74ALVC00-Q100
Quad 2-input NAND gate
Rev. 1 — 16 May 2014
Product data sheet
1. General description
The 74ALVC00-Q100 is a quad 2-input NAND gate.
Schmitt trigger action on all inputs makes the device tolerant of slow rise and fall times.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 3) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 3)
Specified from 40 C to +85 C
Wide supply voltage range from 1.65 V to 3.6 V
3.6 V tolerant inputs/outputs
CMOS low power consumption
Direct interface with TTL levels (2.7 V to 3.6 V)
Power-down mode
Latch-up performance exceeds 250 mA
Complies with JEDEC standards:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
3. Ordering information
Table 1.
Type number
74ALVC00D-Q100
Package
Temperature range
Name
Description
Version
40 C to +85 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74ALVC00PW-Q100 40 C to +85 C
74ALVC00BQ-Q100
40 C to +85 C
DHVQFN14 plastic dual in-line compatible thermal enhanced
SOT762-1
very thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
74ALVC00-Q100
Nexperia
4. Functional diagram
1
2
4
5
9
10
12
13
3
6
8
A
Y
11
B
Fig 1.
mna211
mna246
PQD
Logic symbol
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram for one gate
5. Pinning information
5.1 Pinning
WHUPLQDO
LQGH[DUHD
$/9&4
*1'
*1'
9&&
9&&
$/9&4
*1'
DDD
7UDQVSDUHQWWRSYLHZ
DDD
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 4.
Pin configuration SO14 and TSSOP14
Fig 5.
Pin configuration DHVQFN14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A to 4A
1, 4, 9, 12
data input
1B to 4B
2, 5, 10, 13
data input
1Y to 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
74ALVC00-Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
74ALVC00-Q100
Nexperia
6. Functional description
Table 3.
Function selection[1]
Input
Output
nA
nB
nY
L
X
H
X
L
H
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
VI < 0 V
VO > VCC or VO < 0 V
output HIGH or LOW state
[1] [2]
output 3-state
power-down mode, VCC = 0 V
[2]
Max
Unit
0.5
+4.6
V
50
mA
0.5
+4.6
V
50
mA
0.5
VCC + 0.5
V
0.5
+4.6
V
0.5
+4.6
V
50
mA
100
mA
IO
output current
ICC
supply current
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
500
mW
total power dissipation
Ptot
[1]
VO = 0 V to VCC
Min
Tamb = 40 C to +85 C
[3]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (power-down mode), the output voltage can be 3.6 V in normal operation.
[3]
For SO14 packages: above 70 C derate linearly with 8 mW/K.
For TSSOP14 packages: above 60 C derate linearly with 5.5 mW/K.
For DHVQFN14 packages: above 60 C derate linearly with 4.5 mW/K.
74ALVC00-Q100
Product data sheet
3 of 14
74ALVC00-Q100
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
1.65
3.6
V
VI
input voltage
V
VO
output voltage
VCC
V
output 3-state
V
power-down mode; VCC = 0 V
V
Tamb
ambient temperature
in free air
40
+85
C
t/V
input transition rise and fall rate
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
Conditions
LOW-level output voltage
Max
Unit
0.65 VCC
V
VCC = 2.3 V to 2.7 V
1.7
V
2.0
V
VCC = 1.65 V to 1.95 V
0.7
V
0.8
V
VCC 0.2
V
0.35 VCC V
VI = VIH or VIL
IO = 100 A; VCC = 1.65 V to 3.6 V
VOL
Min
Typ[1]
IO = 6 mA; VCC = 1.65 V
1.25
1.51
V
IO = 12 mA; VCC = 2.3 V
1.8
2.10
V
IO = 18 mA; VCC = 2.3 V
1.7
2.01
V
IO = 12 mA; VCC = 2.7 V
2.2
2.53
V
IO = 18 mA; VCC = 3.0 V
2.4
2.76
V
IO = 24 mA; VCC = 3.0 V
2.2
2.68
V
0.2
V
VI = VIH or VIL
0.11
0.3
V
0.17
0.4
V
0.25
0.6
V
0.16
0.4
V
0.23
0.4
V
0.30
0.55
V
II
input leakage current
VCC = 3.6 V; VI = 3.6 V or GND
0.1
5
A
IOFF
power-off leakage current
VCC = 0 V; VI or VO = 0 V to 3.6 V
0.1
10
A
74ALVC00-Q100
Product data sheet
4 of 14
74ALVC00-Q100
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
ICC
supply current
VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.2
A
ICC
additional supply current
per input pin; VCC = 3.0 V to 3.6 V;
VI = VCC 0.6 V; IO = 0 A
5
750
A
CI
input capacitance
3.5
pF
[1]
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C.
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 7.
Symbol
Parameter
propagation delay
tpd
Conditions
nA, nB to nY; see Figure 6
Max
1.0
2.8
4.4
Unit
ns
1.0
2.1
2.8
ns
VCC = 2.7 V
1.0
2.6
3.2
ns
1.0
2.1
3.0
ns
28
pF
power dissipation
capacitance
Typ[1]
[2]
CPD
Min
per gate; VI = GND to VCC; VCC = 3.3 V
[1]
Typical values are measured at Tamb = 25 C
[2]
tpd is the same as tPHL and tPLH.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
[3]
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs
74ALVC00-Q100
Product data sheet
5 of 14
74ALVC00-Q100
Nexperia
11. Waveforms
VI
nA, nB input
VM
GND
tPHL
tPLH
VOH
nY output
VM
mna213
VOL
Measurement points are given in Table 8.
Fig 6.
Table 8.
Inputs nA, nB to output nY propagation delay times
Measurement points
Supply voltage VCC
Input VI
VM
1.65 V to 1.95 V
VCC
0.5VCC
2.3 V to 2.7 V
VCC
0.5VCC
2.7 V
2.7 V
1.5 V
3.0 V to 3.6 V
2.7 V
1.5 V
74ALVC00-Q100
Product data sheet
6 of 14
74ALVC00-Q100
Nexperia
W:
9,
QHJDWLYH
SXOVH
90
90
9
WI
WU
WU
WI
9,
SRVLWLYH
SXOVH
90
90
9
W:
9(;7
9&&
9,
5/
92
'87
57
5/
DDH
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 7.
Table 9.
Test circuit for measuring switching times
Test data
Supply voltage VCC
Input
Load
VEXT
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.65 V to 1.95 V
VCC
2.0 ns
30 pF
1 k
open
2 VCC
GND
2.3 V to 2.7 V
VCC
2.0 ns
30 pF
500
open
2 VCC
GND
2.7 V
2.7 V
2.5 ns
50 pF
500
open
6V
GND
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF
500
open
6V
GND
74ALVC00-Q100
Product data sheet
7 of 14
74ALVC00-Q100
Nexperia
12. Package outline
62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
',0(16,216LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
PP
LQFKHV
ș
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
Fig 8.
5()(5(1&(6
287/,1(
9(56,21
627
06
-(,7$
(8523($1
352-(&7,21
,668('$7(
Package outline SOT108-1 (SO14)
74ALVC00-Q100
Product data sheet
8 of 14
74ALVC00-Q100
Nexperia
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
Fig 9.
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Package outline SOT402-1 (TSSOP14)
74ALVC00-Q100
Product data sheet
9 of 14
74ALVC00-Q100
Nexperia
'+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV
627
WHUPLQDOVERG\[[PP
F
GHWDLO;
WHUPLQDO
LQGH[DUHD
WHUPLQDO
LQGH[DUHD
H
H
E
Y 0 & $ %
Z 0 &
(K
H
'K
PP
VFDOH
81,7
PP
PD[
E
F
'K
(K
H
H
Y
Z
1RWH
5()(5(1&(6
287/,1(
9(56,21
-(,7$
627
02
(8523($1
352-(&7,21
,668('$7(
Fig 10. Package outline SOT762-1 (DHVQFN14)
74ALVC00-Q100
Product data sheet
10 of 14
74ALVC00-Q100
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ALVC00_Q100 v.1
20140516
Product data sheet
74ALVC00-Q100
Product data sheet
11 of 14
74ALVC00-Q100
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74ALVC00-Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
12 of 14
74ALVC00-Q100
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74ALVC00-Q100
Product data sheet
13 of 14
Nexperia
74ALVC00-Q100
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . 12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Date of release: 16 May 2014
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74ALVC00D-Q100J 74ALVC00PW-Q100J 74ALVC00BQ-Q100X
