74LVT04
3.3 V Hex inverter
Rev. 2 — 28 April 2014
Product data sheet
1. General description
The 74LVT04 is a high-performance product designed for VCC operation at 3.3 V.
The 74LVT04 provides six inverting buffers.
2. Features and benefits
TTL input and output switching levels
Latch-up protection
JESD78 class II exceeds 500 mA
ESD protection:
HBM JESD22-A114E exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Specified from 40 C to +85 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVT04D
40 C to +85 C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
74LVT04DB
40 C to +85 C
SSOP14
plastic shrink small outline package; 14 leads; body
width 5.3 mm
SOT337-1
74LVT04PW
40 C to +85 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74LVT04
Nexperia
3.3 V Hex inverter
4. Functional diagram
PQD
Logic symbol
Fig 1.
Y
A
PQD
Fig 2.
mna341
IEC logic symbol
Fig 3.
Logic diagram for one gate
5. Pinning information
5.1 Pinning
1A
1
14 VCC
1Y
2
13 6A
2A
3
12 6Y
2Y
4
3A
5
3Y
6
9
4A
GND
7
8
4Y
04
11 5A
10 5Y
001aac915
Fig 4.
Pin configuration SOT108-1 (SO14), SOT337-1 (SSOP14) and SOT402-1 (TSSOP14)
74LVT04
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
74LVT04
Nexperia
3.3 V Hex inverter
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
nA
1, 3, 5, 9, 11, 13
data input
nY
2, 4, 6, 8, 10, 12
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Input
Output
nA
nY
L
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+4.6
V
0.5
+7.0
V
input voltage
[1]
VO
output voltage
output in OFF-state or HIGH-state
[1]
0.5
+7.0
V
IIK
input clamping current
VI < 0 V
50
mA
IOK
output clamping current
VO < 0 V
50
mA
IO
output current
output in LOW-state
64
mA
output in HIGH-state
32
mA
Tstg
storage temperature
65
+150
C
Tj
junction temperature
[2]
150
C
[3]
500
mW
VI
total power dissipation
Ptot
Tamb = 40 °C to +85 °C
[1]
The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
[2]
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability.
[3]
For SO14 packages: above 70 C derate linearly with 8 mW/K.
For SSOP14 and TSSOP14 packages: above 60 C derate linearly with 5.5 mW/K.
74LVT04
Product data sheet
3 of 13
74LVT04
Nexperia
3.3 V Hex inverter
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
Conditions
Min
Max
Unit
supply voltage
2.7
3.6
V
VI
input voltage
V
VIH
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
IOH
HIGH-level output current
mA
IOL
LOW-level output current
32
mA
Tamb
ambient temperature
in free air
40
+85
C
t/V
input transition rise and fall rate
outputs enabled
10
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
40 C to +85 C
Conditions
Min
Typ[1]
Unit
Max
VIK
input clamp voltage
VCC = 2.7 V; IIK = 18 mA
1.2
V
VOH
VCC = 2.7 V to 3.6 V; IOH = 100 A
VCC 0.2
V
VCC = 2.7 V; IOH = 6 mA
2.4
V
VCC = 3.0 V; IOH = 20 mA
2.0
V
VCC = 2.7 V; IOL = 100 A
0.2
V
VCC = 2.7 V; IOL = 24 mA
0.5
V
VCC = 3.0 V; IOL = 32 mA
0.5
V
10
A
LOW-level output voltage
VOL
II
input leakage current
VCC = 0 V or 3.6 V; VI = 5.5 V
VCC = 3.6 V; VI = VCC or GND
±1
A
IOFF
output off current
VCC = 0 V; VI or VO = 0 V to 4.5 V
±100
A
ICCH
quiescent supply current
VCC = 3.6 V; outputs HIGH;
VI = GND or VCC, IO = 0 V
0.02
mA
ICCL
VCC = 3.6 V; outputs LOW;
VI = GND or VCC; IO = 0 V
1.5
3
mA
ICC
additional supply current
per input pin[2]
VCC = 3 V to 3.6 V;
one input at VCC 0.6 V;
other inputs at VCC or GND
0.2
A
CI
input capacitance
VI = 3 V or 0 V
3
pF
[1]
All typical values are at VCC = 3.3 V and Tamb = 25C.
[2]
This is the increase in supply current for each input at the specified voltage level other than VCC or GND.
74LVT04
Product data sheet
4 of 13
74LVT04
Nexperia
3.3 V Hex inverter
10. Dynamic characteristics
Table 7.
GND = 0 V; for test circuit, see Figure 6.
Symbol Parameter
LOW to OFF-state
propagation delay
tPLH
40 C to +85 C
Conditions
OFF-state to LOW
propagation delay
VCC = 2.7 V
Max
4.7
ns
1.0
2.6
3.9
ns
nA to nY; see Figure 5
ns
VCC = 2.7 V
VCC = 3.3 V 0.3 V
[1]
Min
VCC = 3.3 V 0.3 V
tPHL
Unit
Typ[1]
3.2
1.0
2.5
3.5
ns
11. Waveforms
9,
90
Q$LQSXW
90
*1'
W 3+/
W 3/+
92+
90
Q
很抱歉,暂时无法提供与“74LVT04PW,112”相匹配的价格&库存,您可以联系我们找货
