74AHC08; 74AHCT08
Quad 2-input AND gate
Rev. 03 — 14 November 2007
Product data sheet
1. General description
The 74AHC08; 74AHCT08 is a high-speed Si-gate CMOS device and is pin compatible
with Low-power Schottky TTL (LSTTL). They are specified in compliance with JEDEC
standard JESD7-A.
The 74AHC08; 74AHCT08 provides the quad 2-input AND function.
2. Features
Balanced propagation delays
All inputs have a Schmitt-trigger action
Inputs accepts voltages higher than VCC
For 74AHC08 only: operates with CMOS input levels
For 74AHCT08 only: operates with TTL input levels
ESD protection:
◆ HBM JESD22-A114E exceeds 2000 V
◆ MM JESD22-A115-A exceeds 200 V
◆ CDM JESD22-C101C exceeds 1000 V
■ Multiple package options
■ Specified from −40 °C to +85 °C and from −40 °C to +125 °C
3. Ordering information
Table 1.
Type number
74AHC08D
Package
Temperature range
Name
Description
Version
−40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
−40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
−40 °C to +125 °C
DHVQFN14 plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
74AHCT08D
74AHC08PW
74AHCT08PW
74AHC08BQ
74AHCT08BQ
SOT762-1
74AHC08; 74AHCT08
Nexperia
4. Functional diagram
1
3
6
2
1
1A
2
1B
4
2A
5
2B
9
3A
10
3B
12
4A
13
4B
1Y
3
4
2Y
6
5
3Y
8
9
A
Y
8
B
10
4Y
mna221
11
12
mna222
11
13
mna223
Fig 1. Logic symbol
Fig 2. IEC logic symbol
Fig 3. Logic diagram (one gate)
5. Pinning information
1A
terminal 1
index area
14 VCC
5.1 Pinning
1
14 VCC
1B
2
13 4B
1B
2
13 4B
1Y
3
12 4A
1Y
3
12 4A
2A
4
2A
4
08
11 4Y
2B
5
GND(1)
10 3B
2Y
6
1
1A
2Y
6
9
3A
GND
7
8
3Y
9
8
5
3Y
10 3B
2B
7
11 4Y
GND
08
3A
001aac946
Transparent top view
001aac945
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as
a supply pin or input.
Fig 4. Pin configuration SO14 and TSSOP14
Fig 5. Pin configuration DHVQFN14
74AHC_AHCT08_3
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 14
74AHC08; 74AHCT08
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A
1
data input
1B
2
data input
1Y
3
data output
2A
4
data input
2B
5
data input
2Y
6
data output
GND
7
ground (0 V)
3Y
8
data output
3A
9
data input
3B
10
data input
4Y
11
data output
4A
12
data input
4B
13
data input
VCC
14
supply voltage
6. Functional description
Table 3.
Function selection[1]
Input
Output
nA
nB
nY
L
X
L
X
L
L
H
H
H
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
Conditions
Min
Max
Unit
−0.5
+7.0
V
−0.5
+7.0
V
−20
mA
±20
mA
±25
mA
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
ICC
supply current
75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
IIK
74AHC_AHCT08_3
Product data sheet
3 of 14
74AHC08; 74AHCT08
Nexperia
Table 4.
Limiting values …continued
Symbol
Parameter
Conditions
Ptot
total power dissipation
Tamb = −40 °C to +125 °C
[1]
Min
Max
Unit
SO14 package
[2]
500
mW
TSSOP14 package
[3]
500
mW
DHVQFN14 package
[4]
500
mW
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Ptot derates linearly with 8 mW/K above 70 °C.
[3]
Ptot derates linearly with 5.5 mW/K above 60 °C.
[4]
Ptot derates linearly with 4.5 mW/K above 60 °C.
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74AHC08
74AHCT08
Unit
Min
Typ
Max
Min
Typ
Max
VCC
supply voltage
2.0
5.0
5.5
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
−40
+25
+125
−40
+25
+125
°C
∆t/∆V
input transition rise
and fall rate
VCC = 3.3 V ± 0.3 V
100
ns/V
VCC = 5.0 V ± 0.5 V
ns/V
9. Static characteristics
Table 6.
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
1.5
1.5
1.5
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
For type 74AHC08
VIH
VIL
VOH
HIGH-level
input voltage
LOW-level
input voltage
VCC = 2.0 V
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.4
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.8
3.7
V
74AHC_AHCT08_3
Product data sheet
4 of 14
74AHC08; 74AHCT08
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
VOL
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
VI = 5.5 V or GND; VCC = 0 V
to 5.5 V
0.1
1.0
2.0
µA
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
2.0
µA
CI
input
capacitance
3.0
10
10
10
pF
For type 74AHCT08
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = −50 µA
4.4
4.5
4.4
4.4
V
3.94
3.8
3.7
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
IO = −8.0 mA
VOL
LOW-level
output voltage
IO = 50 µA
IO = 8.0 mA
II
input leakage
current
to 5.5 V
ICC
VCC = 5.5 V
2.0
µA
∆ICC
additional
per input pin;
supply current VI = VCC − 2.1 V; IO = 0 A;
other pins at VCC or GND;
1.35
1.5
1.5
mA
CI
input
capacitance
3.0
10
10
10
pF
74AHC_AHCT08_3
Product data sheet
5 of 14
74AHC08; 74AHCT08
Nexperia
10. Dynamic characteristics
Table 7.
GND = 0 V; For test circuit see Figure 7.
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
4.0
8.8
1.0
10.5
1.0
11.0
ns
CL = 50 pF
5.6
12.3
1.0
14
1.0
15.5
ns
3.0
5.9
1.0
7.0
1.0
7.5
ns
4.2
7.9
1.0
9.0
1.0
10.0
ns
10.0
pF
3.2
6.9
1.0
8.0
1.0
9.0
ns
4.2
7.9
1.0
9.0
1.0
10.0
ns
12.0
pF
For type 74AHC08
tpd
propagation
delay
nA, nB to nY; see Figure 6
[2]
VCC = 3.0 V to 3.6 V
CL = 15 pF
CL = 50 pF
CPD
[3]
power
CL = 50 pF; fi = 1 MHz;
dissipation
VI = GND to VCC
capacitance
For type 74AHCT08
tpd
propagation
delay
[2]
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
VI = GND to VCC
capacitance
[3]
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz, fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
Σ(CL × VCC2 × fo) = sum of the outputs.
74AHC_AHCT08_3
Product data sheet
6 of 14
74AHC08; 74AHCT08
Nexperia
11. Waveforms
VI
VM
nA, nB input
GND
t PHL
t PLH
VOH
VM
nY output
VOL
mna224
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6. The input (nA, nB) to output (nY) propagation delays
Table 8.
Measurement points
Type
Input
Output
VM
VM
74AHC08
0.5VCC
0.5VCC
74AHCT08
1.5 V
0.5VCC
74AHC_AHCT08_3
Product data sheet
7 of 14
74AHC08; 74AHCT08
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VCC
PULSE
GENERATOR
VI
VO
RL
S1
open
DUT
CL
RT
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig 7. Load circuit for switching times
Table 9.
Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74AHC08
VCC
≤ 3.0 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74AHCT08
3.0 V
≤ 3.0 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74AHC_AHCT08_3
Product data sheet
8 of 14
74AHC08; 74AHCT08
Nexperia
12. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 8. Package outline SOT108-1 (SO14)
74AHC_AHCT08_3
Product data sheet
9 of 14
74AHC08; 74AHCT08
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 9. Package outline SOT402-1 (TSSOP14)
74AHC_AHCT08_3
Product data sheet
10 of 14
74AHC08; 74AHCT08
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
mm
c
D (1)
Dh
E (1)
Eh
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 10. Package outline SOT762-1 (DHVQFN14)
74AHC_AHCT08_3
Product data sheet
11 of 14
74AHC08; 74AHCT08
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
LSTTL
Low-power Schottky Transistor-Transistor Logic
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
CDM
Charged Device Model
TTL
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT08_3
20071114
Product data sheet
74AHC_AHCT08_2
Modifications:
The format of this data sheet has been redesigned to comply with the new identity guidelines
of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Section 3: DHVQFN14 package added.
Section 7: derating values added for DHVQFN14 package.
Section 12: outline drawing added for DHVQFN14 package.
74AHC_AHCT08_2
19990924
Product specification
74AHC_AHCT08_1
74AHC_AHCT08_1
19981218
74AHC_AHCT08_3
Product data sheet
12 of 14
74AHC08; 74AHCT08
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
74AHC_AHCT08_3
Product data sheet
13 of 14
Nexperia
74AHC08; 74AHCT08
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 14 November 2007
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC08BQ,115 74AHC08D,112 74AHC08D,118 74AHC08PW,112 74AHC08PW,118 74AHCT08BQ,115
74AHCT08D,112 74AHCT08D,118 74AHCT08PW,112 74AHCT08PW,118 74AHCT08PW/AUJ
