74AXP1T34
Dual supply translating buffer
Rev. 1 — 22 December 2015
Product data sheet
1. General description
The 74AXP1T34 is a dual supply translating buffer. It features one input (A), an output (Y)
and dual supply pins (VCCI and VCCO). The inputs are referenced to VCCI and the output is
referenced to VCCO. All inputs can be connected directly to VCCI or GND. VCCI can be
supplied at any voltage between 0.7 V and 2.75 V and VCCO can be supplied at any
voltage between 1.2 V and 5.5 V. This feature allows voltage level translation.
Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall
times.
This device ensures very low static and dynamic power consumption across the entire
supply range and is fully specified for partial power down applications using IOFF. The IOFF
circuitry disables the output, preventing the potentially damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range:
VCCI: 0.7 V to 2.75 V
VCCO: 1.2 V to 5.5 V
Low input capacitance; CI = 0.6 pF (typical)
Low output capacitance; CO = 1.8 pF (typical)
Low dynamic power consumption; CPD = 0.4 pF at VCCI = 1.2 V (typical)
Low dynamic power consumption; CPD = 7.1 pF at VCCO = 3.3 V (typical)
Low static power consumption; ICCI = 0.5 A (85 C maximum)
Low static power consumption; ICCO = 1.8 A (85 C maximum)
High noise immunity
Complies with JEDEC standard:
JESD8-12A.01 (1.1 V to 1.3 V; A input)
JESD8-11A.01 (1.4 V to 1.6 V)
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A.01 (2.3 V to 2.7 V)
JESD8-C (2.7 V to 3.6 V; Y output)
JESD12-6 (4.5 V to 5.5 V; Y output)
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV
CDM JESD22-C101E exceeds 1000 V
Latch-up performance exceeds 100 mA per JESD78D Class II
Inputs accept voltages up to 2.75 V
74AXP1T34
Nexperia
Low noise overshoot and undershoot < 10% of VCCO
IOFF circuitry provides partial power-down mode operation
Multiple package options
Specified from 40 C to +85 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AXP1T34GW
40 C to +85 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74AXP1T34GM
40 C to +85 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AXP1T34GN
40 C to +85 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AXP1T34GS
40 C to +85 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74AXP1T34GX
40 C to +85 C
X2SON5
X2SON5: plastic thermal enhanced extremely thin
small outline package; no leads; 5 terminals;
body 0.8 0.8 0.35 mm
SOT1226
4. Marking
Table 2.
Marking
Marking code[1]
Type number
74AXP1T34GW
rQ
74AXP1T34GM
rQ
74AXP1T34GN
rQ
74AXP1T34GS
rQ
74AXP1T34GX
rQ
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
9&&,
DDF
Fig 1.
Logic symbol
74AXP1T34
Product data sheet
9&&2
DDD
Fig 2.
Logic diagram
All information provided in this document is subject to legal disclaimers.
2 of 21
Nexperia B.V. 2017. All rights reserved
74AXP1T34
Nexperia
6. Pinning information
6.1 Pinning
$;37
$;37
$;37
9&&,
*1'
9&&2
QF
*1'
DDD
Fig 4.
Pin configuration SOT886,
SOT1115 and SOT1202
(XSON6)
9&&2
*1'
DDD
7UDQVSDUHQWWRSYLHZ
Pin configuration
SOT353-1 (TSSOP5)
9&&,
9&&2
DDD
Fig 3.
9&&,
7UDQVSDUHQWWRSYLHZ
Fig 5.
Pin configuration SOT1226
(X2SON5)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
TSSOP5 and X2SON5
XSON6
VCCI
1
1
input supply voltage
A
2
2
data input A
GND
3
3
ground (0 V)
Y
4
4
data output Y
n.c.
5
not connected
VCCO
5
6
output supply voltage
Input
Output
7. Functional description
Table 4.
Function table[1]
Supply voltage
VCCI
VCCO
A
Y
0.7 V to 2.75 V
1.2 V to 5.5 V
L
L
0.7 V to 2.75 V
1.2 V to 5.5 V
H
H
GND
1.2 V to 5.5 V
X
Z
0.7 V to 2.75 V
GND
X
Z
GND
GND
X
Z
[1]
H = HIGH voltage level; L = LOW voltage level.
74AXP1T34
Product data sheet
3 of 21
74AXP1T34
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCCI
VCCO
IIK
input clamping current
Conditions
Min
Max
Unit
0.5
3.3
V
0.5
6.0
V
50
[1]
0.5
3.3
50
[1][2]
0.5
VCCO + 0.5
V
[1]
0.5
6.0
V
25
mA
VI < 0 V
VI
input voltage
IOK
output clamping current
VO < 0 V
VO
output voltage
Active mode
Power-down or 3-state mode
VO = 0 V to VCCO
mA
V
mA
IO
output current
ICCI
input supply current
50
mA
ICCO
output supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
250
mW
Tamb = 40 C to +85 C
total power dissipation
Ptot
[3]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
VCCO + 0.5 V should not exceed 6.0 V.
[3]
For SOT353-1 package: above 75 C the value of Ptot derates linearly with 3.3 mW/K.
For SOT886 package: above 75 C the value of Ptot derates linearly with 3.3 mW/K.
For SOT1115 package: above 70 C the value of Ptot derates linearly with 3.2 mW/K.
For SOT1202 package: above 75 C the value of Ptot derates linearly with 3.3 mW/K.
For SOT1226 package: above 70 C the value of Ptot derates linearly with 3.1 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCCI
Min
Max
Unit
0.7
2.75
V
VCCO
1.2
5.5
V
VI
input voltage
VO
output voltage
Tamb
ambient temperature
t/V
input transition rise
and fall rate
74AXP1T34
Product data sheet
Conditions
V
Active mode
VCCO
V
V
40
+85
C
ns/V
VCCI = 0.7 V to 2.75 V
4 of 21
74AXP1T34
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
HIGH-level input
voltage
VIH
LOW-level input
voltage
VIL
HIGH-level output
voltage
0.75VCCI
V
VCCI = 1.1 V to 1.95 V
0.65VCCI
V
VCCI = 2.3 V to 2.7 V
1.6
V
VCCI = 0.75 V to 0.85 V
0.25VCCI
0.25VCCI
V
0.35VCCI
0.35VCCI
V
0.7
0.7
V
1.05
V
IO = 3 mA; VCCO = 1.4 V
1.05
V
IO = 4.5 mA; VCCO = 1.65 V
1.2
V
IO = 8 mA; VCCO = 2.3 V
1.7
V
IO = 10 mA; VCCO = 3.0 V
2.2
V
3.7
V
0.18
V
0.35
0.35
V
0.45
0.45
V
0.7
0.7
V
0.8
0.8
V
0.8
0.8
V
0.001
0.1
0.5
A
0.001
0.1
0.5
A
IO = 2 mA; VCCO = 1.2 V
[1]
IO = 12 mA; VCCO = 4.5 V
LOW-level output
voltage
VOL
Typ 25 C Max 25 C Max 85 C
VOH
Unit
[1]
[1]
II
input leakage
current
VI = 0 V to 2.75 V;
VCCI = 0 V to 2.75 V
IOZ
OFF-state output
current
VO = 0 V to 5.5 V;
VCCO = 1.2 V to 5.5 V
IOFF
power-off leakage
current
inputs; VI = 0 V to 2.75 V;
VCCI = 0 V; VCCO = 0 V to 5.5 V
[1]
0.01
0.1
0.5
A
output; VO = 0 V to 5.5 V;
VCCO = 0 V; VCCI = 0 V to 2.75 V;
VI = 0 V to 2.75 V
[1]
0.01
0.1
0.5
A
inputs; VI = 0 V or 2.75 V;
VCCI = 0 V to 0.1 V;
VCCO = 0 V to 5.5 V
[1]
0.02
0.1
0.5
A
output; VO = 0 V or 5.5 V;
VCCO = 0 V to 0.1 V;
VI = 0 V or 2.75 V
[1]
0.02
0.1
0.5
A
IOFF
[1]
additional
power-off leakage
current
Typical values are measured at VCCI = VCCO = 1.2 V unless otherwise specified.
74AXP1T34
Product data sheet
5 of 21
74AXP1T34
Nexperia
Table 8.
Static characteristics supply current
Symbol Parameter
ICCI
input supply
current
ICCO
output supply
current
Conditions
Max 85 C
[1]
1
100
10
300
nA
VCCI = 1.3 V to 2.75 V
[2]
1
100
nA
VCCI = 2.75 V; VCCO = 0 V
1
100
nA
VCCI = 0 V; VCCO = 5.5 V
1
100
1
100
nA
0.001
1.0
0.01
1.2
A
0.8
1.5
1.0
1.8
A
0.001
0.1
0.003
0.2
A
VCCI = 0 V; VCCO = 3.6 V
0.2
0.6
0.3
0.8
A
0.4
0.8
0.5
1.0
A
VI = VCCI 0.5 V; VCCI = 2.5 V
2
100
14
150
A
VI = 0 V or VCCI; IO = 0 A;
see Table 9
[1]
[3]
[1]
Typical values are measured at VCCI = VCCO = 1.2 V.
[2]
Typical values are measured at VCCI = VCCO = 2.5 V.
[3]
Typical values are measured at VCCI = 1.2 V and VCCO = 5.0 V.
Table 9.
Typ 85 C
VCCI = 0.7 V to 1.3 V
VCCO = 3.6 V to 5.5 V
additional input
supply current
Max 25 C
VI = 0 V or VCCI;
VCCO = 1.2 V to 3.6 V
ICCI
Unit
Typ 25 C
Typical output supply current (ICCO )
VCCI
VCCO
0V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
0V
5
200
400
nA
0.8 V
1
10
150
200
300
500
800
nA
1.2 V
1
1
5
200
300
500
800
nA
1.5 V
1
1
5
100
300
500
800
nA
1.8 V
1
1
5
100
300
500
800
nA
2.5 V
1
1
5
100
100
500
800
nA
74AXP1T34
Product data sheet
Unit
6 of 21
74AXP1T34
Nexperia
11. Dynamic characteristics
Table 10. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 13; for wave form see Figure 6.
Symbol Parameter
Conditions
VCCO
1.5 V 0.1 V
1.2 V
Typ[1]
Unit
Min
Typ[1]
1.8 V 0.15 V
Max
Min
Typ[1]
Max
Tamb = 25 C
propagation A to Y
delay
tpd
[2]
22
3
16
61
3
15
57
ns
VCCI = 1.1 V to 1.3 V
16.2
3.1
10.3
19.8
2.8
8.2
15.8
ns
VCCI = 1.4 V to 1.6 V
15.4
2.8
9.5
18.2
2.5
7.4
13.2
ns
VCCI = 1.65 V to 1.95 V
15.0
2.7
9.1
17.4
2.4
7.0
11.9
ns
14.7
2.5
8.7
16.9
2.2
6.6
11.1
ns
22
3
16
136
3
15
133
ns
16.2
3.1
10.3
19.8
2.8
8.2
15.8
ns
15.4
2.8
9.5
18.2
2.5
7.4
13.2
ns
15.0
2.7
9.1
17.4
2.4
7.0
11.9
ns
14.7
2.5
8.7
16.9
2.2
6.6
11.1
ns
1.0
1.0
ns
propagation A to Y
delay
tpd
[2]
transition
time
tt
[1]
VCCI = 0.75 V to 2.7 V
[3]
Typical values are measured at nominal supply voltages and Tamb = +25 C.
[2]
tpd is the same as tPLH and tPHL.
[3]
tt is the same as tTHL and tTLH.
74AXP1T34
Product data sheet
7 of 21
74AXP1T34
Nexperia
Table 11. Dynamic characteristics
Symbol Parameter
Conditions
VCCO
2.5 V 0.2 V
Min
Unit
3.3 V 0.3 V
Typ[1] Max
Min
5.0 V 0.5 V
Typ[1] Max
Min
Typ[1] Max
Tamb = 25 C
propagation A to Y
delay
tpd
[2]
2
13
57
2
13
65
2
14
77
ns
2.4
6.5
10.8
2.2
5.9
9.5
2.1
5.6
9.0
ns
2.1
5.7
9.1
2.0
5.1
8.2
1.9
4.8
7.7
ns
2.0
5.3
8.7
1.8
4.7
7.7
1.8
4.4
7.3
ns
1.9
4.9
8.1
1.7
4.3
7.1
1.6
4.0
6.6
ns
propagation A to Y
delay
tpd
[2]
2
13
152
2
13
179
2
14
210 ns
2.4
6.5
10.8
2.2
5.9
9.5
2.1
5.6
9.0
ns
2.1
5.7
9.1
2.0
5.1
8.2
1.9
4.8
7.7
ns
2.0
5.3
8.7
1.8
4.7
7.7
1.8
4.4
7.3
ns
1.9
4.9
8.1
1.7
4.3
7.1
1.6
4.0
6.6
ns
1.0
1.0
1.0
ns
transition
time
tt
[1]
[3]
Typical values are measured at nominal supply voltages and tamb = +25 C.
[2]
[3]
74AXP1T34
Product data sheet
8 of 21
74AXP1T34
Nexperia
Table 12. Typical dynamic characteristics at Tamb = 25 C
Symbol Parameter
CPD
power
dissipation
capacitance
Conditions
VCCO
Unit
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
VCCI = 0.8 V
0.4
0.4
0.4
0.4
0.4
0.4
pF
VCCI = 1.2 V
0.4
0.4
0.4
0.4
0.4
0.4
pF
VCCI = 1.5 V
0.5
0.5
0.5
0.5
0.5
0.5
pF
VCCI = 1.8 V
0.5
0.5
0.5
0.5
0.5
0.5
pF
0.7
0.7
0.7
0.7
0.7
0.7
pF
VCCI = 0.8 V
6.7
6.8
6.8
6.9
7.5
9.5
pF
VCCI = 1.2 V
6.8
6.9
7.0
7.0
7.1
7.6
pF
VCCI = 1.5 V
6.9
6.9
6.9
7.0
7.1
7.6
pF
VCCI = 1.8 V
6.9
6.9
6.9
7.0
7.2
7.6
pF
VCCI = 2.5 V
6.9
7.0
7.0
7.0
7.2
7.6
pF
fi = 1 MHz; RL = ; VI = 0 V to VCCI
[1]
[2]
input supply
VCCI = 2.5 V
[3]
output supply
CI
input
capacitance
VI = 0 V or VCCI; VCCI = 0 V to 2.7 V
0.6
0.6
0.6
0.6
0.6
0.6
pF
CO
output
capacitance
VO = 0 V; VCCO = 0 V
1.8
1.8
1.8
1.8
1.8
1.8
pF
[1]
CPD is used to determine the dynamic power dissipation (PD in W).
[2]
Power dissipated from input supply (VCCI)
PD = CPD VCCI2 fi N where:
CPD = power dissipation capacitance of the input supply.
VCCI = input supply voltage in V;
fi = input frequency in MHz;
N = number of inputs switching;
[3]
Power dissipated from output supply (VCCO)
PD = (CL + CPD) VCCO2 fo where:
CL = load capacitance in pF;
CPD = power dissipation capacitance of the output supply.
VCCO = output supply voltage in V;
fo = output frequency in MHz;
74AXP1T34
Product data sheet
9 of 21
74AXP1T34
Nexperia
11.1 Waveforms and graphs
9,
$LQSXW
90
90
9
W3+/
92+
W3/+
很抱歉,暂时无法提供与“74AXP1T34GXH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.502671+0.06071
- 10+0.4942110+0.05968
- 25+0.4869625+0.05881
- 50+0.4797150+0.05793
- 100+0.47126100+0.05691
- 250+0.46401250+0.05604
- 500+0.45676500+0.05516
- 1000+0.448301000+0.05414
