74HCT3G14DC,125
74HCT3G14DC,125
    NEXPERIA(安世)
    VSSOP8_2.1X2.4MM
    电压电平转换器 5V 50mA VSSOP8_2.1X2.4MM
74HCT3G14DC,125 数据手册
74HC3G14; HCT3G14 Triple inverting Schmitt trigger Rev. 6 — 1 February 2019 Product data sheet 1. General description The 74HC3G14; 74HCT3G14 is a triple inverter with Schmitt-trigger inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. 2. Features and benefits • • • • • • • • • • Wide supply voltage range from 2.0 V to 6.0 V Complies with JEDEC standard no. 7A Input levels: • For 74HC3G14: CMOS level • For 74HCT3G14: TTL level High noise immunity Low power dissipation Balanced propagation delays Unlimited input rise and fall times Multiple package options ESD protection: • HBM JESD22-A114E exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Applications • • • Wave and pulse shaper for highly noisy environments Astable multivibrators Monostable multivibrators 4. Ordering information Table 1. Ordering information Type number Package 74HC3G14DP Temperature range Name Description Version -40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm SOT505-2 -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 74HCT3G14DP 74HC3G14DC 74HCT3G14DC 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger 5. Marking Table 2. Marking Type number Marking code [1] 74HC3G14DP H14 74HCT3G14DP T14 74HC3G14DC H14 74HCT3G14DC T14 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 6. Functional diagram 1A 1Y 3Y 3A 2A 2Y A Y mna025 001aah729 001aah728 Fig. 1. Logic symbol Fig. 2. Fig. 3. IEC logic symbol Logic diagram (one Schmitt trigger) 7. Pinning information 7.1. Pinning 74HC3G14 74HCT3G14 1A 1 8 VCC 3Y 2 7 1Y 2A 3 6 3A GND 4 5 2Y 001aak035 Fig. 4. Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8) 7.2. Pin description Table 3. Pin description Symbol Pin Description 1A, 2A, 3A 1, 3, 6 data input GND 4 ground (0 V) 1Y, 2Y, 3Y 7, 5, 2 data output VCC 8 supply voltage 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 2 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger 8. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Input Output nA nY L H H L 9. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7.0 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current VO = -0.5 V to VCC + 0.5 V [1] - ±25 mA ICC supply current [1] - +50 mA IGND ground current [1] -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 300 mW [1] [2] [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K. For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K. 10. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC3G14 74HCT3G14 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 3 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger 11. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C. Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 4.18 4.32 - 4.13 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.68 5.81 - 5.63 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC3G14 VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT- VI = VT+ or VT- II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current per input pin; VCC = 6.0 V; VI = VCC or GND; IO = 0 A - - 1.0 - 10 - 20 μA CI input capacitance - 2.0 - - - - - pF IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA; VCC = 4.5 V 4.18 4.32 - 4.13 - 3.7 - V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V 74HCT3G14 VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT- VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current per input pin; VCC = 5.5 V; VI = VCC or GND; IO = 0 A - - 1.0 - 10 - 20 μA ΔICC additional supply current per input; VCC = 4.5 V to 5.5 V; VI = VCC - 2.1 V; IO = 0 A - - 300 - 375 - 410 μA CI input capacitance - 2.0 - - - - - pF 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 4 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger 11.1. Transfer characteristics Table 8. Transfer characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 10. Symbol Parameter Conditions 25 °C -40 °C to +125 °C Unit Min Typ Max Min Max Max (85 °C) (125 °C) VCC = 2.0 V 1.00 1.18 1.50 1.00 1.50 1.50 V VCC = 4.5 V 2.30 2.60 3.15 2.30 3.15 3.15 V VCC = 6.0 V 3.00 3.46 4.20 3.00 4.20 4.20 V VCC = 2.0 V 0.30 0.60 0.90 0.30 0.90 0.90 V VCC = 4.5 V 1.13 1.47 2.00 1.13 2.00 2.00 V VCC = 6.0 V 1.50 2.06 2.60 1.50 2.60 2.60 V VCC = 2.0 V 0.30 0.60 1.00 0.30 1.00 1.00 V VCC = 4.5 V 0.60 1.13 1.40 0.60 1.40 1.40 V VCC = 6.0 V 0.80 1.40 1.70 0.80 1.70 1.70 V VCC = 4.5 V 1.20 1.58 1.90 1.20 1.90 1.90 V VCC = 5.5 V 1.40 1.78 2.10 1.40 2.10 2.10 V VCC = 4.5 V 0.50 0.87 1.20 0.50 1.20 1.20 V VCC = 5.5 V 0.60 1.11 1.40 0.60 1.40 1.40 V VCC = 4.5 V 0.40 0.71 - 0.40 - - V VCC = 5.5 V 0.40 0.67 - 0.40 - - V 74HC3G14 VT+ VT- VH positive-going threshold voltage negative-going threshold voltage see Fig. 5, Fig. 6 see Fig. 5, Fig. 6 hysteresis voltage (VT+ - VT-); see Fig. 5, Fig. 6 and Fig. 7 74HCT3G14 VT+ VT- VH positive-going threshold voltage negative-going threshold voltage see Fig. 5, Fig. 6 see Fig. 5, Fig. 6 hysteresis voltage (VT+ - VT-); see Fig. 5, Fig. 6 and Fig. 8 11.2. Transfer characteristics waveforms VO VI VI VH VT- Fig. 5. VT+ Transfer characteristic 74HC_HCT3G14 Product data sheet VT+ VH VT- VO mna207 mna208 Fig. 6. Definition of VT+, VT- and VH All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 5 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger mna028 100 mna029 1.0 ICC (mA) ICC (µA) 0.8 0.6 50 0.4 0.2 0 0 1.0 VI (V) 0 2.0 a. VCC = 2.0 V 0 2.5 VI (V) 5.0 b. VCC = 4.5 V mna030 1.6 ICC (mA) 0.8 0 0 3.0 VI (V) 6.0 c. VCC = 6.0 V Fig. 7. Typical 74HC3G14 transfer characteristics mna031 2.0 mna032 3.0 ICC (mA) ICC (mA) 2.0 1.0 1.0 0 0 2.5 VI (V) 5.0 a. VCC = 4.5 V. Fig. 8. 0 0 3.0 VI (V) 6.0 b. VCC = 5.5 V. Typical 74HCT3G14 transfer characteristics 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 6 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger 12. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 10. Symbol Parameter Conditions 25 °C -40 °C to +125 °C Unit Min Typ Max Min Max Max (85 °C) (125 °C) VCC = 2.0 V - 53 125 - 155 190 ns VCC = 4.5 V - 16 25 - 31 38 ns VCC = 6.0 V - 13 21 - 26 32 ns VCC = 2.0 V - 20 75 - 95 110 ns VCC = 4.5 V - 7 15 - 19 22 ns VCC = 6.0 V - 5 13 - 16 19 ns [3] - 10 - - - - pF 21 32 - 40 48 ns 74HC3G14 propagation delay nA to nY; see Fig. 9 tpd tt transition time CPD [1] nY; see Fig. 9 [2] power dissipation VI = GND to VCC capacitance 74HCT3G14 tpd propagation delay nA to nY; VCC = 4.5 V; see Fig. 9 [1] - tt transition time [2] - 6 15 - 19 22 ns CPD power dissipation VI = GND to VCC - 1.5 V capacitance [3] - 10 - - - - pF [1] [2] [3] nY; VCC = 4.5 V; see Fig. 9 tpd is the same as tPLH and tPHL tt is the same as tTLH and tTHL CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. 12.1. Waveforms and test circuit VI nA input VM VM GND t PHL t PLH VOH nY output 90 % VM VM 10 % VOL t THL t TLH mna722 Measurement points are given in Table 10. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 9. The data input (nA) to output (nY) propagation delays and output transition times 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 7 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger Table 10. Measurement points Type Input Output VM VM 74HC3G14 0.5VCC 0.5VCC 74HCT3G14 1.3 V 1.3 V VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI VCC VO DUT RT RL S1 open CL 001aad983 Test data is given in Table 11. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig. 10. Test circuit for measuring switching times Table 11. Test data Type Input S1 position Load VI tr, tf CL RL tPHL, tPLH 74HC3G14 GND to VCC ≤ 6 ns 50 pF 1 kΩ open 74HCT3G14 GND to 3.0 V ≤ 6 ns 50 pF 1 kΩ open 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 8 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger 13. Application information The slow input rise and fall times cause additional power dissipation, which can be calculated using the following formula: Padd = fi × (tr × ΔICC(AV) + tf × ΔICC(AV)) × VCC where: • • • • • Padd = additional power dissipation (μW); fi = input frequency (MHz); tr = input rise time (ns); 10 % to 90 %; tf = input fall time (ns); 90 % to 10 %; ΔICC(AV) = average additional supply current (μA). ΔICC(AV) differs with positive or negative input transitions, as shown in Fig. 11 and Fig. 12. An example of a relaxation circuit using the 74HC3G14/74HCT3G14 is shown in Fig. 13. mna036 200 ΔICC(AV) (µA) 150 positive-going edge 100 50 0 negative-going edge 0 2.0 4.0 VCC (V) 6.0 Linear change of VI between 0.1VCC to 0.9VCC. Fig. 11. ΔICC(AV) as a function of VCC for 74HC3G14 mna058 200 ΔICC(AV) (µA) 150 positive-going edge 100 negative-going edge 50 0 0 2 4 VCC (V) 6 Linear change of VI between 0.1VCC to 0.9VCC. Fig. 12. ΔICC(AV) as a function of VCC for 74HCT3G14 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 9 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger R C mna035 For 74HC3G14: For 74HCT3G14: For K-factor, see Fig. 14 Fig. 13. Relaxation oscillator aaa-004609 2.0 K aaa-004610 1.2 K 1.0 1.5 0.8 1.0 0.6 0.4 0.5 0.2 0 2 3 4 5 VCC (V) 6 a. K-factor for 74HC3G14 0 4.5 5.0 VCC (V) 5.5 b. K-factor for 74HCT3G14 Fig. 14. Typical K-factor for relaxation oscillator 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 10 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger 14. Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 pin 1 index (A3) A1 θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Fig. 15. Package outline SOT505-2 (TSSOP8) 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 11 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit A max. max nom min mm 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Fig. 16. Package outline SOT765-1 (VSSOP8) 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 12 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger 15. Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 16. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT3G14 v.6 20190201 Product data sheet - Modifications: • • • • 74HC_HCT3G14 v.5 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74HC3G14GD and 74HCT3G14GD (SOT996-2) removed. Package outline drawing SOT765-1 (VSSOP8) updated. 74HC_HCT3G14 v.5 20131209 Modifications: • 74HC_HCT3G14 v.4 20131003 Modifications: • 74HC_HCT3G14 v.3 20090508 Product data sheet - 74HC_HCT3G14 v.2 74HC_HCT3G14 v.2 20031104 Product specification - 74HC_HCT3G14 v.1 74HC_HCT3G14 v.1 20020723 Product specification - - 74HC_HCT3G14 Product data sheet Product data sheet - 74HC_HCT3G14 v.4 Fig. 14 added (typical K-factor for relaxation oscillator). Product data sheet - 74HC_HCT3G14 v.3 For type numbers 74HC3G14GD and 74HCT3G14GD XSON8U has changed to XSON8. All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 13 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger 17. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT3G14 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 14 / 15 74HC3G14; HCT3G14 Nexperia Triple inverting Schmitt trigger Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Marking.......................................................................... 2 6. Functional diagram.......................................................2 7. Pinning information......................................................2 7.1. Pinning.........................................................................2 7.2. Pin description............................................................. 2 8. Functional description................................................. 3 9. Limiting values............................................................. 3 10. Recommended operating conditions........................3 11. Static characteristics..................................................4 11.1. Transfer characteristics..............................................5 11.2. Transfer characteristics waveforms............................5 12. Dynamic characteristics............................................ 7 12.1. Waveforms and test circuit........................................ 7 13. Application information............................................. 9 14. Package outline........................................................ 11 15. Abbreviations............................................................ 13 16. Revision history........................................................13 17. Legal information......................................................14 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 1 February 2019 74HC_HCT3G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 1 February 2019 © Nexperia B.V. 2019. All rights reserved 15 / 15 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC3G14DC,125 74HC3G14DP,125 74HCT3G14DC,125 74HCT3G14DP,125 74HC3G14GD,125 74HCT3G14GD,125
74HCT3G14DC,125 价格&库存
很抱歉,暂时无法提供与“74HCT3G14DC,125”相匹配的价格&库存,您可以联系我们找货
