74HC2G04-Q100;
74HCT2G04-Q100
Dual inverter
Rev. 2 — 11 June 2018
1
Product data sheet
General description
The 74HC2G04-Q100; 74HCT2G04-Q100 is a dual inverter. Inputs include clamp diodes
that enable the use of current limiting resistors to interface inputs to voltages in excess of
VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2
Features and benefits
• Automotive product qualification in accordance with AEC-Q100 (Grade 1)
– Specified from -40 °C to +85 °C and from -40 °C to +125 °C
• Wide supply voltage range from 2.0 V to 6.0 V
• Input levels:
– For 74HC2G04-Q100: CMOS level
– For 74HCT2G04-Q100: TTL level
• Complies with JEDEC standard no. 7A
• High noise immunity
• ESD protection:
– MIL-STD-883, method 3015 exceeds 2000 V
– HBM JESD22-A114F exceeds 2000 V
– MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
• Low power dissipation
• Balanced propagation delays
• Multiple package options
3
Ordering information
Table 1. Ordering information
Type number
74HC2G04GW-Q100
Package
Temperature range
Name
Description
Version
-40 °C to +125 °C
SC-88
plastic surface-mounted package; 6 leads
SOT363
-40 °C to +125 °C
SC-74
plastic surface-mounted package (TSOP6);
6 leads
SOT457
74HCT2G04GW-Q100
74HC2G04GV-Q100
74HCT2G04GV-Q100
Nexperia
Dual inverter
4
Marking
Table 2. Marking
Type number
Marking code
74HC2G04GW-Q100
H4
74HCT2G04GW-Q100
T4
74HC2G04GV-Q100
H04
74HCT2G04GV-Q100
T04
5
Functional diagram
1
1A
1Y
6
3
2A
2Y
4
1
1
1
3
6
4
A
mnb080
mnb079
Figure 1. Logic symbol
6
Y
mna110
Figure 2. IEC logic symbol
Figure 3. Logic diagram (one gate)
Pinning information
6.1 Pinning
74HC2G04-Q100
74HCT2G04-Q100
1A 1
GND 2
2A 3
6 1Y
5 VCC
4 2Y
aaa-010001
Figure 4. Pin configuration SOT363 and SOT457
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
74HC_HCT2G04_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2018. All rights reserved.
2 / 15
Nexperia
Dual inverter
7
Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
nA
nY
L
H
H
L
8
Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VCC
supply voltage
IIK
input clamping current
Conditions
Min
Max
Unit
-0.5
+7.0
V
VI < -0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
VO < -0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
VO = -0.5 V to VCC + 0.5 V
[1]
±25
mA
supply current
[1]
+50
mA
IGND
ground current
[1]
-50
mA
Tstg
storage temperature
-65
+150
°C
250
mW
74HCT2G04-Q100
Unit
IOK
output clamping current
IO
output current
ICC
Ptot
[2]
total power dissipation
[1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2] For SC-88 and SC-74 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
9
Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
Conditions
74HC2G04-Q100
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and
fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
139
139
ns/V
VCC = 6.0 V
83
ns/V
74HC_HCT2G04_Q100
Product data sheet
3 / 15
Nexperia
Dual inverter
10 Static characteristics
Table 7. Static characteristics for 74HC2G04-Q100
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
HIGH-level input voltage VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
V
IO = -4.0 mA; VCC = 4.5 V
4.18
4.32
V
IO = -5.2 mA; VCC = 6.0 V
5.68
5.81
V
IO = 20 μA; VCC = 2.0 V
V
IO = 20 μA; VCC = 4.5 V
V
IO = 20 μA; VCC = 6.0 V
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
V
Tamb = 25 °C
VIH
VIL
VOH
VOL
LOW-level input voltage
HIGH-level output
voltage
LOW-level output
voltage
VI = VIH or VIL
VI = VIH or VIL
Il
input leakage current
VI = GND or VCC; VCC = 6.0 V
±0.1
μA
ICC
supply current
VI = GND or VCC; IO = 0 A;
VCC = 6.0 V
1.0
μA
CI
input capacitance
1.5
pF
74HC_HCT2G04_Q100
Product data sheet
4 / 15
Nexperia
Dual inverter
Symbol Parameter
Conditions
Min
Typ
Max
Unit
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
4.13
V
5.63
V
0.1
V
0.1
V
0.1
V
0.33
V
0.33
V
Tamb = -40 °C to +85 °C
VIH
VIL
VOH
VOL
HIGH-level output
voltage
LOW-level output
voltage
VI = VIH or VIL
VI = VIH or VIL
Il
±1.0
μA
ICC
supply current
VCC = 6.0 V
10.0
μA
74HC_HCT2G04_Q100
Product data sheet
5 / 15
Nexperia
Dual inverter
Symbol Parameter
Conditions
Min
Typ
Max
Unit
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.7
V
5.2
V
0.1
V
0.1
V
0.1
V
0.4
V
0.4
V
Tamb = -40 °C to +125 °C
VIH
VIL
VOH
VOL
HIGH-level output
voltage
LOW-level output
voltage
VI = VIH or VIL
VI = VIH or VIL
Il
±1.0
μA
ICC
supply current
VCC = 6.0 V
20.0
μA
Min
Typ
Max
Unit
2.0
1.6
V
1.2
0.8
V
4.4
4.5
V
4.18
4.32
V
V
0.15
0.26
V
Table 8. Static characteristics for 74HCT2G04-Q100
Symbol Parameter
Conditions
Tamb = 25 °C
VIH
HIGH-level input voltage VCC = 4.5 V to 5.5 V
VIL
VOH
HIGH-level output
voltage
VI = VIH or VIL
VOL
LOW-level output
voltage
VI = VIH or VIL
Il
VI = GND or VCC; VCC = 5.5 V
±0.1
μA
ICC
supply current
VCC = 5.5 V
1.0
μA
74HC_HCT2G04_Q100
Product data sheet
6 / 15
Nexperia
Dual inverter
Symbol Parameter
Conditions
Min
Typ
Max
Unit
ΔICC
additional supply current VI = VCC - 2.1 V;VCC = 4.5 V to 5.5 V;
IO = 0 A
300
μA
CI
input capacitance
1.5
pF
2.0
V
0.8
V
4.4
V
4.13
V
0.1
V
0.33
V
VIH
VIL
VOH
HIGH-level output
voltage
VI = VIH or VIL
VOL
LOW-level output
voltage
VI = VIH or VIL
Il
±1.0
μA
ICC
supply current
VCC = 5.5 V
10.0
μA
ΔICC
IO = 0 A
375
μA
2.0
V
0.8
V
4.4
V
3.7
V
0.1
V
0.4
V
VIH
VIL
VOH
HIGH-level output
voltage
VI = VIH or VIL
VOL
LOW-level output
voltage
VI = VIH or VIL
Il
±1.0
μA
ICC
supply current
VCC = 5.5 V
20.0
μA
ΔICC
IO = 0 A
410
μA
74HC_HCT2G04_Q100
Product data sheet
7 / 15
Nexperia
Dual inverter
11 Dynamic characteristics
Table 9. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6.
Symbol Parameter
Conditions
25 °C
-40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
(85 °C)
Max
(125 °C)
VCC = 2.0 V; CL = 50 pF
22
75
90
110
ns
VCC = 4.5 V; CL = 50 pF
8
15
18
22
ns
6
13
16
ns
18
75
95
125
ns
6
15
19
25
ns
5
13
16
ns
9
pF
10
18
23
29
ns
6
15
19
22
ns
9
pF
74HC2G04-Q100
tpd
propagation
delay
nA to nY; see Figure 5
[1]
VCC = 6.0 V; CL = 50 pF
tt
transition time
[2]
nY; see Figure 5
CPD
[3]
power dissipation VI = GND to VCC
capacitance
74HCT2G04-Q100
tpd
tt
propagation
delay
transition time
[1]
[2]
nY; see Figure 5
CPD
power dissipation VI = GND to VCC - 1.5 V
capacitance
[3]
[1] tpd is the same as tPLH and tPHL.
[2] tt is the same as tTLH and tTHL.
[3] CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of the outputs.
74HC_HCT2G04_Q100
Product data sheet
8 / 15
Nexperia
Dual inverter
11.1 Waveform and test circuit
VI
VM
nA input
VM
GND
t PHL
t PLH
VOH
90 %
VM
VM
nY output
10 %
VOL
t THL
t TLH
mna722
Measurement points are given in Table 10.
VOL and VOH are typical voltage output levels that occur with the output load.
Figure 5. The data input (nA) to output (nY) propagation delays and output transition times
Table 10. Measurement points
Type
Output
Input
VM
VI
tr = tf
VM
74HC2G04-Q100
0.5VCC
GND to VCC
6.0 ns
0.5VCC
74HCT2G04-Q100
1.3 V
GND to 3.0 V
6.0 ns
1.3 V
VCC
PULSE
GENERATOR
VCC
VI
VO
D.U.T
RT
RL = 1 kΩ
CL
open
50 pF
mgk563
Test data is given in Table 11.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Figure 6. Test circuit for measuring switching times
Table 11. Test data
Type
Test
Input
VI
tr, tf
tPHL, tPLH
74HC2G04-Q100
GND to VCC
6 ns
open
74HCT2G04-Q100
GND to 3.0 V
6 ns
open
74HC_HCT2G04_Q100
Product data sheet
9 / 15
Nexperia
Dual inverter
12 Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
1
2
e1
A1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
JEITA
SC-88
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
Figure 7. Package outline SOT363 (SC-88)
74HC_HCT2G04_Q100
Product data sheet
10 / 15
Nexperia
Dual inverter
Plastic surface-mounted package (TSOP6); 6 leads
D
SOT457
B
E
y
A
HE
6
5
X
v M A
4
Q
pin 1
index
A
A1
1
2
c
3
Lp
e
bp
w M B
detail X
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT457
JEITA
SC-74
EUROPEAN
PROJECTION
ISSUE DATE
05-11-07
06-03-16
Figure 8. Package outline SOT457 (SC-74)
74HC_HCT2G04_Q100
Product data sheet
11 / 15
Nexperia
Dual inverter
13 Abbreviations
Table 12. Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14 Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT2G04_Q100 v.2
20180611
Product data sheet
Modifications:
• The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
74HC_HCT2G04_Q100 v.1
20140519
74HC_HCT2G04_Q100
Product data sheet
Product data sheet
12 / 15
Nexperia
Dual inverter
15 Legal information
15.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
74HC_HCT2G04_Q100
Product data sheet
13 / 15
Nexperia
Dual inverter
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
74HC_HCT2G04_Q100
Product data sheet
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
14 / 15
Nexperia
Dual inverter
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
11.1
12
13
14
15
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Marking .................................................................2
Functional diagram ............................................. 2
Pinning information ............................................ 2
Pinning ............................................................... 2
Pin description ................................................... 2
Functional description ........................................3
Limiting values .................................................... 3
Recommended operating conditions ................ 3
Static characteristics .......................................... 4
Dynamic characteristics .....................................8
Waveform and test circuit .................................. 9
Package outline .................................................10
Abbreviations .................................................... 12
Revision history ................................................ 12
Legal information .............................................. 13
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 11 June 2018
Document identifier: 74HC_HCT2G04_Q100
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC2G04GV-Q100H 74HC2G04GW-Q100H 74HCT2G04GV-Q100H 74HCT2G04GW-Q100H
很抱歉,暂时无法提供与“74HC2G04GV-Q100H”相匹配的价格&库存,您可以联系我们找货
