HEF4069UBTT,118
HEF4069UBTT,118
    NEXPERIA(安世)
    TSSOP14_5X4.4MM
    IC INVERTER 6CH 6-INP 14TSSOP
HEF4069UBTT,118 数据手册
HEF4069UB Hex unbuffered inverter Rev. 9 — 16 December 2015 Product data sheet 1. General description The HEF4069UB is a general purpose hex unbuffered inverter. Each inverter has a single stage. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits      Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +85 C and 40 C to +125 C Complies with JEDEC standard JESD 13-B 3. Applications  Oscillator 4. Ordering information Table 1. Ordering information All types operate from 40 C to +125 C. Type number Package Name Description Version HEF4069UBT SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 HEF4069UBTT TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 HEF4069UB Nexperia Hex unbuffered inverter 5. Functional diagram $ $ $ $ $ $             < < < < 9'' < $ < < 966 DDJ Fig 1. DDJ Functional diagram Fig 2. Schematic diagram (one inverter) 6. Pinning information 6.1 Pinning $   9'' <   $ $   < <  +()8%  $ $   < <   $ 966   < DDJ Fig 3. Pin configuration 6.2 Pin description Table 2. Pin description Symbol Pin Description 1A to 6A 1, 3, 5, 9, 11, 13 input 1Y to 6Y 2, 4, 6, 8, 10, 12 output VSS 7 ground (0 V) VDD 14 supply voltage HEF4069UB Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 16 December 2015 © Nexperia B.V. 2017. All rights reserved 2 of 16 HEF4069UB Nexperia Hex unbuffered inverter 7. Limiting values Table 3. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage Conditions VI < 0.5 V or VI > VDD + 0.5 V Min Max Unit 0.5 +18 V mA - 10 0.5 VDD + 0.5 - 10 mA - 10 mA 50 mA IIK input clamping current VI input voltage IOK output clamping current II/O input/output current IDD supply current Tstg storage temperature 65 +150 C Tamb ambient temperature 40 +125 C Ptot total power dissipation P power dissipation VO < 0.5 V or VO > VDD + 0.5 V - V Tamb = 40 C to +125 C SO14 [1] - 500 mW TSSOP14 [2] - 500 mW - 100 mW per output [1] For SO14 packages: above Tamb = 70 C, Ptot derates linearly with 8 mW/K. [2] For TSSOP14 packages: above Tamb = 60 C, Ptot derates linearly with 5.5 mW/K. 8. Recommended operating conditions Table 4. Recommended operating conditions Symbol Parameter Min Typ Max VDD supply voltage 3 - 15 V VI input voltage 0 - VDD V Tamb ambient temperature 40 - +125 C HEF4069UB Product data sheet Conditions in free air All information provided in this document is subject to legal disclaimers. Rev. 9 — 16 December 2015 © Unit Nexperia B.V. 2017. All rights reserved 3 of 16 HEF4069UB Nexperia Hex unbuffered inverter 9. Static characteristics Table 5. Static characteristics VSS = 0 V; VI = VSS or VDD; unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL Conditions VDD Tamb = 40 C Tamb = +25 C Tamb = +85 C Tamb = +125 C Unit Min Max Min Max Min Max Min Max 5V 4 - 4 - 4 - 4 - V 10 V 8 - 8 - 8 - 8 - V 15 V 12.5 - 12.5 - 12.5 - 12.5 - V 5V - 1 - 1 - 1 - 1 V 10 V - 2 - 2 - 2 - 2 V 15 V - 2.5 - 2.5 - 2.5 - 2.5 V HIGH-level IO < 1 A output voltage 5V 4.95 - 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - 14.95 - V LOW-level IO < 1 A output voltage 5V - 0.05 - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 - 0.05 V 5V - 1.7 - 1.4 - 1.1 - 1.1 mA 5V - 0.64 - 0.5 - 0.36 - 0.36 mA VO = 9.5 V 10 V - 1.6 - 1.3 - 0.9 - 0.9 mA VO = 13.5 V 15 V - 4.2 - 3.4 - 2.4 - 2.4 mA 5V 0.64 - 0.5 - 0.36 - 0.36 - mA 10 V 1.6 - 1.3 - 0.9 - 0.9 - mA 15 V 4.2 - 3.4 - 2.4 - 2.4 - mA HIGH-level input voltage LOW-level input voltage IO < 1 A IO < 1 A HIGH-level VO = 2.5 V output current V = 4.6 V O LOW-level VO = 0.4 V output current V = 0.5 V O VO = 1.5 V II input leakage current 15 V - 0.1 - 0.1 - 1.0 - 1.0 A IDD supply current all valid input 5 V combinations; 10 V IO = 0 A 15 V - 0.25 - 0.25 - 7.5 - 7.5 A - 0.5 - 0.5 - 15.0 - 15.0 A - 1.0 - 1.0 - 30.0 - 30.0 A - - - 7.5 - - - - pF CI input capacitance HEF4069UB Product data sheet digital inputs All information provided in this document is subject to legal disclaimers. Rev. 9 — 16 December 2015 © Nexperia B.V. 2017. All rights reserved 4 of 16 HEF4069UB Nexperia Hex unbuffered inverter 10. Dynamic characteristics Table 6. Dynamic characteristics Tamb = 25 C; for waveforms see Figure 4; for test circuit see Figure 5. Symbol Parameter HIGH to LOW propagation delay tPHL tPLH tTHL [1] VDD Extrapolation formula[1] nA to nY; 5V LOW to HIGH propagation delay nA to nY HIGH to LOW output transition time output nY LOW to HIGH output transition time tTLH Conditions output nY Min Typ Max Unit 18 ns + (0.55 ns/pF)CL - 45 90 ns 10 V 9 ns + (0.23 ns/pF)CL - 20 40 ns 15 V 7 ns + (0.16 ns/pF)CL - 15 25 ns 5V 13 ns + (0.55 ns/pF)CL - 40 80 ns 10 V 9 ns + (0.23 ns/pF)CL - 20 40 ns 15 V 7 ns + (0.16 ns/pF)CL - 15 30 ns 5V 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 5V 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns The typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF). Table 7. Dynamic power dissipation VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol Parameter PD dynamic power dissipation VDD Typical formula Where 5V PD = 600  fi + (fo  CL)  VDD (W) 2 10 V PD = 4000  fi + (fo  CL)  VDD2 (W) fi = input frequency in MHz; fo = output frequency in MHz; 15 V PD = 22000  fi + (fo  CL)  VDD (W) CL = output load capacitance in pF; (fo  CL) = sum of the outputs; 2 VDD = supply voltage in V. HEF4069UB Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 16 December 2015 © Nexperia B.V. 2017. All rights reserved 5 of 16 HEF4069UB Nexperia Hex unbuffered inverter 11. Waveforms WU 9,  90 LQSXW 9 WI  W3+/ 92+ W3/+  90 RXWSXW  92/ W7+/ W7/+ DDJ Measurement points: VM = 0.5VDD. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 4. Propagation delay and transition times 9'' * 9, 92 '87 &/ 57 DDJ Definitions for test circuit: CL = load capacitance including jig and probe capacitance; RT = termination resistance should be equal to the output impedance Zo of the pulse generator; For test data refer to Table 8. Fig 5. Test circuit for measuring switching times Table 8. Test data Supply voltage Input VDD VI tr, tf CL 5 V to 15 V VSS or VDD  20 ns 50 pF HEF4069UB Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 9 — 16 December 2015 © Nexperia B.V. 2017. All rights reserved 6 of 16 HEF4069UB Nexperia Hex unbuffered inverter 11.1 Transfer characteristics DDJ   92 9     ,' P$           92 9 ,' —$   DDJ           9, 9 9, 9 a. VDD = 5 V; IO = 0 A b. VDD = 10 V; IO = 0 A DDJ   92 9 ,' P$               9, 9 c. VDD = 15 V; IO = 0 A (1) VO = output voltage. (2) ID = drain current. Fig 6. Typical transfer characteristics HEF4069UB Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 16 December 2015 © Nexperia B.V. 2017. All rights reserved 7 of 16 HEF4069UB Nexperia Hex unbuffered inverter 12. Application information Some examples of applications for the HEF4069UB. Figure 7 shows an astable relaxation oscillator using two HEF4069UB inverters and 2 BAW62 diodes. The oscillation frequency is mainly determined by R1  C1, provided R1
HEF4069UBTT,118 价格&库存
很抱歉,暂时无法提供与“HEF4069UBTT,118”相匹配的价格&库存,您可以联系我们找货
HEF4069UBTT,118
