74ABT00
Quad 2-input NAND gate
Rev. 3 — 11 August 2016
Product data sheet
1. General description
The 74ABT00 high-performance BiCMOS device combines low static and dynamic power
dissipation with high speed and high output drive.
The 74ABT00 is a quad 2-input NAND gate.
2. Features and benefits
Latch-up protection exceeds 500 mA per JESD78B class II level A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74ABT00D
40 C to +85 C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
74ABT00DB
40 C to +85 C
SSOP14
plastic shrink small outline package; 14 leads; body
width 5.3 mm
SOT337-1
74ABT00PW
40 C to +85 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74ABT00
Nexperia
4. Functional diagram
PQD
Fig 1.
PQD
Logic symbol
Fig 2.
PQD
IEC logic symbol
Fig 3.
Logic diagram (one gate)
5. Pinning information
5.1 Pinning
$%7
$%7
9&&
9&&
*1'
*1'
DDD
Fig 4.
DDD
Pin configuration for SO14
Fig 5.
Pin configuration for SSOP14 and TSSOP14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A to 4A
1, 4, 9, 12
data input
1B to 4B
2, 5, 10, 13
data input
1Y to 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
74ABT00
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
74ABT00
Nexperia
6. Functional description
Table 3.
Function table[1]
Input
Output
nA
nB
nY
L
X
H
X
L
H
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7.0
V
[1]
1.2
+7.0
V
[1]
0.5
+5.5
V
VI
input voltage
VO
output voltage
output HIGH or LOW
IIK
input clamping current
VI < 0 V
18
mA
IOK
output clamping current
VO < 0 V
50
mA
IO
output current
output in LOW-state
Tj
junction temperature
Tstg
storage temperature
[2]
40
mA
150
C
65
+150
C
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150 C.
8. Recommended operating conditions
Table 5.
Operating conditions
Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VIH
Conditions
Min
Typ
Max
Unit
4.5
5.5
V
VCC
V
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
IOH
HIGH-level output current
15
mA
IOL
LOW-level output current
mA
t/V
input transition rise and fall rate
ns/V
Tamb
ambient temperature
40
+85
74ABT00
Product data sheet
in free air
C
3 of 12
74ABT00
Nexperia
9. Static characteristics
Table 6.
Symbol
Parameter
25 C
Conditions
40 C to +85 C Unit
Min
Typ
Max
Min
Max
1.2
0.9
1.2
V
2.5
2.9
2.5
V
0.5
0.5
V
VIK
input clamping voltage VCC = 4.5 V; IIK = 18 mA
VOH
HIGH-level output
voltage
VCC = 4.5 V; IOH = 15 mA;
VI = VIL or VIH
VOL
LOW-level output
voltage
VCC = 4.5 V; IOL = 20 mA;
VI = VIL or VIH
0.35
II
input leakage current
VCC = 5.5 V; VI = GND or 5.5 V
0.01 1.0
1.0
A
IOFF
power-off leakage
current
VCC = 0 V; VI or VO 4.5 V
5.0
100
100
A
ICEX
output high leakage
current
HIGH-state; VO = 5.5 V;
VCC = 5.5 V; VI = GND or VCC
5.0
50
50
A
IO
output current
VCC = 5.5 V; VO = 2.5 V
50
75
180
50
180
mA
ICC
supply current
2
50
50
A
0.25
500
500
A
3
pF
40 C to +85 C;
VCC = 5.0 V 0.5 V
Unit
ICC
additional supply
current
per input pin; VCC = 5.5 V;
one input at 3.4 V;
other inputs at VCC or GND
CI
input capacitance
VI = 0 V or VCC
[1]
[2]
[1]
Not more than one output should be tested at a time, and the duration of the test should not exceed one second.
[2]
This is the increase in supply current for each input at 3.4 V.
10. Dynamic characteristics
Table 7.
GND = 0 V; for test circuit, see Figure 7.
Symbol Parameter
25 C; VCC = 5.0 V
Conditions
Min
Typ
Max
Min
Max
tPLH
LOW to HIGH
propagation delay
nA, nB to nY; see Figure 6
1.0
2.5
3.6
1.0
4.1
ns
tPHL
HIGH to LOW
propagation delay
1.0
2.0
2.8
1.0
3.4
ns
tsk(o)
output skew time
0.4
0.5
0.5
ns
[1]
[1]
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
74ABT00
Product data sheet
4 of 12
74ABT00
Nexperia
11. Waveforms
9,
90
Q$Q%LQSXW
*1'
W3+/
W3/+
92+
90
Q
很抱歉,暂时无法提供与“74ABT00D,118”相匹配的价格&库存,您可以联系我们找货
