74AXP1G06
Low-power inverter with open-drain output
Rev. 1 — 15 January 2014
Product data sheet
1. General description
The 74AXP1G06 is a single inverter with open-drain output.
Schmitt-trigger action at the input makes the circuit tolerant of slower input rise and fall
times.
This device ensures very low static and dynamic power consumption across the entire
VCC range from 0.7 V to 2.75 V. It is fully specified for partial power down applications
using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging
backflow current through the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.7 V to 2.75 V
Low input capacitance; CI = 0.5 pF (typical)
Low output capacitance; CO = 0.7 pF (typical)
Low dynamic power consumption; CPD = 1.0 pF at VCC = 1.2 V (typical)
Low static power consumption; ICC = 0.6 A (85 C maximum)
High noise immunity
Complies with JEDEC standard:
JESD8-12A.01 (1.1 V to 1.3 V)
JESD8-11A.01 (1.4 V to 1.6 V)
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A.01 (2.3 V to 2.7 V)
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV
CDM JESD22-C101E exceeds 1000 V
Latch-up performance exceeds 100 mA per JESD 78 Class II
Input accepts voltages up to 2.75 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C
74AXP1G06
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AXP1G06GM
40 C to +85 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AXP1G06GN
40 C to +85 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AXP1G06GS
40 C to +85 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74AXP1G06GX
40 C to +85 C
X2SON5
X2SON5: plastic thermal enhanced extremely thin
small outline package; no leads; 5 terminals;
body 0.8 0.8 0.35 mm
SOT1226
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74AXP1G06GM
rR
74AXP1G06GN
rR
74AXP1G06GS
rR
74AXP1G06GX
rR
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Y
2
A
Y
4
A
2
4
Y
A
GND
Fig 1.
Logic symbol
74AXP1G06
Product data sheet
mna620
mna619
mna618
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 17
74AXP1G06
Nexperia
6. Pinning information
6.1 Pinning
$;3*
$;3*
QF
9&&
QF
QF
*1'
9&&
*1'
DDD
DDD
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
Fig 4.
Pin configuration SOT886, SOT1115 and
SOT1202 (XSON6)
Fig 5.
Pin configuration SOT1226 (X2SON5)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
X2SON5
XSON6
n.c.
1
1
not connected
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
7. Functional description
Table 4.
Function table[1]
Input
Output
A
Y
L
Z
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
74AXP1G06
Product data sheet
3 of 17
74AXP1G06
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
[1]
Min
Max
Unit
0.5
+3.3
V
50
mA
0.5
+3.3
V
50
mA
0.5
+3.3
V
VO
output voltage
IO
output current
mA
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
[1]
VO = 0 V to VCC
Tamb = 40 C to +85 C
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
0.7
2.75
V
VI
input voltage
V
VO
output voltage
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+85
C
ns/V
Tamb
ambient temperature
t/V
input transition rise and fall rate
74AXP1G06
Product data sheet
VCC = 0.7 V to 2.75 V
4 of 17
74AXP1G06
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
HIGH-level input
voltage
VIH
LOW-level input
voltage
VIL
LOW-level output
voltage
VOL
Unit
Typ 25 C Max 25 C Max 85 C
VCC = 0.75 V to 0.85 V
0.75VCC
V
VCC = 1.1 V to 1.95 V
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.6
V
0.25VCC
0.25VCC
V
0.35VCC
0.35VCC
V
0.7
0.7
V
IO = 20 A; VCC = 0.7 V
0.01
V
IO = 100 A; VCC = 0.75 V
0.1
0.1
V
IO = 2 mA; VCC = 1.1 V
0.275
0.275
V
IO = 3 mA; VCC = 1.4 V
0.35
0.35
V
IO = 4.5 mA; VCC = 1.65 V
0.45
0.45
V
IO = 8 mA; VCC = 2.3 V
0.7
0.7
V
0.001
0.1
0.5
A
II
input leakage
current
VI = 0 V to 2.75 V;
VCC = 0 V to 2.75 V
[1]
IOZ
OFF-state output
current
VI = VIL; VO = 0 V to 2.75 V
[1]
0.02
0.1
0.5
A
IOFF
power-off leakage
current
VI or VO = 0 V to 2.75 V;
VCC = 0 V
[1]
0.01
0.1
0.5
A
IOFF
additional power-off VI or VO = 0 V or 2.75 V;
leakage current
VCC = 0 V to 0.1 V
[1]
0.02
0.1
0.5
A
ICC
supply current
VI = 0 V or VCC; IO = 0 A
[1]
0.01
0.3
0.6
A
ICC
additional supply
current
VI = VCC 0.5 V; IO = 0 A;
VCC = 2.5 V
2
100
150
A
[1]
All typical values are measured at VCC = 1.2 V.
74AXP1G06
Product data sheet
5 of 17
74AXP1G06
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 12.
Symbol Parameter
propagation
delay
tpd
Tamb = 25 C
Conditions
Unit
Min
Typ[1]
Max
Min
Max
3
12
33
3
104
ns
VCC = 1.1 V to 1.3 V
2.2
5.1
7.9
2.0
8.3
ns
VCC = 1.4 V to 1.6 V
1.7
3.7
5.2
1.5
5.6
ns
VCC = 1.65 V to 1.95 V
1.4
3.5
5.3
1.2
5.6
ns
1.2
2.6
3.8
1.0
4.0
ns
0.9
ns
[2][3]
A to Y; see Figure 6
VCC = 2.7 V; see Figure 6
[4]
tt
transition time
CI
input capacitance VI = 0 V or VCC;
VCC = 0 V to 2.75 V
0.5
pF
CO
output
capacitance
0.7
pF
CPD
power dissipation fi = 1 MHz; VI = 0 V to VCC
capacitance
VO = 0 V; VCC = 0 V
[5]
0.9
pF
1.0
pF
1.0
pF
1.1
pF
1.3
pF
[1]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPZL and tPLZ.
[3]
For additional propagation delay (tPZL) values at different load capacitances see Figure 7 to Figure 11.
[4]
tt is the same as tTZL and tTLZ.
[5]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi + CL VCC2 fo where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V.
74AXP1G06
Product data sheet
6 of 17
74AXP1G06
Nexperia
12. Waveforms
9,
90
$LQSXW
*1'
W3=/
W3/=
9&&
很抱歉,暂时无法提供与“74AXP1G06GNH”相匹配的价格&库存,您可以联系我们找货
