74HC594-Q100; 74HCT594-Q100
8-bit shift register with output register
Rev. 2 — 13 June 2016
Product data sheet
1. General description
The 74HC594-Q100; 74HCT594-Q100 is a high-speed Si-gate CMOS device and is pin
compatible with Low-Power Schottky TTL (LSTTL).
The 74HC594-Q100; 74HCT594-Q100 is an 8-bit, non-inverting, serial-in, parallel-out shift
register that feeds an 8-bit D-type storage register. Separate clocks (SHCP and STCP)
and direct overriding clears (SHR and STR) are provided on both the shift and storage
registers. A serial output (Q7S) is provided for cascading purposes.
Both the shift and storage register clocks are positive-edge triggered. If both clocks are
connected together, the shift register is always one count pulse ahead of the storage
register.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Synchronous serial input and output
Complies with JEDEC standard No.7A
8-bit parallel output
Shift and storage registers have independent direct clear and clocks
Independent clocks for shift and storage registers
100 MHz (typical)
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
3. Applications
Serial-to parallel data conversion
Remote control holding register
Nexperia
4. Ordering information
Table 1.
Type number
Package
74HC594D-Q100
Temperature range
Name
Description
Version
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
40 C to +125 C
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
74HCT594D-Q100
74HC594PW-Q100
5. Functional diagram
'6
6+&3
67$*(6+,)75(*,67(5
6+5
67&3
675
%,76725$*(5(*,67(5
4 4 4 4 4 4 4 4
Fig 1.
46
PEF
Functional diagram
6+&3 67&3
675
'6
6+5
Fig 2.
Logic symbol
74HC_HCT594_Q100
Product data sheet
46
6+5
5
5 65*
4
4
4
4
4
4
4
4
67&3
6+&3
'6
675
PEF
4
4
4
4
4
4
4
4
46
PEF
Fig 3.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 25
Nexperia
67$*(672
67$*(
'6
4
67$*(
4
46
4
))6+
))6+
&3
&3
5
5
6+&3
6+5
4
))67
4
))67
&3
&3
5
5
67&3
675
4
Fig 4.
4 4 4 4 4 4
4
PEF
Logic diagram
6+&3
'6
67&3
6+5
675
4
4
4
4
46
PEF
Fig 5.
Timing diagram
74HC_HCT594_Q100
Product data sheet
3 of 25
Nexperia
6. Pinning information
6.1 Pinning
+&4
+&74
4
9&&
4
4
4
'6
4
675
4
67&3
4
6+&3
4
6+5
*1'
+&4
46
4
4
9&&
4
4
'6
4
675
4
67&3
4
6+&3
4
6+5
*1'
DDD
Fig 6.
46
DDD
Pin configuration SO16
Fig 7.
Pin configuration TSSOP16
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7
15, 1, 2, 3, 4, 5, 6, 7
parallel data output
GND
8
ground (0 V)
Q7S
9
serial data output
SHR
10
shift register reset (active LOW)
SHCP
11
shift register clock input
STCP
12
storage register clock input
STR
13
storage register reset (active LOW)
DS
14
serial data input
VCC
16
supply voltage
74HC_HCT594_Q100
Product data sheet
4 of 25
Nexperia
7. Functional description
Table 3.
Function table[1]
Function
Input
SHR
STR
SHCP STCP
DS
Clear shift register
L
X
X
X
X
Clear storage register
X
L
X
X
X
Load DS into shift register stage 0, advance previous stage data to the next stage
H
X
X
H or L
Transfer shift register data to storage register and outputs Qn
X
H
X
X
Shift register one count pulse ahead of storage register
H
H
X
[1]
H = HIGH voltage level; L = LOW voltage level; = LOW-to-HIGH transition; X = don’t care.
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7.0
V
mA
mA
Serial data output Q7S
25
mA
Parallel data output
35
mA
50
mA
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = 0.5 V to VCC + 0.5 V
IIK
ICC
supply current
IGND
ground current
total power dissipation
Ptot
[2]
70
mA
50
mA
70
mA
65
+150
C
500
mW
storage temperature
Tstg
[1]
Tamb = 40 C to +125 C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SO16 package: above 70 C the value of Ptot derates linearly with 8 mW/K.
For TSSOP16 package: Ptot derates linearly with 5.5 mW/K above 60 C.
74HC_HCT594_Q100
Product data sheet
5 of 25
Nexperia
9. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
2.0
5.0
6.0
V
Type 74HC594-Q100
VCC
supply voltage
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
tr
rise time
VCC = 2.0 V
1000
ns
fall time
tf
VCC = 4.5 V
6.0
500
ns
VCC = 6.0 V
400
ns
VCC = 2.0 V
1000
ns
VCC = 4.5 V
6.0
500
ns
VCC = 6.0 V
400
ns
4.5
5.0
5.5
V
VCC
V
Type 74HCT594-Q100
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
tr
rise time
tf
fall time
VCC
V
40
+25
+125
C
VCC = 4.5 V
6.0
500
ns
VCC = 4.5 V
6.0
500
ns
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
10. Static characteristics
Table 6.
Static characteristics type 74HC594-Q100
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Tamb = 25 C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
VCC = 6.0 V
4.2
3.2
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
IO = 4.0 mA; VCC = 4.5 V
3.98
4.32
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
V
IO = 6.0 mA; VCC = 4.5 V
3.98
4.32
V
IO = 7.8 mA; VCC = 6.0 V
5.48
5.81
V
VI = VIH or VIL
Parallel data outputs
74HC_HCT594_Q100
Product data sheet
6 of 25
Nexperia
Table 6.
Static characteristics type 74HC594-Q100 …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VOL
LOW-level output voltage
VI = VIH or VIL
0.15
0.26
V
0.16
0.26
V
0.15
0.26
V
0.16
0.26
V
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
0.1
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
A
Ci
input capacitance
3.5
pF
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
Tamb = 40 C to +85 C
VIH
VIL
VOH
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
3.84
V
5.34
V
3.84
V
5.34
V
0.33
V
0.33
V
0.33
V
0.33
V
VI = VIH or VIL
VOL
VI = VIH or VIL
II
1.0
A
ICC
supply current
VCC = 6.0 V
80
A
74HC_HCT594_Q100
Product data sheet
7 of 25
Nexperia
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
3.7
V
5.2
V
3.7
V
5.2
V
0.4
V
0.4
V
0.4
V
0.4
V
VIH
VIL
VOH
V
VI = VIH or VIL
VOL
VI = VIH or VIL
II
1.0
A
ICC
supply current
VCC = 6.0 V
160
A
74HC_HCT594_Q100
Product data sheet
8 of 25
Nexperia
Table 7.
Static characteristics type 74HCT594-Q100
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Tamb = 25 C
VIH
VCC = 4.5 V to 5.5 V
2.0
1.6
V
VIL
1.2
0.8
V
VOH
VI = VIH or VIL
3.98
4.32
V
3.98
4.32
V
0.15
0.26
V
VOL
VI = VIH or VIL
0.16
0.26
V
II
VI = VCC or GND; VCC = 5.5 V
0.1
A
ICC
supply current
VCC = 5.5 V
8.0
A
ICC
additional supply current
per input pin; VI = VCC 2.1 V and
other inputs at VCC or GND;
IO = 0 A; VCC = 4.5 V to 5.5 V
pins SHR, SHCP, STCP, STR
150
540
A
pin DS
25
90
A
3.5
pF
2.0
V
0.8
V
3.84
V
3.84
V
0.33
V
0.33
V
Ci
input capacitance
VIH
VIL
VOH
VI = VIH or VIL
VOL
VI = VIH or VIL
Serial data output
II
1.0
A
ICC
supply current
VCC = 5.5 V
80
A
74HC_HCT594_Q100
Product data sheet
9 of 25
Nexperia
Table 7.
Static characteristics type 74HCT594-Q100 …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICC
675
A
pin DS
112.5
A
VIH
2.0
V
VIL
0.8
V
VOH
VI = VIH or VIL
3.7
V
3.7
V
0.4
V
0.4
V
VOL
VI = VIH or VIL
II
1.0
A
ICC
supply current
VCC = 5.5 V
160
A
ICC
735
A
pin DS
122.5
A
74HC_HCT594_Q100
Product data sheet
10 of 25
Nexperia
11. Dynamic characteristics
Table 8.
Dynamic characteristics type 74HC594-Q100
GND = 0 V; tr = tf = 6 ns; CL = 50 pF; see Figure 14.
Symbol Parameter
tpd
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
44
150
185
225
ns
VCC = 4.5 V
16
30
37
45
ns
VCC = 5.0 V;
CL = 15 pF
13
ns
VCC = 6.0 V
14
26
31
38
ns
VCC = 2.0 V
44
150
185
225
ns
VCC = 4.5 V
16
30
37
45
ns
VCC = 5.0 V;
CL = 15 pF
13
ns
VCC = 6.0 V
14
26
31
38
ns
HIGH to LOW SHR to Q7S;
propagation
see Figure 12
delay
VCC = 2.0 V
39
150
185
225
ns
VCC = 4.5 V
14
30
37
45
ns
VCC = 5.0 V;
CL = 15 pF
11
ns
VCC = 6.0 V
12
26
31
38
ns
39
125
155
185
ns
VCC = 4.5 V
14
25
31
37
ns
VCC = 5.0 V;
CL = 15 pF
11
ns
VCC = 6.0 V
12
21
26
31
ns
19
75
95
110
ns
7
15
19
22
ns
6
13
16
19
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
VCC = 6.0 V
4
10
13
15
ns
[1]
propagation d SHCP to Q7S;
elay
see Figure 8
STCP to Qn;
see Figure 9
tPHL
STR to Qn;
see Figure 13
VCC = 2.0 V
tTHL
HIGH to LOW see Figure 8
output
transition
VCC = 2.0 V
time
VCC = 4.5 V
VCC = 6.0 V
74HC_HCT594_Q100
Product data sheet
11 of 25
Nexperia
Table 8.
Dynamic characteristics type 74HC594-Q100 …continued
Symbol Parameter
tTLH
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
19
75
95
110
ns
7
15
19
22
ns
6
13
16
19
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
VCC = 6.0 V
4
10
13
15
ns
VCC = 2.0 V
80
10
100
120
ns
VCC = 4.5 V
16
4
ns
VCC = 6.0 V
14
3
17
ns
VCC = 2.0 V
80
10
100
120
ns
VCC = 4.5 V
16
4
ns
VCC = 6.0 V
14
3
17
ns
VCC = 2.0 V
80
14
100
120
ns
VCC = 4.5 V
16
5
ns
VCC = 6.0 V
14
4
17
ns
VCC = 2.0 V
100
10
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
3
21
26
ns
VCC = 2.0 V
100
14
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
4
21
26
ns
VCC = 2.0 V
100
17
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
5
21
26
ns
LOW to HIGH see Figure 8
output
transition
VCC = 2.0 V
time
VCC = 4.5 V
VCC = 6.0 V
tW
pulse width
SHCP (HIGH or
LOW); see Figure 8
STCP (HIGH or
LOW); see Figure 9
SHR and STR (HIGH
or LOW);
see Figure 12 and
Figure 13
tsu
set-up time
DS to SHCP;
see Figure 10
SHR to STCP;
see Figure 11
SHCP to STCP;
see Figure 9
74HC_HCT594_Q100
Product data sheet
12 of 25
Nexperia
Table 8.
Symbol Parameter
th
trec
fmax
hold time
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
25
8
30
35
ns
VCC = 4.5 V
5
3
6
7
ns
VCC = 6.0 V
4
2
5
6
ns
DS to SHCP;
see Figure 10
recovery time SHR to SHCP and
STR to STCP;
see Figure 12 and
Figure 13
maximum
frequency
VCC = 2.0 V
50
14
65
75
ns
VCC = 4.5 V
10
5
13
15
ns
VCC = 6.0 V
9
4
11
13
ns
VCC = 2.0 V
6.0
30
4.8
4.0
MHz
VCC = 4.5 V
30
92
24
MHz
VCC = 5.0 V;
CL = 15 pF
100
MHz
35
109
28
24
MHz
84
pF
SHCP or STCP;
see Figure 8 and
Figure 9
VCC = 6.0 V
CPD
[1]
[2]
power
dissipation
capacitance
VI = GND to VCC;
VCC = 5 V; fi = 1 MHz
[2]
tpd is the same as tPHL and tPLH.
CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74HC_HCT594_Q100
Product data sheet
13 of 25
Nexperia
Table 9.
Dynamic characteristics type 74HCT594-Q100
GND = 0 V; VCC = 4.5 V; tr = tf = 6 ns; CL = 50 pF; see Figure 14.
Symbol Parameter
tpd
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
18
32
40
48
ns
15
ns
18
32
40
48
ns
VCC = 5.0 V;
CL = 15 pF
15
ns
propagation
see Figure 12
delay
VCC = 5.0 V;
CL = 15 pF
17
30
38
45
ns
14
ns
17
30
38
45
ns
14
ns
7
15
19
22
ns
5
12
15
18
ns
7
15
19
22
ns
5
12
15
18
ns
SHCP (HIGH or LOW);
see Figure 8
16
4
ns
STCP (HIGH or LOW);
see Figure 9
16
4
ns
SHR and STR (HIGH or
LOW); see Figure 12
and Figure 13
16
6
ns
DS to SHCP;
see Figure 10
25
30
ns
SHR to STCP;
see Figure 11
25
30
ns
SHCP to STCP;
see Figure 9
25
30
ns
DS to SHCP;
see Figure 10
5
3
6
7
ns
propagation
delay
[1]
SHCP to Q7S;
see Figure 8
VCC = 5.0 V;
CL = 15 pF
STCP to Qn;
see Figure 9
tPHL
STR to Qn;
see Figure 13
VCC = 5.0 V;
CL = 15 pF
tTHL
output
transition time
VCC = 4.5 V
VCC = 4.5 V
tTLH
output
transition time
VCC = 4.5 V
VCC = 4.5 V
tW
tsu
th
pulse width
set-up time
hold time
74HC_HCT594_Q100
Product data sheet
14 of 25
Nexperia
Table 9.
Dynamic characteristics type 74HCT594-Q100 …continued
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
trec
STR to STCP;
see Figure 12 and
Figure 13
10
5
13
15
ns
fmax
maximum
frequency
SHCP or STCP;
see Figure 8 and
Figure 9
30
92
24
MHz
VCC = 5.0 V;
CL = 15 pF
100
MHz
89
pF
CPD
[1]
[2]
power
dissipation
capacitance
VI = GND to VCC
1.5 V; VCC = 5 V;
fi = 1 MHz
[2]
12. Waveforms
IPD[
6+&3LQSXW
90
W:
W3/+
46RXWSXW
W3+/
90
W7/+
W7+/
DDH
Measurement points are given in Table 10.
tPLH and tPHL are the same as tpd.
tTLH = LOW to HIGH output transition time; tTHL = HIGH to LOW output transition time.
Fig 8.
The shift clock (SHCP) to output (Q7S) propagation delays, the shift clock pulse width, the maximum shift
clock frequency, and output transition times
74HC_HCT594_Q100
Product data sheet
15 of 25
Nexperia
6+&3LQSXW
90
WVX
IPD[
90
67&3LQSXW
W:
W3+/
W3/+
4QRXWSXWV
90
POD
Fig 9.
The storage clock (STCP) to output (Qn), propagation delays, the storage clock pulse width, the
maximum storage clock pulse frequency and the shift clock to storage clock set-up time
90
6+&3LQSXW
W VX
W VX
WK
WK
90
'6LQSXW
90
4RXWSXW
DDH
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig 10. The data set-up time and hold times for DS input to SHCP
74HC_HCT594_Q100
Product data sheet
16 of 25
Nexperia
6+5LQSXW
90
WVX
90
67&3LQSXW
90
4QRXWSXWV
PEF
Fig 11. The set-up time shift reset (SHR) to storage clock (STCP)
6+5LQSXW
90
W:
WUHF
90
6+&3LQSXW
W3+/
46RXWSXW
90
PEF
Fig 12. The shift reset (SHR) pulse width, the shift reset to output (Q7S) propagation delay and the shift reset to
shift clock (SHCP) recovery time
74HC_HCT594_Q100
Product data sheet
17 of 25
Nexperia
90
675LQSXW
W:
WUHF
90
67&3LQSXW
W3+/
90
4QRXWSXWV
PEF
Fig 13. The storage reset (STR) pulse width, the storage reset to output (Qn) propagation delay and the storage
reset to storage clock (STCP) recovery time
Table 10.
Measurement points
Type
Input
Output
VM
VM
74HC594-Q100
0.5 VCC
0.5 VCC
74HCT594-Q100
1.3 V
1.3 V
74HC_HCT594_Q100
Product data sheet
18 of 25
Nexperia
9,
W:
QHJDWLYH
SXOVH
90
9
WI
WU
WU
WI
9,
SRVLWLYH
SXOVH
9
90
90
90
W:
9&&
9&&
9,
92
5/
6
RSHQ
'87
57
DDG
Test data is given in Table 11.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistor
S1 = Test selection switch
Fig 14. Test circuit for measuring switching times
Table 11.
Test data
Type
Input
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74HC594-Q100
VCC
6 ns
15 pF, 50 pF
1 k
open
GND
VCC
74HCT594-Q100
3V
6 ns
15 pF, 50 pF
1 k
open
GND
VCC
74HC_HCT594_Q100
Product data sheet
Load
S1 position
19 of 25
Nexperia
13. Package outline
62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
Z 0
ES
GHWDLO;
PP
VFDOH
',0(16,216LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
PP
LQFKHV
ș
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
5()(5(1&(6
287/,1(
9(56,21
627
06
-(,7$
(8523($1
352-(&7,21
,668('$7(
Fig 15. Package outline SOT109-1 (SO16)
74HC_HCT594_Q100
Product data sheet
20 of 25
Nexperia
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Fig 16. Package outline SOT403-1 (TSSOP16)
74HC_HCT594_Q100
Product data sheet
21 of 25
Nexperia
14. Abbreviations
Table 12.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-Power Schottky Transistor-Transistor Logic
MM
Machine Model
TTL
15. Revision history
Table 13.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT594_Q100 v.2
20160613
Product data sheet
74HC_HCT594_Q100 v.1
Modifications:
74HC_HCT594_Q100
Product data sheet
Added type number 74HC594PW-Q100 (SOT403-1).
20120802
Product data sheet
22 of 25
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC_HCT594_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
23 of 25
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC_HCT594_Q100
Product data sheet
24 of 25
Nexperia
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 6
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . 11
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 20
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 22
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 22
Legal information. . . . . . . . . . . . . . . . . . . . . . . 23
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 23
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 23
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 24
Contact information. . . . . . . . . . . . . . . . . . . . . 24
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25
Date of release: 13 June 2016
