74LVCU04AD,112
74LVCU04AD,112
    NEXPERIA(安世)
    SO-14_8.65X3.9MM
    电压电平转换器 1.65~3.6V 100mA SOIC14_8.75X4MM
74LVCU04AD,112 数据手册
74LVCU04A Hex unbuffered inverter Rev. 8 — 18 December 2015 Product data sheet 1. General description The 74LVCU04A is a general purpose hex unbuffered inverter. Each of the six inverters is a single stage with unbuffered outputs. 2. Features and benefits      Wide supply voltage range from 1.2 V to 3.6 V Inputs accept voltages up to 5.5 V CMOS low power consumption Direct interface with TTL levels Complies with JEDEC standard:  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A (2.3 V to 2.7 V)  JESD8-C/JESD36 (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-B exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Specified from 40 C to +85 C and 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LVCU04ADB 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 74LVCU04APW 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LVCU04ABQ 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 74LVCU04AD SOT762-1 74LVCU04A Nexperia Hex unbuffered inverter 4. Functional diagram 1 1 1 1A 1Y 3 2A 2Y 2 2 1 3 4 4 1 5 5 3A 3Y 6 9 4A 4Y 8 11 5A 5Y 10 6 1 9 8 VCC VCC 1 11 10 100 Ω nY nA 13 6Y 6A 12 1 13 mna926 Fig 1. 12 mna927 mna925 Logic symbol Fig 2. IEC logic symbol Fig 3. Schematic diagram for one inverter 5. Pinning information 1A terminal 1 index area 14 VCC 5.1 Pinning 1 14 VCC 1Y 2 13 6A 1Y 2 2A 3 12 6Y 2A 3 2Y 4 04 11 5A 3A 5 GND(1) 10 5Y 3Y 6 1 1A 3Y 6 9 4A GND 7 8 4Y 10 5Y 9 4Y 5 8 3A 7 11 5A 4 12 6Y GND 04 2Y 13 6A 4A 001aad063 Transparent top view 001aad062 (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 4. Pin configuration for SO14 and (T)SSOP14 74LVCU04A Product data sheet Fig 5. Pin configuration for DHVQFN14 All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 2 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A, 5A, 6A 1, 3, 5, 9, 11, 13 data input 1Y, 2Y, 3Y, 4Y, 5Y, 6Y 2, 4, 6, 8, 10, 12 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function table[1] Input nA Output nY L H H L [1] H = HIGH voltage level; L = LOW voltage level 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO output voltage IO output current Conditions VI < 0 V [1] VO > VCC or VO < 0 V [2] VO = 0 V to VCC Min Max Unit 0.5 +6.5 V 50 - 0.5 +6.5 V - 50 mA 0.5 VCC + 0.5 - 50 mA V mA ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot Tamb = 40 C to +125 C [3] [1] The minimum input voltage ratings may be exceeded if the input current ratings are observed. [2] The output voltage ratings may be exceeded if the output current ratings are observed. [3] For SO14 packages: above 70 C the value of Ptot derates linearly with 8 mW/K. For (T)SSOP14 packages: above 60 C the value of Ptot derates linearly with 5.5 mW/K. For DHVQFN14 packages: above 60 C the value of Ptot derates linearly with 4.5 mW/K. 74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 3 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage 1.65 - 3.6 V VI input voltage 1.2 - - V 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature in free air 40 - +125 C t/V input transition rise and fall rate VCC = 1.65 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V functional 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74LVCU04A Product data sheet 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max VCC = 1.2 V 1.08 - - 1.12 - V VCC = 1.65 V to 1.95 V 1.3 - - 1.5 - V VCC = 2.3 V to 2.7 V 1.8 - - 2.0 - V VCC = 3.0 V 2.0 - - 2.4 - V VCC = 3.6 V 2.4 - - 2.8 - V VCC = 1.2 V - - 0.12 - 0.1 V VCC = 1.65 V to 1.95 V - - 0.6 - 0.4 V VCC = 2.3 V to 2.7 V - - 0.6 - 0.5 V VCC = 3.0 V - - 1.0 - 0.6 V VCC = 3.6 V - - 1.2 - 0.7 V VCC = 3.0 V; IO = 100 A VCC  0.2 - - VCC  0.3 - V VCC = 1.65 V; IO = 4 mA 1.2 - - 1.05 - V VOL(max) = 0.5 V; IO = 100 A VOH(min) = VCC  0.5 V; IO = 100 A VI = GND VCC = 2.3 V; IO = 8 mA 1.8 - - 1.65 - V VCC = 2.7 V; IO = 12 mA 2.2 - - 2.05 - V VCC = 3.0 V; IO = 18 mA 2.4 - - 2.25 - V VCC = 3.0 V; IO = 24 mA 2.2 - - 2.0 - V All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 4 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter Table 6. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VOL LOW-level output voltage 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max VCC = 3.0 V; IO = 100 A - - 0.20 - 0.60 V VCC = 1.65 V; IO = 4 mA - - 0.45 - 0.65 V VCC = 2.3 V; IO = 8 mA - - 0.60 - 0.80 V VCC = 2.7 V; IO = 12 mA - - 0.40 - 0.30 V VCC = 3.0 V; IO = 24 mA - - 0.55 - 0.80 V VI = VCC II input leakage VCC = 3.6 V; VI = 5.5 V or GND current - 0.1 5 - 20 A ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 10 - 40 A ICC additional supply current per input pin; VCC = 2.7 V to 3.6 V; VI = VCC  0.6 V; IO = 0 A - 5 500 - 5000 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 5.5 - - - pF [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 9. Symbol Parameter propagation delay tpd 40 C to +85 C Conditions nA to nY; see Figure 6 VCC = 1.65 V to 1.95 V power dissipation capacitance CPD Max Min Max - 6.0 - - - ns 0.3 3.7 7.8 0.3 9.0 ns VCC = 2.3 V to 2.7 V 0.5 2.2 4.4 0.5 5.2 ns VCC = 2.7 V 0.5 2.0 4.5 0.5 6.0 ns 0.5 2.0 4.0 0.5 5.0 ns - - 1.0 - 1.5 ns VCC = 1.65 V to 1.95 V - 2.3 - - - pF VCC = 2.3 V to 2.7 V - 5.5 - - - pF VCC = 3.0 V to 3.6 V - 8.4 - - - pF VCC = 3.0 V to 3.6 V output skew time Min [2] VCC = 1.2 V tsk(o) 40 C to +125 C Unit Typ[1] VCC = 3.0 V to 3.6 V [3] per inverter; VI = GND to VCC [4] [1] Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively. [2] tpd is the same as tPLH and tPHL. [3] Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF 74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 5 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs 11. Waveforms VI VM nA input GND t PHL t PLH VOH VM nY output VOL mna928 VM = 1.5 V at VCC  2.7 V; VM = 0.5  VCC at VCC < 2.7 V; VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. Input (nA) to output (nY) propagation delays Rbias = 560 kΩ VCC 0.47 μF input output 100 μF Vi (f = 1 kHz) A Io mna929 dI O g fs = -------- ; at cons tan t V O dV I fi = 1 kHz at VO is constant Fig 7. Test setup for measuring forward transconductance 74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 6 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter mna930 100 gfs (mA/V) 80 60 40 20 0 0 1 2 3 VCC(V) 4 Tamb = 25 C Fig 8. Typical forward transconductance as a function of supply voltage 74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 7 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 38/6( *(1(5$725 9, 92 '87 57 &/ 5/ DDI Test data is given in Table 8. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 9. Table 8. Test circuit for measuring switching times Test data Supply voltage Input Load VI tr, tf CL RL 1.2 V VCC  2 ns 30 pF 1 k 1.65 V to 1.95 V VCC  2 ns 30 pF 1 k 2.3 V to 2.7 V VCC  2 ns 30 pF 500  2.7 V 2.7 V  2.5 ns 50 pF 500  3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF 500  74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 8 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter 12. Application information 12.1 Application diagrams Some applications for the 74LVCU04A are: • Linear amplifier: see Figure 10 • Crystal oscillator designs; see Figure 11 • Astable multivibrator; see Figure 12 R2 VCC 1 μF R1 U04 ZL GND mna931 Vo(p-p) = VCC  1.5 V centered at 0.5VCC. G OL A u = – ----------------------------------------R1 1 + -------  1 + G OL  R2 GOL = loop gain. Au = voltage amplification. R1  3 k, R2  1 M ZL > 10 k; AOL = 20 (typ.) Typical unity gain bandwidth product is 5 MHz. Fig 10. 74LVCU04A used as linear amplifier R1 R2 U04 U04 U04 C1 RS C2 R C out mna932 C1 = 47 pF (typical) 1 1 f = ---  --------------T 2.2RC C2 = 22 pF (typical) R1 = 1 to 10 M (typical) RS  2R. R2 optimum value depends on the frequency and required stability against changes in VCC or average minimum ICC (ICC is typically 2 mA at VCC = 3 V and f = 1 MHz) Fig 11. 74LVCU04A used as crystal oscillator 74LVCU04A Product data sheet mna933 The average ICC is approximately 3.5 + 0.05f (MHz)  C (pF) [mA] at VCC = 3.0 V. Fig 12. 74LVCU04A used as astable multivibrator All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 9 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter 13. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV        ș R R  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 13. Package outline SOT108-1 (SO14) 74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 10 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   GHWDLO; Z 0 ES H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 14. Package outline SOT337-1 (SSOP14) 74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 11 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 15. Package outline SOT402-1 (TSSOP14) 74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 12 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter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ig 16. Package outline SOT762-1 (DHVQFN14) 74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 13 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter 14. Abbreviations Table 9. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVCU04A v.8 20151218 Product data sheet - 74LVCU04A v.7 Modifications: 74LVCU04A v.7 Modifications: • Descriptive title updated. Added “unbuffered” (errata). 20111117 • • Product data sheet - 74LVCU04A v.6 Legal pages updated. Table 6, bodyrow ICC: condition VCC changed. 74LVCU04A v.6 20110809 Product data sheet - 74LVCU04A v.5 74LVCU04A v.5 20040312 Product specification - 74LVCU04A v.4 74LVCU04A v.4 20030901 Product specification - 74LVCU04A v.3 74LVCU04A v.3 19980729 Product specification - 74LVCU04A v.2 74LVCU04A v.2 19980729 Product specification - 74LVCU04A v.1 74LVCU04A v.1 19980729 Product specification - - 74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 14 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LVCU04A Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 15 of 17 © Nexperia B.V. 2017. All rights reserved 74LVCU04A Nexperia Hex unbuffered inverter Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LVCU04A Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 8 — 18 December 2015 16 of 17 © Nexperia B.V. 2017. All rights reserved Nexperia 74LVCU04A Hex unbuffered inverter 18. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 12.1 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Application information. . . . . . . . . . . . . . . . . . . 9 Application diagrams . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 18 December 2015 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVCU04ABQ,115 74LVCU04AD,112 74LVCU04ADB,112 74LVCU04ADB,118 74LVCU04AD,118 74LVCU04APW,112 74LVCU04APW,118 74LVCU04APW/AUJ 74LVCU04AD-Q100J 74LVCU04APW-Q100J
74LVCU04AD,112 价格&库存
很抱歉,暂时无法提供与“74LVCU04AD,112”相匹配的价格&库存,您可以联系我们找货
