PBHV9115TLHR
PBHV9115TLHR
    NEXPERIA(安世)
    SOT-23
    PBHV9115T/SOT23/TO-236AB
PBHV9115TLHR 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PBHV9115TLH 150 V, 1 A PNP high-voltage low VCEsat BISS transistor 16 January 2017 Product data sheet 1. General description PNP high-voltage low VCEsat Breakthrough In Small Signal (BISS) transistor in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package. NPN complement: PBHV8115TLH 2. Features and benefits • • • • • High voltage Low collector-emitter saturation voltage VCEsat High collector current capability IC and ICM Small SMD plastic package AEC-Q101 qualified 3. Applications • • • • Power management LCD backlighting LED driver for LED chain module Switch Mode Power Supply (SMPS) 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - -150 V IC collector current - - -1 A ICM peak collector current single pulse; tp ≤ 1 ms - - -2 A hFE DC current gain VCE = -10 V; IC = -50 mA; Tamb = 25 °C 70 - 300 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 B base 2 E emitter 3 C collector Simplified outline Graphic symbol 3 C B E 1 sym132 2 TO-236AB (SOT23) 6. Ordering information Table 3. Ordering information Type number PBHV9115TLH Package Name Description Version TO-236AB plastic surface-mounted package; 3 leads SOT23 7. Marking Table 4. Marking codes [1] Type number Marking code PBHV9115TLH FC% [1] % = placeholder for manufacturing site code PBHV9115TLH Product data sheet All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 2 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - -200 V VCEO collector-emitter voltage open base - -150 V VCESM collector-emitter peak voltage VBE = 0 V - -200 V VEBO emitter-base voltage open collector - -6 V IC collector current - -1 A ICM peak collector current - -2 A IBM peak base current - -400 mA - 300 mW single pulse; tp ≤ 1 ms [1] Ptot total power dissipation Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] Tamb ≤ 25 °C Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 006aab150 400 Ptot (mW) 300 200 100 0 - 75 - 25 25 75 125 175 Tamb (°C) FR4 PCB, standard footprint Fig. 1. Power derating curve PBHV9115TLH Product data sheet All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 3 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) thermal resistance from junction to solder point [1] [1] in free air Min Typ Max Unit - - 417 K/W - - 70 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 006aab151 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.33 0.5 0.2 0.1 0.05 10 1 0.02 0.01 0 10- 1 10- 5 10- 4 10- 3 10- 2 10- 1 1 102 10 tp (s) 103 FR4 PCB, standard footprint Fig. 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PBHV9115TLH Product data sheet All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 4 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = -120 V; IE = 0 A; Tamb = 25 °C - - -100 nA VCB = -120 V; IE = 0 A; Tj = 150 °C - - -10 µA ICES collector-emitter cut-off VCE = -120 V; VBE = 0 V; Tamb = 25 °C current - - -100 nA IEBO emitter-base cut-off current VEB = -5 V; IC = 0 A; Tamb = 25 °C - - -100 nA hFE DC current gain VCE = -10 V; IC = -50 mA; Tamb = 25 °C 70 - 300 VCE = -10 V; IC = -100 mA; Tamb = 25 °C 60 - 300 VCE = -10 V; IC = -500 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 50 - 300 VCE = -10 V; IC = -1 A; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C 10 - - IC = -100 mA; IB = -10 mA; Tamb = 25 °C - - -120 mV IC = -100 mA; IB = -20 mA; Tamb = 25 °C - - -100 mV IC = -500 mA; IB = -100 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - - -300 mV VCEsat collector-emitter saturation voltage VBEsat base-emitter saturation IC = -1 A; IB = -200 mA; pulsed; tp ≤ voltage 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - - -1.2 V td delay time - 10 - ns tr rise time - 285 - ns ton turn-on time - 295 - ns ts storage time - 430 - ns tf fall time - 300 - ns toff turn-off time - 730 - ns fT transition frequency VCE = -10 V; IC = -10 mA; f = 100 MHz; Tamb = 25 °C - 55 - MHz Cc collector capacitance VCB = -20 V; IE = 0 A; ie = 0 A; f = 1 MHz; Tamb = 25 °C - 10 - pF Ce emitter capacitance VEB = -0.5 V; IC = 0 A; ic = 0 A; f = 1 MHz; Tamb = 25 °C - 150 - pF PBHV9115TLH Product data sheet VCC = -6 V; IC = -0.5 A; IBon = -0.1 mA; IBoff = 0.1 mA; Tamb = 25 °C All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 5 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor aaa-026066 300 aaa-026067 -2.0 -400 IC (A) hFE -360 -240 -1.6 (1) -280 -200 -160 200 -120 -1.2 -80 (2) -0.8 100 -320 IB (mA) = -40 (3) -0.4 0 -10-1 -1 -10 -102 0 -103 -104 IC (mA) -1 -2 -3 -4 VCE (V) -5 Tamb = 25 °C VCE = -10 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig. 3. 0 Fig. 4. Collector current as a function of collectoremitter voltage; typical values DC current gain as a function of collector current; typical values aaa-026068 -1.2 aaa-026069 -1.2 VBE (V) VBEsat (V) -0.9 (1) (1) -0.6 -0.8 (2) (2) (3) (3) -0.4 -0.3 0 -10-1 -1 -10 -102 0 -10-1 -103 -104 IC (mA) VCE = -10 V (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 100 °C Fig. 5. Product data sheet -102 -10 -103 -104 IC (mA) IC/IB = 5 (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 100 °C Base-emitter voltage as a function of collector current; typical values PBHV9115TLH -1 Fig. 6. Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 6 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor aaa-026070 -10 aaa-026071 -10 VCEsat (V) VCEsat (V) -1 -1 (1) (1) (2) (2) -10-1 -10-1 (3) -10-2 -10-1 -1 -10 -102 -10-2 -10-1 -103 -104 IC (mA) IC/IB = 5 (1) Tamb =100 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 7. -1 -102 -10 -103 -104 IC (mA) Tamb = 25 °C (1) IC/IB = 20 (2) IC/IB = 10 Collector-emitter saturation voltage as a function of collector current; typical values aaa-026072 103 Fig. 8. Collector-emitter saturation voltage as a function of collector current; typical values aaa-026073 104 RCEsat (Ω) RCEsat (Ω) 103 102 102 (1) 10 (2) 10 (3) 1 10-1 -10-1 -1 -10 -102 10-1 -10-1 -103 -104 IC (mA) IC/IB = 5 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig. 9. (1) 1 Product data sheet -102 -10 -103 -104 IC (mA) Tamb = 25 °C (1) IC/IB = 20 (2) IC/IB = 10 Collector-emitter saturation resistance as a function of collector current; typical values PBHV9115TLH -1 (2) Fig. 10. Collector-emitter saturation resistance as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 7 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor 11. Test information - IB input pulse (idealized waveform) 90 % - I Bon (100 %) 10 % - I Boff output pulse (idealized waveform) - IC 90 % - I C (100 %) 10 % t td ts tr t on tf t off 006aaa266 Fig. 11. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω R2 VI oscilloscope DUT R1 mgd624 Fig. 12. Test circuit for switching times Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PBHV9115TLH Product data sheet All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 8 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor 12. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 0.48 0.38 1.9 Dimensions in mm 0.15 0.09 04-11-04 Fig. 13. Package outline TO-236AB (SOT23) 13. Soldering 3.3 2.9 1.9 solder lands 3 solder resist 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Fig. 14. Reflow soldering footprint for TO-236AB (SOT23) PBHV9115TLH Product data sheet All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 9 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig. 15. Wave soldering footprint for TO-236AB (SOT23) PBHV9115TLH Product data sheet All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 10 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PBHV9115TLH v.1 20170116 Product data sheet - - PBHV9115TLH Product data sheet All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 11 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. 15. Legal information Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document [1] [2] status Product [3] status Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Suitability for use in automotive applications — This NXP Semiconductors product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. PBHV9115TLH Product data sheet Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 12 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Bitsound, CoolFlux, CoReUse, DESFire, FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE, ITEC, MIFARE, MIFARE Plus, MIFARE Ultralight, SmartXA, STARplug, TOPFET, TrenchMOS, TriMedia and UCODE — are trademarks of NXP Semiconductors N.V. HD Radio and HD Radio logo — are trademarks of iBiquity Digital Corporation. PBHV9115TLH Product data sheet All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 13 / 14 PBHV9115TLH NXP Semiconductors 150 V, 1 A PNP high-voltage low VCEsat BISS transistor 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 5 11. Test information......................................................... 8 12. Package outline.......................................................... 9 13. Soldering..................................................................... 9 14. Revision history........................................................11 15. Legal information..................................................... 12 © NXP Semiconductors N.V. 2017. All rights reserved For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 16 January 2017 PBHV9115TLH Product data sheet All information provided in this document is subject to legal disclaimers. 16 January 2017 © NXP Semiconductors N.V. 2017. All rights reserved 14 / 14
PBHV9115TLHR 价格&库存
很抱歉,暂时无法提供与“PBHV9115TLHR”相匹配的价格&库存,您可以联系我们找货
PBHV9115TLHR
    PBHV9115TLHR
    • 1+5.475871+0.70978
