74HCT20D,653
74HCT20D,653
    NEXPERIA(安世)
    SO-14_8.65X3.9MM
    电压电平转换器 5V 20μA SOIC14_8.75X4MM
74HCT20D,653 数据手册
74HC20; 74HCT20 Dual 4-input NAND gate Rev. 5 — 27 March 2019 Product data sheet 1. General description The 74HC20; 74HCT20 is a dual 4-input NAND gate. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • Complies with JEDEC standard JESD7A Low-power dissipation Input levels: • For 74HC20: CMOS level • For 74HCT20: TTL level ESD protection: • HBM JESD22-A114F exceeds 2 000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +80 °C and from -40 °C to +125 °C. 3. Ordering information Table 1. Ordering information Type number Package 74HC20D Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 -40 °C to +125 °C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm 74HCT20D 74HC20DB 74HCT20DB 74HC20PW 4. Functional diagram 1 2 4 5 9 10 12 13 1A 1B 1C 1Y 1 6 2 1D 4 2A 2B 2C 5 2Y 9 8 10 2D 12 13 aaa-004014 Fig. 1. Functional diagram Fig. 2. 1A 1B 1C 1Y 6 1D 2A 2B 2C 2Y 8 2D Logic symbol aaa-004015 SOT402-1 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate & 1 2 6 4 A 5 B & 9 Y 10 C 8 12 13 D aaa-004016 Fig. 3. IEC Logic symbol Fig. 4. aaa-004017 Logic diagram 5. Pinning information 5.1. Pinning 74HC20 74HCT20 1A 1 14 VCC 1B 2 13 2D n.c. 3 12 2C 1C 1D 4 74HC20 74HCT20 11 n.c. 5 10 2B 1Y 6 9 2A GND 7 8 2Y 1A 1 14 VCC 1B 2 13 2D n.c. 3 12 2C 1C 4 11 n.c. 1D 5 10 2B 1Y 6 9 2A GND 7 8 2Y aaa-004018 Fig. 5. aaa-004019 Pin configuration SOT108-1 Fig. 6. Pin configuration SOT337-1 and SOT402-1 5.2. Pin description Table 2. Pin description Symbol Pin Description 1A, 1B, 1C, 1D 1, 2, 4, 5 data input n.c. 3, 11 not connected 1Y 6 data output GND 7 ground (0 V) 2Y 8 data output 2A, 2B, 2C, 2D 9, 10, 12, 13 data input VCC 14 supply voltage 74HC_HCT20 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 2 / 12 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. Output Input nA nB nC nD nY L X X X H X L X X H X X L X H X X X L H H H H H L 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Max VCC supply voltage -0.5 +7 V IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V ICC supply current - ±25 mA - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] Conditions SO14, and (T)SSOP14 packages [2] Unit The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SO14 package: Ptot derates linearly with 8 mW/K above 70 °C. For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC20 Min Typ 74HCT20 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 74HC_HCT20 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 3 / 12 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 VCC = 4.5 V 3.15 2.4 - 1.5 - 3.15 - 1.5 - V - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V 74HC20 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V VI = VIH or VIL HIGH-level output voltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V VI = VIH or VIL LOW-level output voltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1 - ±1 μA II input leakage current VI = VCC or GND; VCC = 6.0 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 2 - 20 - 40 μA CI input capacitance - 3.5 - - - - - pF 74HCT20 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH VI = VIH or VIL; VCC = 4.5 V HIGH-level output voltage IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V IO = -4.0 mA VOL VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage IO = 20 μA IO = 5.2 mA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V 74HC_HCT20 Product data sheet VI = VCC or GND; VCC = 5.5 V - 0 0.1 - 0.1 - 0.1 V - 0.15 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1 - ±1 μA - - 2 - 20 - 40 μA All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 4 / 12 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max ΔICC additional per input pin; VI = VCC - 2.1 V; supply current IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - 30 108 - 135 - 147 μA CI input capacitance - 3.5 - - - - - pF 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for test circuit see Fig. 8. Symbol Parameter Conditions 25 °C -40 °C to +125 °C Unit Min Typ Max Max (85 °C) Max (125 °C) VCC = 2.0 V - 28 90 115 135 ns VCC = 4.5 V - 10 18 23 27 ns VCC = 6.0 V - 8 15 20 23 ns VCC = 5.0 V; CL = 15 pF - 8 - - - ns VCC = 2.0 V - 19 75 95 110 ns VCC = 4.5 V - 7 15 19 22 ns - 6 13 16 19 ns - 22 - - - pF VCC = 4.5 V - 16 28 35 42 ns VCC = 5.0 V; CL = 15 pF - 13 - - - ns 74HC20 propagation delay nA, nB, nC or nD to nY; see Fig. 7 tpd tt transition time nY; see Fig. 7 [1] [2] VCC = 6.0 V CPD power dissipation per package; VI = GND to VCC capacitance [3] 74HCT20 propagation delay nA, nB, nC or nD to nY; see Fig. 7 tpd tt transition time [2] - 7 15 19 22 ns CPD power dissipation per package; VI = GND to VCC - 1.5 V [3] capacitance - 17 - - - pF [1] [2] [3] nY; VCC = 4.5 V; see Fig. 7 [1] tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL x VCC x fo) = sum of outputs. 74HC_HCT20 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 5 / 12 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate 10.1. Waveform and test circuit VI nA, nB, nC, nD input VM GND tPHL VOH tPLH VY VM nY output VX VOL tTHL tTLH aaa-004020 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Waveforms showing the input (nA, nB, nC, nD) to output (nY) propagation delays and the output transition times Table 8. Measurement points Input Type Output VM VM VX VY 74HC20 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT20 1.3 V 1.3 V 0.1VCC 0.9VCC VI negative pulse VM tf tr tr VI GND VM 10 % GND positive pulse tW 90 % tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. Fig. 8. Test circuit for measuring switching times Table 9. Test data Type Load Input Test VI tr, tf CL 74HC20 VCC 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HCT20 3.0 V 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HC_HCT20 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 6 / 12 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 inches 0.010 0.057 0.069 0.004 0.049 0.05 0.244 0.039 0.028 0.041 0.228 0.016 0.024 0.01 0.01 0.028 0.004 0.012 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74HC_HCT20 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 7 / 12 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm D SOT337-1 E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp L 7 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.4 0.9 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT337-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 10. Package outline SOT337-1 (SSOP14) 74HC_HCT20 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 8 / 12 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 11. Package outline SOT402-1 (TSSOP14) 74HC_HCT20 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 9 / 12 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT20 v.5 20190327 Product data sheet - 74HC_HCT20 v.4 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74HCT20PW (SOT402-1/TSSOP14) removed. 74HC_HCT20 v.4 20151118 Modifications: • 74HC_HCT20 v.3 20120903 Modifications: • • 74HC_HCT20_CNV v.2 74HC_HCT20 Product data sheet Product data sheet - 74HC_HCT20 v.3 Type numbers 74HC20N and 74HCT20N (SOT27-1) removed. Product data sheet - 74HC_HCT20_CNV v.2 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. 19970828 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 74HC_HCT20_1 © Nexperia B.V. 2019. All rights reserved 10 / 12 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT20 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 11 / 12 74HC20; 74HCT20 Nexperia Dual 4-input NAND gate Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................1 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 2 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................3 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 5 10.1. Waveform and test circuit.......................................... 6 11. Package outline.......................................................... 7 12. Abbreviations............................................................ 10 13. Revision history........................................................10 14. Legal information......................................................11 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 March 2019 74HC_HCT20 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 March 2019 © Nexperia B.V. 2019. All rights reserved 12 / 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC20PW 74HCT20D 74HCT20DB 74HC20D,652 74HC20DB,112 74HC20DB,118 74HC20D,653 74HC20N,652 74HC20PW,112 74HC20PW,118 74HCT20D,652 74HCT20DB,112 74HCT20DB,118 74HCT20D,653 74HCT20N,652
74HCT20D,653 价格&库存
很抱歉,暂时无法提供与“74HCT20D,653”相匹配的价格&库存,您可以联系我们找货
