74HC2GU04
Dual unbuffered inverter
Rev. 2 — 20 August 2014
Product data sheet
1. General description
The 74HC2GU04 is a high-speed Si-gate CMOS device.
The 74HC2GU04 provides two unbuffered inverters.
2. Features and benefits
Wide supply voltage range from 2.0 V to 6.0 V
Complies with JEDEC standard no. 7A
High noise immunity
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Low power dissipation
Balanced propagation delays
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
74HC2GU04GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74HC2GU04GV
40 C to +125 C
SC-74
plastic surface-mounted package (TSOP6); 6 leads
SOT457
4. Marking
Table 2.
Marking
Type number
Marking code
74HC2GU04GW
PD
74HC2GU04GV
HU4
Version
74HC2GU04
Nexperia
5. Functional diagram
1
1A
1Y
6
3
2A
2Y
4
1
1
1
3
4
mnb080
mnb079
Fig 1.
6
Logic symbol
Fig 2.
PQD
IEC logic symbol
Fig 3.
Logic diagram (one gate)
6. Pinning information
6.1 Pinning
74HC2GU04
1A
1
6
1Y
GND
2
5
VCC
2A
3
4
2Y
001aaf305
Fig 4.
Pin configuration
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
7. Functional description
Table 4.
Function table[1]
Input
Output
nA
nY
L
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level.
74HC2GU04
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 16
74HC2GU04
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7.0
V
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
mA
output current
VO = 0.5 V to VCC + 0.5 V
[1]
25
mA
supply current
[1]
+50
mA
IGND
ground current
[1]
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
IO
ICC
[2]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
Min
Typ
Max
Unit
VCC
supply voltage
2.0
5.0
6.0
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
tr
rise time
VCC = 2.0 V
1000
ns
VCC = 4.5 V
500
ns
VCC = 6.0 V
400
ns
VCC = 2.0 V
1000
ns
VCC = 4.5 V
500
ns
VCC = 6.0 V
400
ns
tf
fall time
74HC2GU04
Product data sheet
Conditions
except for Schmitt trigger inputs
3 of 16
74HC2GU04
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
HIGH-level input voltage
VCC = 2.0 V
1.7
1.1
V
VCC = 4.5 V
3.6
2.4
V
VCC = 6.0 V
4.8
3.1
V
VCC = 2.0 V
0.9
0.3
V
VCC = 4.5 V
2.1
0.9
V
VCC = 6.0 V
2.9
1.2
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
V
IO = 4.0 mA; VCC = 4.5 V
4.13
4.32
V
IO = 5.2 mA; VCC = 6.0 V
5.63
5.81
V
V
V
V
0.15
0.26
V
0.16
0.26
V
Tamb = 25 C
VIH
VIL
VOH
VOL
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage current
VI = GND or VCC; VCC = 6.0 V
0.1
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
VCC = 6.0 V
1.0
A
CI
input capacitance
3.0
pF
VCC = 2.0 V
1.7
1.1
V
VCC = 4.5 V
3.6
2.4
V
VCC = 6.0 V
4.8
3.1
V
VCC = 2.0 V
0.9
0.3
V
VCC = 4.5 V
2.1
0.9
V
VCC = 6.0 V
2.9
1.2
V
1.9
2.0
V
4.4
4.5
V
Tamb = 40 C to +85 C
VIH
VIL
VOH
74HC2GU04
Product data sheet
VI = VIH or VIL
5.9
6.0
V
4.13
4.32
V
5.63
5.81
V
4 of 16
74HC2GU04
Nexperia
Table 7.
Static characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VOL
VI = VIH or VIL
V
V
V
0.15
0.33
V
0.16
0.33
V
II
1.0
A
ICC
supply current
VCC = 6.0 V
10.0
A
VCC = 2.0 V
1.7
V
VCC = 4.5 V
3.6
V
VCC = 6.0 V
4.8
V
VCC = 2.0 V
0.3
V
VCC = 4.5 V
0.9
V
VCC = 6.0 V
1.2
V
1.9
V
4.4
V
5.9
V
3.7
V
5.2
V
0.1
V
0.1
V
0.1
V
0.4
V
0.4
V
Tamb = 40 C to +125 C
VIH
VIL
VOH
VOL
VI = VIH or VIL
VI = VIH or VIL
II
1.0
A
ICC
supply current
VCC = 6.0 V
20.0
A
74HC2GU04
Product data sheet
5 of 16
74HC2GU04
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6.
Symbol Parameter
25 C
Conditions
40 C to +125 C
Min Typ Max Min
propagation delay
tpd
nA to nY; see Figure 5
VCC = 2.0 V; CL = 50 pF
13
60
75
90
ns
VCC = 4.5 V; CL = 50 pF
6
12
15
18
ns
5
10
13
15
ns
18
75
95
125
ns
6
15
19
25
ns
5
13
16
ns
5
pF
[2]
nY; see Figure 5
VCC = 6.0 V; CL = 50 pF
[1]
tpd is the same as tPLH and tPHL.
[2]
tt is the same as tTLH and tTHL.
[3]
[3]
power dissipation capacitance VI = GND to VCC
CPD
Max
Max
(85 C) (125 C)
[1]
transition time
tt
Unit
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
12. Waveforms
9,
Q$LQSXW
90
90
*1'
W 3+/
W 3/+
92+
Q 10 k.
R1 3 k.
R2 1 M.
Open loop amplification: AOL = 20.
A OL
Voltage amplification: A V = – ----------------------------------------- .
R1
1 + ------- 1 + A OL
R2
Vo(p-p) = VCC 1.5 V centered at 0.5 VCC.
Unity gain bandwidth product is 5 MHz.
Fig 12. Linear amplifier application
74HC2GU04
Product data sheet
9 of 16
74HC2GU04
Nexperia
5
5
8
RXW
PQD
See Table 11 and Table 12.
C1 = 47 pF.
C2 = 22 pF.
R1 = 1 M to 10 M.
R2 optimum value depends on the frequency and required stability against changes in VCC or average minimum ICC
(ICC = 2 mA at VCC = 3.0 V and f = 1 MHz).
Fig 13. Crystal oscillator application
Table 11.
External components for resonator (f < 1 MHz)
Frequency
R1
R2
C1
C2
10 kHz to 15.9 kHz
2.2 M
220 k
56 pF
20 pF
16 kHz to 24.9 kHz
2.2 M
220 k
56 pF
10 pF
25 kHz to 54.9 kHz
2.2 M
100 k
56 pF
10 pF
55 kHz to 129.9 kHz
2.2 M
100 k
47 pF
5 pF
130 kHz to 199.9 kHz
2.2 M
47 k
47 pF
5 pF
200 kHz to 349.9 kHz
2.2 M
47 k
47 pF
5 pF
350 kHz to 600 kHz
2.2 M
47 k
47 pF
5 pF
Table 12.
Optimum value for R2
Frequency
3 kHz
6 kHz
10 kHz
14 kHz
> 14 kHz
74HC2GU04
Product data sheet
R2
Optimum
2.0 k
for minimum required ICC
8.0 k
for minimum influence due to change in VCC
1.0 k
4.7 k
or minimum influence by VCC
0.5 k
2.0 k
0.5 k
2.0 k
replace R2 by C3 = 35 pF (typical)
10 of 16
74HC2GU04
Nexperia
16. Package outline
3ODVWLFVXUIDFHPRXQWHGSDFNDJHOHDGV
627
Y 0 $
4
SLQ
LQGH[
H
ES
F
/S
Z 0 %
H
GHWDLO;
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
H
/S
4
Y
Z
PP
287/,1(
9(56,21
5()(5(1&(6
-(,7$
6&
627
(8523($1
352-(&7,21
,668('$7(
Fig 14. Package outline SOT363 (SC-88)
74HC2GU04
Product data sheet
11 of 16
74HC2GU04
Nexperia
3ODVWLFVXUIDFHPRXQWHGSDFNDJH7623OHDGV
627
Y 0 $
4
SLQ
LQGH[
F
/S
H
ES
Z 0 %
GHWDLO;
PP
VFDOH
81,7
ES
F
H
/S
4
Y
Z
PP
287/,1(
9(56,21
5()(5(1&(6
-(,7$
6&
627
(8523($1
352-(&7,21
,668('$7(
Fig 15. Package outline SOT457 (SC-74)
74HC2GU04
Product data sheet
12 of 16
74HC2GU04
Nexperia
17. Abbreviations
Table 13.
Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
18. Revision history
Table 14.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC2GU04 v.2
20140820
Product data sheet
74HC2GU04 v.1
Modifications:
74HC2GU04 v.1
74HC2GU04
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity guidelines of
NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
20061006
Product data sheet
13 of 16
74HC2GU04
Nexperia
19. Legal information
19.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
19.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
19.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC2GU04
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
14 of 16
74HC2GU04
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
19.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
20. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC2GU04
Product data sheet
15 of 16
Nexperia
74HC2GU04
21. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
17
18
19
19.1
19.2
19.3
19.4
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional description . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 3
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Additional characteristics . . . . . . . . . . . . . . . . . 7
Typical transfer characteristics . . . . . . . . . . . . 8
Application information. . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 20 August 2014
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC2GU04GV,125 74HC2GU04GW,125
