PESD24VL1BA
Low capacitance bidirectional ESD protection diode in
SOD323
12 July 2018
Product data sheet
1. General description
Bidirectional ElectroStatic Discharge (ESD) protection diode in a very small SOD323 (SC-76) SMD
plastic package designed to protect one signal line from the damage caused by ESD and other
transients.
2. Features and benefits
Bidirectional ESD protection of one line
Max. peak pulse power: PPPM = 200 W
Low clamping voltage: V(CL)R = 70 V
Ultra low leakage current: IRM < 1 nA
ESD protection > 23 kV
IEC 61000-4-2, level 4 (ESD)
IEC 61000-4-5 (surge); IPPM = 3 A
Very small SMD plastic package
3. Applications
Computers and peripherals
Communication systems
Audio and video equipment
Data lines
CAN bus protection
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VRWM
reverse standoff
voltage
Tamb = 25 °C
24
V
Cd
diode capacitance
f = 1 MHz; VR = 0 V; Tamb = 25 °C
11
pF
PESD24VL1BA
Nexperia
Low capacitance bidirectional ESD protection diode in SOD323
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
K1
cathode 1
2
K2
cathode 2
Simplified outline
1
Graphic symbol
2
K1
K2
sym045
SOD323
6. Ordering information
Table 3. Ordering information
Type number
PESD24VL1BA
Package
Name
Description
Version
SOD323
plastic, surface-mounted package; 2 leads; 1.3 mm pitch; 1.7
mm x 1.25 mm x 0.95 mm body
SOD323
7. Marking
Table 4. Marking codes
Type number
Marking code
PESD24VL1BA
AF
PESD24VL1BA
Product data sheet
All information provided in this document is subject to legal disclaimers.
12 July 2018
Nexperia B.V. 2018. All rights reserved
2 / 12
PESD24VL1BA
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
PPPM
rated peak pulse power
tp = 8/20 µs
[1]
200
W
IPPM
rated peak pulse current
[1]
3
A
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
ESD maximum ratings
VESD
[1]
[2]
electrostatic discharge
voltage
IEC 61000-4-2; contact discharge
[2]
23
kV
HBM (MIL-STD 883)
[2]
10
kV
Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC61000-4-5.
Device stressed with ten non-repetitive ESD pulses.
001aaa630
120
IPP
100 %
100 % IPP; 8 µs
IPP
80
90 %
e-t
50 % IPP; 20 µs
40
10 %
Fig. 1.
t (µs)
8/20 µs pulse waveform according to
IEC 61000-4-5
PESD24VL1BA
Product data sheet
t
tr = 0.6 ns to 1 ns
40
30 ns
60 ns
Fig. 2.
ESD pulse waveform according to
IEC 61000-4-2
12 July 2018
001aaa631
3 / 12
PESD24VL1BA
Nexperia
9. Characteristics
Table 6. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VRWM
reverse standoff
voltage
Tamb = 25 °C
24
V
VBR
breakdown voltage
IR = 5 mA; Tamb = 25 °C
25.4
27.8
30.3
V
IRM
reverse leakage
current
VRWM = 24 V; Tamb = 25 °C
1
50
nA
Cd
diode capacitance
11
pF
VCL
clamping voltage
IPP = 1 A; Tamb = 25 °C
[1]
40
V
IPP = 3 A; Tamb = 25 °C
[1]
70
V
300
Ω
rdif
[1]
differential resistance
IR = 1 mA; Tamb = 25 °C
aaa-026838
104
PPP
PPP
(W)
PPP(25°C)
103
0.8
102
0.4
10
1
10
102
103
t p (µs)
Tamb = 25 °C
tp = 8/20 µs exponential decay waveform
Fig. 3.
001aaa193
1.2
Fig. 4.
Peak pulse power dissipation as a function of
pulse time; typical values
PESD24VL1BA
Product data sheet
150
Tj (°C)
200
Relative variation of peak pulse power as a
function of junction temperature; typical values
12 July 2018
50
4 / 12
PESD24VL1BA
Nexperia
aaa-026839
Cd
(pF)
16
12
8
4
10
15
VR (V)
25
Tamb = 25 °C; f = 1 MHz
Fig. 5.
Diode capacitance as a function of reverse voltage; typical values
PESD24VL1BA
Product data sheet
12 July 2018
5 / 12
PESD24VL1BA
Nexperia
ESD TESTER
4 GHz DIGITAL
OSCILLOSCOPE
RG 223/U
50 Ω coax
RZ
CZ
40 dB
ATTENUATOR
50 Ω
1
DUT: PESD24VL1BA
IEC 61000-4-2 network
CZ = 150 pF; RZ = 330 Ω
2
vertical scale = 20 V/div; horizontal scale = 50 ns/div
vertical scale = 200 V/div
PESD24VL1BA
GND
GND
unclamped +1 kV ESD voltage waveform
(IEC 61000-4-2 network)
GND
GND
PESD24VL1BA
unclamped -1 kV ESD voltage waveform
Fig. 6.
aaa-026840
ESD clamping test setup and waveforms
PESD24VL1BA
Product data sheet
12 July 2018
6 / 12
PESD24VL1BA
Nexperia
10. Application information
The device is designed for the protection of one bidirectional data line from surge pulses and ESD
damage. The device is suitable on lines where the signal polarities are both positive and negative
with respect to ground. The device is not designed to be used on lines connected to a DC supply.
line to be protected
GND
aaa-002737
Fig. 7.
Application diagram
Circuit board layout and protection device placement
Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge
transients. The following guidelines are recommended:
1.
2.
3.
4.
5.
6.
7.
8.
Place the device as close to the input terminal or connector as possible.
Minimize the path length between the device and the protected line.
Keep parallel signal paths to a minimum.
Avoid running protected conductors in parallel with unprotected conductors.
Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops.
Minimize the length of the transient return path to ground.
Avoid using shared transient return paths to a common ground point.
Use ground planes whenever possible. For multilayer PCBs, use ground vias.
11. Package outline
1.35
1.15
1.1
0.8
0.45
0.15
1
2.7
2.3
1.8
1.6
2
0.40
0.25
0.25
0.10
Dimensions in mm
Fig. 8.
03-12-17
Package outline SOD323
PESD24VL1BA
Product data sheet
12 July 2018
7 / 12
PESD24VL1BA
Nexperia
12. Soldering
3.05
2.1
solder lands
solder resist
1.65 0.95
0.5 (2×)
0.6 (2×)
solder paste
occupied area
2.2
Dimensions in mm
0.5
(2×)
0.6
(2×)
Fig. 9.
sod323_fr
Reflow soldering footprint for SOD323
5
2.9
1.5 (2×)
solder lands
solder resist
occupied area
2.75
1.2
(2×)
Dimensions in mm
preferred transport
direction during soldering
sod323_fw
Fig. 10. Wave soldering footprint for SOD323
PESD24VL1BA
Product data sheet
12 July 2018
8 / 12
PESD24VL1BA
Nexperia
13. Revision history
Table 7. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PESD24VL1BA v.2
20180711
Product data sheet
PESD24VL1BA v.1
Modifications:
PESD24VL1BA v.1
PESD24VL1BA
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Limiting values: minimum ambient temperature corrected
Characteristics: Figure 6 corrected
20170724
Product data sheet
12 July 2018
9 / 12
PESD24VL1BA
Nexperia
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
14. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
PESD24VL1BA
Product data sheet
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
12 July 2018
10 / 12
PESD24VL1BA
Nexperia
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PESD24VL1BA
Product data sheet
12 July 2018
11 / 12
PESD24VL1BA
Nexperia
Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Characteristics..............................................................4
10. Application information............................................. 7
11. Package outline.......................................................... 7
12. Soldering..................................................................... 8
13. Revision history..........................................................9
14. Legal information.......................................................10
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 12 July 2018
PESD24VL1BA
Product data sheet
12 July 2018
12 / 12
