74AUP1G08
Low-power 2-input AND gate
Rev. 7 — 30 November 2017
1
Product data sheet
General description
The 74AUP1G08 provides the single 2-input AND function.
Schmitt-trigger action at all inputs makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire
This device is fully specified for partial Power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the
device when it is powered down.
2
Features and benefits
• Wide supply voltage range from 0.8 V to 3.6 V
• High noise immunity
• Complies with JEDEC standards:
– JESD8-12 (0.8 V to 1.3 V)
– JESD8-11 (0.9 V to 1.65 V)
– JESD8-7 (1.2 V to 1.95 V)
– JESD8-5 (1.8 V to 2.7 V)
– JESD8-B (2.7 V to 3.6 V)
• ESD protection:
– HBM JESD22-A114F Class 3A exceeds 5000 V
– MM JESD22-A115-A exceeds 200 V
– CDM JESD22-C101E exceeds 1000 V
• Low static power consumption; ICC = 0.9 μA (maximum)
• Latch-up performance exceeds 100 mA per JESD 78 Class II
• Inputs accept voltages up to 3.6 V
• Low noise overshoot and undershoot < 10 % of VCC
• IOFF circuitry provides partial Power-down mode operation
• Multiple package options
• Specified from -40 °C to +85 °C and -40 °C to +125 °C
74AUP1G08
Nexperia
3
Ordering information
Table 1. Ordering information
Type number
Package
Temperature range Name
Description
Version
74AUP1G08GW
-40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74AUP1G08GM
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 x 1.45 x 0.5 mm
74AUP1G08GF
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 x 1 x 0.5 mm
74AUP1G08GN
-40 °C to +125 °C
XSON6
6 terminals; body 0.9 x 1.0 x 0.35 mm
SOT1115
74AUP1G08GS
-40 °C to +125 °C
XSON6
6 terminals; body 1.0 x 1.0 x 0.35 mm
SOT1202
74AUP1G08GX
-40 °C to +125 °C
X2SON5
X2SON5: plastic thermal enhanced extremely
thin small outline package; no leads; 5 terminals;
body 0.8 x 0.8 x 0.35 mm
SOT1226
4
Marking
Table 2. Marking
[1]
Type number
Marking code
74AUP1G08GW
pE
74AUP1G08GM
pE
74AUP1G08GF
pE
74AUP1G08GN
pE
74AUP1G08GS
pE
74AUP1G08GX
pE
[1] The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5
Functional diagram
1
B
2
A
Y
mna113
Figure 1. Logic symbol
74AUP1G08
Product data sheet
4
1
A
4
2
mna114
Figure 2. IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Y
B
mna221
Figure 3. Logic diagram
© Nexperia B.V. 2017. All rights reserved.
2 / 21
74AUP1G08
Nexperia
6
Pinning information
6.1 Pinning
74AUP1G08
74AUP1G08
B
1
A
2
GND
5
3
4
B
1
6
VCC
A
2
5
n.c.
GND
3
4
Y
VCC
Y
001aaf026
Transparent top view
001aaf025
Figure 4. Pin configuration SOT353-1 (TSSOP5)
Figure 5. Pin configuration SOT886 (XSON6)
74AUP1G08
74AUP1G08
B
1
6
VCC
A
2
5
n.c.
GND
3
4
Y
B
1
5
VCC
4
Y
3
GND
A
001aaf027
2
aaa-003000
Figure 6. Pin configuration SOT891, SOT1115 and
SOT1202 (XSON6)
Figure 7. Pin configuration SOT1226 (X2SON5)
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
TSSOP5 and X2SON5
XSON6
B
1
1
data input
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
74AUP1G08
Product data sheet
3 / 21
74AUP1G08
Nexperia
7
Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
A
B
Y
L
L
L
L
H
L
H
L
L
H
H
H
8
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
[1]
Min
Max
Unit
-0.5
+4.6
V
-50
-0.5
+4.6
-50
-0.5
+4.6
V
±20
mA
mA
V
mA
VO
output voltage
Active mode and Power-down mode
IO
output current
VO = 0 V to VCC
ICC
supply current
+50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
250
mW
Ptot
total power dissipation
Tamb = -40 °C to +125 °C
[2]
[1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2] For TSSOP5 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON5 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
9
Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74AUP1G08
Product data sheet
Min
Max
Unit
0.8
3.6
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
-40
+125
°C
ns/V
VCC = 0.8 V to 3.6 V
4 / 21
74AUP1G08
Nexperia
10 Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70 × VCC
V
VCC = 0.9 V to 1.95 V
0.65 × VCC
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 × VCC
V
0.35 × VCC
V
0.7
V
0.9
V
VCC - 0.1
V
IO = -1.1 mA; VCC = 1.1 V
0.75 × VCC
V
IO = -1.7 mA; VCC = 1.4 V
1.11
V
IO = -1.9 mA; VCC = 1.65 V
1.32
V
IO = -2.3 mA; VCC = 2.3 V
2.05
V
IO = -3.1 mA; VCC = 2.3 V
1.9
V
IO = -2.7 mA; VCC = 3.0 V
2.72
V
IO = -4.0 mA; VCC = 3.0 V
2.6
V
IO = 20 μA; VCC = 0.8 V to 3.6 V
0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.3 × VCC
V
IO = 1.7 mA; VCC = 1.4 V
0.31
V
IO = 1.9 mA; VCC = 1.65 V
0.31
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
Tamb = 25 °C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
VI = VIH or VIL
IO = -20 μA; VCC = 0.8 V to 3.6 V
VOL
II
IOFF
ΔIOFF
ICC
LOW-level output voltage
VI = VIH or VIL
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
±0.1
μA
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.2
μA
additional power-off
leakage current
VCC = 0 V to 0.2 V
±0.2
μA
supply current
VI = GND or VCC; IO = 0 A;
0.5
μA
74AUP1G08
Product data sheet
5 / 21
74AUP1G08
Nexperia
Symbol Parameter
ΔICC
Conditions
[1]
Min
Typ
Max
Unit
40
μA
additional supply current
VI = VCC - 0.6 V; IO = 0 A; VCC = 3.3 V
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
VCC = 0.8 V
0.70 × VCC
V
0.65 × VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.30 × VCC
V
0.35 × VCC
V
0.7
V
0.9
V
VCC - 0.1
V
0.7 × VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.3 × VCC
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
Tamb = -40 °C to +85 °C
VIH
VIL
VOH
VOL
II
IOFF
ΔIOFF
ICC
VI = VIH or VIL
VI = VIH or VIL
±0.5
μA
±0.5
μA
leakage current
VCC = 0 V to 0.2 V
±0.6
μA
supply current
0.9
μA
74AUP1G08
Product data sheet
6 / 21
74AUP1G08
Nexperia
Symbol Parameter
ΔICC
Conditions
Min
Typ
Max
Unit
50
μA
VCC = 0.8 V
0.75 × VCC
V
0.70 × VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.25 × VCC
V
0.30 × VCC
V
0.7
V
0.9
V
VCC - 0.11
V
0.6 × VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33 × VCC
V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
[1]
VIH
VIL
VOH
VOL
II
IOFF
ΔIOFF
ICC
ΔICC
VI = VIH or VIL
VI = VIH or VIL
±0.75
μA
±0.75
μA
leakage current
VCC = 0 V to 0.2 V
±0.75
μA
supply current
1.4
μA
75
μA
[1]
[1] One input at VCC - 0.6 V, other input at VCC or GND.
74AUP1G08
Product data sheet
7 / 21
74AUP1G08
Nexperia
11 Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9
Symbol
Parameter
Conditions
Min
Typ
[1]
Max
Unit
Tamb = 25 °C; CL = 5 pF
tpd
propagation delay
A, B to Y; see Figure 8
[2]
VCC = 0.8 V
17.0
ns
VCC = 1.1 V to 1.3 V
2.6
5.1
10.8
ns
VCC = 1.4 V to 1.6 V
1.6
3.7
6.5
ns
VCC = 1.65 V to 1.95 V
1.3
3.0
5.2
ns
1.1
2.4
4.0
ns
1.0
2.2
3.5
ns
20.6
ns
2.4
6.0
12.5
ns
2.0
4.3
7.6
ns
1.7
3.6
6.1
ns
1.4
2.9
4.8
ns
1.3
2.7
4.2
ns
24.1
ns
3.4
6.8
14.2
ns
2.3
4.9
8.6
ns
1.9
4.0
6.9
ns
1.7
3.4
5.5
ns
1.5
3.1
4.8
ns
34.4
ns
4.6
9.1
19.4
ns
3.4
6.4
11.5
ns
2.6
5.3
9.1
ns
2.3
4.5
7.2
ns
2.2
4.2
6.2
ns
Tamb = 25 °C; CL = 10 pF
tpd
propagation delay
[2]
VCC = 0.8 V
Tamb = 25 °C; CL = 15 pF
tpd
propagation delay
[2]
VCC = 0.8 V
Tamb = 25 °C; CL = 30 pF
tpd
propagation delay
[2]
VCC = 0.8 V
74AUP1G08
Product data sheet
8 / 21
74AUP1G08
Nexperia
Symbol
Parameter
Conditions
Min
Typ
[1]
Max
Unit
Tamb = 25 °C
power dissipation capacitance f = 1 MHz; VI = GND to VCC
CPD
[3]
VCC = 0.8 V
2.5
pF
2.7
pF
2.8
pF
2.9
pF
3.5
pF
4.0
pF
[1] All typical values are measured at nominal VCC.
[2] tpd is the same as tPLH and tPHL.
[3] CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of the outputs.
Table 9. Dynamic characteristics
Symbol
Parameter
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Max
Min
Max
2.1
11.7
2.1
12.9
ns
1.5
7.5
1.5
8.3
ns
1.3
6.1
1.3
6.7
ns
1.0
4.8
1.0
5.3
ns
0.9
4.3
0.9
4.8
ns
2.2
13.6
2.2
15.0
ns
1.8
8.9
1.8
9.8
ns
1.6
7.2
1.6
7.9
ns
1.3
5.7
1.3
6.3
ns
1.2
4.7
1.2
5.2
ns
CL = 5 pF
tpd
propagation delay
[1]
CL = 10 pF
tpd
propagation delay
74AUP1G08
Product data sheet
[1]
9 / 21
74AUP1G08
Nexperia
Symbol
Parameter
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Max
Min
Max
3.1
15.7
3.1
17.3
ns
2.1
10.1
2.1
11.2
ns
1.8
8.2
1.8
9.0
ns
1.6
6.5
1.6
7.2
ns
1.5
5.9
1.5
6.5
ns
4.1
21.8
4.1
24.0
ns
2.9
13.6
2.9
15.0
ns
2.4
10.9
2.4
12.1
ns
2.2
8.6
2.2
9.5
ns
2.1
7.5
2.1
8.3
ns
CL = 15 pF
tpd
propagation delay
[1]
CL = 30 pF
tpd
propagation delay
[1]
[1] tpd is the same as tPLH and tPHL.
11.1 Waveforms and test circuit
VI
VM
A, B input
GND
t PHL
t PLH
VOH
VM
Y output
mna614
VOL
Measurement points are given in Table 10.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Figure 8. The data input (A or B) to output (Y) propagation delays
Table 10. Measurement points
Supply voltage
Output
Input
VCC
VM
VM
VI
tr = tf
0.8 V to 3.6 V
0.5 x VCC
0.5 x VCC
VCC
≤ 3.0 ns
74AUP1G08
Product data sheet
10 / 21
74AUP1G08
Nexperia
VCC
G
VI
DUT
VEXT
5 kΩ
VO
RT
CL
RL
001aac521
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 9. Test circuit for measuring switching times
Table 11. Test data
Supply voltage
Load
VEXT
RL
[1]
VCC
CL
0.8 V to 3.6 V
5 pF, 10 pF, 15 pF and 30 pF 5 kΩ or 1 MΩ
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
open
GND
2 x VCC
[1] For measuring enable and disable times RL = 5 kΩ, for measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ.
74AUP1G08
Product data sheet
11 / 21
74AUP1G08
Nexperia
12 Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Figure 10. Package outline SOT353-1 (TSSOP5)
74AUP1G08
Product data sheet
12 / 21
74AUP1G08
Nexperia
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
4
e1
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
0.5
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Figure 11. Package outline SOT886 (XSON6)
74AUP1G08
Product data sheet
13 / 21
74AUP1G08
Nexperia
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
4
e1
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Figure 12. Package outline SOT891 (XSON6)
74AUP1G08
Product data sheet
14 / 21
74AUP1G08
Nexperia
XSON6: extremely thin small outline package; no leads;
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
0.3
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Figure 13. Package outline SOT1115 (XSON6)
74AUP1G08
Product data sheet
15 / 21
74AUP1G08
Nexperia
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Figure 14. Package outline SOT1202 (XSON6)
74AUP1G08
Product data sheet
16 / 21
74AUP1G08
Nexperia
X2SON5: plastic thermal enhanced extremely thin small outline package; no leads;
5 terminals; body 0.8 x 0.8 x 0.35 mm
D
A
B
SOT1226
X
A
E
A1
A3
detail X
terminal 1
index area
e
v
w
b
1
2
terminal 1
index area
C
C A B
C
y1 C
y
k
D
h
3
L
5
4
1 mm
scale
Dimensions
Unit
mm
A(1)
A1
A3
D
Dh
E
b
e
k
L
max 0.35 0.04 0.128 0.85 0.30 0.85 0.27
0.27
nom
0.80 0.25 0.80 0.22 0.48
0.22
min
0.040 0.75 0.20 0.75 0.17
0.20 0.17
v
0.1
w
y
y1
0.05 0.05 0.05
Note
1. Dimension A is including plating thickness.
2. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
References
IEC
JEDEC
EIAJ
sot1226_po
European
projection
Issue date
12-04-10
12-04-25
SOT1226
Figure 15. Package outline SOT1226 (X2SON5)
74AUP1G08
Product data sheet
17 / 21
74AUP1G08
Nexperia
13 Abbreviations
Table 12. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
14 Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AUP1G08 v.7
20171130
Product data sheet
74AUP1G08 v.6
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
74AUP1G08 v.6
20120622
Modifications:
• Package outline drawing of SOT1226 (Figure 15) modified.
74AUP1G08 v.5
20120412
Modifications:
• Added type number 74AUP1G08GX (SOT1226)
• Package outline drawing of SOT886 (Figure 11) modified.
74AUP1G08 v.4
20111115
Modifications:
• Legal pages updated.
74AUP1G08 v.3
20101007
74AUP1G08 v.2
74AUP1G08 v.1
74AUP1G08
Product data sheet
Product data sheet
Product data sheet
Product data sheet
74AUP1G08 v.5
74AUP1G08 v.4
74AUP1G08 v.3
Product data sheet
74AUP1G08 v.2
20060629
Product data sheet
74AUP1G08 v.1
20050720
Product data sheet
18 / 21
74AUP1G08
Nexperia
15 Legal information
15.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74AUP1G08
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
19 / 21
74AUP1G08
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74AUP1G08
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
20 / 21
74AUP1G08
Nexperia
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
11.1
12
13
14
15
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 2
Marking .................................................................2
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 3
Functional description ........................................4
Limiting values .................................................... 4
Recommended operating conditions ................ 4
Static characteristics .......................................... 5
Dynamic characteristics .....................................8
Waveforms and test circuit .............................. 10
Package outline .................................................12
Abbreviations .................................................... 18
Revision history ................................................ 18
Legal information .............................................. 19
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 30 November 2017
Document identifier: 74AUP1G08
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AUP1G08GF,132 74AUP1G08GM,115 74AUP1G08GM,132 74AUP1G08GW,125 74AUP1G08GN,132
74AUP1G08GS,132 74AUP1G08GX,125
