.7
V
±1
±5
μA
[3]
±5
±30
μA
VCCO; VCC(A) = 3.6 V; VCC(B) = 0 V
[3]
±5
±30
μA
VCCO; VCC(A) = 0 V; VCC(B) = 3.6 V
[3]
±5
±30
μA
VCC(A) = 0 V; VCC(B) = 0.8 V to 3.6 V
±5
±30
μA
VCC(B) = 0 V; VCC(A) = 0.8 V to 3.6 V
±5
±30
μA
VI = VIH or VIL
current
OFF-state
output current VCC(A) = VCC(B) = 3.6 V
IOFF
power-off
leakage
current
74AVC4T774PW
Product data sheet
7 / 24
74AVC4T774PW
Nexperia
Symbol
ICC
Parameter
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Max
Min
Max
VCC(A) = 0.8 V to 3.6 V;
10
55
μA
VCC(A) = 1.1 V to 3.6 V;
VCC(B) = 1.1 V to 3.6 V
8
50
μA
8
50
μA
-2
-12
μA
10
55
μA
8
50
μA
-2
-12
μA
8
50
μA
μA
16
65
μA
500
650
μA
supply current A port; VI = 0 V or VCCI; IO = 0 A
B port; VI = 0 V or VCCI; IO = 0 A
A plus B port (ICC(A) + ICC(B));
IO = 0 A; VI = 0 V or VCCI;
ΔICC
additional
VI = 3.0 V; VCC(A) = VCC(B) = 3.6 V
supply current
Table 9. Typical total supply current (ICC(A) + ICC(B))
VCC(A)
VCC(B)
Unit
0V
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
0V
0.1
0.1
0.1
0.1
0.1
μA
0.8 V
0.1
0.1
0.1
0.1
0.1
0.3
1.6
μA
1.2 V
0.1
0.1
0.1
0.1
0.1
0.1
0.8
μA
1.5 V
0.1
0.1
0.1
0.1
0.1
0.1
0.4
μA
1.8 V
0.1
0.1
0.1
0.1
0.1
0.1
0.2
μA
2.5 V
0.1
0.3
0.1
0.1
0.1
0.1
0.1
μA
3.3 V
0.1
1.6
0.8
0.4
0.2
0.1
0.1
μA
74AVC4T774PW
Product data sheet
8 / 24
74AVC4T774PW
Nexperia
11 Dynamic characteristics
Table 10. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 °C
[1] [2]
Symbol
CPD
Parameter
Conditions
VCC(A) = VCC(B)
power dissipation
A port: (direction An to Bn);
capacitance
output enabled
Unit
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
0.2
0.2
0.2
0.2
0.3
0.4
pF
0.2
0.2
0.2
0.2
0.3
0.4
pF
9.5
9.7
9.8
9.9
10.7
11.9
pF
0.6
0.6
0.6
0.6
0.7
0.7
pF
9.5
9.7
9.8
9.9
10.7
11.9
pF
0.6
0.6
0.6
0.6
0.7
0.7
pF
0.2
0.2
0.2
0.2
0.3
0.4
pF
0.2
0.2
0.2
0.2
0.3
0.4
pF
output disabled
A port: (direction Bn to An);
output enabled
output disabled
B port: (direction An to Bn);
output enabled
output disabled
B port: (direction Bn to An);
output enabled
output disabled
[1] CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC × fi x N + Σ(CL x VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of the outputs.
[2] fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = ∞ Ω.
74AVC4T774PW
Product data sheet
9 / 24
74AVC4T774PW
Nexperia
Table 11. Typical dynamic characteristics at VCC(A) = 0.8 V and Tamb = 25 °C
[1]
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6; for waveforms see Figure 4 and Figure 5
Symbol
tpd
tdis
ten
Parameter
Conditions
VCC(B)
Unit
0.8 V
1.2 V
1.5 V
1.8 V
propagation delay An to Bn
14.5
7.3
6.5
6.2
ns
Bn to An
14.5
12.7
12.4
12.3
ns
OE to An
14.3
14.3
14.3
14.3
ns
OE to Bn
17.0
9.9
9.0
9.4
ns
OE to An
18.2
18.2
18.2
18.2
ns
OE to Bn
19.2
10.7
9.8
9.6
ns
disable time
enable time
[1] tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH.
Table 12. Typical dynamic characteristics at VCC(B) = 0.8 V and Tamb = 25 °C
[1]
Symbol
tpd
tdis
ten
Parameter
Conditions
VCC(A)
Unit
0.8 V
1.2 V
1.5 V
1.8 V
14.5
12.7
12.4
12.3
ns
Bn to An
14.5
7.3
6.5
6.2
ns
OE to An
14.3
5.5
4.1
4.0
ns
OE to Bn
17.0
13.8
13.4
13.1
ns
OE to An
18.2
5.6
4.0
3.2
ns
OE to Bn
19.2
14.6
14.1
13.9
ns
disable time
enable time
74AVC4T774PW
Product data sheet
10 / 24
74AVC4T774PW
Nexperia
Table 13. Dynamic characteristics for temperature range -40 °C to +85 °C
[1]
Symbol
Parameter
Conditions
VCC(B)
Unit
1.2 V ±0.1 V
1.5 V ±0.1 V
1.8 V ±0.15 V
2.5 V ±0.2 V
3.3 V ±0.3 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
VCC(A) = 1.1 V to 1.3 V
tpd
tdis
ten
propagation
An to Bn
2.0
10.5
1.3
7.8
1.2
6.9
1.0
5.9
0.8
5.7
ns
delay
Bn to An
2.0
10.5
1.5
9.9
1.5
9.7
1.4
9.4
1.4
9.3
ns
disable time
OE to An
2.0
10.0
2.0
10.0
2.0
10.0
2.0
10.0
2.0
10.0
ns
OE to Bn
2.0
11.1
2.0
8.6
1.0
8.0
0.7
7.0
1.0
8.0
ns
OE to An
2.0
13.5
2.0
13.5
2.0
13.5
2.0
13.5
2.0
13.5
ns
OE to Bn
2.0
15.0
2.0
11.0
2.0
9.4
1.0
7.8
1.0
7.4
ns
propagation
An to Bn
1.5
9.9
1.0
7.1
1.0
6.0
0.5
4.8
0.5
4.3
ns
delay
Bn to An
1.3
7.8
1.0
7.1
0.9
6.9
0.8
6.6
0.6
6.5
ns
disable time
OE to An
1.0
6.0
1.0
6.0
1.0
6.0
1.0
6.0
1.0
6.0
ns
OE to Bn
2.0
10.2
1.5
7.5
0.9
7.2
0.4
6.2
0.4
6.1
ns
OE to An
1.0
7.5
1.0
7.5
1.0
7.5
1.0
7.5
1.0
7.5
ns
OE to Bn
2.0
14.4
1.4
7.9
1.3
7.7
1.1
6.4
1.1
5.6
ns
enable time
VCC(A) = 1.4 V to 1.6 V
tpd
tdis
ten
enable time
VCC(A) = 1.65 V to 1.95 V
tpd
tdis
ten
propagation
An to Bn
1.5
9.7
0.9
6.9
0.8
5.7
0.5
4.5
0.3
4.0
ns
delay
Bn to An
1.2
6.9
1.0
6.0
0.8
5.7
0.5
5.5
0.5
5.3
ns
disable time
OE to An
0.5
5.7
0.5
5.7
0.5
5.7
0.5
5.7
0.5
5.7
ns
OE to Bn
2.0
9.9
1.5
7.0
0.8
6.9
0.2
5.8
0.2
5.9
ns
OE to An
1.0
6.7
1.0
6.7
1.0
6.7
1.0
6.7
1.0
6.7
ns
OE to Bn
1.5
13.9
1.2
7.2
1.2
6.9
0.8
5.4
0.6
5.0
ns
propagation
An to Bn
1.4
9.4
0.8
6.6
0.5
5.5
0.4
4.2
0.2
3.7
ns
delay
Bn to An
1.0
5.9
0.5
4.8
0.5
4.5
0.4
4.2
0.3
3.9
ns
disable time
OE to An
0.2
4.0
0.2
4.0
0.2
4.0
0.2
4.0
0.2
4.0
ns
OE to Bn
2.0
9.3
1.5
6.7
0.7
6.3
0.2
5.0
0.2
5.7
ns
OE to An
0.6
4.5
0.6
4.5
0.6
4.5
0.6
4.5
0.6
4.5
ns
OE to Bn
1.5
13.6
1.0
6.8
1.0
6.0
0.8
4.6
0.6
4.2
ns
enable time
tpd
tdis
ten
enable time
74AVC4T774PW
Product data sheet
11 / 24
74AVC4T774PW
Nexperia
Symbol
Parameter
Conditions
VCC(B)
Unit
1.2 V ±0.1 V
1.5 V ±0.1 V
1.8 V ±0.15 V
2.5 V ±0.2 V
3.3 V ±0.3 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
tpd
tdis
ten
propagation
An to Bn
1.4
9.3
0.6
6.5
0.5
5.3
0.3
3.9
0.2
3.5
ns
delay
Bn to An
0.8
5.7
0.5
4.3
0.3
4.0
0.2
3.7
0.2
3.5
ns
disable time
OE to An
0.2
4.5
0.2
4.5
0.2
4.5
0.2
4.5
0.2
4.5
ns
OE to Bn
2.0
9.0
1.5
6.4
0.7
6.1
0.2
4.8
0.2
5.6
ns
OE to An
0.5
4.0
0.5
4.0
0.5
4.0
0.5
4.0
0.5
4.0
ns
OE to Bn
1.5
13.4
1.0
6.7
1.0
5.9
0.7
4.4
0.5
4.0
ns
enable time
Table 14. Dynamic characteristics for temperature range -40 °C to +125 °C
[1]
Symbol
Parameter
Conditions
VCC(B)
Unit
1.2 V ±0.1 V
1.5 V ±0.1 V
1.8 V ±0.15 V
2.5 V ±0.2 V
3.3 V ±0.3 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
tpd
tdis
ten
propagation
An to Bn
2.0
12.1
1.3
9.0
1.2
8.0
1.0
6.8
0.8
6.6
ns
delay
Bn to An
2.0
12.1
1.5
11.4
1.5
11.2
1.4
10.9
1.4
10.7
ns
disable time
OE to An
2.0
11.5
2.0
11.5
2.0
11.5
2.0
11.5
2.0
11.5
ns
OE to Bn
2.0
12.8
2.0
9.9
1.0
9.2
0.7
8.1
1.0
9.2
ns
OE to An
2.0
15.6
2.0
15.6
2.0
15.6
2.0
15.6
2.0
15.6
ns
OE to Bn
2.0
17.3
2.0
12.7
2.0
10.9
1.0
9.0
1.0
8.6
ns
propagation
An to Bn
1.5
11.4
1.0
8.2
1.0
6.9
0.5
5.6
0.5
5.0
ns
delay
Bn to An
1.3
9.0
1.0
8.2
0.9
8.0
0.8
7.6
0.6
7.5
ns
disable time
OE to An
1.0
6.9
1.0
6.9
1.0
6.9
1.0
6.9
1.0
6.9
ns
OE to Bn
2.0
11.8
1.5
8.7
0.9
8.3
0.4
7.2
0.4
7.1
ns
OE to An
1.0
8.7
1.0
8.7
1.0
8.7
1.0
8.7
1.0
8.7
ns
OE to Bn
2.0
16.6
1.4
9.1
1.3
8.9
1.1
7.4
1.1
6.5
ns
enable time
tpd
tdis
ten
enable time
74AVC4T774PW
Product data sheet
12 / 24
74AVC4T774PW
Nexperia
Symbol
Parameter
Conditions
VCC(B)
Unit
1.2 V ±0.1 V
1.5 V ±0.1 V
1.8 V ±0.15 V
2.5 V ±0.2 V
3.3 V ±0.3 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
tpd
tdis
ten
propagation
An to Bn
1.5
11.2
0.9
8.0
0.8
6.6
0.5
5.2
0.3
4.6
ns
delay
Bn to An
1.2
8.0
1.0
6.9
0.8
6.6
0.5
6.4
0.5
6.1
ns
disable time
OE to An
0.5
6.6
0.5
6.6
0.5
6.6
0.5
6.6
0.5
6.6
ns
OE to Bn
2.0
11.4
1.5
8.1
0.8
8.0
0.2
6.7
0.2
6.8
ns
OE to An
1.0
7.8
1.0
7.8
1.0
7.8
1.0
7.8
1.0
7.8
ns
OE to Bn
1.5
16.0
1.2
8.3
1.2
8.0
0.8
6.3
0.6
5.8
ns
propagation
An to Bn
1.4
10.9
0.8
7.6
0.5
6.4
0.4
4.9
0.2
4.3
ns
delay
Bn to An
1.0
6.8
0.5
5.6
0.5
5.2
0.4
4.9
0.3
4.5
ns
disable time
OE to An
0.2
4.6
0.2
4.6
0.2
4.6
0.2
4.6
0.2
4.6
ns
OE to Bn
2.0
10.7
1.5
7.8
0.7
7.3
0.2
5.8
0.2
6.6
ns
OE to An
0.6
5.2
0.6
5.2
0.6
5.2
0.6
5.2
0.6
5.2
ns
OE to Bn
1.5
15.7
1.0
7.9
1.0
6.9
0.8
5.3
0.6
4.9
ns
propagation
An to Bn
1.4
10.7
0.6
7.5
0.5
6.1
0.3
4.5
0.2
4.1
ns
delay
Bn to An
0.8
6.6
0.5
5.0
0.3
4.6
0.2
4.3
0.2
4.1
ns
disable time
OE to An
0.2
5.2
0.2
5.2
0.2
5.2
0.2
5.2
0.2
5.2
ns
OE to Bn
2.0
10.4
1.5
7.4
0.7
7.1
0.2
5.6
0.2
6.5
ns
OE to An
0.5
4.6
0.5
4.6
0.5
4.6
0.5
4.6
0.5
4.6
ns
OE to Bn
1.5
15.5
1.0
7.8
1.0
6.8
0.7
5.1
0.5
4.6
ns
enable time
tpd
tdis
ten
enable time
tpd
tdis
ten
enable time
11.1 Waveforms and test circuit
VI
An, Bn input
VM
GND
tPHL
tPLH
VOH
Bn, An output
VM
VOL
001aao074
Measurement points are given in Table 15.
VOL and VOH are typical output voltage levels that occur with the output load.
Figure 4. The data input (An, Bn) to output (Bn, An) propagation delay times
74AVC4T774PW
Product data sheet
13 / 24
74AVC4T774PW
Nexperia
VI
VM
OE input
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
VCCO
VM
VX
VOL
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
tPZH
VOH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aao075
Figure 5. Enable and disable times
Table 15. Measurement points
[1]
[2]
Supply voltage
Input
VCC(A), VCC(B)
VM
VM
VX
VY
0.8 V to 1.6 V
0.5VCCI
0.5VCCO
VOL + 0.1 V
VOH - 0.1 V
1.65 V to 2.7 V
0.5VCCI
0.5VCCO
VOL + 0.15 V
VOH - 0.15 V
3.0 V to 3.6 V
0.5VCCI
0.5VCCO
VOL + 0.3 V
VOH - 0.3 V
Output
[1] VCCI is the supply voltage associated with the data input port.
[2] VCCO is the supply voltage associated with the output port.
74AVC4T774PW
Product data sheet
14 / 24
74AVC4T774PW
Nexperia
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
VM
VM
10 %
0V
tW
VEXT
VCC
VI
G
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 16.
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 6. Test circuit for measuring switching times
Table 16. Test data
Supply voltage
Input
[1]
VCC(A), VCC(B)
VI
0.8 V to 1.6 V
VCCI
1.65 V to 2.7 V
3.0 V to 3.6 V
Load
Δt/ΔV
[2]
VEXT
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
≤ 1.0 ns/V
15 pF
2 kΩ
open
GND
2VCCO
VCCI
≤ 1.0 ns/V
15 pF
2 kΩ
open
GND
2VCCO
VCCI
≤ 1.0 ns/V
15 pF
2 kΩ
open
GND
2VCCO
[3]
[2] dV/dt ≥ 1.0 V/ns
[3] VCCO is the supply voltage associated with the output port.
74AVC4T774PW
Product data sheet
15 / 24
74AVC4T774PW
Nexperia
11.2 Typical propagation delay characteristics
aaa-026797
24
tpd
(ns)
(1)
(2)
(3)
(4)
tpd
(ns)
(1)
aaa-026798
21
17
16
12
8
4
13
(2)
(3)
(4)
CL (pF)
60
9
CL (pF)
a. Propagation delay (A to B); VCC(A) = 0.8 V
b. Propagation delay (A to B); VCC(B) = 0.8 V
(1) VCC(B) = 0.8 V
(1) VCC(A) = 0.8 V
(2) VCC(B) = 1.2 V
(2) VCC(A) = 1.2 V
(3) VCC(B) = 1.5 V
(3) VCC(A) = 1.5 V
(4) VCC(B) = 1.8 V
(4) VCC(A) = 1.8 V
60
Figure 7. Typical propagation delay versus load capacitance; Tamb = 25 °C
74AVC4T774PW
Product data sheet
16 / 24
74AVC4T774PW
Nexperia
001aai478
7
tPLH
(ns)
001aai491
7
(1)
tPHL
(ns)
(2)
5
(1)
5
(3)
(2)
(3)
(4)
(4)
(5)
(5)
3
1
3
CL (pF)
1
60
a. LOW to HIGH propagation delay (A to B); VCC(A) = 1.2 V
(1)
tPLH
(ns)
CL (pF)
60
b. HIGH to LOW propagation delay (A to B); VCC(A) = 1.2 V
001aai479
7
001aai480
7
tPHL
(ns)
(1)
5
5
(2)
(3)
(2)
(3)
(4)
(5)
3
1
CL (pF)
(4)
(5)
3
60
c. LOW to HIGH propagation delay (A to B); VCC(A) = 1.5 V
1
CL (pF)
60
d. HIGH to LOW propagation delay (A to B); VCC(A) = 1.5 V
(1) VCC(B) = 1.2 V
(2) VCC(B) = 1.5 V
(3) VCC(B) = 1.8 V
(4) VCC(B) = 2.5 V
(5) VCC(B) = 3.3 V
Figure 8. Typical propagation delay versus load capacitance; Tamb = 25 °C
74AVC4T774PW
Product data sheet
17 / 24
74AVC4T774PW
Nexperia
001aai481
7
(1)
tPLH
(ns)
5
001aai482
7
tPHL
(ns)
(1)
5
(2)
(3)
(3)
(4)
3
1
(2)
(5)
CL (pF)
1
60
a. LOW to HIGH propagation delay (A to B); VCC(A) = 1.8 V
tPLH
(ns)
CL (pF)
60
b. HIGH to LOW propagation delay (A to B); VCC(A) = 1.8 V
001aai483
7
(4)
(5)
3
001aai486
7
tPHL
(ns)
(1)
5
(1)
5
(2)
(2)
(3)
(3)
(4)
3
3
(4)
(5)
(5)
1
CL (pF)
60
c. LOW to HIGH propagation delay (A to B); VCC(A) = 2.5 V
1
CL (pF)
60
d. HIGH to LOW propagation delay (A to B); VCC(A) = 2.5 V
(1) VCC(B) = 1.2 V
(2) VCC(B) = 1.5 V
(3) VCC(B) = 1.8 V
(4) VCC(B) = 2.5 V
(5) VCC(B) = 3.3 V
Figure 9. Typical propagation delay versus load capacitance; Tamb = 25 °C
74AVC4T774PW
Product data sheet
18 / 24
74AVC4T774PW
Nexperia
001aai485
7
tPLH
(ns)
001aai484
7
tPHL
(ns)
(1)
5
(1)
5
(2)
(2)
(3)
(3)
3
3
(4)
(4)
(5)
(5)
1
CL (pF)
60
a. LOW to HIGH propagation delay (A to B); VCC(A) = 3.3 V
1
CL (pF)
60
b. HIGH to LOW propagation delay (A to B); VCC(A) = 3.3 V
(1) VCC(B) = 1.2 V
(2) VCC(B) = 1.5 V
(3) VCC(B) = 1.8 V
(4) VCC(B) = 2.5 V
(5) VCC(B) = 3.3 V
Figure 10. Typical propagation delay versus load capacitance; Tamb = 25 °C
74AVC4T774PW
Product data sheet
19 / 24
74AVC4T774PW
Nexperia
12 Package outline
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Figure 11. Package outline SOT403-1 (TSSOP16)
74AVC4T774PW
Product data sheet
20 / 24
74AVC4T774PW
Nexperia
13 Abbreviations
Table 17. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
14 Revision history
Table 18. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AVC4T774PW v.1
20170925
Product sheet
74AVC4T774PW
Product data sheet
21 / 24
74AVC4T774PW
Nexperia
15 Legal information
15.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74AVC4T774PW
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
22 / 24
74AVC4T774PW
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74AVC4T774PW
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
23 / 24
74AVC4T774PW
Nexperia
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
11.1
11.2
12
13
14
15
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 2
Marking .................................................................2
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 3
Functional description ........................................4
Limiting values .................................................... 4
Recommended operating conditions ................ 5
Static characteristics .......................................... 5
Dynamic characteristics .....................................9
Waveforms and test circuit .............................. 13
Typical propagation delay characteristics ........ 16
Package outline .................................................20
Abbreviations .................................................... 21
Revision history ................................................ 21
Legal information .............................................. 22
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 25 September 2017
Document identifier: 74AVC4T774PW
