74AUP2G132
Low-power dual 2-input NAND Schmitt trigger
Rev. 8 — 3 July 2017
1
Product data sheet
General description
The 74AUP2G132 provides the dual 2-input NAND Schmitt trigger function which
accepts standard input signals. They can transform slowly changing input signals into
sharply defined, jitter-free output signals.
This device ensures a very low static and dynamic power consumption across the entire
VCC range from 0.8 V to 3.6 V.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing a damaging backflow current through the device
when it is powered down.
The inputs switch at different points for positive and negative-going signals. The
difference between the positive voltage VT+ and the negative voltage VT- is defined as the
input hysteresis voltage VH.
2
Features and benefits
• Wide supply voltage range from 0.8 V to 3.6 V
• High noise immunity
• ESD protection:
– HBM JESD22-A114F Class 3A exceeds 5 000 V
– MM JESD22-A115-A exceeds 200 V
– CDM JESD22-C101E exceeds 1 000 V
• Low static power consumption; ICC = 0.9 μA (maximum)
• Latch-up performance exceeds 100 mA per JESD 78 Class II
• Inputs accept voltages up to 3.6 V
• Low noise overshoot and undershoot < 10 % of VCC
• IOFF circuitry provides partial Power-down mode operation
• Multiple package options
• Specified from -40 °C to +85 °C and -40 °C to +125 °C
3
Applications
• Wave and pulse shaper
• Astable multivibrator
• Monostable multivibrator
74AUP2G132
Nexperia
4
Ordering information
Table 1. Ordering information
Type number
Package
Temperature
range
Name
Description
74AUP2G132DC
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package; 8 leads; SOT765-1
body width 2.3 mm
74AUP2G132GT
-40 °C to +125 °C
XSON8
plastic extremely thin small outline package; no leads; SOT833-1
8 terminals; body 1 x 1.95 x 0.5 mm
74AUP2G132GF
-40 °C to +125 °C
XSON8
8 terminals; body 1.35 x 1 x 0.5 mm
SOT1089
74AUP2G132GM
-40 °C to +125 °C
XQFN8
plastic, extremely thin quad flat package; no leads;
8 terminals; body 1.6 x 1.6 x 0.5 mm
SOT902-2
74AUP2G132GN
-40 °C to +125 °C
XSON8
8 terminals; body 1.2 x 1.0 x 0.35 mm
SOT1116
74AUP2G132GS
-40 °C to +125 °C
XSON8
8 terminals; body 1.35 x 1.0 x 0.35 mm
SOT1203
74AUP2G132GX
-40 °C to +125 °C
X2SON8
plastic thermal enhanced extremely thin
small outline package; no leads; 8 terminals;
body 1.35 x 0.8 x 0.35 mm
SOT1233
5
Marking
Table 2. Marking codes
Type number
Marking code
74AUP2G132DC
aE2
74AUP2G132GT
aE2
74AUP2G132GF
aE
74AUP2G132GM
aE2
74AUP2G132GN
aE
74AUP2G132GS
aE
74AUP2G132GX
aE
[1]
Version
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74AUP2G132
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 25
74AUP2G132
Nexperia
6
Functional diagram
1A
1Y
1B
2A
A
2Y
Y
2B
B
001aah880
001aah881
Figure 1. Logic symbol
7
001aac532
Figure 2. IEC logic symbol
Figure 3. Logic diagram (one gate)
Pinning information
7.1 Pinning
74AUP2G132
1A
1
8
VCC
1B
2
7
1Y
2Y
3
6
2B
GND
4
5
2A
74AUP2G132
1A
1
8
VCC
1B
2
7
1Y
2Y
3
6
2B
GND
4
5
2A
001aaf165
Transparent top view
001aaf164
Figure 5. Pin configuration SOT833-1, SOT1089,
SOT1116 and SOT1203
Figure 4. Pin configuration SOT765-1
74AUP2G132
1
74AUP2G132
8
1Y
VCC
terminal 1
index area
7
1A
1A 1
2B
2
6
1B
4
GND
3
5
74AUP2G132
Product data sheet
2
2Y
6
2B
5
2A
4
GND
2Y
3
001aaf166
aaa-027033
Figure 6. Pin configuration SOT902-2
1Y
VCC
1B
2A
7
8
Figure 7. Pin configuration SOT1233
3 / 25
74AUP2G132
Nexperia
7.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
SOT765-1, SOT833-1, SOT1089, SOT1116,
SOT1203 and SOT1233
SOT902-2
1A, 2A
1, 5
7, 3
data input
1B, 2B
2, 6
6, 2
data input
GND
4
4
ground (0 V)
1Y, 2Y
7, 3
1, 5
data output
VCC
8
8
supply voltage
8
Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Output
Input
nA
nB
nY
L
L
H
L
H
H
H
L
H
H
H
L
74AUP2G132
Product data sheet
4 / 25
74AUP2G132
Nexperia
9
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
[1]
Min
Max
Unit
-0.5
+4.6
V
-50
-0.5
+4.6
-50
-0.5
+4.6
V
±20
mA
mA
V
mA
VO
output voltage
Active mode and Power-down mode
IO
output current
VO = 0 V to VCC
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
250
mW
Ptot
[1]
[2]
total power dissipation
Tamb = -40 °C to +125 °C
[2]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For VSSOP8 packages: above 110 °C the value of Ptot derates linearly with 8.0 mW/K.
For XSON8 and XQFN8 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
For X2SON8 package: above 118 °C the value of Ptot derates linearly with 7.7 mW/K.
10 Recommended operating conditions
Table 6. Operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
Conditions
Min
Max
0.8
3.6
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
-40
+125
°C
ambient temperature
74AUP2G132
Product data sheet
Unit
5 / 25
74AUP2G132
Nexperia
11 Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Min
Typ
Max
Unit
VCC - 0.1
V
IO = -1.1 mA; VCC = 1.1 V
0.75 × VCC
V
IO = -1.7 mA; VCC = 1.4 V
1.11
V
IO = -1.9 mA; VCC = 1.65 V
1.32
V
IO = -2.3 mA; VCC = 2.3 V
2.05
V
IO = -3.1 mA; VCC = 2.3 V
1.9
V
IO = -2.7 mA; VCC = 3.0 V
2.72
V
IO = -4.0 mA; VCC = 3.0 V
2.6
V
IO = 20 μA; VCC = 0.8 V to 3.6 V
0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.3 × VCC
V
IO = 1.7 mA; VCC = 1.4 V
0.31
V
IO = 1.9 mA; VCC = 1.65 V
0.31
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
Conditions
Tamb = 25 °C
VOH
HIGH-level output voltage
VI = VT+ or VTIO = -20 μA; VCC = 0.8 V to 3.6 V
VOL
II
LOW-level output voltage
VI = VT+ or VT-
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
±0.1
μA
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.2
μA
additional power-off
leakage current
VCC = 0 V to 0.2 V
±0.2
μA
supply current
VI = GND or VCC; IO = 0 A;
0.5
μA
additional supply current
VI = VCC - 0.6 V; IO = 0 A;VCC = 3.3 V
40
μA
CI
input capacitance
VI = GND or VCC; VCC = 0 V to 3.6 V
1.1
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
IOFF
ΔIOFF
ICC
ΔICC
74AUP2G132
Product data sheet
[1]
6 / 25
74AUP2G132
Nexperia
Symbol Parameter
Min
Typ
Max
Unit
VCC - 0.1
V
0.7 × VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.3 × VCC
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
Conditions
Tamb = -40 °C to +85 °C
VOH
VOL
II
IOFF
ΔIOFF
ICC
ΔICC
VI = VT+ or VT-
VI = VT+ or VT-
±0.5
μA
±0.5
μA
leakage current
VCC = 0 V to 0.2 V
±0.6
μA
supply current
0.9
μA
50
μA
74AUP2G132
Product data sheet
[1]
7 / 25
74AUP2G132
Nexperia
Symbol Parameter
Min
Typ
Max
Unit
VCC - 0.11
V
0.6 × VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33 × VCC
V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
Conditions
VOH
VOL
II
IOFF
ΔIOFF
ICC
ΔICC
[1]
VI = VT+ or VT-
VI = VT+ or VT-
±0.75
μA
±0.75
μA
leakage current
VCC = 0 V to 0.2 V
±0.75
μA
supply current
1.4
μA
75
μA
[1]
One input at VCC - 0.6 V, other input at VCC or GND.
74AUP2G132
Product data sheet
8 / 25
74AUP2G132
Nexperia
12 Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V; for test circuit see Figure 9.
Symbol Parameter
Conditions
Tamb = 25 °C
Min
[1]
Typ
Tamb = -40 °C to +125 °C Unit
Max
Min
Max
Max
(85 °C) (125 °C)
CL = 5 pF
tpd
propagation delay
nA or nB to nY; see Figure 8
[2]
VCC = 0.8 V
22.5
ns
VCC = 1.1 V to 1.3 V
2.6
6.3
13.4
2.4
15.1
16.6
ns
VCC = 1.4 V to 1.6 V
2.2
4.6
8.2
1.9
9.7
10.7
ns
VCC = 1.65 V to 1.95 V
1.9
3.9
6.6
1.7
7.9
8.7
ns
VCC = 2.3 V to 2.7 V
1.7
3.2
5.3
1.5
6.2
6.8
ns
VCC = 3.0 V to 3.6 V
1.6
2.9
4.7
1.4
5.6
6.2
ns
26.1
ns
3.0
7.2
15.4
2.7
17.3
19.0
ns
2.5
5.2
9.3
2.2
11.0
12.1
ns
2.3
4.5
7.5
2.0
9.0
9.9
ns
2.1
3.8
6.1
1.8
7.2
7.9
ns
2.0
3.5
5.5
1.8
6.5
7.2
ns
29.6
ns
3.3
8.0
17.2
3.0
19.4
21.3
ns
2.8
5.8
10.4
2.5
12.3
13.5
ns
2.6
5.0
8.3
2.3
10.0
11.0
ns
2.3
4.2
6.7
2.1
7.9
8.7
ns
2.2
3.9
6.1
2.0
7.3
8.0
ns
CL = 10 pF
tpd
propagation delay
[2]
VCC = 0.8 V
CL = 15 pF
tpd
propagation delay
VCC = 0.8 V
74AUP2G132
Product data sheet
[2]
9 / 25
74AUP2G132
Nexperia
Symbol Parameter
Conditions
Tamb = 25 °C
Min
[1]
Typ
Max
Min
Max
Max
(85 °C) (125 °C)
CL = 30 pF
tpd
propagation delay
[2]
VCC = 0.8 V
39.9
ns
4.3
10.2
22.6
3.8
25.4
27.9
ns
3.6
7.3
13.3
3.2
15.8
17.4
ns
3.2
6.3
10.6
2.9
12.8
14.1
ns
3.0
5.3
8.5
2.7
10.1
11.1
ns
2.8
5.0
7.8
2.7
9.2
10.1
ns
VCC = 0.8 V
2.6
pF
2.9
pF
3.0
pF
3.2
pF
3.8
pF
4.4
pF
CL = 5 pF, 10 pF, 15 pF and 30 pF
CPD
power dissipation
capacitance
[1]
[2]
[3]
fi = 1 MHz; VI = GND to VCC
[3]
All typical values are measured at nominal VCC.
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of the outputs.
74AUP2G132
Product data sheet
10 / 25
74AUP2G132
Nexperia
12.1 Waveforms and test circuit
VT+
VM
nA, nB input
VT-
tPHL
tPLH
VOH
VM
nY output
VOL
001aaj265
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Figure 8. The data input (nA or nB) to output (nY) propagation delays
Table 9. Measurement points
Supply voltage
Output
Input
VCC
VM
VM
VI
tr = tf
0.8 V to 3.6 V
0.5 x VCC
0.5 x VCC
VCC
≤ 3.0 ns
VCC
G
VI
DUT
VEXT
5 kΩ
VO
RT
CL
RL
001aac521
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 9. Test circuit for measuring switching times
Table 10. Test data
Supply voltage Load
VEXT
[1]
VCC
CL
RL
0.8 V to 3.6 V
5 kΩ or 1 MΩ
[1]
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
open
GND
2 x VCC
RL = 5 kΩ when measuring enable and disable times. RL = 1 MΩ when measuring propagation delays, setup and hold times and pulse width.
74AUP2G132
Product data sheet
11 / 25
74AUP2G132
Nexperia
13 Transfer characteristics
Table 11. Transfer characteristics
Symbol Parameter
VT+
VT-
VH
positive-going
threshold voltage
negative-going
threshold voltage
Conditions
Tamb = 25 °C
Min
Typ
Max
Min
Max
(85 °C)
Max
(125 °C)
VCC = 0.8 V
0.30
0.60
0.30
0.60
0.62
V
VCC = 1.1 V
0.53
0.90
0.53
0.90
0.92
V
VCC = 1.4 V
0.74
1.11
0.74
1.11
1.13
V
VCC = 1.65 V
0.91
1.29
0.91
1.29
1.31
V
VCC = 2.3 V
1.37
1.77
1.37
1.77
1.80
V
VCC = 3.0 V
1.88
2.29
1.88
2.29
2.32
V
VCC = 0.8 V
0.10
0.60
0.10
0.60
0.60
V
VCC = 1.1 V
0.26
0.65
0.26
0.65
0.65
V
VCC = 1.4 V
0.39
0.75
0.39
0.75
0.75
V
VCC = 1.65 V
0.47
0.84
0.47
0.84
0.84
V
VCC = 2.3 V
0.69
1.04
0.69
1.04
1.04
V
VCC = 3.0 V
0.88
1.24
0.88
1.24
1.24
V
VCC = 0.8 V
0.07
0.50
0.07
0.50
0.50
V
VCC = 1.1 V
0.08
0.46
0.08
0.46
0.46
V
VCC = 1.4 V
0.18
0.56
0.18
0.56
0.56
V
VCC = 1.65 V
0.27
0.66
0.27
0.66
0.66
V
VCC = 2.3 V
0.53
0.92
0.53
0.92
0.92
V
VCC = 3.0 V
0.79
1.31
0.79
1.31
1.31
V
see Figure 10 and
Figure 11
see Figure 10 and
Figure 11
hysteresis voltage (VT+ - VT-); see Figure 10,
Figure 11, Figure 12 and
Figure 13
74AUP2G132
Product data sheet
12 / 25
74AUP2G132
Nexperia
13.1 Waveforms transfer characteristics
VO
VI
VT+
VH
VT-
VO
VI
VH
VT-
VT+
mna208
VT+ and VT- limits at 70 % and 20 %.
mna207
Figure 10. Transfer characteristic
Figure 11. Definition of VT+, VT- and VH
001aad691
240
001aad692
1200
ICC
(µA)
ICC
(µA)
160
800
80
400
0.8
1.2
1.6
VI (V)
Figure 12. Typical transfer characteristics; VCC = 1.8 V
74AUP2G132
Product data sheet
2.0
VI (V)
3.0
Figure 13. Typical transfer characteristics; VCC = 3.0 V
13 / 25
74AUP2G132
Nexperia
14 Application information
The slow input rise and fall times cause additional power dissipation which can be
calculated using the following formula:
Padd = fi x (tr × ΔICC(AV) + tf x ΔICC(AV)) x VCC where:
Padd = additional power dissipation (μW);
fi = input frequency (MHz);
tr = input rise time (ns); 10 % to 90 %;
tf = input fall time (ns); 90 % to 10 %;
ΔICC(AV) = average additional supply current (μA).
Average ΔICC(AV) differs with positive or negative input transitions, as shown in Figure 14.
001aad027
0.3
ΔICC(AV)
(mA)
(1)
0.2
(2)
0.1
1.8
2.8
VCC (V)
3.8
(1) Positive-going edge
(2) Negative-going edge
Linear change of VI between 0.8 V and 2.0 V. All values given are typical, unless otherwise specified.
Figure 14. Average ICC as a function of VCC
74AUP2G132
Product data sheet
14 / 25
74AUP2G132
Nexperia
15 Package outline
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
A
max.
max
nom
min
mm
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Figure 15. Package outline SOT765-1 (VSSOP8)
74AUP2G132
Product data sheet
15 / 25
74AUP2G132
Nexperia
XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
1
2
SOT833-1
b
4
3
4×
(2)
L
L1
e
8
7
6
e1
5
e1
e1
8×
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A(1)
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.25
0.17
2.0
1.9
1.05
0.95
0.6
0.5
0.35
0.27
0.40
0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT833-1
MO-252
EUROPEAN
PROJECTION
ISSUE DATE
07-11-14
07-12-07
Figure 16. Package outline SOT833-1 (XSON8)
74AUP2G132
Product data sheet
16 / 25
74AUP2G132
Nexperia
XSON8: extremely thin small outline package; no leads;
SOT1089
E
terminal 1
index area
D
A
A1
detail X
(4×)(2)
e
L
(8×)(2)
b 4
5
e1
1
terminal 1
index area
8
L1
X
scale
Dimensions
Unit
max
nom
min
mm
1 mm
A(1)
0.5
A1
b
D
E
e
e1
L
L1
0.04 0.20 1.40 1.05
0.35 0.40
0.15 1.35 1.00 0.55 0.35 0.30 0.35
0.12 1.30 0.95
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
SOT1089
sot1089_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-09
10-04-12
MO-252
Figure 17. Package outline SOT1089 (XSON8)
74AUP2G132
Product data sheet
17 / 25
74AUP2G132
Nexperia
XQFN8: plastic, extremely thin quad flat package; no leads;
SOT902-2
X
D
B
A
terminal 1
index area
E
A
A1
detail X
e
v
w
b
4
C
C A B
C
3
y1 C
y
5
e1
terminal 1
index area
2
6
L 1
7
k
8
L2
L
k
metal area
not for soldering
L3
L1
Dimensions
Unit(1)
max
nom
min
mm
2 mm
scale
A
0.5
A1
b
D
E
e
e1
0.05 0.25 1.65 1.65
0.20 1.60 1.60 0.55
0.00 0.15 1.55 1.55
0.5
k
L
0.2
L1
L2
L3
0.35 0.15 0.25 0.35
0.30 0.10 0.20 0.30
0.25 0.05 0.15 0.25
v
0.1
w
y
y1
0.05 0.05 0.05
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
References
Outline
version
IEC
JEDEC
JEITA
SOT902-2
MO-255
sot902-2_po
European
projection
Issue date
16-07-14
16-11-08
Figure 18. Package outline SOT902-2 (XQFN8)
74AUP2G132
Product data sheet
18 / 25
74AUP2G132
Nexperia
1
2
SOT1116
b
4
3
(4×)(2)
L
L1
e
8
7
e1
6
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 1.25 1.05
nom
0.15 1.20 1.00 0.55
min
0.12 1.15 0.95
mm
1 mm
scale
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
Outline
version
sot1116_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1116
Figure 19. Package outline SOT1116 (XSON8)
74AUP2G132
Product data sheet
19 / 25
74AUP2G132
Nexperia
SOT1203
b
1
2
3
(4×)(2)
4
L
L1
e
8
7
6
e1
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.40 1.05
0.35 0.40
nom
min
0.12 1.30 0.95
0.27 0.32
mm
Note
Outline
version
sot1203_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1203
Figure 20. Package outline SOT1203 (XSON8)
74AUP2G132
Product data sheet
20 / 25
74AUP2G132
Nexperia
X2SON8: plastic thermal enhanced extremely thin small outline package; no leads;
8 terminals; body 1.35 x 0.8 x 0.35 mm
SOT1233
X
A
B
D
A
E
A1
detail X
pin 1
index area
e
e
1
2
pin 1
index area
C
b
(6x)
8
v
w
3
C A B
C
y
4
Dh
L
(6x)
7
6
b1
(2x)
5
y1 C
e1
1 mm
scale
Unit
mm
A
A1
max 0.35 0.04
nom 0.32
min 0.30 0.00
b
0.25
0.20
0.15
b1
D
Dh
E
1.40 0.27 0.85
0.15 1.35 0.22 0.80
(ref) 1.30 0.17 0.75
e
0.5
e1
L
0.27
0.54 0.22
0.17
v
0.1
w
y
y1
0.05 0.05 0.05
sot1233_po
Outline
version
SOT1233
References
IEC
JEDEC
JEITA
European
projection
Issue date
16-04-21
17-01-05
Figure 21. Package outline SOT1233 (X2SON8)
74AUP2G132
Product data sheet
21 / 25
74AUP2G132
Nexperia
16 Abbreviations
Table 12. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
17 Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AUP2G132 v.8
20170703
Product data sheet
74AUP2G132 v.7
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
• Type number 74AUP2G132GX (SOT1233 / X2SON8) added.
• Type number 74AUP2G132GD removed.
74AUP2G132 v.7
20130208
Modifications:
• For type number 74AUP2G132GD XSON8U has changed to XSON8.
74AUP2G132 v.6
20120803
Product data sheet
74AUP2G132 v.5
74AUP2G132 v.5
20111201
Product data sheet
74AUP2G132 v.4
74AUP2G132 v.4
20101104
Product data sheet
74AUP2G132 v.3
74AUP2G132 v.3
20081215
Product data sheet
74AUP2G132 v.2
74AUP2G132 v.2
20080314
Product data sheet
74AUP2G132 v.1
74AUP2G132 v.1
20061018
Product data sheet
74AUP2G132
Product data sheet
Product data sheet
74AUP2G132 v.6
22 / 25
74AUP2G132
Nexperia
18 Legal information
18.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
18.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
18.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74AUP2G132
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
23 / 25
74AUP2G132
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74AUP2G132
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
18.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
24 / 25
74AUP2G132
Nexperia
Contents
1
2
3
4
5
6
7
7.1
7.2
8
9
10
11
12
12.1
13
13.1
14
15
16
17
18
General description ............................................ 1
Features and benefits .........................................1
Applications .........................................................1
Ordering information .......................................... 2
Marking .................................................................2
Functional diagram ............................................. 3
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 4
Functional description ........................................4
Limiting values .................................................... 5
Recommended operating conditions ................ 5
Static characteristics .......................................... 6
Dynamic characteristics .....................................9
Waveforms and test circuit .............................. 11
Transfer characteristics ................................... 12
Waveforms transfer characteristics ..................13
Application information .................................... 14
Package outline .................................................15
Abbreviations .................................................... 22
Revision history ................................................ 22
Legal information .............................................. 23
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 3 July 2017
Document identifier: 74AUP2G132
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AUP2G132DC,125 74AUP2G132GM,125 74AUP2G132GT,115 74AUP2G132GN,115 74AUP2G132GS,115
74AUP2G132GD,125 74AUP2G132GF,115 74AUP2G132GXX
