PMEG40T50EP
40 V, 5 A low VF Trench MEGA Schottky barrier rectifier
9 August 2017
Product data sheet
1. General description
Trench Maximum Efficiency General Application (MEGA) Schottky barrier rectifier encapsulated in
a CFP5 (SOD128) small and flat lead Surface-Mounted Device (SMD) plastic package.
2. Features and benefits
Average forward current: IF(AV) ≤ 5 A
Reverse voltage: VR ≤ 40 V
Low forward voltage
Low leakage current due to Trench MEGA Schottky technology
High power capability due to clip-bonding technology
Small and flat lead SMD power plastic package
AEC-Q101 qualified
3. Applications
Low voltage rectification
High efficiency DC-to-DC conversion
Switch mode power supply
Freewheeling application
Reverse polarity protection
Low power consumption application
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IF(AV)
average forward
current
δ = 0.5 ; f = 20 kHz; Tsp ≤ 145 °C;
square wave
5
A
VR
reverse voltage
Tj = 25 °C
40
V
VF
forward voltage
IF = 5 A; tp ≤ 300 µs; δ ≤ 0.02 ;
Tj = 25 °C
470
525
mV
IR
reverse current
VR = 10 V; Tj = 25 °C; pulsed
[1]
7
24
µA
VR = 40 V; Tj = 25 °C; pulsed
[1]
12
41
µA
[1]
Very short pulse, in order to maintain a stable junction temperature.
PMEG40T50EP
Nexperia
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
K
cathode
2
A
anode
Simplified outline
1
Graphic symbol
2
CFP5 (SOD128)
1
2
sym001
6. Ordering information
Table 3. Ordering information
Type number
PMEG40T50EP
Package
Name
Description
Version
CFP5
plastic, surface mounted package; 2 terminals; 4 mm pitch; 3.8
mm x 2.6 mm x 1 mm body
SOD128
7. Marking
Table 4. Marking codes
Type number
Marking code
PMEG40T50EP
DX
PMEG40T50EP
Product data sheet
All information provided in this document is subject to legal disclaimers.
9 August 2017
Nexperia B.V. 2017. All rights reserved
2 / 14
PMEG40T50EP
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VR
reverse voltage
Tj = 25 °C
40
V
IF
forward current
Tsp ≤ 140 °C; δ = 1
7
A
IF(AV)
average forward current
δ = 0.5 ; f = 20 kHz; Tsp ≤ 145 °C; square
wave
5
A
IFSM
non-repetitive peak
forward current
tp = 8 ms; Tj(init) = 25 °C; square wave
55
A
Ptot
total power dissipation
Tamb ≤ 25 °C
[1]
0.75
W
[2]
1.1
W
Tj
175
°C
Tamb
ambient temperature
-55
175
°C
Tstg
storage temperature
-65
175
°C
[1]
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm .
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance
from junction to
ambient
in free air
Rth(j-sp)
[1]
[2]
[3]
[4]
thermal resistance
from junction to solder
point
Min
Typ
Max
Unit
[1] [2]
200
K/W
[1] [3]
130
K/W
[4]
12
K/W
For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a
significant part of the total power losses.
2
Soldering point of cathode tab.
PMEG40T50EP
Product data sheet
9 August 2017
3 / 14
PMEG40T50EP
Nexperia
aaa-026906
103
Zth(j-a)
(K/W)
102
duty cycle = 1
0.75
0.5
0.33
0.25
0.2
10
0.1
0.05
0.01
0.02
10-1
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB, standard footprint
Fig. 1.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
aaa-026907
103
Zth(j-a)
(K/W)
102
duty cycle = 1
0.75
0.5
0.33
0.2
10
0.25
0.1
0.05
0.01
0.02
10-1
10-3
10-2
10-1
FR4 PCB, mounting pad for cathode 1 cm
Fig. 2.
1
10
102
tp (s)
2
103
PMEG40T50EP
Product data sheet
9 August 2017
4 / 14
PMEG40T50EP
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
V(BR)R
reverse breakdown
voltage
IR = 1 mA; Tj = 25 °C; pulsed
VF
forward voltage
IR
VFRM
[1]
Max
Unit
40
V
IF = 0.1 A; tp ≤ 300 µs; δ ≤ 0.02 ;
Tj = 25 °C
290
mV
IF = 1 A; tp ≤ 300 µs; δ ≤ 0.02 ;
Tj = 25 °C
360
410
mV
IF = 2 A; tp ≤ 300 µs; δ ≤ 0.02 ;
Tj = 25 °C
400
445
mV
Tj = 25 °C
470
525
mV
Tj = -40 °C
525
mV
Tj = 125 °C
400
mV
[1]
[1]
7
24
µA
VR = 30 V; Tj = 25 °C; pulsed
[1]
10
µA
[1]
12
41
µA
VR = 40 V; Tj = 125 °C; pulsed
[1]
8.5
mA
VR = 1 V; f = 1 MHz; Tj = 25 °C
820
pF
VR = 10 V; f = 1 MHz; Tj = 25 °C
350
pF
reverse recovery time
step recovery
IF = 0.5 A; IR = 0.5 A; IR(meas) = 0.1 A;
Tj = 25 °C
24
ns
ramp recovery
dIF/dt = 200 A/µs; Tj = 25 °C; IF = 6 A;
VR = 26 V
16
ns
peak forward recovery
voltage
IF = 0.5 A; dIF/dt = 20 A/µs; Tj = 25 °C
378
mV
diode capacitance
trr
Typ
reverse current
Cd
Min
PMEG40T50EP
Product data sheet
9 August 2017
5 / 14
PMEG40T50EP
Nexperia
aaa-026908
102
IR
(A)
IF
(A)
(1)
(2)
(3)
(4)
10
aaa-026909
10-1
10-2
(1)
10-3
(3)
(4)
(2)
10-4
1
10-5
(5)
10-1
(6)
(7)
(5)
10-6
10-7
10-2
(6)
10-8
10-3
0.4
0.6
0.8
VF (V)
10-9
1.0
pulsed condition
(1) Tj = 175 °C
(2) Tj = 150 °C
(3) Tj = 125 °C
(4) Tj = 100 °C
(5) Tj = 85 °C
(6) Tj = 25 °C
(7) Tj = −40 °C
Fig. 3.
VR (V)
40
pulsed condition
(1) Tj = 150 °C
(2) Tj = 125 °C
(3) Tj = 100 °C
(4) Tj = 85 °C
(5) Tj = 25 °C
(6) Tj = −40 °C
Fig. 4.
Forward current as a function of forward
voltage; typical values
aaa-026910
1.5
Reverse current as a function of reverse
aaa-026911
4
PF(AV)
(W)
Cd
(nF)
(5)
(4)
3
(3)
1.0
(2)
(1)
2
0.5
1
VR (V)
f = 1 MHz; Tamb = 25 °C
Fig. 5.
Fig. 6.
Product data sheet
2
4
6
IF(AV) (A)
8
Tj = 100 °C
(1) δ = 0.1
(2) δ = 0.2
(3) δ = 0.5
(4) δ = 0.8
(5) δ = 1; DC
Diode capacitance as a function of reverse
PMEG40T50EP
Average forward power dissipation as a
function of average forward current; typical
values
9 August 2017
6 / 14
PMEG40T50EP
Nexperia
aaa-026912
0.1
PR(AV)
(W)
aaa-026913
4
IF(AV)
(A)
(1)
(1)
3
(2)
(2)
(3)
2
0.05
(3)
(4)
1
(4)
(5)
VR (V)
Tj = 100 °C
(1) δ = 1; DC
(2) δ = 0.9
(3) δ = 0.8
(4) δ = 0.5
(5) δ = 0.2
Fig. 7.
Fig. 8.
aaa-026914
5
IF(AV)
(A)
3
(2)
150
200
Tamb (°C)
Average forward current as a function of
ambient temperature; typical values
aaa-026915
8
IF(AV)
(A)
(1)
100
Tj = 175 °C
(1) δ = 1; DC
(2) δ = 0.5; f = 20 kHz
(3) δ = 0.2; f = 20 kHz
(4) δ = 0.1; f = 20 kHz
Average reverse power dissipation as a
function of reverse voltage; typical values
4
50
(1)
6
(2)
4
(3)
2
(3)
(4)
2
1
100
Tj = 175 °C
(1) δ = 1; DC
Fig. 9.
PMEG40T50EP
Product data sheet
200
Tamb (°C)
2
(4)
100
150
Tsp (°C)
200
Tj = 175 °C
(1) δ = 1; DC
Fig. 10. Average forward current as a function of solder
point temperature; typical values
9 August 2017
7 / 14
PMEG40T50EP
Nexperia
11. Test information
IF
IR(meas)
time
IR
trr
006aad022
Fig. 11. Reverse recovery definition; step recovery
IF
dlF
dt
trr
time
25 %
100 %
Qr
IR
IRM
003aac562
Fig. 12. Reverse recovery definition; ramp recovery
IF
time
VF
VFRM
VF
time
001aab912
Fig. 13. Forward recovery definition
PMEG40T50EP
Product data sheet
9 August 2017
8 / 14
PMEG40T50EP
Nexperia
P
t2
duty cycle δ =
t1
t2
t1
t
006aaa812
Fig. 14. Duty cycle definition
The current ratings for the typical waveforms are calculated according to the equations:
IF(AV) = IM × δ with IM defined as peak current,
IRMS = IF(AV) at DC, and IRMS = IM × √δ
with IRMS defined as RMS current.
Quality information
This product has been qualified in accordance with the Automotive Electronics Council (AEC)
standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in
automotive applications.
12. Package outline
2.7
2.3
1.1
0.9
0.6
0.3
1
5.0
4.4
4.0
3.6
2
1.9
1.6
0.22
0.10
Dimensions in mm
07-09-12
Fig. 15. Package outline CFP5 (SOD128)
PMEG40T50EP
Product data sheet
9 August 2017
9 / 14
PMEG40T50EP
Nexperia
13. Soldering
6.2
4.4
4.2
solder lands
1.9 2.1
(2×) (2×)
3.4 2.5
solder resist
solder paste
occupied area
Dimensions in mm
1.2
(2×)
1.4
(2×)
sod128_fr
Fig. 16. Reflow soldering footprint for CFP5 (SOD128)
PMEG40T50EP
Product data sheet
9 August 2017
10 / 14
PMEG40T50EP
Nexperia
Wave soldering footprint information
SOD128
10.2
5.8
2.3
5.7
4.2
(2×)
4.35
(2×)
3.5 (2×)
3.65 (2×)
occupied area
solder resist
solder lands
dummy track (solder resist and Cu free)
Dimensions in mm
Issue date
17-06-06
17-06-07
sod128_fw
Fig. 17. Wave soldering footprint for CFP5 (SOD128)
PMEG40T50EP
Product data sheet
9 August 2017
11 / 14
PMEG40T50EP
Nexperia
14. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PMEG40T50EP v.1
20170809
Product data sheet
PMEG40T50EP
Product data sheet
9 August 2017
12 / 14
PMEG40T50EP
Nexperia
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
15. Legal information
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to the accuracy
or completeness of information included herein and shall have no liability for
the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’ aggregate and cumulative liability towards customer
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PMEG40T50EP
Product data sheet
Trademarks
9 August 2017
13 / 14
PMEG40T50EP
Nexperia
16. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 3
10. Characteristics............................................................ 5
11. Test information......................................................... 8
12. Package outline.......................................................... 9
13. Soldering................................................................... 10
14. Revision history........................................................12
15. Legal information..................................................... 13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 9 August 2017
PMEG40T50EP
Product data sheet
9 August 2017
14 / 14
