74ABT04PW,112
74ABT04PW,112
    NEXPERIA(安世)
    TSSOP14_5.1X4.5MM
    IC INVERTER 6CH 6-INP 14TSSOP
74ABT04PW,112 数据手册
74ABT04 Hex inverter Rev. 3 — 12 August 2016 Product data sheet 1. General description The 74ABT04 high-performance BiCMOS device combines low static and dynamic power dissipation with high speed and high output drive. The 74ABT04 is a hex inverter. 2. Features and benefits  Latch-up protection exceeds 500 mA per JESD78B class II level A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74ABT04D 40 C to +85 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74ABT04DB 40 C to +85 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 74ABT04PW 40 C to +85 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74ABT04 Nexperia Hex inverter 4. Functional diagram   $ <   $ <     $ <   $ <   $ <   $ <     PQD Fig 1.             < $ PQD Logic symbol Fig 2. PQD IEC logic symbol Fig 3. Logic diagram (one inverter) 5. Pinning information 5.1 Pinning $%7 $%7 $   9&& <   $ $  $   < <   9&&  $ <   $ $   < <   $  < $   <  <   $ *1'   < $ < *1'     $ < DDD DDD Fig 4. Pin configuration for SO14 74ABT04 Product data sheet Fig 5. Pin configuration for SSOP14 and TSSOP14 All information provided in this document is subject to legal disclaimers. Rev. 3 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 2 of 13 74ABT04 Nexperia Hex inverter 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A, 5A, 6A 1, 3, 5, 9, 11, 13 data input 1Y, 2Y, 3Y, 4Y, 5Y, 6Y 2, 4, 6, 8, 10, 12 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level Input Output nA nY L H H L 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7.0 V [1] 1.2 +7.0 V [1] 0.5 +5.5 V VI input voltage VO output voltage output HIGH or LOW IIK input clamping current VI < 0 V 18 - mA IOK output clamping current VO < 0 V 50 - mA IO output current output in LOW-state Tj junction temperature Tstg storage temperature [2] - 40 mA - 150 C 65 +150 C [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150 C. 74ABT04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 3 of 13 74ABT04 Nexperia Hex inverter 8. Recommended operating conditions Table 5. Operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Typ Max Unit 4.5 - 5.5 V VI input voltage 0 - VCC V VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V IOH HIGH-level output current 15 - - mA IOL LOW-level output current - - 20 mA t/V input transition rise and fall rate 0 - 5 ns/V Tamb ambient temperature 40 - +85 in free air C 9. Static characteristics Table 6. Static characteristics Symbol Parameter 25 C Conditions 40 C to +85 C Unit Min Typ Max Min Max 1.2 0.9 - 1.2 - V 2.5 2.9 - 2.5 - V VIK input clamping voltage VCC = 4.5 V; IIK = 18 mA VOH HIGH-level output voltage VCC = 4.5 V; IOH = 15 mA; VI = VIL or VIH VOL LOW-level output voltage VCC = 4.5 V; IOL = 20 mA; VI = VIL or VIH - 0.35 0.5 - 0.5 V II input leakage current VCC = 5.5 V; VI = GND or 5.5 V - 0.01 1.0 - 1.0 A IOFF power-off leakage current VCC = 0 V; VI or VO  4.5 V - 5.0 100 - 100 A ICEX output high leakage current HIGH-state; VO = 5.5 V; VCC = 5.5 V; VI = GND or VCC - 5.0 50 - 50 A IO output current VCC = 5.5 V; VO = 2.5 V 50 75 180 50 180 mA ICC supply current VCC = 5.5 V; VI = GND or VCC - 2 50 - 50 A - 0.25 500 - 500 A - 3 - - - pF ICC additional supply current per input pin; VCC = 5.5 V; one input at 3.4 V; other inputs at VCC or GND CI input capacitance VI = 0 V or VCC [1] [2] [1] Not more than one output should be tested at a time, and the duration of the test should not exceed one second. [2] This is the increase in supply current for each input at 3.4 V. 74ABT04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 4 of 13 74ABT04 Nexperia Hex inverter 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; for test circuit, see Figure 7. Symbol Parameter 25 C; VCC = 5.0 V Conditions 40 C to +85 C; VCC = 5.0 V  0.5 V Unit Min Typ Max Min Max tPLH LOW to HIGH propagation delay nA to nY; see Figure 6 1.0 2.2 3.4 1.0 4.1 ns tPHL HIGH to LOW propagation delay nA to nY; see Figure 6 1.0 1.6 2.5 1.0 3.0 ns tsk(o) output skew time - 0.4 0.5 - 0.5 ns [1] [1] Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. 11. Waveforms 9O Q$LQSXW 90 *1' W3+/ W3/+ 92+ Q
74ABT04PW,112 价格&库存
很抱歉,暂时无法提供与“74ABT04PW,112”相匹配的价格&库存,您可以联系我们找货
