74AXP1G14
Low-power Schmitt trigger inverter
Rev. 1 — 28 August 2014
Product data sheet
1. General description
The 74AXP1G14 is a single inverter with Schmitt trigger input. It transforms slowly
changing input signals into sharply defined, jitter-free output signals.
This device ensures very low static and dynamic power consumption across the entire
VCC range from 0.7 V to 2.75 V. It is fully specified for partial power down applications
using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging
backflow current through the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.7 V to 2.75 V
Low input capacitance; CI = 0.5 pF (typical)
Low output capacitance; CO = 1.0 pF (typical)
Low dynamic power consumption; CPD = 2.4 pF at VCC = 1.2 V (typical)
Low static power consumption; ICC = 0.6 A (85 C maximum)
High noise immunity
Complies with JEDEC standard:
JESD8-12A.01 (1.1 V to 1.3 V)
JESD8-11A.01 (1.4 V to 1.6 V)
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A.01 (2.3 V to 2.7 V)
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV
CDM JESD22-C101E exceeds 1000 V
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 2.75 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C
74AXP1G14
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AXP1G14GM
40 C to +85 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AXP1G14GN
40 C to +85 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AXP1G14GS
40 C to +85 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74AXP1G14GX
40 C to +85 C
X2SON5
X2SON5: plastic thermal enhanced extremely thin
small outline package; no leads; 5 terminals;
body 0.8 0.8 0.35 mm
SOT1226
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74AXP1G14GM
rF
74AXP1G14GN
rF
74AXP1G14GS
rF
74AXP1G14GX
rF
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
2
A
Y
4
2
mna023
Fig 1.
Logic symbol
74AXP1G14
Product data sheet
4
PQD
mna024
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 17
74AXP1G14
Nexperia
6. Pinning information
6.1 Pinning
74AXP1G14
74AXP1G14
n.c.
1
6
VCC
n.c.
A
2
5
n.c.
GND
3
4
Y
5
VCC
4
Y
3
GND
A
aaa-014791
2
aaa-014792
Transparent top view
Fig 4.
1
Pin configuration SOT886, SOT1115 and
SOT1202 (XSON6)
Fig 5.
Pin configuration SOT1226 (X2SON5)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
X2SON5
XSON6
n.c.
1
1
not connected
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
7. Functional description
Table 4.
Function table[1]
Input
Output
A
Y
L
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level.
74AXP1G14
Product data sheet
3 of 17
74AXP1G14
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
[1]
Min
Max
Unit
0.5
+3.3
V
50
mA
0.5
+3.3
V
50
mA
0.5
+3.3
V
VO
output voltage
IO
output current
mA
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
[1]
VO = 0 V to VCC
Tamb = 40 C to +85 C
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
Min
Max
Unit
supply voltage
0.7
2.75
V
VI
input voltage
V
VO
output voltage
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+85
C
Tamb
Conditions
ambient temperature
74AXP1G14
Product data sheet
4 of 17
74AXP1G14
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ 25 C
0.3VCC
0.8VCC
0.8VCC
V
VCC = 1.1 V to 1.95 V
0.4VCC
0.7VCC
0.7VCC
V
VCC = 2.3 V to 2.7 V
0.9
1.7
1.7
V
0.2VCC
0.7VCC
0.7VCC
V
0.3VCC
0.6VCC
0.6VCC
V
0.7
1.5
1.5
V
VCC = 0.75 V to 0.85 V
0.06VCC
0.5VCC
0.5VCC
V
0.1VCC
0.4VCC
0.4VCC
V
0.2
1.0
1.0
V
positive-going
see Figure 6 and Figure 7
threshold voltage
VT+
negative-going
threshold voltage
VT
hysteresis
voltage
VH
VOH
HIGH-level
output voltage
LOW-level
output voltage
VOL
Unit
Max 25 C Max 85 C
IO = 20 A; VCC = 0.7 V
0.69
V
IO = 100 A; VCC = 0.75 V
0.65
V
IO = 2 mA; VCC = 1.1 V
0.825
V
IO = 3 mA; VCC = 1.4 V
1.05
V
IO = 4.5 mA; VCC = 1.65 V
1.2
V
IO = 8 mA; VCC = 2.3 V
1.7
V
0.01
V
0.1
0.1
V
0.275
0.275
V
0.35
0.35
V
0.45
0.45
V
0.7
0.7
V
0.001
0.1
0.5
A
II
input leakage
current
VI = 0 V to 2.75 V;
VCC = 0 V to 2.75 V
[1]
IOFF
power-off
leakage current
VI or VO = 0 V to 2.75 V;
VCC = 0 V
[1]
0.01
0.1
0.5
A
IOFF
additional
power-off
leakage current
VI or VO = 0 V or 2.75 V;
VCC = 0 V to 0.1 V
[1]
0.02
0.1
0.5
A
ICC
supply current
VI = 0 V or VCC; IO = 0 A
[1]
0.01
0.3
0.6
A
ICC
additional supply VI = VCC 0.5 V; IO = 0 A;
current
VCC = 2.5 V
2
100
150
A
[1]
Typical values are measured at VCC = 1.2 V.
74AXP1G14
Product data sheet
5 of 17
74AXP1G14
Nexperia
10.1 Waveform transfer characteristics
92
97
9,
9+
97
9,
9+
97
Fig 6.
97
92
PQD
PQD
Transfer characteristic
Fig 7.
Definition of VT+, VT, and VH
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 14.
Symbol Parameter
propagation delay
tpd
Tamb = 25 C
Conditions
Unit
Min
Typ[1]
Max
Min
Max
3
12
35
2
114
ns
VCC = 1.1 V to 1.3 V
2.0
4.6
7.2
1.8
7.5
ns
VCC = 1.4 V to 1.6 V
1.6
3.5
5.0
1.4
5.3
ns
VCC = 1.65 V to 1.95 V
1.4
2.9
4.1
1.2
4.5
ns
1.2
2.3
3.2
1.0
3.5
ns
1.0
ns
A to Y; see Figure 8
[2][3]
[4]
tt
transition time
VCC = 2.7 V; see Figure 8
CI
input capacitance
VI = 0 V or VCC;
VCC = 0 V to 2.75 V
0.5
pF
CO
output capacitance
VO = 0 V; VCC = 0 V
1.0
pF
CPD
power dissipation
capacitance
fi = 1 MHz; VI = 0 V to VCC
2.3
pF
[1]
[5]
2.4
pF
2.5
pF
2.6
pF
3.0
pF
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPLH and tPHL.
[3]
For additional propagation delay values at different load capacitances, see Figure 9 to Figure 13.
[4]
tt is the same as tTHL and tTLH.
[5]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + CL VCC2 fo where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
74AXP1G14
Product data sheet
6 of 17
74AXP1G14
Nexperia
N = number of inputs switching.
12. Waveforms
VI
A input
VM
VM
GND
tPLH
VOH
tPHL
90 %
Y output
90 %
VM
VOL
VM
10 %
10 %
tTLH
tTHL
aaa-014793
Measurement points are given in Table 9.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 8.
The data input (A) to output (Y) propagation delays
Table 9.
Measurement points
Supply voltage
Input
Output
VCC
VM
VI
tr = tf
VM
0.75 V to 2.7 V
0.5VCC
VCC
3.0 ns
0.5VCC
DDD
ǻW
QV
DDD
ǻW
QV
&/S)
Tamb = 40 C to +85 C unless otherwise specified.
&/S)
(1) Minimum: VCC = 2.7 V
(1) Minimum: VCC = 1.95 V
(2) Typical: Tamb = 25 C; VCC = 2.5 V
(2) Typical: Tamb = 25 C; VCC = 1.8 V
(3) Maximum: VCC = 2.3 V
(3) Maximum: VCC = 1.65 V
Fig 9.
Additional tpd versus load capacitance
74AXP1G14
Product data sheet
Fig 10. Additional tpd versus load capacitance
7 of 17
74AXP1G14
Nexperia
DDD
ǻWW
QV
DDD
ǻW
QV
&/S)
&/S)
(1) Minimum: VCC = 1.6 V
(1) Minimum: VCC = 1.3 V
(2) Typical: Tamb = 25 C; VCC = 1.5 V
(2) Typical: Tamb = 25 C; VCC = 1.2 V
(3) Maximum: VCC = 1.4 V
(3) Maximum: VCC = 1.1 V
Fig 11. Additional tpd versus load capacitance
Fig 12. Additional tpd versus load capacitance
DDD
ǻW
QV
&/S)
(1) Minimum: VCC = 0.85 V
(2) Typical: Tamb = 25 C; VCC = 0.8 V
(3) Maximum: VCC = 0.75 V
Fig 13. Additional tpd versus load capacitance
74AXP1G14
Product data sheet
8 of 17
74AXP1G14
Nexperia
9(;7
9&&
9,
5/
92
'87
57
5/
PQD
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 14. Test circuit for measuring switching times
Table 10.
Test data
Supply voltage
Load
VCC
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
0.75 V to 2.7 V
5 pF
10 k
0V
0V
2 VCC
74AXP1G14
Product data sheet
VEXT
9 of 17
74AXP1G14
Nexperia
13. Package outline
627
;621SODVWLFH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGVWHUPLQDOVERG\[[PP
E
H
H
H
WHUPLQDO
LQGH[DUHD
PP
VFDOH
'LPHQVLRQVPPDUHWKHRULJLQDOGLPHQVLRQV
8QLW
PP
PD[
QRP
PLQ
E
H
H
1RWHV
,QFOXGLQJSODWLQJWKLFNQHVV
&DQEHYLVLEOHLQVRPHPDQXIDFWXULQJSURFHVVHV
2XWOLQH
YHUVLRQ
627
VRWBSR
5HIHUHQFHV
-(,7$
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
02
Fig 15. Package outline SOT886 (XSON6)
74AXP1G14
Product data sheet
10 of 17
74AXP1G14
Nexperia
;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV
WHUPLQDOVERG\[[PP
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
VFDOH
'LPHQVLRQV
8QLW
PP
PP
E
H
H
PD[
QRP
PLQ
1RWH
9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\
VRWBSR
5HIHUHQFHV
2XWOLQH
YHUVLRQ
-(,7$
627
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
Fig 16. Package outline SOT1115 (XSON6)
74AXP1G14
Product data sheet
11 of 17
74AXP1G14
Nexperia
WHUPLQDOVERG\[[PP
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
VFDOH
'LPHQVLRQV
8QLW
PP
PP
E
H
H
PD[
QRP
PLQ
1RWH
VRWBSR
5HIHUHQFHV
2XWOLQH
YHUVLRQ
-(,7$
627
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
Fig 17. Package outline SOT1202 (XSON6)
74AXP1G14
Product data sheet
12 of 17
74AXP1G14
Nexperia
;621SODVWLFWKHUPDOHQKDQFHGH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV
WHUPLQDOVERG\[[PP
627
GHWDLO;
WHUPLQDO
LQGH[DUHD
H
Y
Z
E
WHUPLQDO
LQGH[DUHD
N
K
PP
VFDOH
'LPHQVLRQV
8QLW
PP
'K
E
H
N
PD[
QRP
PLQ
Y
Z
1RWH
'LPHQVLRQ$LVLQFOXGLQJSODWLQJWKLFNQHVV
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
2XWOLQH
YHUVLRQ
5HIHUHQFHV
VRWBSR
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
627
Fig 18. Package outline SOT1226 (X2SON5)
74AXP1G14
Product data sheet
13 of 17
74AXP1G14
Nexperia
14. Abbreviations
Table 11.
Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
15. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AXP1G14 v.1
20140828
Product data sheet
74AXP1G14
Product data sheet
14 of 17
74AXP1G14
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74AXP1G14
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
15 of 17
74AXP1G14
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AXP1G14
Product data sheet
16 of 17
Nexperia
74AXP1G14
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
10.1
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Waveform transfer characteristics . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Contact information. . . . . . . . . . . . . . . . . . . . . 16
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Date of release: 28 August 2014
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AXP1G14GMH 74AXP1G14GXH 74AXP1G14GSH 74AXP1G14GNH
