74HC4049
Hex inverting HIGH-to-LOW level shifter
Rev. 7 — 5 February 2016
Product data sheet
1. General description
The 74HC4049 is a hex inverter with over-voltage tolerant inputs. Inputs are overvoltage
tolerant to 15 V. This enables the device to be used in HIGH-to-LOW level shifting
applications.
2. Features and benefits
Low-power dissipation
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2 000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
3. Ordering information
Table 1.
Type number Package
Temperature range
Name
Description
Version
74HC4049D
40 C to +125 C
SO16
plastic small outline package; 16 leads; body width
3.9 mm
SOT109-1
74HC4049DB
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
74HC4049PW 40 C to +125 C
74HC4049
Nexperia
4. Functional diagram
99
99
99
DDL
Fig 1.
99
99
99
DDQ
Logic symbol
Fig 2.
PQD
IEC logic symbol
Fig 3.
Logic diagram (one level
shifter)
5. Pinning information
5.1 Pinning
9&&
QF
*1'
9&&
QF
QF
*1'
QF
DDQ
Fig 4.
Pin configuration SO16
74HC4049
Product data sheet
DDQ
Fig 5.
Pin configuration SSOP16 and TSSOP16
All information provided in this document is subject to legal disclaimers.
2 of 14
Nexperia B.V. 2017. All rights reserved
74HC4049
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
VCC
1
supply voltage
1Y to 6Y
2, 4, 6, 10, 12, 15
output
1A to 6A
3, 5, 7, 9, 11, 14
input
GND
8
ground (0 V)
n.c.
13, 16
not connected
6. Functional description
Table 3.
Function table [1]
Input
Output
nA
nY
L
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
0.5
+7
V
VIK
input clamping voltage
0.5
+16
V
IIK
input clamping current
VI < 0.5 V
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
mA
VO = 0.5 V to (VCC + 0.5 V)
IO
output current
25
mA
ICC
supply current
+50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
500
mW
total power dissipation
Ptot
[1]
SO16, SSOP16 and TSSOP16 packages
[1]
For SO16 package: Ptot derates linearly with 8 mW/K above 70 C.
For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
74HC4049
Product data sheet
3 of 14
74HC4049
Nexperia
ȍ
LQSXW
WRORJLF
FLUFXLW
SRO\VLOLFRQ
UHVLVWRU
*1'
DDQ
Fig 6.
Input protection for the 74HC4049
8. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
t/V
input transition rise and fall rate
Min
Typ
Max
Unit
2.0
5.0
6.0
V
V
VCC
V
40
+25
+125
C
VCC = 2.0 V; VI = 2.0 V
625
ns/V
VCC = 4.5 V; VI = 4.5 V
1.67
139
ns/V
VCC = 6.0 V; VI = 6.0 V
83
ns/V
VCC = 6.0 V; VI = 10.0 V
81
ns/V
VCC = 6.0 V; VI = 15.0 V
83
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VIH
VIL
VOH
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
74HC4049
Product data sheet
Tamb = 25 C
Conditions
Min
Typ
VCC = 2.0 V
1.5
VCC = 4.5 V
3.15
VCC = 6.0 V
4.2
VCC = 2.0 V
VCC = 4.5 V
VCC = 6.0 V
Tamb = 40 C to
+85 C
Tamb = 40 C to Unit
+125 C
Max
Min
Max
Min
Max
1.3
1.5
1.5
V
2.4
3.15
3.15
V
3.1
4.2
4.2
V
0.7
0.5
0.5
0.5
V
1.8
1.35
1.35
1.35
V
2.3
1.8
1.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 4.0 mA; VCC = 4.5 V
3.98
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.34
5.2
V
VI = VIH or VIL
4 of 14
74HC4049
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
Conditions
VOL
VI = VIH or VIL
Tamb = 25 C
Min
II
LOW-level
output voltage
input leakage
current
ICC
supply current
CI
input
capacitance
Tamb = 40 C to
+85 C
Tamb = 40 C to Unit
+125 C
Typ
Max
Min
Max
Min
Max
0.1
0.1
0.1
V
0.1
0.1
0.1
V
0.1
0.1
0.1
V
0.26
0.33
0.4
V
0.26
0.33
0.4
V
VI = VCC or GND;
VCC = 6.0 V
0.1
1.0
1.0
A
VI = 15 V; VCC = 2.0 V to
6.0 V
0.5
5.0
5.0
A
VI = 15 V or GND; IO = 0 A;
VCC = 6.0 V
2.0
A
3.5
pF
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 8.
Symbol Parameter
tpd
propagation
delay
Tamb = 25 C
Conditions
transition
time
74HC4049
Product data sheet
Tamb = 40 C
to +125 C
Unit
Min
Typ
Max
Min
Max
Min
Max
28
85
105
130
ns
VCC = 4.5 V
10
17
21
26
ns
VCC = 5 V; CL = 15 pF
8
ns
8
14
18
22
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
nA to nY; see Figure 7
[1]
VCC = 2.0 V
VCC = 6.0 V
tt
Tamb = 40 C
to +85 C
Yn; see Figure 7
[2]
5 of 14
74HC4049
Nexperia
Table 7.
Dynamic characteristics …continued
Tamb = 25 C
Symbol Parameter
Conditions
CPD
CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[1]
power
dissipation
capacitance
Tamb = 40 C
to +85 C
Tamb = 40 C
to +125 C
Min
Typ
Max
Min
Max
Min
Max
14
[3]
Unit
pF
tpd is the same as tPLH and tPHL.
[2]
tt is the same as tTHL and tTLH.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
11. Waveforms
9,
Q$LQSXW
90
90
*1'
W 3+/
W 3/+
92+
Q
很抱歉,暂时无法提供与“74HC4049DB,112”相匹配的价格&库存,您可以联系我们找货
