74HC3G14; 74HCT3G14
Triple inverting Schmitt trigger
Rev. 03 — 8 May 2009
Product data sheet
1. General description
The 74HC3G14; 74HCT3G14 is a high-speed Si-gate CMOS device.
The 74HC3G14; 74HCT3G14 provides three inverting buffers with Schmitt trigger inputs
which accept standard input signals. They are capable of transforming slowly changing
input signals into sharply defined, jitter-free output signals.
2. Features
n
n
n
n
n
n
n
Wide supply voltage range from 2.0 V to 6.0 V
High noise immunity
Low power dissipation
Balanced propagation delays
Unlimited input rise and fall times
Multiple package options
ESD protection:
u HBM JESD22-A114E exceeds 2000 V
u MM JESD22-A115-A exceeds 200 V
n Specified from −40 °C to +85 °C and −40 °C to +125 °C
3. Applications
n Wave and pulse shaper for highly noisy environments
n Astable multivibrators
n Monostable multivibrators
4. Ordering information
Table 1.
Type number
74HC3G14DP
Package
Temperature range Name
Description
Version
−40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package; 8 leads;
body width 3 mm; lead length 0.5 mm
SOT505-2
−40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package; 8 leads; SOT765-1
body width 2.3 mm
−40 °C to +125 °C
XSON8U
plastic extremely thin small outline package; no leads; SOT996-2
8 terminals; UTLP based; body 3 × 2 × 0.5 mm
74HCT3G14DP
74HC3G14DC
74HCT3G14DC
74HC3G14GD
74HCT3G14GD
74HC3G14; 74HCT3G14
NXP Semiconductors
5. Marking
Table 2.
Marking
Type number
Marking code
74HC3G14DP
H14
74HCT3G14DP
T14
74HC3G14DC
H14
74HCT3G14DC
T14
74HC3G14GD
H14
74HCT3G14GD
T14
6. Functional diagram
1A
1Y
3Y
3A
2A
2Y
A
001aah728
Fig 1.
Y
mna025
001aah729
Logic symbol
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram
(one Schmitt trigger)
7. Pinning information
7.1 Pinning
74HC3G14
74HCT3G14
74HC3G14
74HCT3G14
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
001aak036
Pin configuration SOT505-2 (TSSOP8) and
SOT765-1 (VSSOP8)
Fig 5.
74HC_HCT3G14_3
Product data sheet
1
Transparent top view
001aak035
Fig 4.
1A
Pin configuration SOT996-2 (XSON8U)
© NXP B.V. 2009. All rights reserved.
2 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
7.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A, 2A, 3A
1, 3, 6
data input
GND
4
ground (0 V)
1Y, 2Y, 3Y
7, 5, 2
data output
VCC
8
supply voltage
8. Functional description
Table 4.
Function table[1]
Input
Output
nA
nY
L
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level.
9. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
−0.5
+7.0
V
input clamping current
VI < −0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
IO
output current
VO = −0.5 V to VCC + 0.5 V
[1]
±25
mA
supply current
[1]
+50
mA
IGND
ground current
[1]
−50
mA
Tstg
storage temperature
−65
+150
°C
Ptot
total power dissipation
300
mW
IIK
ICC
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K.
For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K.
For XSON8U package: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
74HC_HCT3G14_3
Product data sheet
3 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
10. Recommended operating conditions
Table 6.
Symbol Parameter
Conditions
74HC3G14
Min
Typ
74HCT3G14
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
−40
+25
+125
−40
+25
+125
°C
11. Static characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C.
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
HIGH-level
VI = VT+ or VT−
output voltage
IO = −20 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −20 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −20 µA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = −4.0 mA; VCC = 4.5 V
4.18
4.32
4.13
3.7
V
IO = −5.2 mA; VCC = 6.0 V
74HC3G14
VOH
VOL
5.68
5.81
5.63
5.2
V
LOW-level
VI = VT+ or VT−
output voltage
IO = 20 µA; VCC = 2.0 V
0.1
0.1
V
IO = 20 µA; VCC = 4.5 V
0.1
0.1
V
IO = 20 µA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
VI = VCC or GND; VCC = 6.0 V
±0.1
±1.0
±1.0
µA
II
input leakage
current
ICC
supply current per input pin; VCC = 6.0 V;
VI = VCC or GND; IO = 0 A;
1.0
10
µA
CI
input
capacitance
2.0
pF
4.4
4.5
4.4
4.4
V
4.18
4.32
4.13
3.7
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
VI = VCC or GND; VCC = 5.5 V
±0.1
±1.0
±1.0
µA
74HCT3G14
VOH
HIGH-level
VI = VT+ or VT−
output voltage
VOL
II
LOW-level
VI = VIH or VIL
output voltage
input leakage
current
74HC_HCT3G14_3
Product data sheet
4 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
Table 7.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ
Max
Min
Max
Min
Max
ICC
supply current per input pin; VCC = 5.5 V;
1.0
10
µA
∆ICC
additional
per input;
supply current VCC = 4.5 V to 5.5 V;
VI = VCC − 2.1 V; IO = 0 A
300
375
410
µA
CI
input
capacitance
2.0
pF
Table 8.
Transfer characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 11.
Symbol Parameter
25 °C
Conditions
−40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
(85 °C)
Max
(125 °C)
VCC = 2.0 V
1.00
1.18
1.50
1.00
1.50
1.50
V
VCC = 4.5 V
2.30
2.60
3.15
2.30
3.15
3.15
V
VCC = 6.0 V
3.00
3.46
4.20
3.00
4.20
4.20
V
VCC = 2.0 V
0.30
0.60
0.90
0.30
0.90
0.90
V
VCC = 4.5 V
1.13
1.47
2.00
1.13
2.00
2.00
V
VCC = 6.0 V
1.50
2.06
2.60
1.50
2.60
2.60
V
VCC = 2.0 V
0.30
0.60
1.00
0.30
1.00
1.00
V
VCC = 4.5 V
0.60
1.13
1.40
0.60
1.40
1.40
V
VCC = 6.0 V
0.80
1.40
1.70
0.80
1.70
1.70
V
VCC = 4.5 V
1.20
1.58
1.90
1.20
1.90
1.90
V
VCC = 5.5 V
1.40
1.78
2.10
1.40
2.10
2.10
V
VCC = 4.5 V
0.50
0.87
1.20
0.50
1.20
1.20
V
VCC = 5.5 V
0.60
1.11
1.40
0.60
1.40
1.40
V
VCC = 4.5 V
0.40
0.71
0.40
V
VCC = 5.5 V
0.40
0.67
0.40
V
74HC3G14
VT+
VT−
VH
positive-going
threshold voltage
negative-going
threshold voltage
hysteresis voltage
see Figure 6, Figure 7
(VT+ − VT−); see Figure 6,
Figure 7 and Figure 9
74HCT3G14
VT+
VT−
VH
positive-going
threshold voltage
negative-going
threshold voltage
hysteresis voltage
Figure 7 and Figure 8
74HC_HCT3G14_3
Product data sheet
5 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
11.1 Waveforms transfer characteristics
VO
VT+
VI
VH
VT−
VI
VH
VT−
Fig 6.
VT+
VO
mna207
mna208
Fig 7.
mna031
2.0
Definition of VT+, VT− and VH
mna032
3.0
ICC
(mA)
ICC
(mA)
2.0
1.0
1.0
VI (V)
a. VCC = 4.5 V.
Fig 8.
3.0
VI (V)
6.0
b. VCC = 5.5 V.
Typical 74HCT3G14 transfer characteristics
74HC_HCT3G14_3
Product data sheet
6 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
mna028
100
mna029
1.0
ICC
(mA)
ICC
(µA)
0.8
0.6
50
0.4
0.2
VI (V)
a. VCC = 2.0 V
2.5
VI (V)
5.0
b. VCC = 4.5 V
mna030
1.6
ICC
(mA)
0.8
c.
Fig 9.
3.0
VI (V)
6.0
VCC = 6.0 V
Typical 74HC3G14 transfer characteristics
74HC_HCT3G14_3
Product data sheet
7 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
12. Dynamic characteristics
Table 9.
Symbol
Parameter
25 °C
Conditions
−40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
(85 °C)
Max
(125 °C)
VCC = 2.0 V
53
125
155
190
ns
VCC = 4.5 V
16
25
31
38
ns
VCC = 6.0 V
13
21
26
32
ns
VCC = 2.0 V
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
5
13
16
19
ns
10
pF
21
32
40
48
ns
6
15
19
22
ns
10
pF
74HC3G14
propagation delay
tpd
transition time
tt
power dissipation
capacitance
CPD
nA to nY; see Figure 10
nY; see Figure 10
[1]
[2]
VI = GND to VCC
[3]
[1]
74HCT3G14
propagation delay
tpd
VCC = 4.5 V
tt
transition time
CPD
power dissipation
capacitance
nY; see Figure 10
[2]
VCC = 4.5 V
VI = GND to VCC − 1.5 V
[1]
tpd is the same as tPLH and tPHL
[2]
tt is the same as tTLH and tTHL
[3]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
[3]
74HC_HCT3G14_3
Product data sheet
8 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
13. Waveforms
VI
nA input
VM
VM
GND
t PHL
t PLH
VOH
nY output
90 %
VM
VM
10 %
VOL
t THL
t TLH
mna722
Measurement points are given in Table 10.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 10. The data input (nA) to output (nY) propagation delays and output transition times
Table 10.
Measurement points
Type
Input
Output
VM
VM
74HC3G14
0.5VCC
0.5VCC
74HCT3G14
1.3 V
1.3 V
74HC_HCT3G14_3
Product data sheet
9 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
VI
tW
90 %
negative
pulse
VM
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VCC
G
VI
VO
RL
S1
open
DUT
RT
CL
001aad983
Test data is given in Table 11.
Definitions for test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig 11. Test circuit for measuring switching times
Table 11.
Test data
Type
Input
Load
VI
tr, tf
CL
RL
tPHL, tPLH
74HC3G14
GND to VCC
≤ 6 ns
50 pF
1 kΩ
open
74HCT3G14
GND to 3.0 V
≤ 6 ns
50 pF
1 kΩ
open
74HC_HCT3G14_3
Product data sheet
S1 position
10 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
14. Application information
The slow input rise and fall times cause additional power dissipation, which can be
calculated using the following formula:
Padd = fi × (tr × ∆ICC(AV) + tf × ∆ICC(AV)) × VCC where:
Padd = additional power dissipation (µW);
fi = input frequency (MHz);
tr = input rise time (ns); 10 % to 90 %;
tf = input fall time (ns); 90 % to 10 %;
∆ICC(AV) = average additional supply current (µA).
∆ICC(AV) differs with positive or negative input transitions, as shown in Figure 12 and
Figure 13.
An example of a relaxation circuit using the 74HC3G14/74HCT3G14 is shown
in Figure 14.
mna036
200
∆ICC(AV)
(µA)
150
positive-going
edge
100
50
negative-going
edge
4.0
VCC (V)
6.0
linear change of VI between 0.1VCC to 0.9VCC.
Fig 12. ∆ICC(AV) as a function of VCC for 74HC3G14
74HC_HCT3G14_3
Product data sheet
11 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
mna058
200
∆ICC(AV)
(µA)
150
positive-going
edge
100
negative-going
edge
50
4
VCC (V)
6
Fig 13. ∆ICC(AV) as a function of VCC for 74HCT3G14
R
C
mna035
1
T
1
0.8 × RC
For 74HC3G14: f = --- ≈ ----------------------
1
T
1
0.67 × RC
For 74HCT3G14: f = --- ≈ -------------------------
Fig 14. Relaxation oscillator
74HC_HCT3G14_3
Product data sheet
12 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
15. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
(A3)
A1
pin 1 index
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Fig 15. Package outline SOT505-2 (TSSOP8)
74HC_HCT3G14_3
Product data sheet
13 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
E
SOT765-1
A
X
c
y
HE
v M A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
4
e
L
detail X
w M
bp
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(2)
e
HE
L
Lp
Q
v
w
y
Z(1)
θ
mm
1
0.15
0.00
0.85
0.60
0.12
0.27
0.17
0.23
0.08
2.1
1.9
2.4
2.2
0.5
3.2
3.0
0.4
0.40
0.15
0.21
0.19
0.2
0.13
0.1
0.4
0.1
8°
0°
Notes
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT765-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-06-07
MO-187
Fig 16. Package outline SOT765-1 (VSSOP8)
74HC_HCT3G14_3
Product data sheet
14 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
XSON8U: plastic extremely thin small outline package; no leads;
8 terminals; UTLP based; body 3 x 2 x 0.5 mm
B
D
SOT996-2
A
A
E
A1
detail X
terminal 1
index area
e1
v
w
b
e
L1
1
4
8
5
C
C A B
C
M
M
y
y1 C
L2
L
X
2 mm
scale
UNIT
A
max
A1
b
D
E
e
e1
L
L1
L2
v
w
y
y1
mm
0.5
0.05
0.00
0.35
0.15
2.1
1.9
3.1
2.9
0.5
1.5
0.5
0.3
0.15
0.05
0.6
0.4
0.1
0.05
0.05
0.1
REFERENCES
OUTLINE
VERSION
IEC
SOT996-2
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
07-12-18
07-12-21
Fig 17. Package outline SOT996-2 (XSON8U)
74HC_HCT3G14_3
Product data sheet
15 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
16. Abbreviations
Table 12.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
17. Revision history
Table 13.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT3G14_3
20090508
Product data sheet
74HC_HCT3G14_2
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Added type number 74HC3G14GD and 74HCT3G14GD (XSON8U package)
74HC_HCT3G14_2
20031104
Product specification
74HC_HCT3G14_1
74HC_HCT3G14_1
20020723
74HC_HCT3G14_3
Product data sheet
16 of 18
74HC3G14; 74HCT3G14
NXP Semiconductors
18. Legal information
18.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
18.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
18.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
18.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
19. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
74HC_HCT3G14_3
Product data sheet
17 of 18
NXP Semiconductors
74HC3G14; 74HCT3G14
20. Contents
1
2
3
4
5
6
7
7.1
7.2
8
9
10
11
11.1
12
13
14
15
16
17
18
18.1
18.2
18.3
18.4
19
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Waveforms transfer characteristics. . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Application information. . . . . . . . . . . . . . . . . . 11
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16
Legal information. . . . . . . . . . . . . . . . . . . . . . . 17
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Contact information. . . . . . . . . . . . . . . . . . . . . 17
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2009.
Date of release: 8 May 2009
Document identifier: 74HC_HCT3G14_3
