74AXP2G3404
Low-power buffer and inverter
Rev. 1 — 5 November 2015
Product data sheet
1. General description
The 74AXP2G3404 is a single buffer and single inverter.
Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall
times.
This device ensures very low static and dynamic power consumption across the entire
VCC range from 0.7 V to 2.75 V. It is fully specified for partial power down applications
using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging
backflow current through the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.7 V to 2.75 V
Low input capacitance; CI = 0.5 pF (typical)
Low output capacitance; CO = 1.0 pF (typical)
Low dynamic power consumption; CPD = 2.4 pF at VCC = 1.2 V (typical)
Low static power consumption; ICC = 0.6 A (85 C maximum)
High noise immunity
Complies with JEDEC standard:
JESD8-12A.01 (1.1 V to 1.3 V)
JESD8-11A.01 (1.4 V to 1.6 V)
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A.01 (2.3 V to 2.7 V)
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV
CDM JESD22-C101E exceeds 1000 V
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 2.75 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C
74AXP2G3404
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AXP2G3404GM
40 C to +85 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AXP2G3404GN
40 C to +85 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AXP2G3404GS
40 C to +85 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74AXP2G3404GM
rZ
74AXP2G3404GN
rZ
74AXP2G3404GS
rZ
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Logic symbol
74AXP2G3404
Product data sheet
DDD
DDD
DDD
Fig 1.
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 16
74AXP2G3404
Nexperia
6. Pinning information
6.1 Pinning
$;3*
$;3*
*1'
9&&
*1'
9&&
DDD
DDD
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
Fig 4.
Pin configuration SOT886
Fig 5.
Pin configuration SOT1115 and SOT1202
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
7. Functional description
Table 4.
Function table[1]
Input
Output
1A
1Y
L
L
H
H
[1]
H = HIGH voltage level; L = LOW voltage level.
Table 5.
Function table[1]
Input
Output
2A
2Y
L
H
H
L
[1]
74AXP2G3404
Product data sheet
3 of 16
74AXP2G3404
Nexperia
8. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
[1]
Min
Max
Unit
0.5
+3.3
V
50
mA
0.5
+3.3
V
50
mA
0.5
+3.3
V
VO
output voltage
IO
output current
mA
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
[1]
VO = 0 V to VCC
Tamb = 40 C to +85 C
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
9. Recommended operating conditions
Table 7.
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
0.7
2.75
V
VI
input voltage
V
VO
output voltage
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+85
C
ns/V
Tamb
ambient temperature
t/V
input transition rise and fall rate
74AXP2G3404
Product data sheet
VCC = 0.7 V to 2.75 V
4 of 16
74AXP2G3404
Nexperia
10. Static characteristics
Table 8.
At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
LOW-level input
voltage
VOH
HIGH-level
output voltage
LOW-level
output voltage
VOL
Typ 25 C
Max 25 C
Max 85 C
0.75 VCC
V
V
1.6
V
VCC = 0.75 V to 0.85 V
0.25 VCC
0.25 VCC V
VCC = 1.1 V to 1.95 V
0.35 VCC
0.35 VCC V
VCC = 2.3 V to 2.7 V
0.7
0.7
V
IO = 20 A; VCC = 0.7 V
0.69
V
IO = 100 A; VCC = 0.75 V
0.65
V
VIL
Min
0.65 VCC
HIGH-level input VCC = 0.75 V to 0.85 V
voltage
VIH
Unit
IO = 2 mA; VCC = 1.1 V
0.825
V
IO = 3 mA; VCC = 1.4 V
1.05
V
IO = 4.5 mA; VCC = 1.65 V
1.2
V
IO = 8 mA; VCC = 2.3 V
1.7
V
0.01
V
0.1
0.1
V
0.275
0.275
V
0.35
0.35
V
0.45
0.45
V
0.7
0.7
V
II
input leakage
current
VI = 0 V to 2.75 V;
VCC = 0 V to 2.75 V
[1]
0.001
0.1
0.5
A
IOFF
power-off
leakage current
VI or VO = 0 V to 2.75 V;
VCC = 0 V
[1]
0.01
0.1
0.5
A
IOFF
additional
power-off
leakage current
VI or VO = 0 V or 2.75 V;
VCC = 0 V to 0.1 V
[1]
0.02
0.1
0.5
A
ICC
supply current
VI = 0 V or VCC; IO = 0 A
[1]
0.01
0.3
0.6
A
ICC
additional supply VI = VCC 0.5 V; IO = 0 A;
current
VCC = 2.5 V
2
100
150
A
[1]
Typical values are measured at VCC = 1.2 V.
74AXP2G3404
Product data sheet
5 of 16
74AXP2G3404
Nexperia
11. Dynamic characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 12.
Symbol Parameter
Tamb = 25 C
Conditions
propagation delay 1A to 1Y or 2A to 2Y;
see Figure 6
tpd
Tamb = 40 C to +85 C Unit
Min
Typ[1]
Max
Min
Max
2
11
44
2
110
ns
1.7
4.2
7.0
1.7
7.3
ns
[2][3]
VCC = 1.1 V to 1.3 V
VCC = 1.4 V to 1.6 V
1.4
3.1
4.8
1.3
5.1
ns
VCC = 1.65 V to 1.95 V
1.2
2.5
3.9
1.1
4.2
ns
1.0
2.0
2.9
0.9
3.1
ns
1.0
ns
tt
transition time
CI
input capacitance VI = 0 V or VCC;
VCC = 0 V to 2.75 V
0.5
pF
CO
output
capacitance
VO = 0 V; VCC = 0 V
1.0
pF
CPD
power dissipation
capacitance
fi = 1 MHz; VI = 0 V to VCC
2.3
pF
2.4
pF
2.4
pF
2.5
pF
2.8
pF
[1]
VCC = 2.7 V; see Figure 6
[4]
[5]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPLH and tPHL.
[3]
For additional propagation delay values at different load capacitances, see Figure 7 to Figure 11.
[4]
tt is the same as tTHL and tTLH.
[5]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + CL VCC2 fo where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching.
74AXP2G3404
Product data sheet
6 of 16
74AXP2G3404
Nexperia
12. Waveforms
9,
9,
$LQSXW
90
$LQSXW
90
*1'
90
90
*1'
W3/+
92+
W3+/
很抱歉,暂时无法提供与“74AXP2G3404GNH”相匹配的价格&库存,您可以联系我们找货
