74LVC1GU04-Q100
Unbuffered inverter
Rev. 2 — 13 December 2016
Product data sheet
1. General description
The 74LVC1GU04-Q100 is a single unbuffered inverter.
The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of
this device in a mixed 3.3 V and 5 V environment.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide supply voltage range from 1.65 V to 5.5 V
High noise immunity
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 )
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Input accepts voltages up to 5 V
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1GU04GW-Q100 40 C to +125 C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
74LVC1GU04GV-Q100 40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74LVC1GU04-Q100
Nexperia
Unbuffered inverter
4. Marking
Table 2.
Marking codes
Type number
Marking[1]
74LVC1GU04GW-Q100
VD
74LVC1GU04GV-Q100
VU4
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
9&&
PQD
Fig 1.
Logic symbol
ȍ
PQD
Fig 2.
9&&
PQD
IEC logic symbol
Fig 3.
Logic diagram
6. Pinning information
6.1 Pinning
/9&*84
QF
*1'
9&&
DDD
Fig 4.
Pin configuration SOT353-1 and SOT753
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
n.c.
1
not connected
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
74LVC1GU04_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
74LVC1GU04-Q100
Nexperia
Unbuffered inverter
7. Functional description
Function table[1]
Table 4.
Input (A)
Output (Y)
L
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
Conditions
Min
Max
Unit
0.5
+6.5
V
50
mA
[1]
0.5
+6.5
V
50
[1][2]
0.5
VCC + 0.5
50
mA
+100
mA
100
mA
250
mW
65
+150
C
VI < 0 V
IOK
output clamping current
VO > VCC or VO < 0 V
VO
output voltage
Active mode
IO
output current
VO = 0 V to VCC
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Tamb = 40 C to +125 C
[3]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
mA
V
9. Recommended operating conditions
Table 6.
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
t/V
input transition rise and fall rate
74LVC1GU04_Q100
Product data sheet
Conditions
Active mode
Min
Typ
Max
Unit
1.65
5.5
V
V
VCC
V
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
ns/V
3 of 14
74LVC1GU04-Q100
Nexperia
Unbuffered inverter
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
Tamb = 40 C to +85 C
VIH
HIGH-level input voltage
VCC = 1.65 V to 5.5 V
0.75 VCC
V
VIL
LOW-level input voltage
0.25 VCC
V
VOH
HIGH-level output voltage VI = VIH or VIL
VCC 0.1
V
IO = 4 mA; VCC = 1.65 V
1.2
V
IO = 8 mA; VCC = 2.3 V
1.9
V
IO = 12 mA; VCC = 2.7 V
2.2
V
IO = 24 mA; VCC = 3.0 V
2.3
V
IO = 32 mA; VCC = 4.5 V
3.8
V
IO = 100 A;
0.1
V
0.45
V
0.3
V
0.4
V
0.55
V
0.55
V
IO = 100 A;
VOL
LOW-level output voltage
VI = VIH or VIL
II
input leakage current
VI = 5.5 V or GND; VCC = 0 V to
5.5 V
0.1
1
A
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
A
CI
input capacitance
VCC = 3.3 V; VI = GND to VCC
6
pF
VIH
0.8 VCC
V
VIL
0.2 VCC
V
VOH
VCC 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
IO = 100 A;
74LVC1GU04_Q100
Product data sheet
4 of 14
74LVC1GU04-Q100
Nexperia
Unbuffered inverter
Table 7.
Static characteristics …continued
Min
Typ[1]
Max
Unit
IO = 100 A;
0.1
V
0.7
V
0.45
V
0.6
V
0.80
V
0.80
V
Symbol Parameter
Conditions
VOL
VI = VIH or VIL
II
5.5 V
0.1
1
A
ICC
supply current
4
A
[1]
All typical values are measured at VCC = 3.3 V and Tamb = 25 C.
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 8.
Symbol Parameter
tpd
CPD
40 C to +85 C
Conditions
Min
Max
Min
Max
VCC = 1.65 V to 1.95 V
0.3
1.7
5.0
0.3
6.5
ns
VCC = 2.3 V to 2.7 V
0.3
1.3
4.0
0.3
5.5
ns
VCC = 2.7 V
0.5
1.7
5.0
0.5
6.5
ns
VCC = 3.0 V to 3.6 V
0.5
1.6
3.7
0.5
5.0
ns
VCC = 4.5 V to 5.5 V
0.5
1.3
3.0
0.5
4.0
ns
14.9
pF
propagation delay A to Y; see Figure 5
power dissipation
capacitance
40 C to +125 C Unit
Typ[1]
[2]
[3]
VI = GND to VCC;
VCC = 3.3 V
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74LVC1GU04_Q100
Product data sheet
5 of 14
74LVC1GU04-Q100
Nexperia
Unbuffered inverter
12. Waveforms
9,
90
$LQSXW
*1'
W 3+/
W 3/+
92+
90
很抱歉,暂时无法提供与“74LVC1GU04GW-Q100H”相匹配的价格&库存,您可以联系我们找货
