74LVC132APW-Q100J
74LVC132APW-Q100J
    NEXPERIA(安世)
    TSSOP14_5X4.4MM
    电压电平转换器 1.65~3.6V 100mA TSSOP14_5.1X4.5MM
74LVC132APW-Q100J 数据手册
74LVC132A-Q100 Quad 2-input NAND Schmitt trigger Rev. 1 — 4 April 2013 Product data sheet 1. General description The 74LVC132A-Q100 provides four 2-input NAND gates with Schmitt trigger inputs. It can transform slowly changing input signals into sharply defined, jitter-free output signals. The inputs switch at different points for positive and negative-going signals. The difference between the positive voltage VT+ and the negative voltage VT is defined as the input hysteresis voltage VH. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V environment. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide supply voltage range from 1.2 V to 3.6 V  5 V tolerant inputs for interfacing with 5 V logic  CMOS low-power consumption  Direct interface with TTL levels  Unlimited input rise and fall times  Inputs accept voltages up to 5.5 V  Complies with JEDEC standard JESD8-C/JESD36 (2.7 V to 3.6 V)  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Applications  Wave and pulse shapers for highly noisy environments  Astable multivibrator  Monostable multivibrator. 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description 40 C to +125 C SO14 plastic small outline package; 14 leads; body width SOT108-1 3.9 mm 74LVC132APW-Q100 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; SOT402-1 body width 4.4 mm 74LVC132ABQ-Q100 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 74LVC132AD-Q100 Version SOT762-1 5. Functional diagram 1 1 1A 2 1B 1Y 3 4 2A 5 2B 2Y 6 9 3A 10 3B 3Y 8 12 4A 13 4B 4Y 11 4 9 10 12 13 Fig 1. Logic symbol Product data sheet 5 & 3 & 6 & 8 & 11 A mna212 74LVC132A_Q100 2 Y B 001aac532 mna246 Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 Fig 3. Logic diagram (one gate) © Nexperia B.V. 2017. All rights reserved 2 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger 6. Pinning information 6.1 Pinning  /9&$4 $ WHUPLQDO LQGH[DUHD  9&& /9&$4 %   %  $  $  <   $ $   < %  %   % <  <   $ *1'   <  < *1'   %   <  % <  9&&    % *1' $ $  7UDQVSDUHQWWRSYLHZ DDD (1) The die substrate is attached to this pad using conductive die attach material. It cannot be used as a supply pin or input. Fig 4. Pin configuration SO14 and TSSOP14 Fig 5. Pin configuration DHVQFN14 6.2 Pin description Table 2. Pin description Symbol Pin Description 1A 1 data input 1B 2 data input 1Y 3 data output 2A 4 data input 2B 5 data input 2Y 6 data output GND 7 ground (0 V) 3Y 8 data output 3A 9 data input 3B 10 data input 4Y 11 data output 4A 12 data input 4B 13 data input VCC 14 supply voltage 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 3 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger 7. Functional description Table 3. Function table[1] Input Output nA nB nY L L H L H H H L H H H L [1] H = HIGH voltage level; L = LOW voltage level. 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage IIK input clamping current IOK output clamping current IO output current ICC Conditions Min Max Unit 0.5 +6.5 V [1] 0.5 +6.5 V [2][3] 0.5 VCC + 0.5 V 50 - mA VO > VCC or VO < 0 V - 50 mA VO = 0 V to VCC - 50 mA supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature Ptot total power dissipation [1] VI < 0 V Tamb = 40 C to +125 C [4] 65 +150 C - 500 mW The minimum input voltage ratings may be exceeded if the input current ratings are observed. [2] The output voltage ratings may be exceeded if the output current ratings are observed. [3] When VCC = 0 V (Power-down mode), the output voltage can be 3.6 V in normal operation. [4] For SO14 packages: Ptot derates linearly with 8 mW/K above 70 C. For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C. 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage Conditions Min Typ Max Unit 1.65 - 3.6 V functional 1.2 - - V VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature 40 - +125 C 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 4 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger 10. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Typ[1] Max Unit IO = 100 A; VCC = 1.65 V to 3.6 V VCC  0.2 - - V IO = 4 mA; VCC = 1.65 V VCC  0.45 - - V IO = 8 mA; VCC = 2.3 V VCC  0.5 - - V IO = 12 mA; VCC = 2.7 V VCC  0.5 - - V IO = 18 mA; VCC = 3.0 V VCC  0.6 - - V IO = 24 mA; VCC = 3.0 V VCC  0.8 - - V Conditions Tamb = 40 C to +85 C VOH HIGH-level output voltage LOW-level output voltage VOL VI = VT+ or VT VI = VT+ or VT IO = 100 A; VCC = 1.65 V to 3.6 V - - 0.2 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.6 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V II input leakage current VCC = 3.6 V; VI = 5.5 V or GND - 0.1 5 A ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 10 A ICC additional supply current per input pin; VCC = 2.7 V to 3.6 V; VI = VCC  0.6 V; IO = 0 A - 5 500 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 4.0 - pF IO = 100 A; VCC = 1.65 V to 3.6 V VCC  0.3 - - V IO = 4 mA; VCC = 1.65 V VCC  0.6 - - V IO = 8 mA; VCC = 2.3 V VCC  0.65 - - V IO = 12 mA; VCC = 2.7 V VCC  0.65 - - V IO = 18 mA; VCC = 3.0 V VCC  0.75 - - V IO = 24 mA; VCC = 3.0 V VCC  1 - - V IO = 100 A; VCC = 1.65 V to 3.6 V - - 0.3 V Tamb = 40 C to +125 C VOH HIGH-level output voltage LOW-level output voltage VOL VI = VT+ or VT VI = VT+ or VT IO = 4 mA; VCC = 1.65 V - - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.8 V II input leakage current VCC = 3.6 V; VI = 5.5 V or GND - - 20 A ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - - 40 A ICC additional supply current per input pin; VCC = 2.7 V to 3.6 V; VI = VCC  0.6 V; IO = 0 A - - 5 mA [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C. 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 5 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger 11. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 7. Symbol Parameter propagation delay tpd 40 C to +85 C Conditions Min Max Min Max - 18.0 - - - ns VCC = 1.65 V to 1.95 V 2.0 7.2 12.8 2.0 16.0 ns VCC = 2.3 V to 2.7 V 1.5 4.0 7.6 1.5 9.6 ns [2] nA, nB to nY; see Figure 6 VCC = 1.2 V tsk(o) CPD [1] 40 C to +125 C Unit Typ[1] VCC = 2.7 V 1.5 3.8 7.6 1.5 9.6 ns VCC = 3.0 V to 3.6 V 1.5 3.4 6.4 1.5 8.0 ns - - 1.0 - 1.5 ns output skew time [3] power dissipation capacitance [4] per buffer; VI = GND to VCC VCC = 1.65 V to 1.95 V - 10.5 - - - pF VCC = 2.3 V to 2.7 V - 10.8 - - - pF VCC = 3.0 V to 3.6 V - 11.4 - - - pF Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively. [2] tpd is the same as tPLH and tPHL. [3] Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 12. Waveforms VI nA, nB input VM GND tPHL tPLH VOH nY output VM mna213 VOL VM = 1.5 V at VCC  2.7 V. VM = 0.5  VCC at VCC < 2.7 V. VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. The input (nA, nB) to output (nY) propagation delays 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 6 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VI PULSE GENERATOR VO DUT RT CL RL 001aaf615 Test data is given in Table 8. Definitions for test circuit: RL = Load resistance CL = Load capacitance including jig and probe capacitance RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 7. Table 8. Load circuitry for measuring switching times Test data Supply voltage Input Load VI tr, tf CL RL 1.2 V VCC  2 ns 30 pF 1 k 1.65 V to 1.95 V VCC  2 ns 30 pF 1 k 2.3 V to 2.7 V VCC  2 ns 30 pF 500  2.7 V 2.7 V  2.5 ns 50 pF 500  3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF 500  74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 7 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger 13. Transfer characteristics Table 9. Transfer characteristics Voltages are referenced to GND (ground = 0 V); see Figure 8. Symbol Parameter positive-going threshold voltage VT+ negative-going threshold voltage VT hysteresis voltage VH 40 C to +85 C Conditions Min Max Min Max Unit VCC = 1.2 V 0.2 1.0 0.2 1.0 V VCC = 1.65 V 0.4 1.3 0.4 1.3 V VCC = 1.95 V 0.6 1.5 0.6 1.5 V VCC = 2.3 V 0.8 1.7 0.8 1.7 V VCC = 2.5 V 0.9 1.7 0.9 1.7 V VCC = 2.7 V 1.1 2 1.1 2 V VCC = 3 V 1.2 2 1.2 2 V VCC = 3.6 V 1.2 2 1.2 2 V VCC = 1.2 V 0.12 0.75 0.12 0.75 V VCC = 1.65 V 0.15 0.85 0.15 0.85 V VCC = 1.95 V 0.25 0.95 0.25 0.95 V VCC = 2.3 V 0.4 1.1 0.4 1.1 V VCC = 2.5 V 0.4 1.2 0.4 1.2 V VCC = 2.7 V 0.8 1.4 0.8 1.4 V VCC = 3 V 0.8 1.5 0.8 1.5 V VCC = 3.6 V 0.8 1.5 0.8 1.5 V VCC = 1.2 V 0.1 1.0 0.1 1.0 V VCC = 1.65 V 0.2 1.15 0.2 1.15 V VCC = 1.95 V 0.2 1.25 0.2 1.25 V (VT+  VT) VCC = 2.3 V 0.3 1.3 0.3 1.3 V VCC = 2.5 V 0.3 1.3 0.3 1.3 V VCC = 2.7 V 0.3 1.1 0.3 1.1 V 0.3 1.2 0.3 1.2 V 0.3 1.2 0.3 1.2 V VCC = 3 V [1] VCC = 3.6 V [1] 40 C to +125 C Typical transfer characteristic is displayed in Figure 9. 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 8 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger 14. Waveforms transfer characteristics VT+ VO VI VH VT− VO VI VH VT− Fig 8. VT+ mna208 mna207 VT at 20 % and VT+ at 70 % Definition of VT+, VT and VH mna582 5 I CC (mA) 4 3 2 1 0 0 0.6 1.2 1.8 2.4 3 VI (V) VCC = 3.3 V. Fig 9. Typical transfer characteristic 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 9 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger 15. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 10. Package outline SOT108-1 (SO14) 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 10 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 11. Package outline SOT402-1 (TSSOP14) 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 11 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT762-1 14 terminals; body 2.5 x 3 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 6 y y1 C v M C A B w M C b L 1 7 Eh e 14 8 13 9 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.1 2.9 1.65 1.35 2.6 2.4 1.15 0.85 0.5 2 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT762-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 12. Package outline SOT762-1 (DHVQFN14) 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 12 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger 16. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 17. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC132A_Q100 v.1 20130404 Product data sheet - - 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 13 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger 18. Legal information 18.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 18.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 18.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LVC132A_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 14 of 16 74LVC132A-Q100 Nexperia Quad 2-input NAND Schmitt trigger No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 18.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 19. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LVC132A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 April 2013 © Nexperia B.V. 2017. All rights reserved 15 of 16 Nexperia 74LVC132A-Q100 Quad 2-input NAND Schmitt trigger 20. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 17 18 18.1 18.2 18.3 18.4 19 20 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Transfer characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms transfer characteristics. . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 04 April 2013 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC132ABQ-Q100X 74LVC132APW-Q100J 74LVC132AD-Q100J
74LVC132APW-Q100J 价格&库存
很抱歉,暂时无法提供与“74LVC132APW-Q100J”相匹配的价格&库存,您可以联系我们找货
