74AUP3G3404
Low-power dual buffer and single inverter
Rev. 2 — 26 April 2019
Product data sheet
1. General description
The 74AUP3G3404 is a dual buffer and single inverter.
Schmitt trigger action at all inputs makes the circuit tolerant of slower input rise and fall times
across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire VCC range
This device is fully specified for partial Power-down applications using IOFF. The IOFF circuitry
disables the output, preventing a damaging backflow current through the device when it is powered
down.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
• JESD8-12 (0.8 V to 1.3 V)
• JESD8-11 (0.9 V to 1.65 V)
• JESD8-7 (1.2 V to 1.95 V)
• JESD8-5 (1.8 V to 2.7 V)
• JESD8-B (2.7 V to 3.6 V)
ESD protection:
• HBM JESD22-A114F Class 3A exceeds 5000 V
• MM JESD22-A115-A exceeds 200 V
• CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 μA (maximum)
Latch-up performance exceeds 100 mA per JESD 78B Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C
74AUP3G3404
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range Name
Description
Version
74AUP3G3404DC
-40 °C to +125 °C
VSSOP8 plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
SOT765-1
74AUP3G3404GT
-40 °C to +125 °C
XSON8
plastic extremely thin small outline package;
no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
SOT833-1
74AUP3G3404GF
-40 °C to +125 °C
XSON8
extremely thin small outline package; no leads;
8 terminals; body 1.35 x 1 x 0.5 mm
SOT1089
74AUP3G3404GM
-40 °C to +125 °C
XQFN8
plastic, extremely thin quad flat package; no leads;
8 terminals; body 1.6 x 1.6 x 0.5 mm
SOT902-2
74AUP3G3404GN
-40 °C to +125 °C
XSON8
8 terminals; body 1.2 x 1.0 x 0.35 mm
SOT1116
74AUP3G3404GS
-40 °C to +125 °C
XSON8
8 terminals; body 1.35 x 1.0 x 0.35 mm
SOT1203
4. Marking
Table 2. Marking codes
Type number
Marking code[1]
74AUP3G3404DC
aZ
74AUP3G3404GT
aZ
74AUP3G3404GF
aZ
74AUP3G3404GM
aZ
74AUP3G3404GN
aZ
74AUP3G3404GS
aZ
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
1
1A
1Y
2A
2Y
3A
1
Logic symbol
74AUP3G3404
Product data sheet
1Y
2A
2Y
3A
3Y
1
3Y
aaa-005904
Fig. 1.
1A
aaa-005905
Fig. 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
aaa-005906
Fig. 3.
Logic diagram
Nexperia B.V. 2019. All rights reserved
2 / 19
74AUP3G3404
Nexperia
6. Pinning information
6.1. Pinning
74AUP3G3404
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
74AUP3G3404
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
aaa-005907
Transparent top view
aaa-005908
Fig. 4.
Fig. 5.
Pin configuration SOT765-1 (VSSOP8)
Pin configuration SOT833-1, SOT1089, SOT1116
and SOT1203 (XSON8)
74AUP3G3404
1Y
1
3A
2Y
8
VCC
terminal 1
index area
1A
2
6
3Y
3
5
2A
GND
4
7
aaa-005910
Fig. 6.
Pin configuration SOT902-2 (XQFN8)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
SOT765-1, SOT833-1, SOT1089, SOT1116 and
SOT1203
SOT902-2
1A, 2A, 3A
1, 3, 6
7, 5, 2
data input
1Y, 2Y, 3Y
7, 5, 2
1, 3, 6
data output
GND
4
4
ground (0 V)
VCC
8
8
supply voltage
74AUP3G3404
Product data sheet
3 / 19
74AUP3G3404
Nexperia
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
1A, 3A
1Y, 3Y
L
L
H
H
Table 5. Function table
Input
Output
2A
2Y
L
H
H
L
8. Limiting values
Table 6. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
-0.5
+4.6
V
IIK
input clamping current
-50
VI
input voltage
[1]
-0.5
+4.6
IOK
output clamping current
VO < 0 V
VO
output voltage
Active mode and Power-down mode
-50
[1]
-0.5
+4.6
V
IO
output current
VO = 0 V to VCC
±20
mA
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
Conditions
VI < 0 V
Tamb = -40 °C to +125 °C
[2]
mA
V
mA
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For VSSOP8 packages: above 110 °C the value of Ptot derates linearly with 8.0 mW/K.
For XSON8 and XQFN8 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 7. Operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74AUP3G3404
Product data sheet
Min
Max
Unit
0.8
3.6
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
-40
+125
°C
200
ns/V
VCC = 0.8 V to 3.6 V
4 / 19
74AUP3G3404
Nexperia
10. Static characteristics
Table 8. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70VCC
V
VCC = 0.9 V to 1.95 V
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30VCC
V
0.35VCC
V
0.7
V
0.9
V
IO = -20 μA; VCC = 0.8 V to 3.6 V
VCC - 0.1
V
IO = -1.1 mA; VCC = 1.1 V
0.75VCC
V
IO = -1.7 mA; VCC = 1.4 V
1.11
V
IO = -1.9 mA; VCC = 1.65 V
1.32
V
IO = -2.3 mA; VCC = 2.3 V
2.05
V
IO = -3.1 mA; VCC = 2.3 V
1.9
V
IO = -2.7 mA; VCC = 3.0 V
2.72
V
IO = -4.0 mA; VCC = 3.0 V
2.6
V
IO = 20 μA; VCC = 0.8 V to 3.6 V
0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.3VCC
V
IO = 1.7 mA; VCC = 1.4 V
0.31
V
IO = 1.9 mA; VCC = 1.65 V
0.31
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
Tamb = 25 °C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
±0.1
μA
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.2
μA
ΔIOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
±0.2
μA
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
μA
ΔICC
additional supply current
VI = VCC - 0.6 V; IO = 0 A;
VCC = 3.3 V
40
μA
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
1.0
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.8
pF
74AUP3G3404
Product data sheet
5 / 19
74AUP3G3404
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70VCC
V
0.65VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.30VCC
V
0.35VCC
V
0.7
V
0.9
V
VCC - 0.1
V
0.7VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.3VCC
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
Tamb = -40 °C to +85 °C
VIH
VIL
VOH
VI = VIH or VIL
VOL
VI = VIH or VIL
II
±0.5
μA
IOFF
±0.5
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.6
μA
ICC
supply current
0.9
μA
ΔICC
VCC = 3.3 V
50
μA
74AUP3G3404
Product data sheet
6 / 19
74AUP3G3404
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.75VCC
V
0.70VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.25VCC
V
0.30VCC
V
0.7
V
0.9
V
VCC - 0.11
V
0.6VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33VCC
V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
VIH
VIL
VOH
VI = VIH or VIL
VOL
VI = VIH or VIL
II
±0.75
μA
IOFF
±0.75
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.75
μA
ICC
supply current
1.4
μA
ΔICC
VCC = 3.3 V
75
μA
74AUP3G3404
Product data sheet
7 / 19
74AUP3G3404
Nexperia
11. Dynamic characteristics
Table 9. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8.
Symbol Parameter
Conditions
25 °C
Min
-40 °C to +125 °C
Typ[1] Max
Min
Unit
Max
Max
(85 °C) (125 °C)
CL = 5 pF
tpd
propagation delay nA to nY; see Fig. 7
[2]
VCC = 0.8 V
16.0
ns
VCC = 1.1 V to 1.3 V
2.4
5.0
10.3
2.0
11.4
12.6
ns
VCC = 1.4 V to 1.6 V
1.8
3.6
6.4
1.6
7.4
8.2
ns
VCC = 1.65 V to 1.95 V
1.5
2.9
5.0
1.4
5.9
6.5
ns
1.2
2.4
3.9
1.1
4.5
5.0
ns
1.1
2.1
3.2
1.0
3.9
4.3
ns
CL = 10 pF
tpd
[2]
VCC = 0.8 V
19.8
ns
2.8
5.9
12.2
2.3
13.7
15.1
ns
2.3
4.2
7.5
1.9
8.7
9.6
ns
2.0
3.5
5.9
1.7
7.0
7.7
ns
1.7
2.9
4.6
1.5
5.4
6.0
ns
1.6
2.7
3.8
1.4
4.5
5.1
ns
23.3
ns
3.2
6.7
13.0
2.6
15.8
17.4
ns
2.6
4.7
8.6
2.2
10.0
11.0
ns
2.3
4.0
6.7
2.0
8.0
8.8
ns
2.1
3.3
5.1
1.8
6.1
6.8
ns
2.0
3.1
4.2
1.6
5.0
5.5
ns
33.6
ns
4.4
8.9
16.3
3.6
19.0
20.9
ns
3.6
6.3
10.8
3.2
12.9
14.2
ns
3.2
5.3
9.0
2.9
10.5
11.6
ns
2.9
4.5
6.5
2.6
7.6
8.5
ns
2.9
4.2
5.6
2.5
6.2
7.2
ns
CL = 15 pF
tpd
[2]
VCC = 0.8 V
CL = 30 pF
tpd
[2]
VCC = 0.8 V
74AUP3G3404
Product data sheet
8 / 19
74AUP3G3404
Nexperia
Symbol Parameter
Conditions
25 °C
Min
-40 °C to +125 °C
Typ[1] Max
Min
Unit
Max
Max
(85 °C) (125 °C)
CL = 5 pF, 10 pF, 15 pF and 30 pF
CPD
[1]
[2]
[3]
[4]
power dissipation
capacitance
fi = 1 MHz; VI = GND to VCC
[3][4]
VCC = 0.8 V
2.5
pF
2.7
pF
2.8
pF
3.0
pF
3.5
pF
4.0
pF
All typical values are measured at nominal VCC.
tpd is the same as tPLH and tPHL.
All specified values are the average typical values over all stated loads.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of the outputs.
11.1. Waveforms and test circuit
VI
VI
1A, 3A input
VM
2A input
VM
GND
VM
VM
GND
tPLH
tPHL
tPHL
VOH
tPLH
VOH
1Y, 3Y output
VM
VM
2Y output
VOL
VM
VM
VOL
aaa-005911
Measurement points are given in Table 10.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 7.
The data input 1A to output 1Y, input 2A to output 2Y and input 3A to output 3Y propagation delays
Table 10. Measurement points
Supply voltage
Output
Input
VCC
VM
VM
VI
tr = tf
0.8 V to 3.6 V
0.5VCC
0.5VCC
VCC
≤ 3.0 ns
74AUP3G3404
Product data sheet
9 / 19
74AUP3G3404
Nexperia
VCC
G
VI
DUT
VEXT
5 kΩ
VO
RT
CL
RL
001aac521
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 8.
Test circuit for measuring switching times
Table 11. Test data
Supply voltage
Load
VEXT
VCC
CL
RL[1]
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
0.8 V to 3.6 V
5 pF, 10 pF, 15 pF,
and 30 pF
5 kΩ or 1 MΩ
open
GND
2VCC
[1]
For measuring enable and disable times, RL = 5 kΩ.
For measuring propagation delays, setup and hold times, and pulse width, RL = 1 MΩ.
74AUP3G3404
Product data sheet
10 / 19
74AUP3G3404
Nexperia
12. Package outline
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
A
max.
max
nom
min
mm
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
Fig. 9.
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Package outline SOT765-1 (VSSOP8)
74AUP3G3404
Product data sheet
11 / 19
74AUP3G3404
Nexperia
XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
1
2
SOT833-1
b
4
3
4×
(2)
L
L1
e
8
7
6
e1
5
e1
e1
8×
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A(1)
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.25
0.17
2.0
1.9
1.05
0.95
0.6
0.5
0.35
0.27
0.40
0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT833-1
MO-252
EUROPEAN
PROJECTION
ISSUE DATE
07-11-14
07-12-07
Fig. 10. Package outline SOT833-1 (XSON8)
74AUP3G3404
Product data sheet
12 / 19
74AUP3G3404
Nexperia
XSON8: extremely thin small outline package; no leads;
SOT1089
E
terminal 1
index area
D
A
A1
detail X
(4×)(2)
e
L
(8×)(2)
b 4
5
e1
1
terminal 1
index area
8
L1
X
scale
Dimensions
Unit
max
nom
min
mm
1 mm
A(1)
0.5
A1
b
D
E
e
e1
L
L1
0.04 0.20 1.40 1.05
0.35 0.40
0.15 1.35 1.00 0.55 0.35 0.30 0.35
0.12 1.30 0.95
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
SOT1089
sot1089_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-09
10-04-12
MO-252
Fig. 11. Package outline SOT1089 (XSON8)
74AUP3G3404
Product data sheet
13 / 19
74AUP3G3404
Nexperia
XQFN8: plastic, extremely thin quad flat package; no leads;
SOT902-2
X
D
B
A
terminal 1
index area
E
A
A1
detail X
e
v
w
b
4
3
C
C A B
C
y1 C
y
5
e1
terminal 1
index area
2
6
L 1
7
k
8
L2
L
k
metal area
not for soldering
L3
L1
Dimensions
Unit(1)
max
nom
min
mm
2 mm
scale
A
0.5
A1
b
D
E
e
e1
0.05 0.25 1.65 1.65
0.20 1.60 1.60 0.55
0.00 0.15 1.55 1.55
0.5
k
0.2
L
L1
L2
L3
0.35 0.15 0.25 0.35
0.30 0.10 0.20 0.30
0.25 0.05 0.15 0.25
v
0.1
w
y
y1
0.05 0.05 0.05
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
References
Outline
version
IEC
JEDEC
JEITA
SOT902-2
MO-255
sot902-2_po
European
projection
Issue date
16-07-14
16-11-08
Fig. 12. Package outline SOT902-2 (XQFN8)
74AUP3G3404
Product data sheet
14 / 19
74AUP3G3404
Nexperia
1
2
SOT1116
b
4
3
(4×)(2)
L
L1
e
8
7
e1
6
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 1.25 1.05
nom
0.15 1.20 1.00 0.55
min
0.12 1.15 0.95
mm
1 mm
scale
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
Outline
version
sot1116_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1116
Fig. 13. Package outline SOT1116 (XSON8)
74AUP3G3404
Product data sheet
15 / 19
74AUP3G3404
Nexperia
SOT1203
b
1
2
3
(4×)(2)
4
L
L1
e
8
7
6
e1
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.40 1.05
0.35 0.40
nom
min
0.12 1.30 0.95
0.27 0.32
mm
Note
Outline
version
sot1203_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1203
Fig. 14. Package outline SOT1203 (XSON8)
74AUP3G3404
Product data sheet
16 / 19
74AUP3G3404
Nexperia
13. Abbreviations
Table 12. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
14. Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AUP3G3404 v.2
20190426
Product data sheet
74AUP3G3404 v.1
Modifications:
74AUP3G3404 v.1
74AUP3G3404
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74AUP3G3404GD (SOT996-2/XSON8) removed.
Package outline drawing SOT765-1 and SOT902-2 updated.
20130114
Product data sheet
17 / 19
74AUP3G3404
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AUP3G3404
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
18 / 19
74AUP3G3404
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 3
7. Functional description................................................. 4
8. Limiting values............................................................. 4
9. Recommended operating conditions..........................4
10. Static characteristics..................................................5
11. Dynamic characteristics.............................................8
11.1. Waveforms and test circuit........................................ 9
12. Package outline........................................................ 11
13. Abbreviations............................................................ 17
14. Revision history........................................................17
15. Legal information......................................................18
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 26 April 2019
74AUP3G3404
Product data sheet
19 / 19
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AUP3G3404GTX 74AUP3G3404GMH 74AUP3G3404GNX 74AUP3G3404GSX 74AUP3G3404GDH
74AUP3G3404GFX 74AUP3G3404DCH
