74AHC08D-Q100J
74AHC08D-Q100J
    NEXPERIA(安世)
    SOIC14_150MIL
    IC GATE AND 4CH 2-INP 14SO
74AHC08D-Q100J 数据手册
74AHC08-Q100; 74AHCT08-Q100 Quad 2-input AND gate Rev. 1 — 16 April 2013 Product data sheet 1. General description The 74AHC08-Q100; 74AHCT08-Q100 is a high-speed Si-gate CMOS device and is pin compatible with Low-power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard JESD7-A. The 74AHC08-Q100; 74AHCT08-Q100 provides the quad 2-input AND function. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Balanced propagation delays  All inputs have a Schmitt-trigger action  Inputs accept voltages higher than VCC  For 74AHC08-Q100 only: operates with CMOS input levels  For 74AHCT08-Q100 only: operates with TTL input levels  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Ordering information Table 1. Ordering information Type number 74AHC08D-Q100 Package Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 74AHCT08D-Q100 74AHC08PW-Q100 74AHCT08PW-Q100 74AHC08BQ-Q100 74AHCT08BQ-Q100 SOT762-1 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate 4. Functional diagram 1 & 3 & 6 2 1 1A 2 1B 4 2A 5 2B 9 3A 10 3B 12 4A 13 4B 1Y 3 4 2Y 6 5 3Y 8 9 A Y & 8 B 10 4Y mna221 11 12 mna222 & 11 13 mna223 Fig 1. Logic symbol Fig 2. IEC logic symbol Fig 3. Logic diagram (one gate) 5. Pinning information 5.1 Pinning  9&& WHUPLQDO LQGH[DUHD $+&4 $+&74 $ $+&4 $+&74   9&& %   % %   % <   $ <   $ $   <  $   $ *1'   < <   %  $  <  < *1'  <  %     *1' % $ % DDD 7UDQVSDUHQWWRSYLHZ DDD (1) The die substrate is attached to this pad using conductive die attach material. It cannot be used as a supply pin or input. Fig 4. Pin configuration SO14 and TSSOP14 74AHC_AHCT08_Q100 Product data sheet Fig 5. Pin configuration DHVQFN14 All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 2 of 14 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A 1, 4, 9, 12 data input 1B, 2B, 3B, 4B 2, 5, 10, 13 data input 1Y, 2Y, 3Y, 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function selection[1] Input Output nA nB nY L X L X L L H H H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC VI Conditions Min Max Unit supply voltage 0.5 +7.0 V input voltage 0.5 +7.0 V 20 - mA - 20 mA input clamping current VI < 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] VO = 0.5 V to (VCC + 0.5 V) IIK IO output current - 25 mA ICC supply current - 75 mA IGND ground current 75 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation Tamb = 40 C to +125 C SO14 package [2] - 500 mW TSSOP14 package [3] - 500 mW DHVQFN14 package [4] - 500 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 70 C. [3] Ptot derates linearly with 5.5 mW/K above 60 C. [4] Ptot derates linearly with 4.5 mW/K above 60 C. 74AHC_AHCT08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 3 of 14 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74AHC08-Q100 Min Typ 74AHCT08-Q100 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 5.5 4.5 5.0 5.5 V VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 3.3 V  0.3 V - - 100 - - - ns/V VCC = 5.0 V  0.5 V - - 20 - - 20 ns/V 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V For type 74AHC08-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 50 A; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = 50 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.4 - V IO = 8.0 mA; VCC = 4.5 V 3.94 - - 3.8 - 3.7 - V LOW-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 A II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 A CI input capacitance - 3.0 10 - 10 - 10 pF 74AHC_AHCT08_Q100 Product data sheet VI = VCC or GND; VCC = 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 4 of 14 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate Table 6. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max For type 74AHCT08-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.8 - 3.7 - V IO = 8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A IO = 8.0 mA - 0 0.1 - 0.1 - 0.1 V - - 0.36 - 0.44 - 0.55 V II input leakage current VI = VIH or VIL; VCC = 5.5 V - - 0.1 - 1.0 - 2.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 A ICC additional per input pin; supply current VI = VCC  2.1 V; IO = 0 A; other pins at VCC or GND; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3.0 10 - 10 - 10 pF 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 7. Symbol Parameter 25 C Conditions Min 40 C to +85 C 40 C to +125 C Unit Typ[1] Max Min Max Min Max For type 74AHC08-Q100 tpd propagation delay nA, nB to nY; see Figure 6 [2] VCC = 3.0 V to 3.6 V CL = 15 pF - 4.0 8.8 1.0 10.5 1.0 11.0 ns CL = 50 pF - 5.6 12.3 1.0 14 1.0 15.5 ns VCC = 4.5 V to 5.5 V CL = 15 pF - CL = 50 pF CPD power dissipation capacitance 74AHC_AHCT08_Q100 Product data sheet CL = 50 pF; fi = 1 MHz; VI = GND to VCC [3] - 3.0 5.9 1.0 7.0 1.0 7.5 ns 4.2 7.9 1.0 9.0 1.0 10.0 ns 10.0 - - - - - pF All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 5 of 14 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate Table 7. Dynamic characteristics …continued GND = 0 V; For test circuit see Figure 7. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max - 3.2 6.9 1.0 8.0 1.0 9.0 ns - 4.2 7.9 1.0 9.0 1.0 10.0 ns - 12.0 - - - - - pF For type 74AHCT08-Q100 propagation delay tpd nA, nB to nY; see Figure 6 [2] VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF power dissipation capacitance CPD [3] CL = 50 pF; fi = 1 MHz; VI = GND to VCC [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 11. Waveforms VI VM nA, nB input GND t PHL t PLH VOH VM nY output VOL mna224 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Table 8. The input (nA, nB) to output (nY) propagation delays Measurement points Type Input Output VM VM 74AHC08-Q100 0.5VCC 0.5VCC 74AHCT08-Q100 1.5 V 0.5VCC 74AHC_AHCT08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 6 of 14 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 7. Table 9. Test circuit for measuring switching times Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74AHC08-Q100 VCC  3.0 ns 15 pF, 50 pF 1 k open GND VCC 74AHCT08-Q100 3.0 V  3.0 ns 15 pF, 50 pF 1 k open GND VCC 74AHC_AHCT08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 7 of 14 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate 12. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74AHC_AHCT08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 8 of 14 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 Fig 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Package outline SOT402-1 (TSSOP14) 74AHC_AHCT08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 9 of 14 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT762-1 14 terminals; body 2.5 x 3 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 6 y y1 C v M C A B w M C b L 1 7 Eh e 14 8 13 9 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.1 2.9 1.65 1.35 2.6 2.4 1.15 0.85 0.5 2 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT762-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 10. Package outline SOT762-1 (DHVQFN14) 74AHC_AHCT08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 10 of 14 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor LSTTL Low-power Schottky Transistor-Transistor Logic ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT08_Q100 v.1 20130416 - - 74AHC_AHCT08_Q100 Product data sheet Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 11 of 14 74AHC08-Q100; 74AHCT08-Q100 Nexperia Quad 2-input AND gate 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AHC_AHCT08_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 12 of 14 Nexperia 74AHC08-Q100; 74AHCT08-Q100 Quad 2-input AND gate No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AHC_AHCT08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 April 2013 © Nexperia B.V. 2017. All rights reserved 13 of 14 Nexperia 74AHC08-Q100; 74AHCT08-Q100 Quad 2-input AND gate 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 16 April 2013 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AHCT08PW-Q100J 74AHCT08BQ-Q100X 74AHC08BQ-Q100X 74AHCT08D-Q100J 74AHC08D-Q100J 74AHC08PW-Q100J
74AHC08D-Q100J 价格&库存
很抱歉,暂时无法提供与“74AHC08D-Q100J”相匹配的价格&库存,您可以联系我们找货
